  3. Einsteigerfragen
  4. Aktives Repository ist "default" - Was bedeutet die Meldung?
    5.6k
80 Beiträge 6 Kommentatoren 5.3k Aufrufe 4 Beobachtet
  • K klausiob
     iob update
    hash changed or no sources cached => force download of new sources
    Cannot get any information of "_repoInfo". Ignored.
    update done
    Adapter    "admin"         : 6.2.23   , installed 6.2.23
    Adapter    "alexa2"        : 3.21.0   , installed 3.11.2 [Updateable]
    Adapter    "awattar"       : 1.0.6    , installed 1.0.6
    Adapter    "backitup"      : 2.5.4    , installed 2.5.4
    Adapter    "bluelink"      : 2.2.3    , installed 2.2.3
    Adapter    "daswetter"     : 3.1.4    , installed 3.1.4
    Adapter    "discovery"     : 3.0.5    , installed 3.0.5
    Adapter    "dwd"           : 2.8.3    , installed 2.8.3
    Adapter    "flot"          : 1.11.0   , installed 1.11.0
    Adapter    "fritzdect"     : 2.2.6    , installed 2.2.6
    Adapter    "history"       : 2.2.0    , installed 1.11.1 [Updateable]
    Adapter    "hs100"         : 2.1.2    , installed 2.1.2
    Adapter    "ical"          : 1.13.1   , installed 1.13.1
    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
    Adapter    "info"          : 1.9.19   , installed 1.9.19
    Adapter    "iot"           : 1.11.9   , installed 1.11.9
    Adapter    "javascript"    : 6.0.3    , installed 5.2.21 [Updateable]
    Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
    Adapter    "ping"          : 1.5.3    , installed 1.5.3
    Adapter    "proxy"         : 1.3.1    , installed 1.3.1
    Adapter    "rpi2"          : 1.3.2    , installed 1.3.2
    Adapter    "sayit"         : 1.12.3   , installed 1.12.3
    Adapter    "shelly"        : 6.0.0    , installed 4.0.7 [Updateable]
    Adapter    "simple-api"    : 2.7.0    , installed 2.7.0
    Adapter    "socketio"      : 4.2.0    , installed 4.2.0
    Adapter    "tahoma"        : 0.7.1    , installed 0.7.1
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
    Adapter    "tvspielfilm"   : 2.0.4    , installed 2.0.4
    Adapter    "vis"           : 1.4.15   , installed 1.4.15
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "weatherunderground": 3.4.2   , installed 3.4.2
    Adapter    "web"           : 4.3.0    , installed 4.3.0
    Adapter    "ws"            : 1.3.0    , installed 1.3.0
    Adapter    "zigbee"        : 1.7.5    , installed 1.6.16 [Updateable]
    ging heute ganz schnell
    #41
    @klausiob sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
    jepp, der hat's definitv nötig, aber erst mal mit upload versuchen
    • K klausiob
       iob update
      update done
      #42
      Da klemmt auch noch was im Repo-Setup.
      iobroker repo list
      K 1 Antwort Letzte Antwort
        iobroker repo list
        klausiob
        schrieb am zuletzt editiert von klausiob
        #43
        @thomas-braun sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
        iobroker repo list
        Alle Adapter sind jetzt aktuell.
         iobroker repo list
        Stable (default): http://download.iobroker.net/sources-dist.json
        Beta (latest): http://download.iobroker.net/sources-dist-latest.json
        Active repo: Stable (default)
        Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
        node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
        • K klausiob
          iobroker repo list
           iobroker repo list
          #44
          @klausiob
          Dann los.
          • FeuersturmF Offline
            FeuersturmF Offline
            Feuersturm
            #45
            Ich hab mal ein Update von der Doku für den Abschnitt "Auswahl des Repositorys vorbereitet"
            https://github.com/Feuer-sturm/ioBroker.docs/blob/doc-repo-update/docs/de/basics/repositories.md#auswahl-des-repository
            Schaut doch mal drüber ob noch was fehlt, dann kann ich es als Pullrequest zur Verfügung stellen.
              @klausiob
              Dann los.
              klausiob
              #46
              @klausiob
              Dann los.
              mit upload? läuft und dauert wegen den icon-libraries ewig
              • K klausiob
                @klausiob
                Dann los.
                #47
                @klausiob
                Mit
                iobroker update
                iobroker upgrade all
                iobroker upload all
                  @klausiob
                  Mit
                  iobroker update
                  iobroker upload all
                  klausiob
                  #48
                  @klausiob
                  Mit
                  iobroker update
                  iobroker upload all
                  ja ja ist noch beim letzten Befehl, dauerte schon gestern >10 min
                  Gib mal ein Link zu einem sicheren js-controller Update auf 4.xx
                  Hatte im Januar erst auf 3.2.22 upgedatet.
                  Ist dies noch die empfohlene Variante zur Aktualisierung des js-controller, wenn ioBroker mittels "curl shell installation script" installiert wurde?
                  Bitte in einer SSH-Shell (Konsole) folgende Befehle ausführen:
                  iobroker stop
                  iobroker update
                  iobroker fix oder wenn das nicht funktioniert: curl -sL https://iobroker.net/fix.sh | bash -
                  iobroker upgrade self
                  iobroker start oder Server rebooten, danach sollte ioBroker neu starten und man kann sicher sein das alle alten Prozesse beendet waren.
                  • K klausiob
                    @klausiob
                    Mit
                    iobroker update
                    iobroker upload all
                    iobroker stop
                    iobroker update
                    #49
                    @klausiob
                    js-controller:
                    iob stop
                    iob update
                    iob upgrade self
                    iob start
                    Wie sieht es auf der nodejs-Seite aus?
                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    K 2 Antworten Letzte Antwort
                      @klausiob
                      js-controller:
                      iob stop
                      iob update
                      iob upgrade self
                      iob start
                      klausiob
                      #50
                      so jetzt erst fertig
                      node und nodejs v14.18.1, kein Docker
                      ich habe ein Master-Slave-System. Welchen sollte ich zuerst updaten?
                      • K klausiob
                        #51
                        @klausiob Ich würd zuerst nodejs auf Stand bringen.
                        • K klausiob
                          #52
                          Achtung: MASTER-Systeme Reihenfolgen beachten!
                          Bei einem Multi-Host-System, welches auf js-controller 2.2 oder 3.x läuft, ist es beim Update auf Version 4.0 empfohlen, zuerst das Master-System zu aktualisieren. Der Master muss dann wieder gestartet werden. Die Slaves werden danach aktualisiert!
                          • FeuersturmF Feuersturm
                            #53
                            @feuersturm sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
                            gefällt mir ziemlich gut, aber.... :-)
                            Zwei Dinge, die ich nicht wirklich weiß!
                            1.)
                            ist das Repo wirklich der Lagerort für Programme?
                            nicht eher eine Liste der Versionen?
                            2.)
                            ist die Installation per Experte und npm wirklich (immer) die beta Version und nicht doch die github Version?
                            wenn ja, bitte hier trotzdem noch die 3. Ebene erwähnen, dass github = Alpha sein kann.
                              @klausiob
                              js-controller:
                              iob stop
                              iob update
                              iob upgrade self
                              iob start
                              klausiob
                              #54
                              @klausiob
                              js-controller:
                              iob stop
                              iob update
                              iob upgrade self
                              iob start
                              iob upgrade self
                              Update js-controller from @3.3.22 to @4.0.23
                              NPM version: 6.14.15
                              npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              In file included from ../node_modules/nan/nan.h:60,
                                               from ../src/unix_dgram.cc:5:
                              /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                     (node::addon_register_func) (regfunc),                          \
                              /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:821:3: note: in expansion of macro ‘NODE_MODULE_X’
                                 NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
                              ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
                               NODE_MODULE(unix_dgram, Initialize)
                              Server Objects 127.0.0.1:60770 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.features.useSets"]
                              Server Objects 127.0.0.1:60770 Error from InMemDB: Error: GET-UNSUPPORTED for namespace cfg.: Data=["meta.objects.protocolVersion"]
                              Server States 127.0.0.1:41382 Error from InMemDB: Error: GET-UNSUPPORTED for namespace meta.: Data=["meta.states.protocolVersion"]
                              Server States 127.0.0.1:41384 Error from InMemDB: Error: PSUBSCRIBE-UNSUPPORTED for namespace meta.: Data=["meta.*"]
                              • K klausiob
                                @klausiob
                                js-controller:
                                iob stop
                                iob update
                                iob upgrade self
                                iob start
                                iob upgrade self
                                #55
                                @klausiob
                                Kein Problem.
                                  @klausiob
                                  Kein Problem.
                                  klausiob
                                  #56
                                  @klausiob
                                  Kein Problem.
                                  Herzinfarkt 😌 Der Master hat jetzt die Version, aber die Checkboxen fehlen immer noch bei den Repositories.
                                  Jetzt hat er noch den Slave gemacht.
                                  Was nun? Bestätigen? Gibt ja keine andere Wahl.
                                  • K klausiob
                                    @klausiob
                                    Kein Problem.
                                    #57
                                    @klausiob
                                    Kannst du halt nur zur Kenntnis nehmen.
                                    • K klausiob
                                      @klausiob
                                      Kein Problem.
                                      #58
                                      @klausiob
                                      iob update
                                      auf beiden Systemen sagt?
                                        @klausiob
                                        iob update
                                        klausiob
                                        #59
                                        iob update
                                        Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
                                        Adapter    "history"      : 2.2.0    , installed 2.2.0
                                        Adapter    "icons-material-png": 0.1.0, installed 0.1.0
                                        Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
                                        Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
                                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                                        Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                        Controller "js-controller": 4.0.23   , installed 4.0.23
                                        Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                                        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                                        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
                                        Der slave ist aber noch alt, aber die Checkboxen sind jetzt da 🙂
                                        • K klausiob
                                          iob update
                                          #60
                                          Warum?
