  4. BSHB Adapter Pairing
10 Beiträge 3 Kommentatoren 1.0k Aufrufe 3 Beobachtet
    MSpecht87
    Ich versuche seit mehreren Tag den Bosch BSHB Adapter zum laufen zu bekommen. Wenn ich ihn koppeln will schmeißt mir das Log immer wieder den Fehler "instance system.adapter.bshb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)".
    Hat jemand einen Tip für mich was das Problem sein könnte.
    LOG:
    host.raspberrypi-ioBroker	2021-04-27 14:10:14.099	error	instance system.adapter.bshb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    bshb.0	2021-04-27 14:10:13.487	warn	(2254) Terminated (UNCAUGHT_EXCEPTION): Without reason
    bshb.0	2021-04-27 14:10:13.486	info	(2254) terminating
    bshb.0	2021-04-27 14:10:13.485	info	(2254) cleaned everything up...
    bshb.0	2021-04-27 14:10:13.471	error	(2254) error during call to BSHC:
    bshb.0	2021-04-27 14:10:13.471	error	(2254) BshbError: error during call to BSHC: at BshcClient.AbstractBshcClient.handleError (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:167:32) at Clien
    bshb.0	2021-04-27 14:10:13.470	error	(2254) uncaught exception: error during call to BSHC:
    bshb.0	2021-04-27 14:10:13.467	error	(2254) error during call to BSHC:
    bshb.0	2021-04-27 14:10:13.467	error	(2254) BshbError: error during call to BSHC: at BshcClient.AbstractBshcClient.handleError (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:167:32) at Clien
    bshb.0	2021-04-27 14:10:13.465	error	(2254) uncaught exception: error during call to BSHC:
    bshb.0	2021-04-27 14:10:12.833	info	(2254) Detecting intrusion detection system finished
    bshb.0	2021-04-27 14:10:12.763	info	(2254) Start detecting open doors/windows...
    bshb.0	2021-04-27 14:10:12.761	info	(2254) Start detecting devices...
    bshb.0	2021-04-27 14:10:12.760	info	(2254) Start detecting intrusion detection system...
    bshb.0	2021-04-27 14:10:12.759	info	(2254) Start detecting messages...
    bshb.0	2021-04-27 14:10:12.758	info	(2254) Start detecting scenarios...
    bshb.0	2021-04-27 14:10:12.755	info	(2254) Unexpected pairing response. Most likely wrong input data. Check password, etc. Pairing stopped.
    bshb.0	2021-04-27 14:10:12.078	info	(2254) Start pairing. Activate pairing on Bosch Smart Home Controller by pressing button until flashing.
    bshb.0	2021-04-27 14:10:12.077	info	(2254) Client with identifier: ioBroker.bshb_41a42908-c877-4150-a47d-90bfb462f3a4 was not paired yet.
    bshb.0	2021-04-27 14:10:11.865	info	(2254) Check if client with identifier: ioBroker.bshb_41a42908-c877-4150-a47d-90bfb462f3a4 is already paired.
    bshb.0	2021-04-27 14:10:11.855	info	(2254) private key seems to be actual content. Use value from state.
    bshb.0	2021-04-27 14:10:11.855	info	(2254) certificate seems to be actual content. Use value from state.
    bshb.0	2021-04-27 14:10:11.854	info	(2254) Check if certificate is file reference or actual content
    bshb.0	2021-04-27 14:10:11.853	info	(2254) Client certificate found in system.certificates
    bshb.0	2021-04-27 14:10:11.796	info	(2254) starting. Version 0.1.13 in /opt/iobroker/node_modules/iobroker.bshb, node: v10.24.1, js-controller: 3.2.16
    host.raspberrypi-ioBroker	2021-04-27 14:10:10.340	info	instance system.adapter.bshb.0 started with pid 2254
    Mod-Edit: Code in </> Code-Tag gepackt!
    Thomas BraunT UncleSamU 2 Antworten Letzte Antwort
    • M MSpecht87
      LOG:
      @mspecht87
      Bitte Konsolentext in CodeTags </> einbetten.
      NodeJS sauber im System?
      which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
      Davon ab solltest du auf node12 wechseln, node10 ist zum Ende des Monats abgekündigt.
        @mspecht87
        MSpecht87
        @thomas-braun Hallo Thomas danke für die schnelle Antwort. Hab gleich mal auf dein geheiß NodeJS auf 12 geupdated da sa aber unter Version schon sauber aus. Der Fehler ist auch nach wie vor der selbe.
        • M MSpecht87
          @mspecht87
          Bite auch keine Screenshots von Texten.
            @mspecht87
            MSpecht87
            @thomas-braun wird nicht wieder vorkommen. Bin neu im Forum sorry.
            • M MSpecht87
              LOG:
              UncleSamU Offline
              UncleSamU Offline
              UncleSam
              @mspecht87 sagte in BSHB Adapter Pairing:
              👆 Das hast du schon gemacht?
              Aber trotzdem wohl ein Bug im Adapter: der sollte nicht weitermachen, wenn das Pairing schief geht --> ich würde ein Issue auf GitHub erstellen.
              • UncleSamU UncleSam
                MSpecht87
                @unclesam Ja das habe ich schon mehr Fach gecheckt. Sogar das Passort geändert um zu checken ob es an Zeichen liegt mit denen er nicht klar kommt.
                • M MSpecht87
                  UncleSamU Offline
                  UncleSamU Offline
                  UncleSam
                  @mspecht87 Und keine Firewall / PiHole, die im Weg steht?
                    MSpecht87
                    @unclesam Habe die Routereinstellungen nochmal überprüft, da ist nichts verdächtiges zu finden. Sonst würde es ja aber auch nicht möglich sein Bosch eigene Geräte zu paaren vermute ich.
                    Vielleicht sollte ich den Adapter nochmal komplett löschen und neu installieren. Ich habe bei einigen Beispielen gesehen das bei den Einstellungen des Adapters die Mac adresse hinterlegt werden kann. Liegt das an einer älteren Version, da ich diese Eingabe bei mir nicht habe?
                    • M MSpecht87
                      MSpecht87
                      @mspecht87 Hab das Problem jetzt lösen können. Im Passort war ein Zeichen das sich im base64 falsch übersetzt hat und somit das nicht gestimmt hat.
