  4. Fehler bei Neuinstallation (File index.html not found)
    6.4k
46 Beiträge 4 Kommentatoren 4.7k Aufrufe 3 Beobachtet
  • S Shiro82
    Ich als NOOB Linux auskenner habe das als Fehler interpretiert. Habt bitte Nachsicht. Ich bin doch nur ein Datacenter Windows Admin :)
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:179:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:89:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    im IoBroker GUI habe ich aber auch gleich wieder Fehler:
    admin.0 8291	2021-10-31 18:08:26.708	error	error
    admin.0 8291	2021-10-31 18:08:26.694	error	failed connection to socket.io from ::ffff:192.168.2.125:
    admin.0 8291	2021-10-31 18:08:23.671	info	Use link "http://localhost:8081" to configure.
    admin.0 8291	2021-10-31 18:08:23.669	info	http server listening on port 8081
    admin.0 8291	2021-10-31 18:08:23.267	info	received all objects
    admin.0 8291	2021-10-31 18:08:22.709	info	requesting all objects
    admin.0 8291	2021-10-31 18:08:22.708	info	requesting all states
    admin.0 8291	2021-10-31 18:08:22.627	info	starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.7, js-controller: 3.3.18
    host.iobroker 2021-10-31 18:08:19.060	info	instance system.adapter.admin.0 started with pid 8291
    host.iobroker 2021-10-31 18:08:16.593	info	instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    admin.0 8150	2021-10-31 18:08:15.975	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    admin.0 8150	2021-10-31 18:08:15.972	info	terminating
    admin.0 8150	2021-10-31 18:08:15.970	info	terminating http server on port 8081
    host.iobroker 2021-10-31 18:08:15.968	info	stopInstance system.adapter.admin.0 send kill signal
    admin.0 8150	2021-10-31 18:08:15.959	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker 2021-10-31 18:08:15.937	info	stopInstance system.adapter.admin.0 (force=false, process=true)
    host.iobroker 2021-10-31 18:06:55.563	info	Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
    backitup.0 8217	2021-10-31 18:04:39.624	info	[iobroker] backup was activated at 02:40 every 1 day(s)
    backitup.0 8217	2021-10-31 18:04:39.520	info	starting. Version 2.1.17 in /opt/iobroker/node_modules/iobroker.backitup, node: v12.22.7, js-controller: 3.3.18
    host.iobroker 2021-10-31 18:04:36.575	info	instance system.adapter.backitup.0 started with pid 8217
    discovery.0 8202	2021-10-31 18:04:35.481	info	starting. Version 2.7.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v12.22.7, js-controller: 3.3.18
    admin.0 8150	2021-10-31 18:04:32.888	warn	Repository cannot be read
    admin.0 8150	2021-10-31 18:04:32.872	info	State value to set for "admin.0.info.lastUpdateCheck" has to be type "number" but received type "string"
    admin.0 8150	2021-10-31 18:04:32.799	info	Use link "http://localhost:8081" to configure.
    admin.0 8150	2021-10-31 18:04:32.797	info	http server listening on port 8081
    admin.0 8150	2021-10-31 18:04:32.659	info	received all objects
    host.iobroker 2021-10-31 18:04:32.605	info	instance system.adapter.discovery.0 started with pid 8202
    admin.0 8150	2021-10-31 18:04:32.478	info	requesting all objects
    admin.0 8150	2021-10-31 18:04:32.476	info	requesting all states
    admin.0 8150	2021-10-31 18:04:32.392	info	starting. Version 5.1.25 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.7, js-controller: 3.3.18
    host.iobroker 2021-10-31 18:04:28.628	info	instance system.adapter.admin.0 started with pid 8150
    host.iobroker 2021-10-31 18:04:28.532	info	starting 3 instances
    host.iobroker 2021-10-31 18:04:28.509	info	3 instances found
    host.iobroker 2021-10-31 18:04:27.950	info	added notifications configuration of host
    host.iobroker 2021-10-31 18:04:27.829	info	connected to Objects and States
    host.iobroker 2021-10-31 18:04:27.481	info	ip addresses: 192.168.2.18 2003:cd:a715:c600:172d:c79:1684:c4f9 fe80::9aca:51b0:278d:30d4 192.168.2.24 2003:cd:a715:c600:4f68:a037:426a:1eaf fe80::9814:f5d6:f9fe:a2b9
    host.iobroker 2021-10-31 18:04:27.479	info	hostname: iobroker, node: v12.22.7
    host.iobroker 2021-10-31 18:04:27.478	info	Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    @shiro82
    Du scheinst da einen Knoten in deinem Netzwerk zu haben.
    iobroker list instances
    ioBroker-Admin mit Verschlüsselung/Zertifikaten aufgesetzt?
      @shiro82
      Shiro82
      @thomas-braun sagte in Fehler bei Neuinstallation (File index.html not found):
      das ist eine Einfache Fritzbox wo nichts drauf konfiguriert ist. ich wüsste nicht was da nicht richtig sein soll.
      Es ist auch keine Verschlüsselung oder ein Zertifikat drauf.
      pi@iobroker:~ $ iobroker list instances
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + instance is alive
      • S Shiro82
        + instance is alive
        @shiro82
        iobroker als Hostname ist jetzt auch nicht optimal.
        Kommst du denn jetzt auf das Webinterface drauf?
          @shiro82
          Shiro82
          ja die UI Funktioniert. mit Fehler im LOG
          • S Shiro82
            @shiro82
            Welcher denn???
              @shiro82
              Welcher denn???
              HomoranH Offline
              HomoranH Offline
              Welcher denn???
              Geheim!
                Welcher denn???
                Geheim!
                Shiro82
                @homoran @thomas-braun
                aber das hatte ich doch oben geschrieben ihr lieben :/
                • S Shiro82
                  @shiro82
                  Erstmal wurscht.
                  iobroker update -i
                  liefert?
                  Bitte Konsolentext in CodeTags einbetten.
                    @shiro82
                    Erstmal wurscht.
                    iobroker update -i
                    liefert?
                    Shiro82
                    iobroker update -i
                    pi@iobroker:~ $ iobroker update -i
                    Used repository: default
                    hash unchanged, use cached sources
                    update done
                    Adapter    "admin"         : 5.1.25   , installed 5.1.25
                    Adapter    "backitup"      : 2.1.17   , installed 2.1.17
                    Adapter    "discovery"     : 2.7.0    , installed 2.7.0
                    Controller "js-controller" : 3.3.18   , installed 3.3.18
                    pi@iobroker:~ $
                    • S Shiro82
                      iobroker update -i
                      update done
                      pi@iobroker:~ $
                      @shiro82
                      Kein Problem, weiter machen.
                      • S Shiro82
                        iobroker update -i
                        update done
                        pi@iobroker:~ $
                        HomoranH Offline
                        HomoranH Offline
                        @Thomas-Braun
                        @shiro82 sagte in Fehler bei Neuinstallation (File index.html not found):
                        ist das nicht für eine nagelneue Installation etwas seltsam?
                        ich mach das jetzt noch einmal.
                        Müsste es nicht stable oder stable(default) heißen?
                        irgendwas läuft hier schief
                          @Thomas-Braun
                          Shiro82
                          finde ich auch Komisch.
                          ich habe nun NOCH EINMAL das PI OS Lite image auf die karte kopiert und dann nur den einen Befehl
                          curl -sLf https://iobroker.net/install.sh | bash -
                          ausgeführt.
                          und trotzdem bekomme ich im IoBroker GUI Fehler über den Host:
                          admin.0 2021-10-31 20:35:22.398 warn Cannot parse "undefined"
                          admin.0 2021-10-31 20:35:22.355 error error
                          admin.0 2021-10-31 20:35:22.346 warn Cannot parse "undefined"
                          • S Shiro82
                            ausgeführt.
                            HomoranH Offline
                            HomoranH Offline
                            welches?
                            32 oder 64 bit?
                              welches?
                              32 oder 64 bit?
                              Gibt nur ein 32bit Image. Alles andere ist noch im Beta.
                                HomoranH Offline
                                HomoranH Offline
                                eben drum!
                                  eben drum!
                                  Mir sagt die
                                  error error
                                  Meldung irgendwas. Hab's aber vergessen was das war. Hat mich nicht betroffen. Hatte glaube ich mit dem verwendeten Browser zu tun.
                                    Mir sagt die
                                    error error
                                    HomoranH Offline
                                    HomoranH Offline
                                    @thomas-braun sagt mir gar nichts, hab nur [object][object] mitbekommen
                                      Mir sagt die
                                      error error
                                      HomoranH Offline
                                      HomoranH Offline
                                      @thomas-braun https://forum.iobroker.net/topic/48699/admin-error-im-log?_=1635710115544
                                        Möglich. Da ich keine Verschlüsselung einsetze: Nicht betroffen.
                                          HomoranH Offline
                                          HomoranH Offline
                                          aber bei Neuinstallation muss man jetzt ein Passwort setzen
