  4. ioBroker startet nicht mehr - Fehlermeldung js-controller
    6.4k
18 Beiträge 3 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • 4 Offline
    4 Offline
    41vsy
    ich habe gestern die Daten von meiner Festplatten (an Pi4) gesichert / geklont. Seitdem startet er nicht meht. Infolge bin ich die Anleitung (https://www.iobroker.net/#de/documentation/trouble/RunsNoMore.md) durchgegangen.
    Folgende Fehlermeldung erhalte ich:
    npm install iobroker.js-controller
    > iobroker.js-controller@3.3.14 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.12
    > iobroker.js-controller@3.3.14 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object system.certificates updated
    object _design/custom updated
    object _design/system updated
    The following notifications happened during sync:
    - Ignoring Directory "admin.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "cloud.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "deconz.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "discovery.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "info.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "javascript.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "shelly.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis-materialdesign.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis.0" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "vis.admin" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "web" because officially not created as meta object. Please remove directory!
    - Ignoring Directory "web.admin" because officially not created as meta object. Please remove directory!
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    + iobroker.js-controller@3.3.14
    updated 1 package in 36.765s
    27 packages are looking for funding
      run `npm fund` for details
    Kann jemand damit etwas anfangen und hoffentlich weiterhelfen?
    VG
    • 4 41vsy
      VG
      @41vsy
      Bitte CodeTags verwenden.
      iobroker status
      liefert?
      4 1 Antwort Letzte Antwort
        @41vsy
        iobroker status
        liefert?
        4 Offline
        4 Offline
        41vsy
        @thomas-braun said in ioBroker startet nicht mehr - Fehlermeldung js-controller:
        iobroker status
        pi@ioBroker:/opt/iobroker $ iobroker status
        Objects type: file
        States  type: file
        CodeTags... Sorry, bin noch ganz neu im Forum und bei ioBroker
        • 4 41vsy
          iobroker status
          Objects type: file
          States  type: file
          @41vsy
          Läuft doch...
          Ob man 'ganz neu bei ioBroker' gleich mit Beta-Versionen herummachen sollte weiß ich allerdings nicht...
          iobroker list adapters
          iobroker list instances
          iobroker repo list
            @41vsy
            Läuft doch...
            iobroker repo list
            4 Offline
            4 Offline
            41vsy
            Schon mal nicht schlecht, dass er grundsätzlich noch läuft. Allerdings ist er über die IP nicht mehr zu erreichen. Die IP Adresse habe ich nochmal kontrolliert, diese habe ich korrekt eingegeben. Desweiteren laufen, unabhängig von der Erreichbarkeit auch keine Automationen bzw. die Visu nicht mehr.
            pi@ioBroker:/opt/iobroker $  iobroker list adapters
            pi@ioBroker:/opt/iobroker $ iobroker list instances
            + instance is alive
            pi@ioBroker:/opt/iobroker $ iobroker repo list
            stable      : http://download.iobroker.net/sources-dist.json
            beta        : http://download.iobroker.net/sources-dist-latest.json
            Active repo: stable
            J Thomas BraunT 2 Antworten Letzte Antwort
            • 4 41vsy
              + instance is alive
              Active repo: stable
              Jan1
              @41vsy sagte in ioBroker startet nicht mehr - Fehlermeldung js-controller:
              Äh und wo machst das ganze jetzt bitte mit der Konsole, wenn er nicht erreichbar wäre?
              Du sprichst von der Admin Seite?
              Kann es sein, dass Du nur die IP im Browser eingibst, ohne Port Angabe?
              • 4 41vsy
                + instance is alive
                Active repo: stable
                @41vsy
                Da fehlen die Adapter.
                Entweder von Hand nachinstallieren oder damit mal versuchen:
                https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1627306843032
                Könnte sein das es auch in deinem Fall weiterhilft.
                • 4 41vsy
                  VG
                  Aus einem laufenden System/ioBroker? Das geht nicht gut.
                  • J Jan1
                    4 Offline
                    4 Offline
                    41vsy
                    schrieb am zuletzt editiert von 41vsy
                    @jan1
                    Ich habe den Pi an einem Monitor. Port habe mit eingegeben.
                    J 1 Antwort Letzte Antwort
                      4 Offline
                      4 Offline
                      41vsy
                      Nein. Ich habe den Pi runtergefahren und die Daten (Festplatte) an einem separaten Gerät gesichert.
                      • 4 41vsy
                        @jan1
                        Jan1
                        @41vsy
                        Ok, dann fehlen Dir wie Thomas schon geschrieben hat die Adapter und ohne Admin, kein Zugriff über IP via SSH.
                        Monitor am Server kann man machen,,ist aber eigentlich nie nötig, da der Zugriff eben über SSH erfolgt.
                        • 4 41vsy
                          @41vsy
                          Ist der Pi jetzt nicht erreichbar oder lediglich der ioBroker nicht?
                            @41vsy
                            4 Offline
                            4 Offline
                            41vsy
                            Das hat funktioniert. Danke. Danke. Danke.
                            • J Jan1
                              @41vsy
                              4 Offline
                              4 Offline
                              41vsy
                              @jan1
                              Für den ioBroker nutze ich den Monitor auch nicht. Habe ihn nur angeschlossen um die Eingabe am Terminal zu machen.
                              4 Thomas BraunT 2 Antworten Letzte Antwort
                              • 4 41vsy
                                @jan1
                                4 Offline
                                4 Offline
                                41vsy
                                Wie sicher ihr eure Daten bzw. die Festplatte / SD-Karte? Vllt ist ja klonen nicht ganz optimal.
                                Danke nochmal!!!
                                • 4 41vsy
                                  @jan1
                                  @41vsy
                                  Per SSH hätte das aber die ganze Zeit dann funktionieren müssen. Ohne Monitor.
                                  Dann hast du dir 'irgendwie' die States und Objects zerschossen. In der Regel passiert das bei abruptem Stromentzug.
                                  • 4 41vsy
                                    Danke nochmal!!!
                                    Klonen ist aus meiner Sicht alles andere als optimal.
                                    Mach deine Backups mit dem Backitup-Adapter.
                                      4 Offline
                                      4 Offline
                                      41vsy
                                      Ok. Danke dafür. Werde das zukünftig beherzigen.
