  4. Iobroker restartet alle 10 sekunden.....
    6.3k
14 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • K Offline
    Kindsy
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte
    Betriebssystem: Debian
    Node-Version: v12.22.6
    Nodejs-Version: k.A
    NPM-Version: 6.14.15
    Installationsart: Flash Image
    Image genutzt: Ja
    Ort/Name der Imagedatei: Link
    Hier noch das Logfile:
        at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)
    2021-11-29 13:21:00.951  - ESC[32minfoESC[39m: host.iobroker-pi iobroker _restart
    2021-11-29 13:21:01.012  - ESC[31merrorESC[39m: host.iobroker-pi Cannot write host object:Error: DB closed
    2021-11-29 13:21:01.289  - ESC[32minfoESC[39m: host.iobroker-pi terminated
    2021-11-29 13:21:09.751  - ESC[32minfoESC[39m: host.iobroker-pi iobroker.js-controller version 3.3.18 js-controller starting
    2021-11-29 13:21:09.770  - ESC[32minfoESC[39m: host.iobroker-pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-11-29 13:21:09.772  - ESC[32minfoESC[39m: host.iobroker-pi hostname: iobroker-pi, node: v12.22.6
    2021-11-29 13:21:09.774  - ESC[32minfoESC[39m: host.iobroker-pi ip addresses: 192.168.125.4 fe80::5ef0:1324:ff76:1cd5
    2021-11-29 13:21:10.131  - ESC[31merrorESC[39m: host.iobroker-pi Cannot read system.config: null (OK when migrating or restoring)
    2021-11-29 13:21:10.383  - ESC[32minfoESC[39m: host.iobroker-pi connected to Objects and States
    2021-11-29 13:21:10.474  - ESC[32minfoESC[39m: host.iobroker-pi added notifications configuration of host
    2021-11-29 13:21:10.584  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance"
    2021-11-29 13:21:10.587  - ESC[31merrorESC[39m: host.iobroker-pi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-11-29 13:21:10.650  - ESC[32minfoESC[39m: host.iobroker-pi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-11-29 13:21:10.673  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "host"
    2021-11-29 13:21:10.708  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "state"
    2021-11-29 13:21:10.710  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance"
    2021-11-29 13:21:10.715  - ESC[31merrorESC[39m: host.iobroker-pi Could not collect system.host.iobroker-pi states to check for obsolete states: Error: Cannot find view "system"
    2021-11-29 13:21:10.718  - ESC[31merrorESC[39m: host.iobroker-pi _design/system missing - call node iobroker.js setup
    2021-11-29 13:21:10.719  - ESC[32minfoESC[39m: host.iobroker-pi no instances found
    2021-11-29 13:21:10.731  - ESC[31merrorESC[39m: host.iobroker-pi uncaught exception: doc.rows is not iterable
    2021-11-29 13:21:10.733  - ESC[31merrorESC[39m: host.iobroker-pi TypeError: doc.rows is not iterable
    2021-11-29 13:21:10.760  - ESC[32minfoESC[39m: host.iobroker-pi iobroker _restart
    2021-11-29 13:21:10.821  - ESC[31merrorESC[39m: host.iobroker-pi Cannot write host object:Error: DB closed
    2021-11-29 13:21:10.898  - ESC[32minfoESC[39m: host.iobroker-pi terminated
    2021-11-29 13:21:19.450  - ESC[32minfoESC[39m: host.iobroker-pi iobroker.js-controller version 3.3.18 js-controller starting
    2021-11-29 13:21:19.469  - ESC[32minfoESC[39m: host.iobroker-pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-11-29 13:21:19.472  - ESC[32minfoESC[39m: host.iobroker-pi hostname: iobroker-pi, node: v12.22.6
    2021-11-29 13:21:19.474  - ESC[32minfoESC[39m: host.iobroker-pi ip addresses: 192.168.125.4 fe80::5ef0:1324:ff76:1cd5
    2021-11-29 13:21:19.835  - ESC[31merrorESC[39m: host.iobroker-pi Cannot read system.config: null (OK when migrating or restoring)
    2021-11-29 13:21:20.064  - ESC[32minfoESC[39m: host.iobroker-pi connected to Objects and States
    2021-11-29 13:21:20.137  - ESC[32minfoESC[39m: host.iobroker-pi added notifications configuration of host
    2021-11-29 13:21:20.269  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance"
    2021-11-29 13:21:20.272  - ESC[31merrorESC[39m: host.iobroker-pi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-11-29 13:21:20.374  - ESC[32minfoESC[39m: host.iobroker-pi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-11-29 13:21:20.397  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "host"
    2021-11-29 13:21:20.428  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "state"
    2021-11-29 13:21:20.430  - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance"
    2021-11-29 13:21:20.441  - ESC[31merrorESC[39m: host.iobroker-pi Could not collect system.host.iobroker-pi states to check for obsolete states: Error: Cannot find view "system"
    2021-11-29 13:21:20.444  - ESC[31merrorESC[39m: host.iobroker-pi _design/system missing - call node iobroker.js setup
    2021-11-29 13:21:20.446  - ESC[32minfoESC[39m: host.iobroker-pi no instances found
    2021-11-29 13:21:20.458  - ESC[31merrorESC[39m: host.iobroker-pi uncaught exception: doc.rows is not iterable
    2021-11-29 13:21:20.460  - ESC[31merrorESC[39m: host.iobroker-pi TypeError: doc.rows is not iterable
    • K Kindsy
      Hardwaresystem: Pi3
      Nodejs-Version: k.A
      Image genutzt: Ja
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @kindsy sagte in Iobroker restartet alle 10 sekunden.....:
      Cannot read system.config: null (OK when migrating or restoring)>
      Gehe mal hiernach :
      https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host
      K 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Gehe mal hiernach :
        Kindsy
        @glasfaser danke fpür den Tipp
        Aber leider sind die alle gleich groß, ich hab wohl schon länger nicht mehr rein geschaut....
        Noch weitere Ideen?
        Wie zB. die Images unter VIS retten, da hab ich schon ein paar Tage reingesteckt und alle Homematic Aktoren eingetragen....
        Aber vielleicht lerne ich so, dass ich immer nach dem finalisieren ein Backup mach.. :-(
        Thomas BraunT K 2 Antworten Letzte Antwort
        • K Kindsy
          Noch weitere Ideen?
          Zeig mal was da so alles drin liegt.
          • K Kindsy
            Noch weitere Ideen?
            Kindsy
            @kindsy ich hab noch zwei files gefunden die nmA auf den Zeitpunkt hindeuten....
            -rw-rw-r--+ 1 iobroker iobroker 0 Nov 11 10:19 states.json.broken
            -rw-rw-r--+ 1 iobroker iobroker 0 Nov 11 10:18 objects.json.broken
            Aber leider gehen meine Backups nur bis zum 27.11
            K Thomas BraunT 2 Antworten Letzte Antwort
            • K Kindsy
              Kindsy
              @kindsy
              Anfang:
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:27 2021-11-27_14-27_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 481 Nov 27 14:27 2021-11-27_14-27_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:28 2021-11-27_14-28_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 459 Nov 27 14:28 2021-11-27_14-28_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:29 2021-11-27_14-29_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 476 Nov 27 14:29 2021-11-27_14-29_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:30 2021-11-27_14-30_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 489 Nov 27 14:30 2021-11-27_14-30_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:31 2021-11-27_14-31_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 486 Nov 27 14:31 2021-11-27_14-31_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:32 2021-11-27_14-32_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 481 Nov 27 14:32 2021-11-27_14-32_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:33 2021-11-27_14-33_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 447 Nov 27 14:33 2021-11-27_14-33_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:34 2021-11-27_14-34_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 479 Nov 27 14:34 2021-11-27_14-34_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:35 2021-11-27_14-35_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 480 Nov 27 14:35 2021-11-27_14-35_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:36 2021-11-27_14-36_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 477 Nov 27 14:36 2021-11-27_14-36_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:37 2021-11-27_14-37_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 477 Nov 27 14:37 2021-11-27_14-37_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:38 2021-11-27_14-38_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 465 Nov 27 14:38 2021-11-27_14-38_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:39 2021-11-27_14-39_objects.json.gz
              Bis heute
              -rw-rw-r--+ 1 iobroker iobroker 477 Nov 29 14:19 2021-11-29_14-19_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:20 2021-11-29_14-20_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 465 Nov 29 14:20 2021-11-29_14-20_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:21 2021-11-29_14-21_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 467 Nov 29 14:21 2021-11-29_14-21_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:22 2021-11-29_14-22_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 469 Nov 29 14:22 2021-11-29_14-22_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:23 2021-11-29_14-23_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 457 Nov 29 14:23 2021-11-29_14-23_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:24 2021-11-29_14-24_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 468 Nov 29 14:24 2021-11-29_14-24_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:25 2021-11-29_14-25_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 478 Nov 29 14:25 2021-11-29_14-25_states.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:26 2021-11-29_14-26_objects.json.gz
              -rw-rw-r--+ 1 iobroker iobroker 483 Nov 29 14:26 2021-11-29_14-26_states.json.gz
              • K Kindsy
                @kindsy
                Ja, das könnte sein.
                Dann zückst du jetzt dein reguläres Backup von vor dem 11.11. 10:19 und spielst das wieder ein.
                Bitte Ausgaben aus der Konsole in CodeTags setzen. Danke.
                  @kindsy
                  Kindsy
                  @thomas-braun Macht der das automatich, das Backup mein ich.....
                  Ich hab natürlich leider keines gemacht nachdem ich mit der Konfig fertig war
                  • K Kindsy
                    @kindsy
                    Anfang:
                    Bis heute
                    @kindsy
                    Da ist nix brauchbares bei, fürchte ich. Alles zu klein, im Normalfall.
                      @kindsy
                      Kindsy
                      @thomas-braun Alles neu macht der November :-(
                      Danke trotzdem für die schnelle Antwort
                      • K Kindsy
                        Wenn man seinen Backitup-Adapter so einstellt ja.
                        Wobei meine Backups auch keine 18 Tage zurückgingen. Das System muss sich aber eigentlich seither merkwürdig verhalten haben. Da hättest du schneller reagieren müssen/können.
                          Kindsy
                          @thomas-braun ich verwende den iobroker nur für Homematic Visualisierung, deshalb die langsame Reaktionszeit....
                          • K Kindsy
                            dann solltest du dir jetzt die vis-views.json sichern, da sind alle Views drin
                              Kindsy
                              @homoran Danke für den Tipp, jetzt funktionierts größtenteils wieder, du hast mir eine Lawine an Arbeit erspart....
                              DANKE
