  4. Frage zum Adapter Time-Switch
    2.3k
    4.3k
10 Beiträge 2 Kommentatoren 512 Aufrufe 1 Beobachtet
  • K Offline
    Kippe
    Wie bekomme ich das Widget vom Time Switch Adapter kleiner ?
    Und wie bekomme ich die Schieberegler da weg.
    • K Kippe
      sigi234S Online
      sigi234S Online
      sigi234
      @kippe
      In CSS einfügen und anpassen:
      app-on-off-schedule-widget {
          /* Primary color (button background, toggle switch color) */
          --ts-widget-primary-color: #0070bd;
          /* Background color of the widget */
          --ts-widget-bg-color: #transparent;
          /* Background color of the triggers */
          --ts-widget-trigger-bg-color: #272727;
          /* Foreground color (font color and scrollbar color) */
          --ts-widget-fg-color: white;
          /* Font color of the switched states id */
          --ts-widget-oid-fg-color: #a5a5a5;
          /* Font color in buttons */
          --ts-widget-btn-fg-color: white;
          /* Font color of a disabled weekday */
          --ts-widget-weekdays-disabled-fg-color: #5D5D5D;
          /* Font color of an enabled weekday */
          --ts-widget-weekdays-enabled-fg-color: lime;
          /* Font color of the name of the widget (defaults to --ts-widget-fg-color) */
          --ts-widget-name-fg-color: white;
          /* Font color of switched time (defaults to --ts-widget-fg-color) */
          --ts-widget-switched-time-fg-color: white;
          /* Font color of switched value (defaults to --ts-widget-fg-color)*/
          --ts-widget-switched-value-fg-color: white;
          /* Font color of the astro time (defaults to --ts-widget-fg-color) */
          --ts-widget-astro-time-fg-color: black;
          /* Font color of the astro time's shift */
          --ts-widget-astro-shift-fg-color: #5d5d5d;
          /* Font color of condition (defaults to --ts-widget-fg-color) */
          --ts-widget-condition-fg-color: white;
          /* Font family used in the whole widget */
          --ts-widget-font-family: 'Roboto', 'Segoe UI', BlinkMacSystemFont, system-ui, -apple-system;
          /* Font size of the name of the widget */
          --ts-widget-name-font-size: 1.1em;
          /* Font size of the switched oid */
          --ts-widget-oid-font-size: 10px;
          /* Display of edit name button. Use 'none' to hide the button and 'block' to show it
          --ts-widget-edit-name-button-display: block;
          /* Display of condition. Use 'none' to hide the condition and 'block' to show it
          -ts-widget-condition-display: block;
          /* Applies a filter to icons used in buttons (safe, edit, remove, cancel), for
             white use invert(1) and for black invert(0) */
          --ts-widget-img-btn-filter: invert(1);
          /* Add trigger dropdown background color */
          --ts-widget-add-trigger-dropdown-bg-color: #f1f1f1;
          /* Add trigger dropdown font color */
          --ts-widget-add-trigger-dropdown-fg-color: black;
          /* Add trigger dropdown hover background color */
          --ts-widget-add-trigger-dropdown-hover-bg-color: #ddd;
          /* ! Changing these may break the layout, change at your own risk */
          /* Font size of weekdays */
          --ts-widget-weekdays-font-size: 12px;
          /* Font size of switched value (on/off) */
          --ts-widget-switched-value-font-size: 0.8em;
          /* Font size of switched time */
          --ts-widget-switched-time-font-size: 0.8em;
          /* Font size of the astro time (e.g. Sunrise, ...) */
          --ts-widget-astro-time-font-size: 0.3em;
          /* Font size of the astro time's shift */
          --ts-widget-astro-shift-font-size: 1em;
          /* Font size of condition */
          --ts-widget-condition-font-size: 0.8em;
      Immer Daten sichern!
      K 1 Antwort Letzte Antwort
      • sigi234S sigi234
        @kippe
        Kippe
        @sigi234
        Super das hat schon mal geklappt. Wenn ich den oberen Teil des Widget den Hintergrund auch Schwarz haben möchte, in welcher Zeile muss ich was ändern?
        DANKE sigi234👏
        • K Kippe
          @sigi234
          DANKE sigi234👏
          sigi234S Online
          sigi234S Online
          sigi234
          @kippe sagte in Frage zum Adapter Time-Switch:
          Wo? Was genau?
          • sigi234S sigi234
            Wo? Was genau?
            Kippe
            @sigi234
            Da wo die 2 Schieberegler sind? Da ist der Hintergrund noch Transparent, aber würde den auch gerne schwarz haben
            • K Kippe
              @sigi234
              Kippe
              @kippe so wie in meinem Bild oben
              sigi234S 2 Antworten Letzte Antwort
              • K Kippe
                sigi234S Online
                sigi234S Online
                sigi234
                Screenshot bitte
                • K Kippe
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  --ts-widget-bg-color: black;
                  • sigi234S sigi234
                    Kippe
                    @sigi234
                    Alles Top👍
                    Hat Super geklappt und jetzt passt es auch mit der Größe 🤒
                    • K Kippe
                      @sigi234
                      Alles Top👍
                      sigi234S Online
                      sigi234S Online
                      sigi234
                      @kippe
                      Bitte sehr, Thema als [gelöst] setzten.
