  4. Node-Red
  5. [gelöst] Umwandlung von Objekt in String
    6.5k
22 Beiträge 3 Kommentatoren 907 Aufrufe 3 Beobachtet
  • mickymM mickym
    @claus1985-0 sagte in Umwandlung von Objekt in String:
    Jetzt gibt er mir beim Einschalten auch teilweise nur ON = true ohne Brightness aus..
    Es gibt also wohl beide Fälle.
    Ok dann kannst auch die Brightness setzen - dann wird sie mit der nächsten Brightness ggf. auf den richtigen Wert über schrieben. Dann macht man einen Trigger hinten dran. Ich machs mal kurz.
           "id": "78e5c88c.0d9b08",
           "type": "switch",
           "z": "a37484bb.f4a9e8",
           "name": "",
           "property": "payload.On",
           "propertyType": "msg",
           "rules": [
                   "t": "true"
                   "t": "false"
                   "t": "else"
           "checkall": "true",
           "repair": false,
           "outputs": 3,
           "x": 450,
           "y": 1780,
           "wires": [
                   "8b24d14b.fc4a7"
                   "648496f9.de89d8"
                   "39869018.4b8c4"
           "id": "d85d77b3.309d98",
           "type": "inject",
           "name": "Helligkeit geändert",
           "props": [
                   "p": "payload.Brightness",
                   "v": "45",
                   "vt": "num"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payloadType": "str",
           "x": 210,
           "y": 1700,
           "wires": [
                   "78e5c88c.0d9b08"
           "id": "4a5abaae.3d7494",
           "type": "inject",
           "name": "Ein",
           "props": [
                   "p": "payload.On",
                   "v": "true",
                   "vt": "bool"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 260,
           "y": 1780,
           "wires": [
                   "78e5c88c.0d9b08"
           "id": "d4e38a8d.f33978",
           "type": "inject",
           "name": "Aus",
           "props": [
                   "p": "payload.On",
                   "v": "false",
                   "vt": "bool"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 260,
           "y": 1820,
           "wires": [
                   "78e5c88c.0d9b08"
           "id": "3fe1f543.71321a",
           "type": "inject",
           "props": [
                   "v": "100",
                   "vt": "num"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "x": 210,
           "y": 1740,
           "wires": [
                   "78e5c88c.0d9b08"
           "id": "648496f9.de89d8",
           "type": "change",
           "name": "=0",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "0",
                   "tot": "num"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 1760,
           "wires": [
                   "5590f91.34c2208"
           "id": "39869018.4b8c4",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.Brightness",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 630,
           "y": 1800,
           "wires": [
                   "5590f91.34c2208"
           "id": "8b24d14b.fc4a7",
           "type": "change",
           "name": "=100",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "100",
                   "tot": "num"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 670,
           "y": 1720,
           "wires": [
                   "5590f91.34c2208"
           "id": "5590f91.34c2208",
           "type": "trigger",
           "name": "",
           "op1": "",
           "op2": "",
           "op1type": "nul",
           "op2type": "payl",
           "duration": "100",
           "extend": true,
           "overrideDelay": false,
           "units": "ms",
           "reset": "",
           "bytopic": "all",
           "topic": "topic",
           "outputs": 1,
           "x": 850,
           "y": 1760,
           "wires": [
                   "3714948f.7669bc"
           "id": "3714948f.7669bc",
           "type": "debug",
           "name": "Ergebnis",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 1020,
           "y": 1760,
           "wires": []
    Wenn man das mit Inject Nodes testen will muss man es halt auf 1 s hoch setzen. Wenn aber von der Node 2 Nachrichten kommen, sollten 100s vielleicht ausreichen - ansonsten den Wert halt auf 250 ms erhöhen.
    Claus1985 0C Offline
    Claus1985 0
    @mickym Funktioniert perfekt, danke Dir!!
    • Claus1985 0C Claus1985 0
      mickymM Offline
      mickymM Offline
      mickym
      Freut mich! Vielleicht ist NodeRed ohne 20 Programmzeilen doch einfacher. ;)
