  4. backitup redis ENOENT
    6.5k
26 Beiträge 3 Kommentatoren 2.5k Aufrufe 3 Beobachtet
    @xyolyp
    Da muss eigentlich mehr vorab kommen.
    Wird da eine Freigabe in /opt/iobroker/backups gemounted?
    Denn eigentlich sieht das so aus, wenn ein smb-Share eingehängt wird:
    Started iobroker ...
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 3911 states saved
    [DEBUG] [iobroker] - host.raspberrypi 4751 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_04_25-15_28_21_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [redis] - Start Redis Backup ...
    [DEBUG] [redis] - Created redistmp directory
    [DEBUG] [redis] - redis-cli save started, please wait ...
    [DEBUG] [redis] - redis-cli save finish
    [DEBUG] [redis] - detected redis file: dump.rdb | file type: rdb
    [DEBUG] [redis] - Backup created: /opt/iobroker/backups/redis_2021_04_25-15_28_34_backupiobroker.tar.gz
    [DEBUG] [redis] - Try deleting the redis tmp directory: "/opt/iobroker/backups/redistmp"
    [DEBUG] [redis] - redis tmp directory "/opt/iobroker/backups/redistmp" successfully deleted
    [DEBUG] [redis] - done
    [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_04_25-15_28_35_backupiobroker.tar.gz
    [DEBUG] [javascripts] - done
    [DEBUG] [cifs] - done
    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_04_25-15_28_21_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - Google Drive: Copy redis_2021_04_25-15_28_34_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_04_25-15_28_35_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - done
    [DEBUG] [clean] - done
    [DEBUG] [whatsapp] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    X Offline
    X Offline
    Xyolyp
    @thomas-braun SMB und FTP sind deaktiviert bei dem Backup Vorgang, um zu demonstrieren, dass es leider ohne entfernte Sicherung auch schon nicht mehr funktioniert
    • X Xyolyp
      @xyolyp
      Kann es sein, dass die Rechte verfummelt sind?
      Mit mit
      iobroker stop
      iobroker fix
      versucht?
      Denn bei mir wird in
      /opt/iobroker/node_modules/iobroker.js-controller/tmp/
      während des Backups natürlich ein Ordner backup für kurze Zeit angelegt. tmp halt. Offenbar funktioniert das ja schon nicht.
      • X Offline
        X Offline
        Xyolyp
        @thomas-braun auch nach dem Fixer besteht der Fehler unverändert
        • X Xyolyp
          @xyolyp
          Wie sehen die Rechte dort aus:
          getfacl /opt/iobroker/node_modules/iobroker.js-controller/tmp/
          X 1 Antwort Letzte Antwort
            @xyolyp
            X Offline
            X Offline
            Xyolyp
            @thomas-braun der Output von getfacl ist
            getfacl: Removing leading '/' from absolute path names
            # file: opt/iobroker/node_modules/iobroker.js-controller/tmp/
            # owner: iobroker
            # group: iobroker
            user::rwx
            group::r-x
            group:iobroker:rwx
            mask::rwx
            other::r-x
            default:user::rwx
            default:group::r-x
            default:group:iobroker:rwx
            default:mask::rwx
            default:other::r-x
            • X Xyolyp
              # owner: iobroker
              # group: iobroker
              user::rwx
              group::r-x
              group:iobroker:rwx
              mask::rwx
              other::r-x
              default:user::rwx
              default:group::r-x
              default:mask::rwx
              default:other::r-x
              @xyolyp Passt.
