  4. Node-Red
  5. Mit amazon-echo tuya lokal steuern
    6.5k
2 Beiträge 1 Kommentatoren 312 Aufrufe 1 Beobachtet
  • K Offline
    kla960
    Bin schon relativ weit.
    Nutze
    • node-red-contrib-amazon-echo für die Lokale Echo integration
    • node-red-contrib-color-convert für RGB nach HSV, da der hue wert aus amazon-echo mir nicht so zusagt
      zwei tuya rgb LED Strips Datenpunkt sind im ioBroker eingelesen
    An/aus ist jetzt nicht so das Problem.
    Farben setzt man über z.B. für rot 100% Helligkeit:
    color_data 000003e803e8
    hue 0000 möglicher Bereich 0 - 360
    sat 03e8 möglicher Bereich 0 - 1000
    value 03e8 möglicher Bereich0 - 1000
    kann schon mal die Ausgabe aus dem echo node in die Bereiche bringen
            "id": "c898591b.0e6fe8",
            "type": "tab",
            "label": "Test Tuya",
            "disabled": false,
            "info": ""
            "id": "32ab7202.1284ee",
            "type": "debug",
            "z": "c898591b.0e6fe8",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "true",
            "targetType": "full",
            "statusVal": "",
            "statusType": "auto",
            "x": 250,
            "y": 440,
            "wires": []
            "id": "b7ed32a5.e1d11",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "move",
                    "p": "rgb",
                    "pt": "msg",
                    "to": "payload",
                    "tot": "msg"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 240,
            "y": 220,
            "wires": [
                    "d84bff51.26272"
            "id": "6fb8b57d.2a653c",
            "type": "link in",
            "name": "Test Tuya",
            "links": [
                "d06fcf08.164fd"
            "x": 115,
            "y": 220,
            "wires": [
                    "32ab7202.1284ee",
                    "b7ed32a5.e1d11"
            "id": "d84bff51.26272",
            "type": "color-convert",
            "input": "rgb",
            "output": "hsv",
            "outputType": "object",
            "scaleInput": false,
            "x": 410,
            "y": 220,
            "wires": [
                    "cd2bfe21.53877"
            "id": "b4f125ae.2dfb88",
            "type": "debug",
            "name": "",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "x": 910,
            "y": 220,
            "wires": []
            "id": "cd2bfe21.53877",
            "type": "range",
            "minin": "0",
            "maxin": "100",
            "minout": "0",
            "maxout": "1000",
            "action": "scale",
            "round": true,
            "property": "payload.saturation",
            "name": "saturation",
            "x": 580,
            "y": 220,
            "wires": [
                    "5fe5b78e.4c1578"
            "id": "5fe5b78e.4c1578",
            "type": "range",
            "minin": "0",
            "maxin": "100",
            "minout": "0",
            "maxout": "1000",
            "action": "scale",
            "round": true,
            "property": "payload.value",
            "name": "value",
            "x": 750,
            "y": 220,
            "wires": [
                    "b4f125ae.2dfb88"
    muss jetzt aber noch die payload z.B. für rot
    {"hue":0,"saturation":1000,"value":1000}
    in das Tuya color_data 000003e803e8 sting bringen.
    Werde dann mal googlen. Wenn Ihr Ideen habt, nur zu 😊
    K 1 Antwort Letzte Antwort
    • K kla960
      Nutze
              "type": "tab",
              "disabled": false,
              "info": ""
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 250,
              "y": 440,
              "wires": []
              "type": "change",
              "name": "",
              "rules": [
                      "t": "move",
                      "p": "rgb",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 240,
              "y": 220,
              "wires": [
                      "d84bff51.26272"
              "type": "link in",
              "links": [
                  "d06fcf08.164fd"
              "x": 115,
              "y": 220,
              "wires": [
                      "32ab7202.1284ee",
                      "b7ed32a5.e1d11"
              "input": "rgb",
              "output": "hsv",
              "x": 410,
              "y": 220,
              "wires": [
                      "cd2bfe21.53877"
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "statusVal": "",
              "x": 910,
              "y": 220,
              "wires": []
              "type": "range",
              "minin": "0",
              "maxin": "100",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "x": 580,
              "y": 220,
              "wires": [
                      "5fe5b78e.4c1578"
              "type": "range",
              "minin": "0",
              "maxin": "100",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "name": "value",
              "x": 750,
              "y": 220,
              "wires": [
                      "b4f125ae.2dfb88"
      kla960
      So geht es. In der Alexa bekommt sogar Änderungen bei IR Fernbedienung mit.
              "type": "tab",
              "label": "Lena Tuya",
              "disabled": false,
              "info": ""
              "type": "link in",
              "links": [
                  "d06fcf08.164fd"
              "x": 115,
              "y": 280,
              "wires": [
                      "24745777.87ea88",
                      "2d3cb289.c9ceae"
              "id": "24745777.87ea88",
              "type": "switch",
              "name": "colormode",
              "property": "colormode",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "hs",
                      "vt": "str"
                      "t": "eq",
                      "v": "ct",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 250,
              "y": 220,
              "wires": [
                      "5efba10b.dce29"
                      "8f00528b.9763d"
              "id": "5efba10b.dce29",
              "type": "range",
              "minin": "0",
              "maxin": "254",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "property": "sat",
              "x": 480,
              "y": 180,
              "wires": [
                      "7bc350fb.2de61"
              "id": "7bc350fb.2de61",
              "type": "range",
              "minin": "0",
              "maxin": "254",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "property": "bri",
              "name": "value",
              "x": 630,
              "y": 180,
              "wires": [
                      "e2b9d916.379268"
              "id": "e2b9d916.379268",
              "type": "range",
              "minin": "0",
              "maxin": "65563",
              "minout": "0",
              "maxout": "360",
              "action": "scale",
              "round": true,
              "property": "hue",
              "name": "hue",
              "x": 770,
              "y": 180,
              "wires": [
                      "86ddc18c.0f5cd"
              "id": "86ddc18c.0f5cd",
              "type": "function",
              "name": "joinToHexString",
              "func": "msg.bri = toHex(msg.bri)\nmsg.sat = toHex(msg.sat)\nmsg.hue = toHex(msg.hue)\n\nlet arr = [msg.hue, msg.sat, msg.bri];\nmsg.payload = arr.join(\"\");\nreturn msg;\n\nfunction toHex(decimal) { // This converts a number to a string Hex AND adds padding zeros to a set number of characters.\n    return (decimal + Math.pow(16, 4)).toString(16).slice(-4)\n}\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 940,
              "y": 180,
              "wires": [
                      "68a011f.1c0b6f"
              "id": "8f00528b.9763d",
              "type": "range",
              "minin": "0",
              "maxin": "254",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "property": "bri",
              "name": "value",
              "x": 470,
              "y": 260,
              "wires": [
                      "1cb5e65b.c81d1a"
              "id": "1cb5e65b.c81d1a",
              "type": "function",
              "func": "msg.bri = toHex(msg.bri)\nmsg.sat = \"0000\"\nmsg.hue = \"0000\"\n\nlet arr = [msg.hue, msg.sat, msg.bri];\nmsg.payload = arr.join(\"\");\nreturn msg;\n\nfunction toHex(decimal) { // This converts a number to a string Hex AND adds padding zeros to a set number of characters.\n    return (decimal + Math.pow(16, 4)).toString(16).slice(-4)\n}\n",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 940,
              "y": 260,
              "wires": [
                      "68a011f.1c0b6f"
              "id": "2d3cb289.c9ceae",
              "type": "switch",
              "name": "on/off",
              "property": "payload",
              "rules": [
                      "t": "eq",
                      "v": "on",
                      "vt": "str"
                      "t": "eq",
                      "v": "off",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 230,
              "y": 340,
              "wires": [
                      "7478ffb4.d10b8"
                      "e6f736ec.004098"
              "id": "7478ffb4.d10b8",
              "type": "change",
              "name": "true",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "true",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 390,
              "y": 320,
              "wires": [
                      "4be3cd26.926364"
              "id": "e6f736ec.004098",
              "type": "change",
              "name": "flase",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 390,
              "y": 360,
              "wires": [
                      "4be3cd26.926364"
              "id": "4be3cd26.926364",
              "type": "ioBroker out",
              "name": "Lena Tuya LED Strip switch_led",
              "topic": "tuya.0.08200118e868e759568a.20",
              "ack": "false",
              "autoCreate": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 990,
              "y": 360,
              "wires": []
              "id": "68a011f.1c0b6f",
              "name": "Lena Tuya LED Strip color_data",
              "topic": "tuya.0.08200118e868e759568a.24",
              "ack": "false",
              "stateName": "",
              "role": "",
              "payloadType": "",
              "readonly": "",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1190,
              "y": 220,
              "wires": []
              "id": "b766d64f.558e38",
              "type": "ioBroker in",
              "name": "color_mode",
              "payloadType": "value",
              "onlyack": true,
              "func": "all",
              "gap": "",
              "fireOnStart": "false",
              "x": 250,
              "y": 780,
              "wires": [
                      "a3eb0958.b769e8"
              "id": "52f07af3.8b1f44",
              "name": "switch_led",
              "onlyack": true,
              "func": "all",
              "gap": "",
              "x": 240,
              "y": 600,
              "wires": [
                      "c275b713.8d6788"
              "id": "c275b713.8d6788",
              "type": "change",
              "name": "on",
              "rules": [
                      "t": "move",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload.on",
                      "tot": "msg"
                      "t": "set",
                      "p": "payload.nodeid",
                      "pt": "msg",
                      "to": "6db05f00.c9783",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 690,
              "y": 600,
              "wires": [
                      "81e46aff.74a0d8"
              "id": "a3eb0958.b769e8",
              "type": "split",
              "name": "",
              "splt": "4",
              "spltType": "len",
              "arraySplt": "1",
              "arraySpltType": "len",
              "stream": false,
              "addname": "",
              "x": 390,
              "y": 780,
              "wires": [
                      "5177cbe7.485ab4"
              "id": "5177cbe7.485ab4",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "array",
              "key": "topic",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": false,
              "timeout": "",
              "count": "3",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "num",
              "reduceFixup": "",
              "x": 510,
              "y": 780,
              "wires": [
                      "92af89f0.547b48"
              "id": "92af89f0.547b48",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "move",
                      "p": "payload.0",
                      "pt": "msg",
                      "to": "hue",
                      "tot": "msg"
                      "t": "move",
                      "p": "payload.1",
                      "pt": "msg",
                      "to": "sat",
                      "tot": "msg"
                      "t": "move",
                      "p": "payload.2",
                      "pt": "msg",
                      "to": "bri",
                      "tot": "msg"
                      "t": "delete",
                      "p": "payload",
                      "pt": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 670,
              "y": 780,
              "wires": [
                      "4e112b70.633bc4"
              "id": "8eb7f14.6ee0c1",
              "type": "comment",
              "name": "set Tuya",
              "info": "",
              "x": 240,
              "y": 100,
              "wires": []
              "id": "cfb4977b.415fd8",
              "type": "comment",
              "name": "get Tuya",
              "info": "",
              "x": 240,
              "y": 480,
              "wires": []
              "id": "9826af61.305f2",
              "type": "range",
              "minin": "0",
              "maxin": "360",
              "minout": "0",
              "maxout": "65563",
              "action": "scale",
              "round": true,
              "property": "hue",
              "name": "hue",
              "x": 250,
              "y": 680,
              "wires": [
                      "a3add1ea.138f1"
              "id": "4e112b70.633bc4",
              "type": "function",
              "name": "",
              "func": "msg.hue = parseInt(msg.hue,16);\nmsg.sat = parseInt(msg.sat,16);\nmsg.bri = parseInt(msg.bri,16)\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 860,
              "y": 780,
              "wires": [
                      "9826af61.305f2"
              "id": "a3add1ea.138f1",
              "type": "range",
              "minin": "0",
              "maxin": "1000",
              "minout": "0",
              "maxout": "254",
              "action": "scale",
              "round": true,
              "property": "sat",
              "x": 380,
              "y": 680,
              "wires": [
                      "81962849.8fc1f8"
              "id": "81962849.8fc1f8",
              "type": "range",
              "minin": "0",
              "maxin": "1000",
              "minout": "0",
              "maxout": "254",
              "action": "scale",
              "round": true,
              "property": "bri",
              "name": "value",
              "x": 510,
              "y": 680,
              "wires": [
                      "b5006a27.98cc48"
              "id": "81e46aff.74a0d8",
              "type": "link out",
              "name": "Lena Tuya in",
              "links": [
                  "4ec4c5f2.23c2dc"
              "x": 895,
              "y": 640,
              "wires": []
              "id": "b5006a27.98cc48",
              "type": "change",
              "name": "on",
              "rules": [
                      "t": "set",
                      "pt": "msg",
                      "tot": "str"
                      "t": "move",
                      "p": "bri",
                      "pt": "msg",
                      "to": "payload.bri",
                      "tot": "msg"
                      "t": "move",
                      "p": "hue",
                      "pt": "msg",
                      "to": "payload.hue",
                      "tot": "msg"
                      "t": "move",
                      "p": "sat",
                      "pt": "msg",
                      "to": "payload.sat",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 690,
              "y": 680,
              "wires": [
                      "81e46aff.74a0d8"
