  4. ioBroker Neustarts - States database error: read ECONNRESET
    6.6k
3 Beiträge 2 Kommentatoren 1.7k Aufrufe 2 Beobachtet
  • C Offline
    civi
    Guten Morgen,
    seit dieser Nacht (also ohne, dass ich irgend etwas am System geändert habe) startet der ioBroker-Prozess immer wieder neu.
    Mein System:
    aktuelles Ubuntu 20.04.2 als Proxmox Container mit 4GB Ram
    node Version 12.22.5
    npm Version 6.14.14
    Ich habe versucht, fast alle genutzten Adapter zu deaktivieren, anscheinend ändert das aber nichts. Die Fehlermeldungen im Log sind jetzt noch:
    2021-08-14 08:15:49.900  - info: host.6ad907f78bd1 iobroker.js-controller version 3.3.15 js-controller starting
    2021-08-14 08:15:49.901  - info: host.6ad907f78bd1 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-08-14 08:15:49.901  - info: host.6ad907f78bd1 hostname: 6ad907f78bd1, node: v12.22.5
    2021-08-14 08:15:49.901  - info: host.6ad907f78bd1 ip addresses: 192.168.1.12
    2021-08-14 08:15:50.352  - info: host.6ad907f78bd1 connected to Objects and States
    2021-08-14 08:15:50.465  - info: host.6ad907f78bd1 added notifications configuration of host
    2021-08-14 08:15:50.730  - info: host.6ad907f78bd1 66 instances found
    2021-08-14 08:15:50.762  - info: host.6ad907f78bd1 starting 14 instances
    2021-08-14 08:15:50.824  - info: host.6ad907f78bd1 instance system.adapter.admin.0 started with pid 3475
    2021-08-14 08:15:51.392  - info: admin.0 (3475) starting. Version 5.1.23 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:15:51.405  - info: admin.0 (3475) requesting all states
    2021-08-14 08:15:51.405  - info: admin.0 (3475) requesting all objects
    2021-08-14 08:15:52.163  - info: admin.0 (3475) received all objects
    2021-08-14 08:15:52.282  - info: admin.0 (3475) http server listening on port 8081
    2021-08-14 08:15:52.283  - info: admin.0 (3475) Use link "http://localhost:8081" to configure.
    2021-08-14 08:15:54.846  - info: host.6ad907f78bd1 instance system.adapter.tr-064.0 started with pid 3494
    2021-08-14 08:15:55.427  - info: tr-064.0 (3494) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:15:58.809  - info: host.6ad907f78bd1 instance system.adapter.web.0 started with pid 3512
    2021-08-14 08:15:59.300  - info: web.0 (3512) starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:15:59.408  - error: web.0 (3512) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    2021-08-14 08:15:59.441  - info: web.0 (3512) Secure socket.io server listening on port 8082
    2021-08-14 08:15:59.442  - info: web.0 (3512) https server listening on port 8082
    2021-08-14 08:15:59.495  - info: web.0 (3512) ==>Connected system.user.admin from ::ffff:192.168.1.21
    2021-08-14 08:16:35.976  - error: web.0 (3512) States database error: read ECONNRESET
    2021-08-14 08:16:35.977  - error: admin.0 (3475) States database error: read ECONNRESET
    2021-08-14 08:16:35.979  - error: web.0 (3512) Objects database error: read ECONNRESET
    2021-08-14 08:16:35.977  - error: admin.0 (3475) Objects database error: read ECONNRESET
    2021-08-14 08:16:35.980  - info: admin.0 (3475) terminating http server on port 8081
    2021-08-14 08:16:35.980  - error: tr-064.0 (3494) States database error: read ECONNRESET
    2021-08-14 08:16:35.979  - info: web.0 (3512) terminated https server on port 8082
    2021-08-14 08:16:37.481  - info: admin.0 (3475) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:16:37.481  - info: web.0 (3512) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:16:37.481  - info: tr-064.0 (3494) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:16:40.980  - error: admin.0 (3475) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2021-08-14 08:16:40.982  - error: tr-064.0 (3494) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2021-08-14 08:16:40.983  - warn: web.0 (3512) get state error: DB closed
    2021-08-14 08:16:41.415  - info: host.6ad907f78bd1 iobroker.js-controller version 3.3.15 js-controller starting
    2021-08-14 08:16:41.416  - info: host.6ad907f78bd1 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-08-14 08:16:41.416  - info: host.6ad907f78bd1 hostname: 6ad907f78bd1, node: v12.22.5
    2021-08-14 08:16:41.417  - info: host.6ad907f78bd1 ip addresses: 192.168.1.12
    2021-08-14 08:16:41.781  - info: host.6ad907f78bd1 connected to Objects and States
    2021-08-14 08:16:41.883  - info: host.6ad907f78bd1 added notifications configuration of host
    2021-08-14 08:16:42.088  - info: host.6ad907f78bd1 66 instances found
    2021-08-14 08:16:42.108  - info: host.6ad907f78bd1 starting 14 instances
    2021-08-14 08:16:42.158  - info: host.6ad907f78bd1 instance system.adapter.admin.0 started with pid 3547
    2021-08-14 08:16:42.709  - info: admin.0 (3547) starting. Version 5.1.23 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:16:42.718  - info: admin.0 (3547) requesting all states
    2021-08-14 08:16:42.718  - info: admin.0 (3547) requesting all objects
    2021-08-14 08:16:43.385  - info: admin.0 (3547) received all objects
    2021-08-14 08:16:43.492  - info: admin.0 (3547) http server listening on port 8081
    2021-08-14 08:16:43.492  - info: admin.0 (3547) Use link "http://localhost:8081" to configure.
    2021-08-14 08:16:46.176  - info: host.6ad907f78bd1 instance system.adapter.tr-064.0 started with pid 3562
    2021-08-14 08:16:46.651  - info: tr-064.0 (3562) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:16:50.159  - info: host.6ad907f78bd1 instance system.adapter.web.0 started with pid 3577
    2021-08-14 08:16:50.620  - info: web.0 (3577) starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:16:50.724  - error: web.0 (3577) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    2021-08-14 08:16:50.751  - info: web.0 (3577) Secure socket.io server listening on port 8082
    2021-08-14 08:16:50.753  - info: web.0 (3577) https server listening on port 8082
    2021-08-14 08:16:50.909  - info: web.0 (3577) ==>Connected system.user.admin from ::ffff:192.168.1.21
    2021-08-14 08:17:26.741  - error: tr-064.0 (3562) States database error: read ECONNRESET
    2021-08-14 08:17:26.741  - error: web.0 (3577) States database error: read ECONNRESET
    2021-08-14 08:17:26.743  - error: admin.0 (3547) States database error: read ECONNRESET
    2021-08-14 08:17:26.743  - error: admin.0 (3547) Objects database error: read ECONNRESET
    2021-08-14 08:17:26.745  - info: admin.0 (3547) terminating http server on port 8081
    2021-08-14 08:17:26.743  - error: web.0 (3577) Objects database error: read ECONNRESET
    2021-08-14 08:17:26.748  - info: web.0 (3577) terminated https server on port 8082
    2021-08-14 08:17:28.243  - info: tr-064.0 (3562) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:17:28.246  - info: admin.0 (3547) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:17:28.250  - info: web.0 (3577) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:17:31.742  - warn: tr-064.0 (3562) get state error: DB closed
    2021-08-14 08:17:31.746  - error: admin.0 (3547) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2021-08-14 08:17:31.749  - error: web.0 (3577) Objects database error: connect ECONNREFUSED 0.0.0.0:9001
    2021-08-14 08:17:32.1  - info: host.6ad907f78bd1 iobroker.js-controller version 3.3.15 js-controller starting
    2021-08-14 08:17:32.178  - info: host.6ad907f78bd1 Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-08-14 08:17:32.178  - info: host.6ad907f78bd1 hostname: 6ad907f78bd1, node: v12.22.5
    2021-08-14 08:17:32.178  - info: host.6ad907f78bd1 ip addresses: 192.168.1.12
    2021-08-14 08:17:32.545  - info: host.6ad907f78bd1 connected to Objects and States
    2021-08-14 08:17:32.676  - info: host.6ad907f78bd1 added notifications configuration of host
    2021-08-14 08:17:32.911  - info: host.6ad907f78bd1 66 instances found
    2021-08-14 08:17:32.940  - info: host.6ad907f78bd1 starting 14 instances
    2021-08-14 08:17:33.003  - info: host.6ad907f78bd1 instance system.adapter.admin.0 started with pid 3610
    2021-08-14 08:17:33.533  - info: admin.0 (3610) starting. Version 5.1.23 in /opt/iobroker/node_modules/iobroker.admin, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:17:33.545  - info: admin.0 (3610) requesting all states
    2021-08-14 08:17:33.545  - info: admin.0 (3610) requesting all objects
    2021-08-14 08:17:34.306  - info: admin.0 (3610) received all objects
    2021-08-14 08:17:34.421  - info: admin.0 (3610) http server listening on port 8081
    2021-08-14 08:17:34.421  - info: admin.0 (3610) Use link "http://localhost:8081" to configure.
    2021-08-14 08:17:36.981  - info: host.6ad907f78bd1 instance system.adapter.tr-064.0 started with pid 3625
    2021-08-14 08:17:37.513  - info: tr-064.0 (3625) starting. Version 4.2.14 in /opt/iobroker/node_modules/iobroker.tr-064, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:17:40.986  - info: host.6ad907f78bd1 instance system.adapter.web.0 started with pid 3640
    2021-08-14 08:17:41.410  - info: web.0 (3640) starting. Version 3.4.7 in /opt/iobroker/node_modules/iobroker.web, node: v12.22.5, js-controller: 3.3.15
    2021-08-14 08:17:41.508  - error: web.0 (3640) Please specify the email address and domains to use Let's Encrypt certificates! We reuse old certificates
    2021-08-14 08:17:41.535  - info: web.0 (3640) Secure socket.io server listening on port 8082
    2021-08-14 08:17:41.536  - info: web.0 (3640) https server listening on port 8082
    2021-08-14 08:17:41.589  - info: web.0 (3640) ==>Connected system.user.admin from ::ffff:192.168.1.21
    2021-08-14 08:18:01.476  - info: admin.0 (3610) terminating http server on port 8081
    2021-08-14 08:18:01.477  - info: web.0 (3640) terminated https server on port 8082
    2021-08-14 08:18:02.977  - info: admin.0 (3610) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:18:02.978  - info: tr-064.0 (3625) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2021-08-14 08:18:02.979  - info: web.0 (3640) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    Bisher habe vergeblich ich versucht:
    • Neustart des Systems
    • ein Script, dass im Log als fehlerhaft gemeldet wurde, habe ich deaktiviert
    • Deaktivieren von fast allen Adaptern, die ich normalerweise nutze
    • iobroker fix
    Ich vermute, dass die Meldung "States database error: read ECONNRESET" auf die Ursache schließen lässt, bin mir aber nicht sicher. Im Forum habe ich zwar ein paar Einträge dazu gefunden, aber ich glaube, nichts passendes.
    Wie lässt sich dieses database error-Problem lösen? Oder liegt die Ursache doch woanders?
    • C civi
      Guten Morgen,
      Mein System:
      npm Version 6.14.14
      • iobroker fix
      sigi234S Online
      sigi234S Online
      sigi234
      @civi sagte in ioBroker Neustarts - States database error: read ECONNRESET:
      Zeig mal deine web.0 Einstellungen
      Immer Daten sichern!
      C 1 Antwort Letzte Antwort
      • sigi234S sigi234
        civi
        schrieb am zuletzt editiert von civi
        @sigi234 Danke für die Nachricht. Das Problem war erst, dass ich erst gar nicht sauber mehr in web.0 Einstellunge rein kam. ioBroker startete so schnell neu, dass das über das Admin-Interface nicht mehr ging. Bekam die Konfig erst, als ich über "iobroker stop web.0" gestoppt habe.
        Hier die Config:
          "_id": "system.adapter.web.0",
          "common": {
            "name": "web",
            "version": "3.4.7",
            "title": "WEB server",
            "license": "MIT",
            "mode": "daemon",
            "platform": "Javascript/Node.js",
            "loglevel": "info",
            "icon": "https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/admin/web.png",
            "readme": "https://github.com/ioBroker/ioBroker.web/blob/master/README.md",
            "enabled": false,
            "materialize": true,
            "compact": true,
            "keywords": [
              "web",
              "server",
              "www",
              "express"
            "extIcon": "https://raw.githubusercontent.com/ioBroker/ioBroker.web/master/admin/web.png",
            "type": "general",
            "stopBeforeUpdate": true,
            "webExtendable": true,
            "localLink": "%web_protocol%://%ip%:%web_port%/",
            "dependencies": [
                "js-controller": ">=3.1.0"
            "authors": [
                "name": "bluefox",
                "email": "dogafox@gmail.com"
            "plugins": {
              "sentry": {
                "dsn": "https://3acf24332d994549bfa3b86e06062c21@sentry.iobroker.net/16"
            "installedFrom": "iobroker.web@3.4.7",
            "installedVersion": "3.4.7",
            "host": "6ad907f78bd1",
            "globalDependencies": [
                "admin": ">=5.1.0"
            "connectionType": "none",
            "dataSource": "none",
            "tier": 3
          "native": {
            "port": "8082",
            "auth": false,
            "secure": true,
            "bind": "0.0.0.0",
            "cache": false,
            "socketio": "",
            "simpleapi": false,
            "defaultUser": "admin",
            "ttl": "3600",
            "certPublic": "defaultPublic",
            "certPrivate": "defaultPrivate",
            "certChained": "",
            "addUserName": false,
            "forceWebSockets": false,
            "whiteListEnabled": false,
            "leEnabled": true,
            "leUpdate": false,
            "leCheckPort": 80,
            "loginBackgroundColor": "",
            "loginBackgroundImage": false,
            "basicAuth": false,
            "lePort": "80",
            "whiteListSettings": {
              "default": {
                "user": "defaultname",
                "object": {
                  "read": true,
                  "list": true,
                  "write": true,
                  "delete": true
                "state": {
                  "read": true,
                  "list": true,
                  "write": true,
                  "create": true,
                  "delete": true
                "file": {
                  "read": true,
                  "list": true,
                  "write": true,
                  "create": true,
                  "delete": true
            "disableExtensions": false,
            "disableStates": false,
            "disableFilesObjects": false
        Sollte eigentlich eine einfache Config sein, habe für die Verschlüsselung davor einen nginx Reverse Proxy mit Zertifikaten,.
        Aber seitdem ich den Adapter gestoppt habe, scheint ioBroker wirklich stabil zu sein. Siehst du was Auffälliges in der Config?
        EDIT: Ich habe den Adapter jetzt einmal komplett entfernt, dann wieder hinzugefügt und eine Instanz erstellt mit
        iobroker del web
        iobroker install web
        iobroker add web
        Nun ist anscheinend wieder Ruhe, keine Neustarts bisher. Wenn ich die Configs vergleiche, scheint bei der "alten" Instanz ausirgendeinem Grund die secure-Option aktiv gewesen zu sein. Verstehe nur nicht, warum das über Nacht dann zu einem Problem geworden ist.
        @sigi234 Vielen Dank für die Hilfestellung, damit konnte ich das Problem lösen (zumindest bisher).
