  4. (erledigt) Backitup will nicht...
    6.0k
5 Beiträge 3 Kommentatoren 601 Aufrufe 3 Beobachtet
  • H Online
    H Online
    hm_krause
    schrieb am zuletzt editiert von hm_krause
    hallo,
    versuche gerade auf einem neu aufgesetztem System (Raspi 4 mit 8GB) ein Backup von heute morgen widerherzustellen.
    Hier der Log ```
    2022-02-28 12:17:53.343 - error: backitup.0 (7408) [ERROR] [iobroker] Uncaught Rejection: Error: Cannot create a string longer than 0xffffff0 characters
    2022-02-28 12:17:53.344 - error: backitup.0 (7408) [ERROR] [iobroker] at Buffer.utf8Slice ()
    2022-02-28 12:17:53.345 - error: backitup.0 (7408) [ERROR] [iobroker] at Object.slice (buffer.js:609:37)
    2022-02-28 12:17:53.345 - error: backitup.0 (7408) [ERROR] [iobroker] at Buffer.toString (buffer.js:827:14)
    2022-02-28 12:17:53.346 - error: backitup.0 (7408) [ERROR] [iobroker] at Object.readFileSync (fs.js:437:41)
    2022-02-28 12:17:53.346 - error: backitup.0 (7408) [ERROR] [iobroker] at BackupRestore._restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:664:23)
    2022-02-28 12:17:53.347 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:1102:49)
    2022-02-28 12:17:53.347 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon.emit (events.js:412:35)
    2022-02-28 12:17:53.348 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon.emit (domain.js:475:12)
    2022-02-28 12:17:53.348 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
    2022-02-28 12:17:53.349 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
    2022-02-28 12:17:53.349 - error: backitup.0 (7408) [ERROR] [iobroker] This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2022-02-28 12:17:53.349 - error: backitup.0 (7408) [ERROR] [iobroker] Error: Cannot create a string longer than 0xffffff0 characters
    2022-02-28 12:17:53.350 - error: backitup.0 (7408) [ERROR] [iobroker] at Buffer.utf8Slice ()
    2022-02-28 12:17:53.350 - error: backitup.0 (7408) [ERROR] [iobroker] at Object.slice (buffer.js:609:37)
    2022-02-28 12:17:53.350 - error: backitup.0 (7408) [ERROR] [iobroker] at Buffer.toString (buffer.js:827:14)
    2022-02-28 12:17:53.351 - error: backitup.0 (7408) [ERROR] [iobroker] at Object.readFileSync (fs.js:437:41)
    2022-02-28 12:17:53.351 - error: backitup.0 (7408) [ERROR] [iobroker] at BackupRestore._restoreAfterStop (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:664:23)
    2022-02-28 12:17:53.352 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon. (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupBackup.js:1102:49)
    2022-02-28 12:17:53.352 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon.emit (events.js:412:35)
    2022-02-28 12:17:53.352 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon.emit (domain.js:475:12)
    2022-02-28 12:17:53.353 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon._kill (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:246:14)
    2022-02-28 12:17:53.353 - error: backitup.0 (7408) [ERROR] [iobroker] at Daemon.stop (/opt/iobroker/node_modules/daemonize2/lib/daemonize.js:185:17)
    ...braucht Ihr meht Infos?
    • H hm_krause
      hallo,
      Hier der Log ```
      da_WoodyD Offline
      da_WoodyD Offline
      da_Woody
      @hm_krause irgendwie hast du den falschen text in die code-tags geschrieben... ;)
      gruß vom Woody
      • H Online
        H Online
        hm_krause
        • H hm_krause
          simatecS Offline
          simatecS Offline
          simatec
          @hm_krause
          Wie groß ist denn dein Backup?
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          H 1 Antwort Letzte Antwort
          • simatecS simatec
            @hm_krause
            H Online
            H Online
            hm_krause
            @simatec
            Hat sich erledigt,
            die Backup´s wurden unter Raspi mit 64 bit erstellt, das neue System hatte 32 bit.
            Wider zurück auf 64, dann lief es.
