  4. Node-Red
  5. NodeRed / iobroker / vis installation
    6.5k
7 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • NHarryN Offline
    NHarryN Offline
    NHarry
    bin neu im Thema und habe folgendes Problem.
    Hab auf meinem Raspi ioBroker installiert, Conbee2 als GW.
    Anschließend in ioBroker nodeRed als Adapter installiert.
    Jetzt wollte ich unter Palette erweitern die vis installieren um die Gets für ioBroker zu bekommen.
    Dann kommt jedoch folgende Fehlermeldung:
    2021-06-09T06:12:34.286Z Installieren : node-red-vis 0.4.2
    2021-06-09T06:12:34.994Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-vis@0.4.2
    2021-06-09T06:12:44.131Z [err] npm
    2021-06-09T06:12:44.132Z [err]  WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    2021-06-09T06:12:50.264Z [err] npm
    2021-06-09T06:12:50.265Z [err] WARN deprecated har-validator@5.1.5: this library is no longer supported
    2021-06-09T06:12:50.508Z [err] npm
    2021-06-09T06:12:50.509Z [err] WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    2021-06-09T06:12:54.290Z [err] npm
    2021-06-09T06:12:54.291Z [err]  WARN
    2021-06-09T06:12:54.292Z [err]  deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    2021-06-09T06:12:56.850Z [err] npm
    2021-06-09T06:12:56.851Z [err]
    2021-06-09T06:12:56.852Z [err] WARN
    2021-06-09T06:12:56.853Z [err]
    2021-06-09T06:12:56.854Z [err] deprecated
    2021-06-09T06:12:56.855Z [err]  json3@3.3.2: Please use the native JSON object instead of JSON 3
    2021-06-09T06:13:47.040Z [out]
    2021-06-09T06:13:47.040Z [out] > iobroker.vis@0.10.15 install /opt/iobroker/iobroker-data/node-red/node_modules/iobroker.vis
    2021-06-09T06:13:47.040Z [out] > node main.js --install
    2021-06-09T06:13:47.409Z [out]
    2021-06-09T06:13:47.409Z [out] > iobroker.vis-google-fonts@0.1.0 install /opt/iobroker/iobroker-data/node-red/node_modules/iobroker.vis-google-fonts
    2021-06-09T06:13:47.409Z [out] > node main.js --install
    2021-06-09T06:13:47.754Z [out]
    2021-06-09T06:13:47.754Z [out] > node-red-vis@0.4.2 install /opt/iobroker/iobroker-data/node-red/node_modules/node-red-vis
    2021-06-09T06:13:47.754Z [out] > node node_modules/iobroker.vis/lib/install.js
    2021-06-09T06:13:48.054Z [err] internal/modules/cjs/loader.js:818
    2021-06-09T06:13:48.054Z [err]   throw err;
    2021-06-09T06:13:48.054Z [err]   ^
    2021-06-09T06:13:48.054Z [err] Error: Cannot find module '/opt/iobroker/iobroker-data/node-red/node_modules/node-red-vis/node_modules/iobroker.vis/lib/install.js'
    2021-06-09T06:13:48.054Z [err]     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
    2021-06-09T06:13:48.054Z [err]     at Function.Module._load (internal/modules/cjs/loader.js:667:27)
    2021-06-09T06:13:48.054Z [err]     at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    2021-06-09T06:13:48.054Z [err]     at internal/main/run_main_module.js:17:47 {
    2021-06-09T06:13:48.054Z [err]   code: 'MODULE_NOT_FOUND',
    2021-06-09T06:13:48.054Z [err]   requireStack: []
    2021-06-09T06:13:48.054Z [err] }
    2021-06-09T06:13:50.322Z [err] npm
    2021-06-09T06:13:50.322Z [err]  ERR! code ELIFECYCLE
    2021-06-09T06:13:50.322Z [err] npm ERR! errno
    2021-06-09T06:13:50.323Z [err]  1
    2021-06-09T06:13:50.353Z [err] npm
    2021-06-09T06:13:50.354Z [err] ERR! node-red-vis@0.4.2 install: `node node_modules/iobroker.vis/lib/install.js`
    2021-06-09T06:13:50.354Z [err] npm ERR! Exit status 1
    2021-06-09T06:13:50.354Z [err] npm ERR! Failed at the node-red-vis@0.4.2 install script.
    2021-06-09T06:13:50.355Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    2021-06-09T06:13:51.695Z [err]
    2021-06-09T06:13:51.696Z [err] npm ERR! A complete log of this run can be found in:
    2021-06-09T06:13:51.696Z [err] npm ERR!     /home/iobroker/.npm/_logs/2021-06-09T06_13_50_445Z-debug.log
    2021-06-09T06:13:51.728Z rc=1
    Danke, für eure Hilfe :)!
    • NHarryN NHarry
      mickymM Offline
      mickymM Offline
      mickym
      @nharry Diese Node ist erstens mal alt und zum zweiten für Dich völlig überflüssig.
      Sie macht in meinen Augen nur Sinn, wenn Du NodeRed als Standalone Installation nutzt und vis als Visualisierungssoftware nutzen willst.
      Da Du aber NodeRed unter iobroker nutzt brauchst Du das nicht.
      Du nutzt VIS ganz normal unter dem iobroker und NodeRed als Logikmaschine.
      VIS nutzt die Objekte des iobrokers zur Visualisierung, die von diversen Adaptern zur Verfügung gestellt werden.
      Du kannst Dir das NodeRed Dashboard noch installieren, aber wenn Du mit VIS arbeiten willst, dann brauchst Du nur den VIS Adapter unter iobroker installieren.
      • NHarryN Offline
        NHarryN Offline
        NHarry
        @mickym danke, für deine Erläuterung :)!
        Was benötige ich dann, um die Get´s für ioBroker in NodeRed zu sehen.
        Sprich, dass hier ioBroker auftaucht:
        Oder benötigt ich das überhaupt ?
        Danke und Gruß
        • NHarryN NHarry
          Danke und Gruß
          mickymM Offline
          mickymM Offline
          mickym
          @nharry Wenn Du NodeRed als Adapter im iobroker installiert hast, hast Du weiter unten die iobroker Nodes, um direkt mit iobroker interagieren zu können, sprich in Datenpunkte zu schreiben oder Datenpunkte können Flows triggern.
          Einfach mal nach unten scrollen. ;)
          NHarryN F 2 Antworten Letzte Antwort
          • mickymM mickym
            NHarryN Offline
            NHarryN Offline
            NHarry
            @mickym vielen vielen Dank!:)
            Der Fehler, sahs wohl davor.
            • mickymM mickym
              frank62
              @mickym said in NodeRed / iobroker / vis installation:
              Schön wärs, bei mir tauchen die nicht auf. Wo suche ich den Fehler?
              MfG
              Frank62
              • F frank62
                mickymM Offline
                mickymM Offline
                mickym
                @frank62 wenn du den Node-red Adapter installiert hast sind die iobroker nodes links in eigenen Kategorie iobroker.
                Mach halt mal einen Screenshot dass Dein NodeRed Adapter läuft:
