  4. Gelöst: Raspi stirbt nach Backup ab
    6.4k
64 Beiträge 4 Kommentatoren 7.6k Aufrufe 2 Beobachtet
  • S Steinmetz_4
    ich habe das Problem, dass der Raspi 4 ( 8GB, SSD als Datenträger) nach dem Backup hängen bleibt. Ich muss ihn dann morgens stromlos machen und dann läuft er wieder bis zum nächsten Backup.
    2021-10-13 02:30:37.975 - info: host.raspberrypi instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
    2021-10-13 02:30:41.789 - info: daswetter.0 (25820) Terminated (NO_ERROR): Without reason
    2021-10-13 02:30:42.308 - info: daswetter.0 (25820) cleaned everything up...
    2021-10-13 02:30:42.329 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 02:35:00.132 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26139
    2021-10-13 02:35:02.437 - info: dwd.0 (26139) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:35:04.163 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26154
    2021-10-13 02:35:06.958 - info: netatmo-crawler.0 (26154) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:35:07.037 - info: netatmo-crawler.0 (26154) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:35:07.187 - info: dwd.0 (26139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:35:07.727 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:35:09.214 - info: netatmo-crawler.0 (26154) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:35:09.373 - info: netatmo-crawler.0 (26154) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:35:09.912 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:35:53.765 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 02:40:00.115 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26398
    2021-10-13 02:40:02.416 - info: netatmo-crawler.0 (26398) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:40:02.484 - info: netatmo-crawler.0 (26398) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:40:02.744 - info: netatmo-crawler.0 (26398) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:40:02.908 - info: netatmo-crawler.0 (26398) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:40:03.449 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:40:04.166 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26413
    2021-10-13 02:40:06.352 - info: dwd.0 (26413) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:40:07.757 - info: dwd.0 (26413) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:40:08.313 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:00.205 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26670
    2021-10-13 02:45:02.880 - info: dwd.0 (26670) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:04.241 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26685
    2021-10-13 02:45:07.437 - info: netatmo-crawler.0 (26685) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:07.533 - info: netatmo-crawler.0 (26685) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:45:07.688 - info: dwd.0 (26670) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:45:07.860 - info: netatmo-crawler.0 (26685) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:45:08.037 - info: netatmo-crawler.0 (26685) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:45:08.223 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:08.272 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 26700
    2021-10-13 02:45:08.576 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:10.785 - info: daswetter.0 (26700) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:12.303 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 26715
    2021-10-13 02:45:15.331 - info: coronavirus-statistics.0 (26715) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:45:27.603 - info: coronavirus-statistics.0 (26715) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-10-13 02:45:28.149 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:45:34.482 - info: daswetter.0 (26700) still wrong data structure from server received! repaired...
    2021-10-13 02:45:40.431 - info: daswetter.0 (26700) Terminated (NO_ERROR): Without reason
    2021-10-13 02:45:40.946 - info: daswetter.0 (26700) cleaned everything up...
    2021-10-13 02:45:40.960 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 02:45:53.759 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 02:50:00.165 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 26961
    2021-10-13 02:50:02.864 - info: netatmo-crawler.0 (26961) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:50:02.964 - info: netatmo-crawler.0 (26961) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:50:03.286 - info: netatmo-crawler.0 (26961) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:50:03.462 - info: netatmo-crawler.0 (26961) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:50:04.018 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:50:04.200 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 26976
    2021-10-13 02:50:06.827 - info: dwd.0 (26976) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:50:08.131 - info: dwd.0 (26976) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:50:08.659 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:55:00.128 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27217
    2021-10-13 02:55:02.903 - info: dwd.0 (27217) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:55:04.163 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27232
    2021-10-13 02:55:07.283 - info: netatmo-crawler.0 (27232) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 02:55:07.376 - info: netatmo-crawler.0 (27232) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 02:55:07.465 - info: dwd.0 (27217) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 02:55:08.025 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:55:08.707 - info: netatmo-crawler.0 (27232) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 02:55:08.875 - info: netatmo-crawler.0 (27232) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 02:55:09.423 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 02:55:53.757 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:00:00.036 - info: javascript.0 (825) script.js.Astro_ausführlich: Astro: Gültige Zeiten: [aktueller Tag: 13] | [nächster Tag: 1] | [Aktualisiert: 0] | Aktuelle Tageszeit: Mitternacht | Kommende Tageszeit: Früher Morgen
    2021-10-13 03:00:00.278 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27477
    2021-10-13 03:00:03.067 - info: netatmo-crawler.0 (27477) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:03.137 - info: netatmo-crawler.0 (27477) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:00:04.251 - info: netatmo-crawler.0 (27477) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:00:04.325 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27492
    2021-10-13 03:00:05.115 - info: netatmo-crawler.0 (27477) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:00:05.676 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:00:06.912 - info: dwd.0 (27492) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:08.364 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 27507
    2021-10-13 03:00:08.793 - info: dwd.0 (27492) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:00:09.343 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:00:10.914 - info: coronavirus-statistics.0 (27507) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:12.408 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 27523
    2021-10-13 03:00:15.514 - info: daswetter.0 (27523) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:16.458 - info: host.raspberrypi instance system.adapter.ical.4 started with pid 27538
    2021-10-13 03:00:20.273 - info: ical.4 (27538) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:20.495 - info: host.raspberrypi instance system.adapter.ical.3 started with pid 27553
    2021-10-13 03:00:21.088 - info: ical.4 (27538) processing URL: calendar1 https://calendar.google.com/calendar/ical/bodb8db8cl9aj6ks81gq0rvsv0%40group.calendar.google.com/private-a297fa24a9c2ccd3c422eab38644d026/basic.ics
    2021-10-13 03:00:21.280 - info: coronavirus-statistics.0 (27507) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-10-13 03:00:21.828 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:00:24.148 - info: ical.3 (27553) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:24.530 - info: host.raspberrypi instance system.adapter.ical.1 started with pid 27568
    2021-10-13 03:00:24.633 - info: ical.3 (27553) processing URL: Tom https://calendar.google.com/calendar/ical/k6qjv6gq9102nheldtj973mdu0%40group.calendar.google.com/private-c35a23b62937bd516a7637b1c02e7941/basic.ics
    2021-10-13 03:00:26.610 - info: ical.4 (27538) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:27.216 - info: host.raspberrypi instance system.adapter.ical.4 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:28.449 - info: ical.1 (27568) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:28.586 - info: host.raspberrypi instance system.adapter.ical.0 started with pid 27628
    2021-10-13 03:00:29.038 - info: ical.1 (27568) processing URL: Schichtplan https://calendar.google.com/calendar/ical/opljlsoo63f4urc934b94kfpr4%40group.calendar.google.com/private-d8521c5f76a79bff0e8c5bfd4a94f90c/basic.ics
    2021-10-13 03:00:29.754 - info: ical.3 (27553) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:30.297 - info: host.raspberrypi instance system.adapter.ical.3 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:32.207 - info: ical.0 (27628) starting. Version 1.11.4 in /opt/iobroker/node_modules/iobroker.ical, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:00:32.949 - info: ical.0 (27628) processing URL: Geburtstage und Termine https://calendar.google.com/calendar/ical/stadlmayrs.strass%40gmail.com/private-505b1877c7abcf82f8d2949452f471f1/basic.ics
    2021-10-13 03:00:34.271 - info: ical.1 (27568) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:34.804 - info: host.raspberrypi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:38.539 - info: ical.0 (27628) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:39.080 - info: host.raspberrypi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:00:42.469 - info: daswetter.0 (27523) still wrong data structure from server received! repaired...
    2021-10-13 03:00:47.938 - info: daswetter.0 (27523) Terminated (NO_ERROR): Without reason
    2021-10-13 03:00:48.454 - info: daswetter.0 (27523) cleaned everything up...
    2021-10-13 03:00:48.470 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:05:00.115 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 27827
    2021-10-13 03:05:02.591 - info: dwd.0 (27827) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:05:04.154 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 27842
    2021-10-13 03:05:07.118 - info: netatmo-crawler.0 (27842) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:05:07.224 - info: netatmo-crawler.0 (27842) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:05:07.371 - info: dwd.0 (27827) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:05:07.527 - info: netatmo-crawler.0 (27842) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:05:07.707 - info: netatmo-crawler.0 (27842) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:05:07.919 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:05:08.249 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:05:53.753 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:09:19.881 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect ECONNREFUSED 192.168.178.84:80
    2021-10-13 03:09:19.899 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:09:45.396 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect EHOSTUNREACH 192.168.178.84:80
    2021-10-13 03:09:45.396 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:09:52.400 - warn: sonnen.0 (1363) [REQUEST] <== Error: connect ECONNREFUSED 192.168.178.84:80
    2021-10-13 03:09:52.400 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:10:00.136 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28084
    2021-10-13 03:10:03.048 - info: netatmo-crawler.0 (28084) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:10:03.125 - info: netatmo-crawler.0 (28084) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:10:03.406 - info: netatmo-crawler.0 (28084) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:10:03.582 - info: netatmo-crawler.0 (28084) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:10:04.126 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:10:04.181 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28099
    2021-10-13 03:10:06.489 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
    \n
    \n
    \n
    Something went wrong
    \n
    sonnen Services not running, yet?
    \n
    Try again
    \n
    \n
    \n\n\n"
    2021-10-13 03:10:06.489 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:10:06.522 - info: dwd.0 (28099) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:10:07.803 - info: dwd.0 (28099) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:10:08.336 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:10:13.494 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
    \n
    \n
    \n
    \n
    \n
    Try again
    \n
    \n
    \n\n\n"
    2021-10-13 03:10:13.494 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:10:20.498 - warn: sonnen.0 (1363) [REQUEST] <== 502 - "\n\n\n\n\n\n\n\n\n\n\n
    \n
    \n
    \n
    \n
    \n
    Try again
    \n
    \n
    \n\n\n"
    2021-10-13 03:10:20.499 - warn: sonnen.0 (1363) [CONNECT] Connection failed
    2021-10-13 03:12:00.092 - info: host.raspberrypi instance system.adapter.weatherunderground.0 started with pid 28208
    2021-10-13 03:12:02.880 - info: weatherunderground.0 (28208) starting. Version 3.3.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:12:11.165 - info: weatherunderground.0 (28208) Terminated (NO_ERROR): Without reason
    2021-10-13 03:12:11.700 - info: host.raspberrypi instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:15:00.142 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28362
    2021-10-13 03:15:02.678 - info: dwd.0 (28362) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:04.186 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28377
    2021-10-13 03:15:07.309 - info: netatmo-crawler.0 (28377) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:07.442 - info: netatmo-crawler.0 (28377) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:15:07.538 - info: dwd.0 (28362) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:15:07.752 - info: netatmo-crawler.0 (28377) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:15:07.932 - info: netatmo-crawler.0 (28377) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:15:08.073 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:15:08.216 - info: host.raspberrypi instance system.adapter.daswetter.0 started with pid 28392
    2021-10-13 03:15:08.473 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:15:10.787 - info: daswetter.0 (28392) starting. Version 3.0.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:12.248 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 started with pid 28407
    2021-10-13 03:15:15.219 - info: coronavirus-statistics.0 (28407) starting. Version 0.8.3 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:15:29.033 - info: coronavirus-statistics.0 (28407) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
    2021-10-13 03:15:29.571 - info: host.raspberrypi instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:15:32.730 - info: daswetter.0 (28392) still wrong data structure from server received! repaired...
    2021-10-13 03:15:38.516 - info: daswetter.0 (28392) Terminated (NO_ERROR): Without reason
    2021-10-13 03:15:39.038 - info: daswetter.0 (28392) cleaned everything up...
    2021-10-13 03:15:39.060 - info: host.raspberrypi instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:15:53.751 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:20:00.078 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28659
    2021-10-13 03:20:02.985 - info: netatmo-crawler.0 (28659) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:20:03.063 - info: netatmo-crawler.0 (28659) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:20:03.380 - info: netatmo-crawler.0 (28659) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:20:03.563 - info: netatmo-crawler.0 (28659) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:20:04.129 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28674
    2021-10-13 03:20:04.135 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:20:06.718 - info: dwd.0 (28674) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:20:08.255 - info: dwd.0 (28674) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:20:08.786 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:20:51.839 - warn: telegram.0 (706) polling_error: EFATAL, EFATAL: Error: read ECONNRESET
    2021-10-13 03:21:16.837 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 error: Error: read ECONNRESET
    2021-10-13 03:21:16.882 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 closed: null
    2021-10-13 03:21:16.885 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 error: Error: read ECONNRESET
    2021-10-13 03:21:16.890 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 closed: null
    2021-10-13 03:21:17.214 - error: worx.0 (1475) MQTT ERROR: Error: read ECONNRESET
    2021-10-13 03:21:21.882 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 reconnected
    2021-10-13 03:21:21.907 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 reconnected
    2021-10-13 03:21:22.090 - info: meross.0 (934) Device: 2007226276811490821748e1e9264b44 connected
    2021-10-13 03:21:22.097 - info: meross.0 (934) Device: 2007220281502290821748e1e9264585 connected
    2021-10-13 03:21:42.096 - warn: meross.0 (934) Can not get Abilities for Device 2007226276811490821748e1e9264b44: Error: Timeout / undefined
    2021-10-13 03:21:42.099 - warn: meross.0 (934) Can not get Abilities for Device 2007220281502290821748e1e9264585: Error: Timeout / undefined
    2021-10-13 03:23:00.099 - info: host.raspberrypi instance system.adapter.openweathermap.0 started with pid 28825
    2021-10-13 03:23:02.594 - info: openweathermap.0 (28825) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:23:07.978 - info: openweathermap.0 (28825) Terminated (NO_ERROR): Without reason
    2021-10-13 03:23:08.511 - info: host.raspberrypi instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2021-10-13 03:25:00.108 - info: host.raspberrypi instance system.adapter.dwd.0 started with pid 28931
    2021-10-13 03:25:02.642 - info: dwd.0 (28931) starting. Version 2.7.7 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:25:04.164 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 started with pid 28946
    2021-10-13 03:25:07.154 - info: netatmo-crawler.0 (28946) starting. Version 0.5.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v12.22.6, js-controller: 3.3.18
    2021-10-13 03:25:07.250 - info: netatmo-crawler.0 (28946) Getting data for stationid:70:ee:50:53:56:8c
    2021-10-13 03:25:07.309 - info: dwd.0 (28931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-10-13 03:25:07.773 - info: netatmo-crawler.0 (28946) Getting data for stationid:70:ee:50:06:8d:74
    2021-10-13 03:25:07.845 - info: host.raspberrypi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:25:09.480 - info: netatmo-crawler.0 (28946) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
    2021-10-13 03:25:10.011 - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-10-13 03:25:53.748 - info: knx.0 (1505) State value to set for "knx.0.Datum_Uhrzeit.Datum_und_Uhrzeit.Datum_und_Uhrzeit_Ip-Interface" has to be one of type "string", "number", "boolean" but received type "object"
    2021-10-13 03:17:17.743 - info: host.raspberrypi iobroker.js-controller version 3.3.18 js-controller starting
    2021-10-13 03:17:17.748 - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-10-13 03:17:17.749 - info: host.raspberrypi hostname: raspberrypi, node: v12.22.6
    2021-10-13 03:17:17.750 - info: host.raspberrypi ip addresses: 192.168.178.185 fe80::8570:e996:c644:2cf9
    2021-10-13 03:17:18.625 - info: host.raspberrypi connected to Objects and States
    2021-10-13 03:17:18.729 - info: host.raspberrypi added notifications configuration of host
    2021-10-13 03:17:19.830 - info: host.raspberrypi 65 instances found
    2021-10-13 03:17:19.935 - info: host.raspberrypi starting 43 instances
    2021-10-13 03:17:20.077 - info: host.raspberrypi instance system.adapter.admin.0 started with pid 647
    2021-10-13 03:17:21.877 - error: admin.0 (647) admin.0 already running
    2021-10-13 03:17:21.880 - warn: admin.0 (647) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:22.561 - error: host.raspberrypi instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:22.562 - info: host.raspberrypi Restart adapter system.adapter.admin.0 because enabled
    2021-10-13 03:17:24.583 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 658
    2021-10-13 03:17:27.188 - error: javascript.0 (658) javascript.0 already running
    2021-10-13 03:17:27.191 - warn: javascript.0 (658) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:27.864 - error: host.raspberrypi instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:27.866 - info: host.raspberrypi Restart adapter system.adapter.javascript.0 because enabled
    2021-10-13 03:17:28.052 - info: host.raspberrypi instance system.adapter.node-red.0 started with pid 669
    2021-10-13 03:17:29.240 - error: node-red.0 (669) node-red.0 already running
    2021-10-13 03:17:29.242 - warn: node-red.0 (669) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:29.848 - error: host.raspberrypi instance system.adapter.node-red.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:29.849 - info: host.raspberrypi Restart adapter system.adapter.node-red.0 because enabled
    2021-10-13 03:17:32.101 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 680
    2021-10-13 03:17:34.086 - error: telegram.0 (680) telegram.0 already running
    2021-10-13 03:17:34.088 - warn: telegram.0 (680) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2021-10-13 03:17:34.695 - error: host.raspberrypi instance system.adapter.telegram.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2021-10-13 03:17:34.696 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
    Auf dem Pi sieht das ganze dann so aus:
    Was läuft hier falsch?
    Mfg
    Tom
    #61
    @steinmetz_4 sagte in Gelöst: Raspi stirbt nach Backup ab:
    ich muss ihn dann morgens stromlos machen
    Und das hat jetzt deine Dateien geschreddert.
    Du meinst ja nichts geändert zu haben.
    Und wenn hier etwas hin ist, dann kann in deiner gesamten Installation jede einzelne Datei irgendwo einen Fehler haben.
    Irgendwann wird es dann einen seltsamen, nicht mehr nachvollziehbaren Fehler geben.
    • GlasfaserG Glasfaser
      @steinmetz_4
      Mache mal ein :
      iobroker upload all
      sudo reboot
      Steinmetz_4
      #62
      Was genau habe ich damit gemacht?
      iobroker upload all
      sudo reboot
      Raspi 4 mit aktuellem IoBroker Master (The Brain)
      Raspi 4 mit aktuellem IoBroker Slave und DS18b20 für Warmwasser und Pufferspeicher
      Raspi 4 mit aktuellem Motioneye
      3 x Heizstab zur PV-Eigenverbrauchsoptimierung
      ETS 5 Professionel - 5.7.5
      Samsung Tab 2 - 10.1
      Buskomponenten von MDT
        Steinmetz_4
        #63
        Ich hab ja jetzt alles neu aufgesetzt.
        Alle Datenpunkte neu vergeben und, und, und.
        Ich bin zuversichtlich.
        • S Steinmetz_4
          iobroker upload all
          sudo reboot
          #64
          @steinmetz_4 Damit kopierst du die Installationsdateien der Adapter in die Instanzen.
          https://www.iobroker.net/#de/documentation/tutorial/adapter.md
