  3. Einsteigerfragen
  4. Aktives Repository ist "default" - Was bedeutet die Meldung?
    5.6k
80 Beiträge 6 Kommentatoren 5.3k Aufrufe 4 Beobachtet
    @klausiob
    Das spuckt die installierten Adapter inkl. deren Versionen aus.
    klausiob
    $ iob upgrade -> keine Fehler
    $ iob update
    Cannot download json from http://download.iobroker.net/sources-dist-hash.json. Error: Error: connect ECONNREFUSED 79.143.182.215:80
    failed to download new sources, use cached sources
    update done
    Adapter    "admin"         : 6.2.23   , installed 5.3.8 [Updateable]
    Adapter    "alexa2"        : 3.21.0   , installed 3.11.2 [Updateable]
    Adapter    "awattar"       : 1.0.6    , installed 1.0.6
    Adapter    "backitup"      : 2.5.4    , installed 2.4.12 [Updateable]
    Adapter    "bluelink"      : 2.2.3    , installed 2.2.2 [Updateable]
    Adapter    "daswetter"     : 3.1.4    , installed 3.1.3 [Updateable]
    Adapter    "discovery"     : 3.0.5    , installed 3.0.5
    Adapter    "dwd"           : 2.8.3    , installed 2.8.3
    Adapter    "flot"          : 1.11.0   , installed 1.11.0
    Adapter    "fritzdect"     : 2.2.6    , installed 2.2.3 [Updateable]
    Adapter    "history"       : 2.2.0    , installed 1.11.1 [Updateable]
    Adapter    "hs100"         : 2.1.2    , installed 2.1.2
    Adapter    "ical"          : 1.13.1   , installed 1.13.1
    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
    Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.2
    Adapter    "info"          : 1.9.19   , installed 1.9.19
    Adapter    "iot"           : 1.11.9   , installed 1.11.4 [Updateable]
    Adapter    "javascript"    : 6.0.3    , installed 5.2.21 [Updateable]
    Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
    Adapter    "ping"          : 1.5.3    , installed 1.5.3
    Adapter    "proxy"         : 1.3.1    , installed 1.3.1
    Adapter    "rpi2"          : 1.3.2    , installed 1.3.2
    Adapter    "sayit"         : 1.12.3   , installed 1.12.3
    Adapter    "shelly"        : 6.0.0    , installed 4.0.7 [Updateable]
    Adapter    "simple-api"    : 2.7.0    , installed 2.7.0
    Adapter    "socketio"      : 4.2.0    , installed 4.2.0
    Adapter    "tahoma"        : 0.7.1    , installed 0.7.1
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
    Adapter    "tvspielfilm"   : 2.0.4    , installed 2.0.4
    Adapter    "vis"           : 1.4.15   , installed 1.4.15
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "weatherunderground": 3.4.2   , installed 3.4.2
    Adapter    "web"           : 4.3.0    , installed 4.3.0
    Adapter    "ws"            : 1.3.0    , installed 1.3.0
    Adapter    "zigbee"        : 1.7.5    , installed 1.6.16 [Updateable]
     $ iob repo list
    Beta (latest): http://download.iobroker.net/sources-dist-latest.json
    Stable (default): http://download.iobroker.net/sources-dist.json
    Active repo: Stable (default)
    pi@hsmart4:~ $
    Pi4B, Pi3B+, Master-Slave, EchoPlus, 3xEchoDot, FireTVstick, Xiaomi Sensoren, Fritzbox, DECT200, HS100, ZBT-ExtendedColor (ALDI), Shelly 2.5, 2xZigBee-Router-Plugs, Sileno 500 smart, Somfy switch, IONIQ5, tibber
    node.js: 22.21.0 - npm: 10.9.4 - linux: raspbian-trixie - admin 7.7.19 - vis 1.5.6 - js-controller: 7.0.7
    • K klausiob
      $ iob update
      update done
       $ iob repo list
      pi@hsmart4:~ $
      @klausiob sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
      Wenn der Server wieder läuft aktualisiert du zunächst dein System. Vollständig.
      K 1 Antwort Letzte Antwort
        klausiob
        Also die Keule. Ich habe nur den Admin-Adapter installiert und jetzt geht es. Waren wohl einige Bugs drin.
        • K klausiob
          @klausiob
          Was für eine Keule?
          iobroker update
          sagt nun?
          • K klausiob
            in der Doku ist eine Checkbox
            https://www.iobroker.net/#de/documentation/basics/repositories.md
            Bei mir ist keine Checkbox zu sehen:
            Wie auch oben bei dem user, der diesen Thread eröffnet hat.
            die ist in admin bis 5.x als pulldown auf der Hauptseite (einen Reiter weiter links)
              klausiob
              Danke. mehr wollte ich garnicht wissen und habe den Solarman PV Adapter auch gefunden. Trotzdem ist die Darstellung im Repository-Reiter inklusive ALT-Text auf den Kästchen nicht gerade userfreundlicher gegenüber den früheren Checkboxen. Das weiss nur ein Insider, der das geändert hat. Ich hoffe es gab technische Gründe.
              Bevor ich 1x gewechselt hatte waren sogar 2 Minus-Kästchen zu sehen. Was sagt das Minus aus?
              Was macht dann noch das verschieben der Reihenfolge?
              • K klausiob
                was meinst du?
                  was meinst du?
                  klausiob
                  Naja die aus der Doku
                  • K klausiob
                    @klausiob
                    So schaut das im aktuellen Admin aus:
                    Bring dein System halt auf einen aktuellen Stand.
                    • K klausiob
                      aber das ist doch die aktuelle Situation in admin v6! nicht die frühere
                        @klausiob
                        klausiob
                        schrieb am zuletzt editiert von klausiob
                        OK dann fehlen die immer noch in meinem Admin V.6.2.23. Siehe aktuelles Bild oben. Dann sollte ich vielleicht noch den js-controller aktualisieren. Hat aber kein Adapter-Update bisher verlangt. Habe z.Zt. aber keine Zeit. Alles andere läuft ja. 😕
                        • K klausiob
                          @klausiob
                          Halt die Kiste konsistent aktuell.
                          Alles andere fällt dir immer auf die Füße.
                          • K klausiob
                            @klausiob welcher Browser?
                            browsercache geleert?
                            • FeuersturmF Offline
                              FeuersturmF Offline
                              Feuersturm
                              Ich mach mich mal dran und aktualisiere die Doku :-)
                                klausiob
                                @homoran sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
                                • Firefox 107.0
                                • ja
                                • K klausiob
                                  • Firefox 107.0
                                  • ja
                                  @klausiob
                                  iobroker update
                                  iobroker upgrade all
                                  iobroker upload all
                                  Läuft.
                                    @klausiob
                                    iobroker update
                                    iobroker upload all
                                    Läuft.
                                    @thomas-braun sagte in Aktives Repository ist "default" - Was bedeutet die Meldung?:
                                    iob broker update
                                    K Thomas BraunT 2 Antworten Letzte Antwort
                                      iob broker update
                                      klausiob
                                      iob broker update
                                      Das sollte bestimmt ein Intelligenztest für mich sein
                                        iob broker update
                                        Tippgicht.
                                          Tippgicht.
                                          klausiob
                                           iob update
                                          hash changed or no sources cached => force download of new sources
                                          Cannot get any information of "_repoInfo". Ignored.
                                          update done
                                          Adapter    "admin"         : 6.2.23   , installed 6.2.23
                                          Adapter    "backitup"      : 2.5.4    , installed 2.5.4
                                          Adapter    "bluelink"      : 2.2.3    , installed 2.2.3
                                          Adapter    "daswetter"     : 3.1.4    , installed 3.1.4
                                          Adapter    "fritzdect"     : 2.2.6    , installed 2.2.6
                                          Adapter    "iot"           : 1.11.9   , installed 1.11.9
                                          ging heute ganz schnell
