  4. Huawei Sun2000 & ioBroker via JS script funktioniert
    5.8k
481 Beiträge 62 Kommentatoren 158.6k Aufrufe 63 Beobachtet
  • J juggi1962
    @badsnoopy667
    Die Fehler kommen nur bei 37100 und 37200
    Ich habe aber das Skript von @Alex-Warkentin und da wurde einiges rausgestrichen.
    bei dem Original Skript kamen viel mehr Fehlermeldungen.
    Hier das Skript.
    // License: Beerware! Do what ever you like with this, but I'm not liable for anything that you do with it.
    // If you like this code, feel free to buy me a beer ...
    // Have fun with it! der Kachel
    // @ts-ignore
    var modbusRTU = require("modbus-serial");
    var client = new modbusRTU();
    var modbusErrorMessages = [
        "Unknown error",
        "Illegal function (device does not support this read/write function)",
        "Illegal data address (register not supported by device)",
        "Illegal data value (value cannot be written to this register)",
        "Slave device failure (device reports internal error)",
        "Acknowledge (requested data will be available later)",
        // "Slave device busy (retry request again later)"
    // Enter your inverter modbus IP and port here:
    const modbusHost = "192.168.1.7";
    const modbusPort = 502;
    // Enter the Modbus-IDs of your Sun2000 inverters here:
    const modbusID = [1];
    // On which Modbus-ID can we reach the power meter? (via Sun2000!)
    const powerMeterID = 0;
    // Connect to modbus client
    ConnectModbus();
    // These register spaces need to be read:
    const registerSpacesToReadContinuously = [[37100, 114], [32000, 116]];
    var registerSpacesToReadContinuouslyPtr = 0;
    var globalDataBuffer = new Array(1);
    globalDataBuffer[0] = new Array(50000); // not optimized....
    // Some helper functions:
    function ReadUnsignedInt16(array) {
        var value = array[0];
        return value;
    function ReadUnsignedInt32(array) {
        var value = array[0] * 256 * 256 + array[1];
        return value;
    function ReadSignedInt16(array) {
        var value = 0;
        if (array[0] > 32767)
            value = array[0] - 65535;
        else
            value = array[0];
        return value;
    function ReadSignedInt32(array) {
        var value = 0;
        for (var i = 0; i < 2; i++) {
            value = (value << 16) | array[i];
        return value;
    function GetU16(dataarray, index) {
        var value = ReadUnsignedInt16(dataarray.slice(index, index+1));
        return value;
    function GetU32(dataarray, index) {
        var value = ReadUnsignedInt32(dataarray.slice(index, index+2));
        return value;
    function GetI16(dataarray, index) {
        var value = ReadSignedInt16(dataarray.slice(index, index+1));
        return value;
    function GetI32(dataarray, index) {
        var value = ReadSignedInt32(dataarray.slice(index, index+2));
        return value;
    function GetString(dataarray, index, length) {
        var shortarray = dataarray.slice(index, index+length);
        var bytearray = [];
        for(var i = 0; i < length; i++) {
            bytearray.push(dataarray[index+i] >> 8);
            bytearray.push(dataarray[index+i] & 0xff);
        var value =  String.fromCharCode.apply(null, bytearray);
        return value;
    function GetZeroTerminatedString(dataarray, index, length) {
        var bytearray = [];
        var value2 = new String(value).trim();
        return value2;
    // Funktion zum Herstellen einer Modbus-Verbindung
    function ConnectModbus() {
        console.log("Init connection to: " + modbusHost +":" + modbusPort);
        // set requests parameters
        client.setTimeout (10000);
        // try to connect
        client.connectTCP (modbusHost, { port: modbusPort })
            .then(function()
                console.log("Connected, wait for reading...");
            .catch(function(e)
                console.log(e);
    // Funktion zum Anlegen und Beschreiben eines Datenpunkts
    function ForceSetState(objectname, value, options) {
        if(!existsState("javascript.0." + objectname))      createState(objectname, value, options);
        else                                                setState(objectname, value);
    // Functions to map registers into ioBreaker objects:
    function ProcessPowerMeterStatus() {
        ForceSetState("Solarpower.Huawei.Meter.Status",                     GetU16(globalDataBuffer[powerMeterID], 37100),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Meter.VoltageL1",                  GetI32(globalDataBuffer[powerMeterID], 37101) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Meter.VoltageL2",                  GetI32(globalDataBuffer[powerMeterID], 37103) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Meter.VoltageL3",                  GetI32(globalDataBuffer[powerMeterID], 37105) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Meter.CurrentL1",                  GetI32(globalDataBuffer[powerMeterID], 37107) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Meter.CurrentL2",                  GetI32(globalDataBuffer[powerMeterID], 37109) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Meter.CurrentL3",                  GetI32(globalDataBuffer[powerMeterID], 37111) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Meter.ActivePower",                GetI32(globalDataBuffer[powerMeterID], 37113) / 1,      {name: "", unit: "W"});
        ForceSetState("Solarpower.Huawei.Meter.ReactivePower",              GetI32(globalDataBuffer[powerMeterID], 37115) / 1,      {name: "", unit: "Var"});
        ForceSetState("Solarpower.Huawei.Meter.PowerFactor",                GetI16(globalDataBuffer[powerMeterID], 37117) / 1000,   {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Meter.GridFrequency",              GetI16(globalDataBuffer[powerMeterID], 37118) / 100,    {name: "", unit: "Hz"});
        ForceSetState("Solarpower.Huawei.Meter.PositiveActiveEnergy",       GetI32(globalDataBuffer[powerMeterID], 37119) / 100,    {name: "", unit: "kWh"});
        ForceSetState("Solarpower.Huawei.Meter.ReverseActiveEnergy",        GetI32(globalDataBuffer[powerMeterID], 37121) / 100,    {name: "", unit: "kWh"});
        ForceSetState("Solarpower.Huawei.Meter.AccumulatedReactivePower",   GetI32(globalDataBuffer[powerMeterID], 37123) / 100,    {name: "", unit: "kVarh"});
        //ForceSetState("Solarpower.Huawei.Meter.MeterType",                  GetU16(globalDataBuffer[powerMeterID], 37125),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Meter.VoltageL1-L2",               GetI32(globalDataBuffer[powerMeterID], 37126) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Meter.VoltageL2-L3",               GetI32(globalDataBuffer[powerMeterID], 37128) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Meter.VoltageL3-L1",               GetI32(globalDataBuffer[powerMeterID], 37130) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Meter.ActivePowerL1",              GetI32(globalDataBuffer[powerMeterID], 37132) / 1,      {name: "", unit: "W"});
        ForceSetState("Solarpower.Huawei.Meter.ActivePowerL2",              GetI32(globalDataBuffer[powerMeterID], 37134) / 1,      {name: "", unit: "W"});
        ForceSetState("Solarpower.Huawei.Meter.ActivePowerL3",              GetI32(globalDataBuffer[powerMeterID], 37136) / 1,      {name: "", unit: "W"});
        //ForceSetState("Solarpower.Huawei.Meter.MeterModel",                 GetU16(globalDataBuffer[powerMeterID], 37138),          {name: "", unit: ""});
    function ProcessInverterStatus(id) {
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".State1",                   GetU16(globalDataBuffer[id-1], 32000),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".State2",                   GetU16(globalDataBuffer[id-1], 32002),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".State3",                   GetU32(globalDataBuffer[id-1], 32003),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm1",                   GetU16(globalDataBuffer[id-1], 32008),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm2",                   GetU16(globalDataBuffer[id-1], 32009),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Alarm3",                   GetU16(globalDataBuffer[id-1], 32010),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Voltage",         GetI16(globalDataBuffer[id-1], 32016) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.1_Current",         GetI16(globalDataBuffer[id-1], 32017) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Voltage",         GetI16(globalDataBuffer[id-1], 32018) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.2_Current",         GetI16(globalDataBuffer[id-1], 32019) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Voltage",         GetI16(globalDataBuffer[id-1], 32020) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.3_Current",         GetI16(globalDataBuffer[id-1], 32021) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Voltage",         GetI16(globalDataBuffer[id-1], 32022) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".String.4_Current",         GetI16(globalDataBuffer[id-1], 32023) / 100,    {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".InputPower",               GetI32(globalDataBuffer[id-1], 32064) / 1000,   {name: "", unit: "kW"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1-L2_Voltage",       GetU16(globalDataBuffer[id-1], 32066) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2-L3_Voltage",       GetU16(globalDataBuffer[id-1], 32067) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3-L1_Voltage",       GetU16(globalDataBuffer[id-1], 32068) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Voltage",          GetU16(globalDataBuffer[id-1], 32069) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Voltage",          GetU16(globalDataBuffer[id-1], 32070) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Voltage",          GetU16(globalDataBuffer[id-1], 32071) / 10,     {name: "", unit: "V"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L1_Current",          GetI32(globalDataBuffer[id-1], 32072) / 1000,   {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L2_Current",          GetI32(globalDataBuffer[id-1], 32074) / 1000,   {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Grid.L3_Current",          GetI32(globalDataBuffer[id-1], 32076) / 1000,   {name: "", unit: "A"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".PeakActivePowerDay",       GetI32(globalDataBuffer[id-1], 32078) / 1000,   {name: "", unit: "kW"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".ActivePower",              GetI32(globalDataBuffer[id-1], 32080) / 1000,   {name: "", unit: "kW"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".ReactivePower",            GetI32(globalDataBuffer[id-1], 32082) / 1000,   {name: "", unit: "kVar"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".PowerFactor",              GetI16(globalDataBuffer[id-1], 32084) / 1000,   {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".GridFrequency",            GetU16(globalDataBuffer[id-1], 32085) / 100,    {name: "", unit: "Hz"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".Efficiency",               GetU16(globalDataBuffer[id-1], 32086) / 100,    {name: "", unit: "%"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".InternalTemperature",      GetI16(globalDataBuffer[id-1], 32087) / 10,     {name: "", unit: "°C"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".InsulationResistance",     GetU16(globalDataBuffer[id-1], 32088) / 1000,   {name: "", unit: "MOhm"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".DeviceStatus",             GetU16(globalDataBuffer[id-1], 32089),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".FaultCode",                GetU16(globalDataBuffer[id-1], 32090),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".StartupTime",              String(new Date(GetU32(globalDataBuffer[id-1], 32091)*1000)),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".ShutdownTime",             String(new Date(GetU32(globalDataBuffer[id-1], 32093)*1000)),          {name: "", unit: ""});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".AccomulatedEnergyYield",   GetU32(globalDataBuffer[id-1], 32106) / 100,          {name: "", unit: "kWh"});
        ForceSetState("Solarpower.Huawei.Inverter." + id + ".DailyEnergyYield",         GetU32(globalDataBuffer[id-1], 32114) / 100,          {name: "", unit: "kWh"});
    function ReadRegisterSpace(id, address, length) {
        client.setID(modbusID[id-1]);
        client.readHoldingRegisters(address, length, function(err, data) {
            if (err) {
                if (err.modbusCode == null) {
                    console.warn("Lost connection to client. Trying to reconnect...");
                    ConnectModbus();
                else console.warn("Error received reading address " + address + " from id: " + modbusID[id-1] + " with error: " + err.modbusCode);
            else
                console.debug("Read data from id/address " + modbusID[id-1] + "/" + address + "\nData is: " + data.data);
                    globalDataBuffer[id-1][address+i] = data.data[i];
    function ProcessData() {
        //console.log("Processing new data...");
        for(var i = 1; i <= modbusID.length; i++) {
            ProcessInverterStatus(i);
        ProcessPowerMeterStatus();
        //console.log("Processing done!");
    // This is the main function triggering a  read via modbus-tcp every two seconds.
    // Processing of data is triggered as soon as one complete set of registers is copied.
    var triggerprocessing = 0;
    var currentinverter = 1;
    setInterval(function() {
        if(triggerprocessing == 1) {
            ProcessData();
        //console.log("Triggering read of inverter " + currentinverter + " at address " + registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0] + " with length " +  registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
        ReadRegisterSpace(currentinverter, registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][0], registerSpacesToReadContinuously[registerSpacesToReadContinuouslyPtr][1]);
        registerSpacesToReadContinuouslyPtr++;
        if(registerSpacesToReadContinuouslyPtr >= registerSpacesToReadContinuously.length) {
            currentinverter++
            if(currentinverter > modbusID.length){
                triggerprocessing = 1;
    }, 3000);
    Leider kenne ich mich mit dem JS überhaupt nicht aus 😞
    Gruß Jürgen
    B Online
    B Online
    badsnoopy667
    #81
    @juggi1962
    Kommentier die beiden Zeilen wo 37100 und 32000 abgefragt werden doch einfach aus! Also // davorschreiben, so wie das im Script bei anderen Zeilen ja auch schon gemacht wurde.
    J 1 Antwort Letzte Antwort
    • B badsnoopy667
      @juggi1962
      juggi1962
      #82
      @badsnoopy667
      Meinst du diese?
      Brauch ich die gar nicht?
      B 1 Antwort Letzte Antwort
      • J juggi1962
        @badsnoopy667
        Meinst du diese?
        B Online
        B Online
        badsnoopy667
        #83
        @juggi1962
        Ja, das sollten die beiden Zeilen sein. Die brauchst Du nur, wenn du die beiden Register abfragen willst. Aber wie gesagt: Da steht meiner Meinung nach nix wirklich wichtiges drin. Wenn es also nicht klappt, würde ich die einfach nicht abfragen und gut ist.
        J 2 Antworten Letzte Antwort
        • B badsnoopy667
          @juggi1962
          juggi1962
          #84
          @badsnoopy667
          Okay Danke, werde ich mal versuchen.
          Gruß Jürgen
          • J Offline
            juggi1962
            #85
            @badsnoopy667
            kannst du mir vielleicht sagen, was der Unterschid zwischen
            AktivePower und InputPower ist?
            Was von beiden kommt bei mir im Zählerkasten an?
            • B badsnoopy667
              @juggi1962
              juggi1962
              #86
              @badsnoopy667 sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
              @juggi1962
              Hmmmmmmmmmmm das ausklammern hat nichts gebracht die Fehlermeldungen kommen trotzdem
              javascript.0
              2023-03-13 13:18:07.967	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
              2023-03-13 13:17:04.965	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 37100 from id: 1 with error: undefined
              2023-03-13 13:16:01.958	warn	script.js.Neu.PV_Anlage.Modbus_Huawei_Sun2000_neu: Error received reading address 32000 from id: 1 with error: undefined
              Was nun ?? Gruß Jürgen
              • J juggi1962
                @juggi1962
                javascript.0
                B Online
                B Online
                badsnoopy667
                #87
                @juggi1962
                Ja, ich glaube da war ich etwas zu schnell.
                Ich glaube diese Zeile hier muss auch angepasst werden, weiß aber nicht genau wie:
                • J juggi1962
                  @alex-warkentin
                  Danke, hab das gerade gemacht und werde es heute beobachten.
                  Wenn ich weiterhin lästig sein darf geb ich dir falls was daher kommt Bescheid.
                  Gruß Jürgen.
                  So nun sind die ersten Fehlermeldungen gekommen und zwar
                  Error received reading address 37100 from id: 1 with error: 6
                  Error received reading address 32000 from id: 1 with error: 6
                  Gruß Jürgen
                  Alex WarkentinA Offline
                  Alex Warkentin
                  #88
                  @juggi1962 said in Huawei Sun2000 & ioBroker via JS script funktioniert:
                  @alex-warkentin
                  Gruß Jürgen.
                  Gruß Jürgen
                  Error 6 ist verkraftbar. Kommt bei mir auch zwischendurch mal vor. Bedeutet, dass der Client busy ist. Du könntest vielleicht das Abfrageintervall erhöhen.
                  Die undefined Fehler, die du später gepostet hast, sind sie mit der letzten Änderung (nur errorcode) erfolgt, oder hast du es wieder rückgängig gemacht?
                  • Alex WarkentinA Alex Warkentin
                    @alex-warkentin
                    Gruß Jürgen.
                    Gruß Jürgen
                    juggi1962
                    #89
                    @alex-warkentin sagte in Huawei Sun2000 & ioBroker via JS script funktioniert:
                    @alex-warkentin
                    Gruß Jürgen.
                    Gruß Jürgen
                    @alex-warkentin
                    ich hab es zwischenzeitlich wieder rückgängig gemacht
                    Alex WarkentinA 1 Antwort Letzte Antwort
                    • J juggi1962
                      @alex-warkentin
                      Gruß Jürgen.
                      Gruß Jürgen
                      @alex-warkentin
                      Alex Warkentin
                      #90
                      @alex-warkentin
                      @alex-warkentin
                      Du solltest das mit der Änderung laufen lassen, damit du die Fehlercodes bekommst. Wie gesagt, 6 kannst du erstmal ignorieren.
                      Das mit dem Auskommentieren der Arrays macht keinen Sinn. Dann rufst du nichts mehr ab.
                        @alex-warkentin
                        @alex-warkentin
                        juggi1962
                        schrieb am zuletzt editiert von juggi1962
                        #91
                        @alex-warkentin
                        @alex-warkentin
                        Okay, hab es wieder umgestellt und werde es weiter beobachten.
                        Danke noch mal für deine Bemühungen und Hilfe.
                        Ach ja, kannst du mir vielleicht noch sagen, was der Unterschid zwischen
                        Schönen Abend, Gruß Jürgen
                        • J juggi1962
                          @alex-warkentin
                          @alex-warkentin
                          Alex Warkentin
                          #92
                          @juggi1962
                          Ich nutze eigentlich nur die Infos von Smart Meter. Die active power dort zeigt dir den aktuellen Überschuss oder Bezug. Nagel mich daher nicht darauf fest, aber ich denke Active Power ist das was der WR aktuell in liefert und Input Power müsste das sein, was von den Modulen in den WR geht
                            @juggi1962
                            juggi1962
                            #93
                            @juggi1962
                            Okay, Danke
                            baumiliciousnessssB 1 Antwort Letzte Antwort
                            • J juggi1962
                              @juggi1962
                              Okay, Danke
                              baumiliciousnessssB Offline
                              baumiliciousnessss
                              #94
                              gerade ist der SUN2000 in Betrieb gegangen mit 10kwh und 11kwp
                              Was ist denn der aktuelle Stand hier ? hat es jemand am Laufen?
                              • baumiliciousnessssB baumiliciousnessss
                                juggi1962
                                #95
                                @baumiliciousnessss
                                Ja, ich habe das Skript von @Alex-Warkentin und das funktioniert jetzt.
                                Er hat das Original Skript ein wenig abgespeckt und den Batterie Teil rausgenommen da er und ich keine Haben.
                                // @ts-ignore
                                    "Unknown error",
                                const modbusHost = "xxx.xxx.x.x";
                                ConnectModbus();
                                const registerSpacesToReadContinuously = [[37100, 114],[32000, 116]];
                                    return value;
                                    return value;
                                    var value = 0;
                                    else
                                        value = array[0];
                                    return value;
                                    var value = 0;
                                    return value;
                                    return value;
                                    return value;
                                    return value;
                                    return value;
                                    var bytearray = [];
                                    return value;
                                    var bytearray = [];
                                    return value2;
                                    // try to connect
                                        .then(function()
                                        .catch(function(e)
                                            console.log(e);
                                        if (err) {
                                                ConnectModbus();
                                        else
                                        ProcessData();
                                        currentinverter++
                                }, 4000);
                                Die Fehler die bei mir gekommen sind, sind jetzt fast weg, seit ich die Abfragezeit auf 4000 ms geändert habe.
                                Ich hoffe ich konnte helfen, Gruß Jürgen
                                AtifanA 1 Antwort Letzte Antwort
                                  @atari
                                  Das Abfrageintervall kannst du in der letzten Zeile des Scripts in ms einstellen. Dein Problem liegt wohl aber weniger am Intervall (dann kommt zwischendurch eine Warnung, dass das Gerät beschäftigt ist), sondern, dass das Script beim Verlust der Modbus-Verbindung diese nicht wieder automatisch aufbaut.
                                  ATARI
                                  #96
                                  @alex-warkentin
                                  Mir ging es nicht um den eigentlichen Abfrageintervall, mit dem habe ich schon experimentiert.
                                  Mein bestes Ergebnis habe ich bei 3333ms erhalten, hierbei treten nur sehr sporadisch Fehlermeldungen
                                  wegen "...Busy..." auf und ich erhalte dennoch ca. 2 mal pro Minute neue Daten.
                                  ATARI
                                  Raspberry Pi 5B (ioB via pi OS_lite(64bit) | Synology NAS (ioB via Docker)
                                  Fibaro Home Center 2 & Home Center 3 | Homematic IP | EMS-ESP32 Gateway
                                  Aeotec Z-Wave | Tuya 4 in 1 Gateway | Zigbee & BLE Gateway
                                  • Alex WarkentinA Offline
                                    Alex Warkentin
                                    #97
                                    Funktioniert das Script bei euch noch? Seit heute bekomme ich fast bei jedem Abruf die Fehlermeldung, dass der Port nicht geöffnet ist.
                                    • T Thomas42
                                      Erst mal vielen Dank für das Script, hat fast sofort funtioniert.
                                      Ich musste nur die IDs raten, bei meiner nagelneuen Anlage mit 2 KTLs und dem Powermeter und ohne Batterien bin ich hier gelandet:
                                      const ModBusIDs = [1, 2];
                                      const PowerMeterID = 0;
                                      Powermeter läuft wunderbar.
                                      Das Problem, daß die Werte nur einmal geschrieben wurden habe ich mit einem Workaround hier gelöst:
                                      function forcesetState(objectname, value, options) {
                                          if(!existsState(objectname)) {
                                              console.log("createstate " +  objectname + " to value " + value);
                                          //Workaround
                                      also das setstate aus der else-clause genommen, denn das !existsState scheint nicht sauber zu funktionieren.
                                      Ach so, noch eine gute Nachricht:
                                      Der Installateur kann den Modbus (inwischen?) remote aktivieren, da muss keiner vor Ort sein.
                                      Hat mich eine Mail an meinen Solateur gekostet und zwei Stunden später war alles aktiv.
                                      severendis
                                      #98
                                      @thomas42
                                      Hallo Thomas!
                                      Danke für die Beschreibung, mit der ich das Script zum laufen bekommen habe.
                                      Aber etwas ist bei Dir scheinbar anders.
                                      Du schreibts, das du 2 WR hast und die mit der Modbus ID 1 und 2 ansteuerst.
                                      Hast Du dann an jedem WR einen Dongle dran?
                                      Bei mir hängen 2 WR im Verbund an einem Dongle.
                                      Ich habe somit nur eine Modbus Adresse (die 1)
                                      Bisher arbeite ich über NodeRed (was mir zu langsam und speicherintensiv ist). Da kann ich die Register von beiden WR abfragen.
                                      Hierfür gibt es eine "Unit-Id"
                                      So frage ich dort z.B. mit
                                      32064 Unit-Id 1 die PV Input Power des ersten WR ab
                                      32064 Unit-Id 2 die PV Input Power des zweiten WR ab
                                      Das kann ich aber in diesem Script nicht finden und somit nur einen WR auslesen.
                                      Wie sind die WR bei Dir angeschlossen?
                                      • O Offline
                                        O Offline
                                        OliWit82
                                        #99
                                        Hallo zusammen.
                                        Vielen Dank das Script läuft super.
                                        Hat vielleicht jemand die Adresse für die Last vom Haus?
                                        • O Offline
                                          O Offline
                                          OliWit82
                                          #100
                                          Kann man die Werte abfragen?
                                          Oder muss man dich durch ein Script selber errechnen?
