  4. Error in Upgrade js-controller 3.1.6 zu 3.2.16
23 Beiträge 5 Kommentatoren 877 Aufrufe 6 Beobachtet
  • apollon77A Offline
    Ahhhhh ... stop ... the cache clean needs to run as ipbroker user!!!
    sudo -u iobroker -H npm cache clean --force
    arteckA Marcel K 0M 2 Antworten Letzte Antwort
    • apollon77A apollon77
      arteckA Offline
      arteckA Offline
      arteck
      @apollon77 ach jo der hat ja auch einz... da bin ich letzten auch drauf reingefallen
        Marcel K 0M Offline
        Marcel K 0M Offline
        Marcel K 0
        schrieb am zuletzt editiert von Marcel K 0
        @apollon77 @arteck
        Vielen Dank für eure Hilfe ich glaube es ist jetzt erfolgreich durchgelaufen! Mal sehen ob alle Adapter und Skripte noch laufen :)
        pi@raspberrypi:~ $ sudo -u iobroker -H npm cache clean --force
        npm WARN using --force I sure hope you know what you are doing.
        pi@raspberrypi:~ $ cd /opt/iobroker
        pi@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller@3.2.16
        > iobroker.js-controller@3.2.16 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.12
        > iobroker.js-controller@3.2.16 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        object _design/system updated
        Renamed repository "default to "stable"
        Renamed repository "latest to "beta"
        > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
        > node scripts/postinstall
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/chokidar/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        + iobroker.js-controller@3.2.16
        added 38 packages from 12 contributors, removed 29 packages, updated 50 packages and moved 1 package in 114.713s
        49 packages are looking for funding
          run `npm fund` for details
           â­âââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ®
           â        â
           â     New major version of npm available! 6.14.12 -> 7.16.0      â
           â   Changelog: https://github.com/npm/cli/releases/tag/v7.16.0   â
           â               Run npm install -g npm to update!                â
           â        â
           â°âââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¯
        pi@raspberrypi:/opt/iobroker $ iobroker fix
        iobroker fix
        Execute the installation fixer script, this updates your ioBroker installation
        Options:
              --help     Show help  [boolean]
          -v, --version  Show version  [boolean]
