  4. neues Widget wird nicht angezeigt
    2.6k
    4.5k
vistemplate
11 Beiträge 4 Kommentatoren 1.1k Aufrufe 4 Beobachtet
  • J Offline
    jampr
    Hi zusammen,
    ich habe mir das widget vom template kopiert und wollte ein Eigenes unter eigenem Namen draus machen. Doch dummerweise wird es in meiner VIS nicht angezeigt. Auch nach iobroker visdebug iobroker.snapcast nicht. Auch nach Löschen der offline Inhalte vom Browser und Restart des Web-Adapters. Weiß jemand, was ich falsch mache?
    pi@raspi4:/opt/iobroker# iobroker visdebug iobroker.snapcast
    Modify "/opt/iobroker/node_modules/iobroker.vis/www/cache.manifest"
    Upload "/opt/iobroker/node_modules/iobroker.snapcast/widgets"
    Upload "/opt/iobroker/node_modules/iobroker.snapcast/widgets/pathbrowser/css/style.css"
    Upload "/opt/iobroker/node_modules/iobroker.snapcast/widgets/pathbrowser/js/pathbrowser.js"
    Upload "/opt/iobroker/node_modules/iobroker.snapcast/widgets/pathbrowser.html"
    pathbrowser.html:
    	ioBroker.vis template Widget-Set
    	version: "0.0.1"
    	Copyright 2020 Author author@mail.com
    <!-- here you can include so many css as you want -->
    <link rel="stylesheet" href="widgets/pathbrowser/css/style.css" />
    <!-- here you can include so many js-files as you want -->
    <script type="text/javascript" src="widgets/pathbrowser/js/pathbrowser.js"></script>
    <script id="pathbrowser"
    		type="text/ejs"
    		class="vis-tpl"
    		data-vis-prev='<div id="prev_pathbrowser" style="position: relative; text-align: initial;padding: 4px "><div class="vis-widget_prev " style="width: 280px; height: 159px;" > <div class="template-class vis-widget-prev-body " style="padding:2px">pathbrowser</div>'
    		data-vis-attrs="oid/id;myColor/color;htmlText/text;"
    		data-vis-attrs0="group.extraPath;extraAttr"
    		data-vis-set="pathbrowser"
    		data-vis-type="helper"
    		data-vis-name="pathbrowser">
    	<div class="vis-widget <%== this.data.attr('class') %>" style="overflow:visible; width: 230px; height: 210px" id="<%= this.data.attr('wid') %>"><%
    		vis.binds['pathbrowser'].createWidget(this.data.wid, this.view, this.data, this.style);
    	%></div>
    </script>
    	version: "0.0.1"
    "use strict";
    // add translations for edit mode
    $.extend(
    	true,
    	systemDictionary,
    		// Add your translations here, e.g.:
    		// "size": {
    		// 	"en": "Size",
    		// 	"de": "Größe",
    		// 	"ru": "Размер",
    		// 	"pt": "Tamanho",
    		// 	"nl": "Grootte",
    		// 	"fr": "Taille",
    		// 	"it": "Dimensione",
    		// 	"es": "Talla",
    		// 	"pl": "Rozmiar",
    		// 	"zh-cn": "尺寸"
    // this code can be placed directly in pathbrowser.html
    vis.binds["pathbrowser"] = {
    	version: "0.0.1",
    	showVersion: function () {
    		if (vis.binds["pathbrowser"].version) {
    			console.log("Version pathbrowser: " + vis.binds["pathbrowser"].version);
    			vis.binds["pathbrowser"].version = null;
    	createWidget: function (widgetID, view, data, style) {
    		var $div = $("#" + widgetID);
    		// if nothing found => wait
    		if (!$div.length) {
    			return setTimeout(function () {
    				vis.binds["pathbrowser"].createWidget(widgetID, view, data, style);
    			}, 100);
    		var text = "HALLO";/*
    		text += "OID: " + data.oid + "</div><br>";
    		text += 'OID value: <span class="pathbrowser-value">' + vis.states[data.oid + ".val"] + "</span><br>";
    		text += 'Color: <span style="color: ' + data.myColor + '">' + data.myColor + "</span><br>";
    		text += "extraAttr: " + data.extraAttr + "<br>";
    		text += "Browser instance: " + vis.instance + "<br>";
    		text += 'htmlText: <textarea readonly style="width:100%">' + (data.htmlText || "") + "</textarea><br>";
    		$("#" + widgetID).html(text);
    		// subscribe on updates of value
    		function onChange(e, newVal, oldVal) {
    			$div.find(".pathbrowser-value").html(newVal);
    		if (data.oid) {
    			vis.states.bind(data.oid + ".val", onChange);
    			//remember bound state that vis can release if didnt needed
    			$div.data("bound", [data.oid + ".val"]);
    			//remember onchange handler to release bound states
    			$div.data("bindHandler", onChange);
    vis.binds["pathbrowser"].showVersion();
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      @jampr Wenn alles zum erstellen eines Widgets befolgt wurde kannst du mal ein
      iobroker upload all
      versuchen.
      J 1 Antwort Letzte Antwort
      • wendy2702W wendy2702
        iobroker upload all
        versuchen.
        jampr
        @wendy2702
        Leider keine Änderung. Der Befehl macht ja nur den Upload für alle Adapter.
        was meinst du mit 'alles zum Erstellen eines Widgets'?
        Ich habe das Template benutzt, um https://github.com/jampr21/ioBroker.snapcast zu erstellen. Und im Widget-Verzeichnis das Template umbenannt.
        • J jampr
          @wendy2702
          wendy2702W Offline
          wendy2702W Offline
          wendy2702
          @jampr Gibt hier irgendwo ne Anleitung zum erstellen eigener Widgets... wenn ich die nur auf die Schnelle finden würde.
            jampr
            ja, ich finde dazu auch wenig. Außer ein paar Forums-Beiträge.
            • J jampr
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @jampr
              Beispiel :
              https://forum.iobroker.net/topic/35311/vis-eigenes-widget-erstellen
              https://forum.iobroker.net/topic/42086/vorstellung-shelly-style-widgets
              • GlasfaserG Glasfaser
                @jampr
                Beispiel :
                jampr
                @glasfaser
                danke. Aber ich verstehe nicht, wie ich so ein Widget einem Adapter hinterlegen kann. https://github.com/jampr21/ioBroker.snapcast/tree/main/widgets
                Das exportierte Widget sieht auch anders aus, als das vom Adapter. Hat sich da was geändert?
                • J jampr
                  @glasfaser
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @jampr sagte in neues Widget wird nicht angezeigt:
                  @glasfaser
                  widgets existieren nur im rahmen eines adapters.
                  auch wenn du keinen exchten adapter javascript code schreiben möchtest, sondern einfach nur widgets bereit stellen möchtest.
                  damit du alle voraussetzungen dafür schaffst ist es das beste, das adapter creator script zu starten.
                  da wirst du alles wichtige gefragt und kannst auch angeben, das du nur widgets machen möchtest.
                  https://github.com/ioBroker/create-adapter
                  das script erzeugt dir dann im richtigen verzeichnis dein adapter inklusive probe widget, welches du im vis auch ausprobieren kannst. Als Startpfad empfehle ich dir /opt/iobroker. dein adapter wird dann unter /opt/iobroker/node_modules/ioBroker.deinAdapterName erzeugt
                  auf basis dessen, passt du dann dein widget entsprechend an.
                  Meine Adapter und Widgets
                  Links im Profil
                  • OliverIOO OliverIO
                    @glasfaser
                    jampr
                    @oliverio
                    genau. Mit dem create adapter habe ich ja meinen Adapter auch angelegt. Incl. Widget (namens template). Der Adapter funktioniert auch einwandfrei. Auch Änderungen am main oder an den admin-Seiten klappen hervorragend. Nur dieses Widget bekomme ich nicht zu greifen. Ich habe den Code schon in nem basic-html vorbereitet und dachte, das ich das template-widget einfach umbenenne und dann meinen Code in das Adapter-Widget überführe. Dummerweise scheitere ich direkt beim umbenennen (s. Post 1).
                    Im ersten Code-Abschnitt steht ja auch:
                    Aber ich sehe es im vis-Editor nicht. Ich habe diverse Browser probiert und cache natürlich auch gelöscht. Ich sehe das Ding einfach nicht links im Menü.
                    • J jampr
                      @oliverio
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      @oliverio
                      Diesen Ausschnitt verstehe ich nicht? was soll das bedeuten? Das sind deine Dateien? Siehe unten mein Hinweis wie man Änderungen Uploaded
                      Also das Probe-Widget, welches zusammen mit deinem Adapter generiert wird funktioniert?
                      Wenn du dann sachen änderst, musst du die Änderungen noch "hochladen" mit
                      iobroker upload snapcast
                      Zu beachten ist, das sich in deiner Datei
                      jedesmal mindestens ein Zeichen ändern muss (ich füge am Ende einfach leerzeichen ein oder lösche diese.
                      Sonst wird nichts hochgeladen, auch wenn es so aussieht.
                      Es gibt wohl auch eine Möglichkeit das Caching auszuschalten, das hat bei mir aber noch nie richtig funktioniert. Also deswegen immer mit iobroker upload ...
                      Links im Profil
                        @oliverio
                        jampr
                        schrieb am zuletzt editiert von jampr
                        @oliverio
                        mir scheint, ich kann da ändern, was ich will. Da passiert nix. Ich habe in einem anderen Adapter auch eine Variante des Templates gefunden, die auch angelistet wird. Nach einer Änderung in nem HTML-Tag incl Space im js taucht die Änderung nicht auf.
                        edit:
                        natürlich incl des
                        iobroker upload x
                        sogar mit zus
