  4. [Gelöst] influxdb läuft nach update/upgrade nicht mehr
    6.7k
influxdb
5 Beiträge 3 Kommentatoren 1.3k Aufrufe 4 Beobachtet
  • qqolliQ Offline
    qqolliQ Offline
    qqolli
    schrieb am zuletzt editiert von qqolli
    nach einem update und anschliessendem dist-upgrade läuft meine influxdb nicht mehr und ich weiss nicht warum:
    pi@ioBroker:~ $ systemctl status influxdb.service
    ● influxdb.service - InfluxDB is an open-source, distributed, time series database
       Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
       Active: failed (Result: exit-code) since Fri 2021-07-30 09:45:24 CEST; 26s ago
         Docs: https://docs.influxdata.com/influxdb/
      Process: 23787 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
    Jul 30 09:45:24 ioBroker systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
    Jul 30 09:45:24 ioBroker systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
    Jul 30 09:45:24 ioBroker systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
    Jul 30 09:45:24 ioBroker systemd[1]: influxdb.service: Start request repeated too quickly.
    Jul 30 09:45:24 ioBroker systemd[1]: influxdb.service: Failed with result 'exit-code'.
    Jul 30 09:45:24 ioBroker systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
    und
    pi@ioBroker:~ $ journalctl -xe
    -- Subject: A stop job for unit influxdb.service has finished
    -- Defined-By: systemd
    -- Support: https://www.debian.org/support
    -- A stop job for unit influxdb.service has finished.
    -- The job identifier is 1827 and the job result is done.
    -- Subject: Unit failed
    -- The unit influxdb.service has entered the 'failed' state with result 'exit-code'.
    -- Subject: A start job for unit influxdb.service has failed
    -- A start job for unit influxdb.service has finished with a failure.
    -- The job identifier is 1827 and the job result is failed.
    [2]+  Angehalten              journalctl -xe
    Zu allem Überdruss will auch der BackitUp-Adapter die Datenbank nicht wiederherstellen:
    eError: {"errno":-1,"code":"EPERM","syscall":"utime","path":"/opt/iobroker/backups/influxDBtmp/"}
    Kann mir da vielleicht jemand helfen?
    arteckA P 2 Antworten Letzte Antwort
    • qqolliQ qqolli
      und
      arteckA Offline
      arteckA Offline
      arteck
      @qqolli was sagt das log ??
      nach einem update
      nach welchem update ????????
      ausserdem was willst du da wiederherstellen wenn der service nicht startet
      qqolliQ 1 Antwort Letzte Antwort
      • qqolliQ qqolli
        und
        picky
        @qqolli Hatte es gerade schon in diesen Thread geschrieben gehabt: https://forum.iobroker.net/topic/39887/gekl%C3%A4rt-problem-bei-influx-installation/165
        Hatte gestern meinen Raspi auch updatet, und auch das Problem gehabt das influxdb nicht mehr starten konnte. Bei mir hat geholfen
        sudo chmod +x /usr/lib/influxdb/scripts/influxd-systemd-start.sh
        und dann ließ es sich starten mit
        sudo systemctl start influxdb
        • arteckA arteck
          nach einem update
          qqolliQ Offline
          qqolliQ Offline
          qqolli
          @arteck
          Sorry, war vielleicht etwas unpräzise ausgedrückt: sudo apt update && sudo dist-upgrade :-)
          • P picky
            qqolliQ Offline
            qqolliQ Offline
            qqolli
            @picky
            Perfekt, genau das war es. Jetzt läuft wieder alles.
            Vielen Dank!
