  4. Netatmo 1.4.3 Fehlermeldung
    6.4k
4 Beiträge 3 Kommentatoren 428 Aufrufe 1 Beobachtet
  • htreckslerH Offline
    htreckslerH Offline
    htrecksler
    Forum Testing
    schrieb am zuletzt editiert von htrecksler
    Controller: 3.2.16
    Admin: 4.2.2
    Wenn ich die Kamera (Presence) über die App von Netatmo starte kommt neuerdings folgender Log Eintrag:
    2021-07-20 19:43:11.706 - error: netatmo.0 (5898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-07-20 19:43:11.707 - error: netatmo.0 (5898) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
    2021-07-20 19:43:11.710 - error: netatmo.0 (5898) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
    at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5861:27)
    at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5935:21)
    at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1569:16
    at new Promise ()
    at Adapter.setStateAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1568:16)
    at onSocketAlert (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:174:31)
    at async Socket. (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:25:46)
    2021-07-20 19:43:11.711 - error: netatmo.0 (5898) The state property "ack" has the wrong type "object" (should be "boolean")!
    2021-07-20 19:43:11.727 - info: netatmo.0 (5898) Unregistering realtime events
    2021-07-20 19:43:11.731 - info: netatmo.0 (5898) cleaned everything up...
    2021-07-20 19:43:11.732 - info: netatmo.0 (5898) terminating
    2021-07-20 19:43:11.733 - warn: netatmo.0 (5898) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2021-07-20 19:43:11.899 - error: netatmo.0 (5898) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2021-07-20 19:43:11.900 - error: netatmo.0 (5898) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
    2021-07-20 19:43:11.900 - error: netatmo.0 (5898) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
    at new Promise ()
    2021-07-20 19:43:11.901 - error: netatmo.0 (5898) The state property "ack" has the wrong type "object" (should be "boolean")!
    2021-07-20 19:43:12.385 - error: host.iobrokerVM instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2021-07-20 19:43:12.390 - info: host.iobrokerVM Restart adapter system.adapter.netatmo.0 because enabled
    2021-07-20 19:43:42.425 - info: host.iobrokerVM instance system.adapter.netatmo.0 started with pid 8010
    2021-07-20 19:43:44.649 - info: netatmo.0 (8010) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.netatmo, node: v12.19.0, js-controller: 3.2.16
    2021-07-20 19:43:44.845 - info: netatmo.0 (8010) Registering realtime events with https://iobroker.herokuapp.com/netatmo/
    kann das jemand bestätigen?
    Gruss Hermann
    ioBroker auf Proxmox (Debian) auf IntelNuc als Produktivsystem
    • htreckslerH htrecksler
      Controller: 3.2.16
      Admin: 4.2.2
      at new Promise ()
      at new Promise ()
      @htrecksler sagte in Netatmo 1.4.3 Fehlermeldung:
      Nee, aber ich kann bestätigen dass deine node-Installation etwas Aufmerksamkeit bekommen sollte.
      htreckslerH 1 Antwort Letzte Antwort
        htreckslerH Offline
        htreckslerH Offline
        htrecksler
        Forum Testing
        @thomas-braun besser?
        2021-07-20 20:43:37.591 - error: netatmo.0 (806) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-07-20 20:43:37.593 - error: netatmo.0 (806) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
        2021-07-20 20:43:37.596 - error: netatmo.0 (806) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
        at new Promise ()
        at runNextTicks (internal/process/task_queues.js:62:5)
        at processImmediate (internal/timers.js:434:9)
        2021-07-20 20:43:37.597 - error: netatmo.0 (806) The state property "ack" has the wrong type "object" (should be "boolean")!
        2021-07-20 20:43:37.621 - info: netatmo.0 (806) Unregistering realtime events
        2021-07-20 20:43:37.626 - info: netatmo.0 (806) cleaned everything up...
        2021-07-20 20:43:37.627 - info: netatmo.0 (806) terminating
        2021-07-20 20:43:37.628 - warn: netatmo.0 (806) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2021-07-20 20:43:37.685 - error: netatmo.0 (806) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2021-07-20 20:43:37.685 - error: netatmo.0 (806) unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
        2021-07-20 20:43:37.686 - error: netatmo.0 (806) Error: The state property "ack" has the wrong type "object" (should be "boolean")!
        at new Promise ()
        2021-07-20 20:43:37.687 - error: netatmo.0 (806) The state property "ack" has the wrong type "object" (should be "boolean")!
        2021-07-20 20:43:38.231 - error: host.iobrokerVM instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2021-07-20 20:43:38.235 - info: host.iobrokerVM Restart adapter system.adapter.netatmo.0 because enabled
        2021-07-20 20:44:08.341 - info: host.iobrokerVM instance system.adapter.netatmo.0 started with pid 890
        2021-07-20 20:44:11.725 - info: netatmo.0 (890) starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.netatmo, node: v12.22.2, js-controller: 3.2.16
        2021-07-20 20:44:12.271 - info: netatmo.0 (890) Registering realtime events with https://iobroker.herokuapp.com/netatmo/
        Gruss Hermann
          Sprite01
          Die Fehlermeldung habe ich seit dem neuesten Update (Host 3.3.15 und Admin5) jetzt auch, kann ich bestätigen.
          host.iobroker
          	2021-08-09 11:36:09.732	error	instance system.adapter.netatmo.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          netatmo.0
          	2021-08-09 11:36:08.813	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          netatmo.0
          	2021-08-09 11:36:08.803	error	The state property "ack" has the wrong type "object" (should be "boolean")!
          netatmo.0
          	2021-08-09 11:36:08.802	error	Error: The state property "ack" has the wrong type "object" (should be "boolean")! at validateSetStateObjectArgument (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6017:27) at Adapter.setState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6091:21) at /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1576:16 at new Promise (<anonymous>) at Adapter.setStateAsync (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:1575:16) at onSocketAlert (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:174:31) at async Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.netatmo/lib/netatmoWelcome.js:25:46)
          netatmo.0
          	2021-08-09 11:36:08.799	error	unhandled promise rejection: The state property "ack" has the wrong type "object" (should be "boolean")!
          netatmo.0
          	2021-08-09 11:36:08.797	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          Dirk
          http://www.DessauWetter.de
          (ioBroker auf IntelNuc und Proxmox)
