  4. Java Scrip Modul
    6.3k
Java Scrip Modul
16 Beiträge 4 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • L Offline
    Lucascoco
    Systemdata arm4
    Hardwaresystem: PI4.
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Ubuntu
    Node-Version: 14.18.2
    Nodejs-Version: 10.x.x
    NPM-Version: 6.14.15
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: Link
    nach dem Update auf die neue NPM Version kommt immer folgender Fehler
    2021-12-31 12:30:52.501 - info: host.IpBrokerPi4 instance system.adapter.javascript.0 started with pid 5243
    2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: internal/modules/cjs/loader.js:905
    2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: throw err;
    2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: ^
    2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: Error: Cannot find module 'typescript'
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: Require stack:
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
    2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
    2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: at internal/main/run_main_module.js:17:47
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: {
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: requireStack: [
    2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
    2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
    2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
    2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: ]
    2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: }
    2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-12-31 12:30:52.983 - info: host.IpBrokerPi4 Restart adapter system.adapter.javascript.0 because enabled
    • L Lucascoco
      Systemdata arm4
      Image genutzt: Nein
      @lucascoco
      NodeJS ist sauber im System? Wenn du von npm alleine sprichst schwant mir da schon wieder was.
      • L Offline
        Lucascoco
        Wie erkenne ich denn, ob es sauber im System ist ?
        • L Lucascoco
          @lucascoco
          Das sagt dir die Ausgabe von
          which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          • L Offline
            Lucascoco
            Das kam raus
            v14.18.2
            v14.18.2
            6.14.15
            • L Lucascoco
              Das kam raus
              v14.18.2
              v14.18.2
              6.14.15
              @lucascoco
              Nicht nacherzählen, vollständige Ein- und Ausgaben. Da kam hofffentlich noch mehr ums Eck.
              • L Offline
                Lucascoco
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v14.18.2
                v14.18.2
                6.14.15
                OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                Aktualisierung für 129 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                nodejs:
                  Installiert:           14.18.2-deb-1nodesource1
                  Installationskandidat: 14.18.2-deb-1nodesource1
                  Versionstabelle:
                 *** 14.18.2-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                        100 /var/lib/dpkg/status
                     10.24.0~dfsg-1~deb10u1 500
                • L Lucascoco
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.18.2
                  v14.18.2
                  6.14.15
                  nodejs:
                    Versionstabelle:
                  @lucascoco sagte in Java Scrip Modul:
                  Die node-Installation ist okay, der Rest hängt schwer hinterher:
                  sudo apt update
                  sudo apt full-upgrade
                  sudo reboot
                  • AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    Scheinbar zufällige
                    Cannot find module
                    hab ich bisher immer dann gesehen, wenn jemand manuell einzelne Module in /opt/iobroker nachinstalliert hat. Wäre also ein Versuch wert, sich mal /opt/iobroker/package.json anzuschauen, ob da nicht ein unnötiges typescript drin auftaucht.
                    • L Offline
                      Lucascoco
                      @alcalzone said in Java Scrip Modul:
                      typescript
                      nein ist nicht mit drin
                      Full upgrade ist System wurde gemacht, Fehler ist immer noch da
                      Thomas BraunT AlCalzoneA 2 Antworten Letzte Antwort
                      • L Lucascoco
                        typescript
                        War auch nicht anders zu erwarten. Ich schau mir aber lieber voll durchpatchte Systeme an.
                        cd /opt/iobroker
                        npm list
                        • L Lucascoco
                          typescript
                          AlCalzoneA Offline
                          AlCalzoneA Offline
                          AlCalzone
                          ggf. was anderes - zeig doch mal den Inhalt
                          • L Offline
                            Lucascoco
                            npm ERR! missing: @types/node@14.18.0, required by iobroker.javascript@5.2.13
                            npm ERR! peer dep missing: typescript@>=2.0.0, required by virtual-tsc@0.6.1
                            npm ERR! missing: @types/node@14.18.0, required by @types/iobroker@3.3.4
                            Die Ausgabe ist zu lang, habe mal das Ende angefügt
                              "name": "iobroker.inst",
                              "version": "2.0.3",
                              "private": true,
                              "description": "Automation platform in node.js",
                              "scripts": {
                                "install": "node lib/checkVersions.js",
                                "postinstall": "node lib/install.js",
                                "test": "node node_modules/mocha/bin/mocha --exit"
                              "dependencies": {
                                "colors": "^1.3.3",
                                "fs-extra": "^7.0.1",
                                "iobroker": "^2.0.3",
                                "iobroker.admin": "^5.2.3",
                                "iobroker.alexa2": "^3.11.2",
                                "iobroker.backitup": "^2.2.2",
                                "iobroker.devices": "^1.0.9",
                                "iobroker.discovery": "^2.7.3",
                                "iobroker.email": "^1.0.10",
                                "iobroker.flot": "^1.10.7",
                                "iobroker.history": "^1.9.14",
                                "iobroker.hm-rega": "^3.0.33",
                                "iobroker.hm-rpc": "^1.14.50",
                                "iobroker.hue-extended": "^2.0.0",
                                "iobroker.info": "^1.9.8",
                                "iobroker.javascript": "^5.2.13",
                                "iobroker.js-controller": "^3.3.22",
                                "iobroker.rpi2": "^1.3.1",
                                "iobroker.shelly": "^4.0.7",
                                "iobroker.simple-api": "^2.6.1",
                                "iobroker.sonoff": "^2.4.5",
                                "iobroker.tahoma": "github:Excodibur/ioBroker.tahoma",
                                "iobroker.telegram": "^1.10.0",
                                "iobroker.viessmannapi": "^2.0.6",
                                "iobroker.web": "^3.4.9",
                                "iobroker.yahka": "^0.13.1",
                                "semver": "^5.6.0",
                                "yargs": "^7.0.2"
                            • L Lucascoco
                                "version": "2.0.3",
                                "private": true,
                                "scripts": {
                                "dependencies": {
                                  "colors": "^1.3.3",
                                  "semver": "^5.6.0",
                                  "yargs": "^7.0.2"
                              AlCalzoneA Offline
                              AlCalzoneA Offline
                              AlCalzone
                              @lucascoco Ok in package.json ist wirklich nix auffälliges dabei... Ggf. nochmal iobroker.javascript drüber installieren, aber ansonsten bin ich raus.
                              • AlCalzoneA AlCalzone
                                @alcalzone sagte in Java Scrip Modul:
                                und in package-lock.json vielleicht?
                                • L Offline
                                  Lucascoco
                                  Ich glaube das hat geholfen
                                  npm install iobroker.javascript
