Iobroker restartet alle 10 sekunden.....
Systemdata Bitte Ausfüllen Hardwaresystem: Pi3 Arbeitsspeicher: 1GB Festplattenart: SD-Karte Betriebssystem: Debian Node-Version: v12.22.6 Nodejs-Version: k.A NPM-Version: 6.14.15 Installationsart: Flash Image Image genutzt: Ja Ort/Name der Imagedatei: Link Hier noch das Logfile:
at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27) 2021-11-29 13:21:00.951 - ESC[32minfoESC[39m: host.iobroker-pi iobroker _restart 2021-11-29 13:21:01.012 - ESC[31merrorESC[39m: host.iobroker-pi Cannot write host object:Error: DB closed 2021-11-29 13:21:01.289 - ESC[32minfoESC[39m: host.iobroker-pi terminated 2021-11-29 13:21:09.751 - ESC[32minfoESC[39m: host.iobroker-pi iobroker.js-controller version 3.3.18 js-controller starting 2021-11-29 13:21:09.770 - ESC[32minfoESC[39m: host.iobroker-pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker 2021-11-29 13:21:09.772 - ESC[32minfoESC[39m: host.iobroker-pi hostname: iobroker-pi, node: v12.22.6 2021-11-29 13:21:09.774 - ESC[32minfoESC[39m: host.iobroker-pi ip addresses: 192.168.125.4 fe80::5ef0:1324:ff76:1cd5 2021-11-29 13:21:10.131 - ESC[31merrorESC[39m: host.iobroker-pi Cannot read system.config: null (OK when migrating or restoring) 2021-11-29 13:21:10.383 - ESC[32minfoESC[39m: host.iobroker-pi connected to Objects and States 2021-11-29 13:21:10.474 - ESC[32minfoESC[39m: host.iobroker-pi added notifications configuration of host 2021-11-29 13:21:10.584 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance" 2021-11-29 13:21:10.587 - ESC[31merrorESC[39m: host.iobroker-pi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system" 2021-11-29 13:21:10.650 - ESC[32minfoESC[39m: host.iobroker-pi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system 2021-11-29 13:21:10.673 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "host" 2021-11-29 13:21:10.708 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "state" 2021-11-29 13:21:10.710 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance" 2021-11-29 13:21:10.715 - ESC[31merrorESC[39m: host.iobroker-pi Could not collect system.host.iobroker-pi states to check for obsolete states: Error: Cannot find view "system" 2021-11-29 13:21:10.718 - ESC[31merrorESC[39m: host.iobroker-pi _design/system missing - call node iobroker.js setup 2021-11-29 13:21:10.719 - ESC[32minfoESC[39m: host.iobroker-pi no instances found 2021-11-29 13:21:10.731 - ESC[31merrorESC[39m: host.iobroker-pi uncaught exception: doc.rows is not iterable 2021-11-29 13:21:10.733 - ESC[31merrorESC[39m: host.iobroker-pi TypeError: doc.rows is not iterable at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27) 2021-11-29 13:21:10.760 - ESC[32minfoESC[39m: host.iobroker-pi iobroker _restart 2021-11-29 13:21:10.821 - ESC[31merrorESC[39m: host.iobroker-pi Cannot write host object:Error: DB closed 2021-11-29 13:21:10.898 - ESC[32minfoESC[39m: host.iobroker-pi terminated 2021-11-29 13:21:19.450 - ESC[32minfoESC[39m: host.iobroker-pi iobroker.js-controller version 3.3.18 js-controller starting 2021-11-29 13:21:19.469 - ESC[32minfoESC[39m: host.iobroker-pi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker 2021-11-29 13:21:19.472 - ESC[32minfoESC[39m: host.iobroker-pi hostname: iobroker-pi, node: v12.22.6 2021-11-29 13:21:19.474 - ESC[32minfoESC[39m: host.iobroker-pi ip addresses: 192.168.125.4 fe80::5ef0:1324:ff76:1cd5 2021-11-29 13:21:19.835 - ESC[31merrorESC[39m: host.iobroker-pi Cannot read system.config: null (OK when migrating or restoring) 2021-11-29 13:21:20.064 - ESC[32minfoESC[39m: host.iobroker-pi connected to Objects and States 2021-11-29 13:21:20.137 - ESC[32minfoESC[39m: host.iobroker-pi added notifications configuration of host 2021-11-29 13:21:20.269 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance" 2021-11-29 13:21:20.272 - ESC[31merrorESC[39m: host.iobroker-pi Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system" 2021-11-29 13:21:20.374 - ESC[32minfoESC[39m: host.iobroker-pi Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system 2021-11-29 13:21:20.397 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "host" 2021-11-29 13:21:20.428 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "state" 2021-11-29 13:21:20.430 - ESC[31merrorESC[39m: host.iobroker-pi Cannot find view "system" for search "instance" 2021-11-29 13:21:20.441 - ESC[31merrorESC[39m: host.iobroker-pi Could not collect system.host.iobroker-pi states to check for obsolete states: Error: Cannot find view "system" 2021-11-29 13:21:20.444 - ESC[31merrorESC[39m: host.iobroker-pi _design/system missing - call node iobroker.js setup 2021-11-29 13:21:20.446 - ESC[32minfoESC[39m: host.iobroker-pi no instances found 2021-11-29 13:21:20.458 - ESC[31merrorESC[39m: host.iobroker-pi uncaught exception: doc.rows is not iterable 2021-11-29 13:21:20.460 - ESC[31merrorESC[39m: host.iobroker-pi TypeError: doc.rows is not iterable at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2863:27)MOD-EDIT: Code in code-tags gesetzt!
@kindsy sagte in Iobroker restartet alle 10 sekunden.....:
Cannot read system.config: null (OK when migrating or restoring)>
Cannot find view "system" for search "instance"Gehe mal hiernach :
https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host
@glasfaser danke fpür den Tipp
Aber leider sind die alle gleich groß, ich hab wohl schon länger nicht mehr rein geschaut....
Noch weitere Ideen?
Wie zB. die Images unter VIS retten, da hab ich schon ein paar Tage reingesteckt und alle Homematic Aktoren eingetragen....
Aber vielleicht lerne ich so, dass ich immer nach dem finalisieren ein Backup mach.. :-( -
Noch weitere Ideen?
Aber vielleicht lerne ich so, dass ich immer nach dem finalisieren ein Backup mach.. :-(@kindsy sagte in Iobroker restartet alle 10 sekunden.....:
Zeig mal was da so alles drin liegt.
Noch weitere Ideen?
Aber vielleicht lerne ich so, dass ich immer nach dem finalisieren ein Backup mach.. :-(@kindsy ich hab noch zwei files gefunden die nmA auf den Zeitpunkt hindeuten....
-rw-rw-r--+ 1 iobroker iobroker 0 Nov 11 10:19 states.json.broken
-rw-rw-r--+ 1 iobroker iobroker 0 Nov 11 10:18 objects.json.brokenAber leider gehen meine Backups nur bis zum 27.11
Anfang:
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:27 2021-11-27_14-27_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 481 Nov 27 14:27 2021-11-27_14-27_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:28 2021-11-27_14-28_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 459 Nov 27 14:28 2021-11-27_14-28_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:29 2021-11-27_14-29_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 476 Nov 27 14:29 2021-11-27_14-29_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:30 2021-11-27_14-30_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 489 Nov 27 14:30 2021-11-27_14-30_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:31 2021-11-27_14-31_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 486 Nov 27 14:31 2021-11-27_14-31_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:32 2021-11-27_14-32_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 481 Nov 27 14:32 2021-11-27_14-32_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:33 2021-11-27_14-33_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 447 Nov 27 14:33 2021-11-27_14-33_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:34 2021-11-27_14-34_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 479 Nov 27 14:34 2021-11-27_14-34_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:35 2021-11-27_14-35_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 480 Nov 27 14:35 2021-11-27_14-35_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:36 2021-11-27_14-36_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 477 Nov 27 14:36 2021-11-27_14-36_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:37 2021-11-27_14-37_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 477 Nov 27 14:37 2021-11-27_14-37_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:38 2021-11-27_14-38_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 465 Nov 27 14:38 2021-11-27_14-38_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 27 14:39 2021-11-27_14-39_objects.json.gzBis heute
-rw-rw-r--+ 1 iobroker iobroker 477 Nov 29 14:19 2021-11-29_14-19_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:20 2021-11-29_14-20_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 465 Nov 29 14:20 2021-11-29_14-20_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:21 2021-11-29_14-21_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 467 Nov 29 14:21 2021-11-29_14-21_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:22 2021-11-29_14-22_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 469 Nov 29 14:22 2021-11-29_14-22_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:23 2021-11-29_14-23_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 457 Nov 29 14:23 2021-11-29_14-23_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:24 2021-11-29_14-24_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 468 Nov 29 14:24 2021-11-29_14-24_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:25 2021-11-29_14-25_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 478 Nov 29 14:25 2021-11-29_14-25_states.json.gz
-rw-rw-r--+ 1 iobroker iobroker 1.1K Nov 29 14:26 2021-11-29_14-26_objects.json.gz
-rw-rw-r--+ 1 iobroker iobroker 483 Nov 29 14:26 2021-11-29_14-26_states.json.gz -
Ja, das könnte sein.
Dann zückst du jetzt dein reguläres Backup von vor dem 11.11. 10:19 und spielst das wieder ein.Bitte Ausgaben aus der Konsole in CodeTags setzen. Danke.
@thomas-braun Macht der das automatich, das Backup mein ich.....
Ich hab natürlich leider keines gemacht nachdem ich mit der Konfig fertig war -
Anfang:
-rw-rw-r--+ 1 iobroker iobroker 483 Nov 29 14:26 2021-11-29_14-26_states.json.gzDa ist nix brauchbares bei, fürchte ich. Alles zu klein, im Normalfall.
@thomas-braun Alles neu macht der November :-(
Danke trotzdem für die schnelle Antwort -
Ich hab natürlich leider keines gemacht nachdem ich mit der Konfig fertig war@kindsy sagte in Iobroker restartet alle 10 sekunden.....:
Wenn man seinen Backitup-Adapter so einstellt ja.
Wobei meine Backups auch keine 18 Tage zurückgingen. Das System muss sich aber eigentlich seither merkwürdig verhalten haben. Da hättest du schneller reagieren müssen/können. -
Wobei meine Backups auch keine 18 Tage zurückgingen. Das System muss sich aber eigentlich seither merkwürdig verhalten haben. Da hättest du schneller reagieren müssen/können.@thomas-braun ich verwende den iobroker nur für Homematic Visualisierung, deshalb die langsame Reaktionszeit....
dann solltest du dir jetzt die vis-views.json sichern, da sind alle Views drin
