  4. Mini-HowTo: Cannot find view "system" for search "host"
    6.0k
302 Beiträge 39 Kommentatoren 122.1k Aufrufe 45 Beobachtet
  • A Anzic
    @apollon77
    i mean that when i restart container with iobroker (buanet/iobroker:v6.1.0). The iobroker.json file is reset to the default one, which states that the "file" object base is used instead of "jsonl". At this point, the controller tries to connect to the objects.json file which is generated automatically, which is 23 KB in size. And if I try to set up iobroker with iobroker setup custom specifying the correct "jsonl" as objects db (even if I put the previously saved objects.jsonl file in a folder), it overwrites it using the objects.json.migrated source file and the system doesn't start. So far I have found such a solution for recovery :
    stop iobroker - iob stop
    then I execute pgrep -f '^io.' | xargs kill -9 because not all processes are stopped, and if I don't do this and try to put the correct iobroker.json and objects.jsonl, the system will still overwrite them from the "wrong" objects.json.migrated. Therefore pgrep -f '^io.' | xargs kill -9
    after that I replace the iobroker.json file and objects.jsonl that I saved on the working system.
    and run iob start
    in this order the system starts up. Unfortunately, I have to go to the slave later, and run iob setup custom , i.e. for some reason, he also loses contact with the master.
    root@iobroker:/opt/iobroker# iob isrun
     Cannot read system.config: null (OK when migrating or restoring)
    Objects type: file
    States  type: redis
    Reboot occurs by restarting the container, not power loss.
    "Last entries" before rebooting do not give anything, there are standard logs that are not related to stopping the controller in any way.
    But the first start can be interesting, apparently, the controller cannot find the objects.json file (although why is it looking for it if it should use objects.jsonl). This is probably due to the fact that after a reboot, an entry appears in the iobroker.json file that it is working with the "file", so it tries to "find" it.
    2022-05-11 22:48:04.387  - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-05-11 22:48:04.391  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-05-11 22:48:04.391  - info: host.iobroker hostname: iobroker, node: v14.19.2
    2022-05-11 22:48:04.391  - info: host.iobroker ip addresses: 192.168.1.100 172.23.0.100
    2022-05-11 22:48:04.402  - warn: host.iobroker-Server Configured backup period 120 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
    2022-05-11 22:48:04.406  - error: host.iobroker-Server Cannot load /opt/iobroker/iobroker-data/objects.json: Database file /opt/iobroker/iobroker-data/objects.json does not exists.. We try last Backup!
    2022-05-11 22:48:04.410  - error: host.iobroker-Server Cannot load /opt/iobroker/iobroker-data/objects.json.bak: Database file /opt/iobroker/iobroker-data/objects.json.bak does not exists.. Continue with empty dataset!
    2022-05-11 22:48:04.410  - error: host.iobroker-Server If this is no Migration or initial start please restore the last backup from /opt/iobroker/iobroker-data/backup-objects
    2022-05-11 22:48:04.500  - error: host.iobroker Cannot read system.config: null (OK when migrating or restoring)
    2022-05-11 22:48:04.548  - error: host.iobroker Cannot find view "system" for search "host"
    2022-05-11 22:48:04.589  - info: host.iobroker connected to Objects and States
    2022-05-11 22:48:04.618  - info: host.iobroker added notifications configuration of host
    2022-05-11 22:48:04.621  - warn: host.iobroker logger system.adapter.admin.0.logging was deleted
    2022-05-11 22:48:04.622  - warn: host.iobroker logger system.adapter.javascript.2.logging was deleted
    2022-05-11 22:48:04.623  - warn: host.iobroker logger system.adapter.javascript.0.logging was deleted
    2022-05-11 22:48:04.623  - warn: host.iobroker logger system.adapter.iot.0.logging was deleted
    2022-05-11 22:48:04.664  - error: host.iobroker Cannot find view "system" for search "instance"
    2022-05-11 22:48:04.664  - error: host.iobroker Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2022-05-11 22:48:04.677  - info: host.iobroker Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-05-11 22:48:04.682  - error: host.iobroker Cannot find view "system" for search "host"
    2022-05-11 22:48:04.689  - error: host.iobroker Cannot find view "system" for search "state"
    2022-05-11 22:48:04.689  - error: host.iobroker Cannot find view "system" for search "instance"
    2022-05-11 22:48:04.690  - error: host.iobroker Could not collect system.host.iobroker states to check for obsolete states: Error: Cannot find view "system"
    2022-05-11 22:48:04.690  - error: host.iobroker  _design/system missing - call node iobroker.js setup
    2022-05-11 22:48:04.691  - info: host.iobroker  no instances found
    Perhaps in my case, it will be correct to make a "reverse" migration to "file" and then back to jsonl. Then the "correct" iobroker.json file will be created and at the next reboot, it will simply start using it, which of course is also not entirely true, but at least it will not "break" the whole system, I hope.
    #281
    @anzic the main question is why the objects.json is not existing. It is not broken. It is not existing. So why???
    Please show the content of /opt/iobroker/iobroker-data while running and ideally directly on such a restart.
    Please also show „iob status“ from a running system
    A 3 Antworten Letzte Antwort
    • apollon77A Offline
      #282
      PS: What the variables are set in your container? e.g. IOB_STATESDB_TYPE .. if this is set to "file" then the DB will be reset on any start ... you then needs to adjust that to jsonl
      A 2 Antworten Letzte Antwort
      • apollon77A apollon77
        Anzic
        #283
        Пользователь @apollon77 написал в Mini-HowTo: Cannot find view "system" for search "host":
        IOB_STATESDB_TYPE
        How did I miss this?? Indeed, "file" was written in docker-compose.yml. I'll change it to jsonl and check again. Thanks for the hint.
          Anzic
          #284
          @apollon77 from nas:
          Anzor@NAS:/volume2/doker_mapping/iobroker/iobroker-data$ ls -la
          total 26416
          drwxrwxr-x 1 Anzor users      626 May 12 09:36 .
          drwxrwxr-x 1 Anzor users      764 May 11 22:47 ..
          drwxr-xr-x 1 Anzor users       64 Apr 15 01:12 backitup
          drwxrwxr-x 1 Anzor users     1840 May 12 11:03 backup-objects
          drwxr-xr-x 1 Anzor users      660 Feb 27 21:41 esphome.0
          drwxrwxr-x 1 Anzor users     4128 May 11 02:07 files
          drwxrwxrwx 1 Anzor users       58 Mar 27 13:15 ham_0
          drwxr-xr-x 1 Anzor users        0 Oct 31  2021 homekit-controller.0
          -rw-rwxr-- 1 Anzor users     3593 May 11 23:18 iobroker.json
          drwxr-xr-x 1 Anzor users        0 Jun 30  2020 letsencrypt
          drwxrwxrwx 1 Anzor users       22 Jun 30  2020 lgtv_0
          drwxr-xr-x 1 Anzor users       22 Jul 10  2020 lgtv_1
          drwxrwxrwx 1 Anzor users       24 Jun 30  2020 mercury_0
          drwxrwxrwx 1 Anzor users      200 May 10 23:08 my-backup
          drwxr-xr-x 1 Anzor users      714 May  8 11:35 node-red
          -rw-rw-rw- 1 Anzor users        3 May 11 02:09 notifications.json
          -rw-r--r-- 1 Anzor  1000    23624 May 11 22:48 objects.json.bak.migrated
          -rw-rw-rw- 1 Anzor  1000 26957147 May 12 11:40 objects.jsonl
          -rw-rw-rw- 1 Anzor users    12762 May 11 01:57 objects.jsonl.444
          -rw-rw-rw- 1 Anzor users    12762 May 11 02:01 objects.jsonl.gj
          drwxrwxrwx 1 Anzor  1000        0 May 12 11:40 objects.jsonl.lock
          -rw-r--r-- 1 Anzor  1000    23624 May 11 22:58 objects.json.migrated
          drwxr-xr-x 1 Anzor users       60 Aug  6  2020 sayit
          drwxrwxrwx 1 Anzor users        0 Apr 24 02:01 telegram_0
          drwxrwxrwx 1 Anzor users       32 Sep 11  2021 tmp
          drwxr-xr-x 1 Anzor users       18 Sep 14  2020 tuya_0
          drwxrwxrwx 1 Anzor users      640 May  7 00:19 yahka.0.hapdata
          drwxr-xr-x 1 Anzor users      128 May  2  2021 yahka.1.hapdata
          drwxr-xr-x 1 Anzor users       22 Jun 30  2020 zigbee_0
          from inside of container:
          root@iobroker:/opt/iobroker/iobroker-data# ls -la
          total 26448
          drwxrwxr-x 1 iobroker users         626 May 12 09:36 .
          drwxrwxr-x 1 iobroker users         764 May 11 22:47 ..
          drwxr-xr-x 1 iobroker users          64 Apr 15 01:12 backitup
          drwxrwxr-x 1 iobroker users        1840 May 12 11:03 backup-objects
          drwxr-xr-x 1 iobroker users         660 Feb 27 21:41 esphome.0
          drwxrwxr-x 1 iobroker users        4128 May 11 02:07 files
          drwxrwxrwx 1 iobroker users          58 Mar 27 13:15 ham_0
          drwxr-xr-x 1 iobroker users           0 Oct 31  2021 homekit-controller.0
          -rw-rwxr-- 1 iobroker users        3593 May 11 23:18 iobroker.json
          drwxr-xr-x 1 iobroker users           0 Jun 30  2020 letsencrypt
          drwxrwxrwx 1 iobroker users          22 Jun 30  2020 lgtv_0
          drwxr-xr-x 1 iobroker users          22 Jul 10  2020 lgtv_1
          drwxrwxrwx 1 iobroker users          24 Jun 30  2020 mercury_0
          drwxrwxrwx 1 iobroker users         200 May 10 23:08 my-backup
          drwxr-xr-x 1 iobroker users         714 May  8 11:35 node-red
          -rw-rw-rw- 1 iobroker users           3 May 11 02:09 notifications.json
          -rw-r--r-- 1 iobroker iobroker    23624 May 11 22:48 objects.json.bak.migrated
          -rw-rw-rw- 1 iobroker iobroker 26992013 May 12 11:41 objects.jsonl
          -rw-rw-rw- 1 iobroker users       12762 May 11 01:57 objects.jsonl.444
          -rw-rw-rw- 1 iobroker users       12762 May 11 02:01 objects.jsonl.gj
          drwxrwxrwx 1 iobroker iobroker        0 May 12 11:42 objects.jsonl.lock
          -rw-r--r-- 1 iobroker iobroker    23624 May 11 22:58 objects.json.migrated
          drwxr-xr-x 1 iobroker users          60 Aug  6  2020 sayit
          drwxrwxrwx 1 iobroker users           0 Apr 24 02:01 telegram_0
          drwxrwxrwx 1 iobroker users          32 Sep 11  2021 tmp
          drwxr-xr-x 1 iobroker users          18 Sep 14  2020 tuya_0
          drwxrwxrwx 1 iobroker users         640 May  7 00:19 yahka.0.hapdata
          drwxr-xr-x 1 iobroker users         128 May  2  2021 yahka.1.hapdata
          drwxr-xr-x 1 iobroker users          22 Jun 30  2020 zigbee_0
          root@iobroker:/opt/iobroker/iobroker-data# iob status
          Objects type: jsonl
          States  type: redis
            Anzic
            #285
            @apollon77 weird but changing IOB_STATESDB_TYPE to jsonl didn't help (. The situation is the same as before. What can I do to catch the error?
              Anzic
              schrieb am zuletzt editiert von Anzic
              #286
              first load after stopping the container:
              from host:
              total 32108
              drwxrwxr-x 1 Anzor users      646 May 12 12:15 .
              drwxrwxr-x 1 Anzor users      764 May 12 12:14 ..
              drwxrwxr-x 1 Anzor users     1904 May 12 12:15 backup-objects
              -rw-rwxr-- 1 Anzor users     3593 May 12 12:15 iobroker.json
              -rw-rw-rw- 1 Anzor users        3 May 12 11:51 notifications.json
              -rw-r--r-- 1 Anzor  1000    23624 May 12 12:15 objects.json
              -rw-r--r-- 1 Anzor  1000    23624 May 12 12:15 objects.json.bak
              -rw-r--r-- 1 Anzor users    23624 May 11 22:48 objects.json.bak.migrated
              -rw-rw-rw- 1 Anzor users 32737610 May 12 12:15 objects.jsonl
              -rw-r--r-- 1 Anzor users    23624 May 11 22:58 objects.json.migrated
              from container:
              total 32108
              drwxrwxr-x 1 iobroker users         646 May 12 12:15 .
              drwxrwxr-x 1 iobroker users         764 May 12 12:14 ..
              drwxrwxr-x 1 iobroker users        1904 May 12 12:15 backup-objects
              -rw-rwxr-- 1 iobroker users        3593 May 12 12:15 iobroker.json
              -rw-rw-rw- 1 iobroker users           3 May 12 11:51 notifications.json
              -rw-r--r-- 1 iobroker iobroker    23624 May 12 12:15 objects.json
              -rw-r--r-- 1 iobroker iobroker    23624 May 12 12:15 objects.json.bak
              -rw-r--r-- 1 iobroker users       23624 May 11 22:48 objects.json.bak.migrated
              -rw-rw-rw- 1 iobroker users    32737610 May 12 12:15 objects.jsonl
              -rw-r--r-- 1 iobroker users       23624 May 11 22:58 objects.json.migrated
              iobroker.json - iobroker.json
              I think I know the answer. I changed the docker compose, but the container remained with the old settings, so everything breaks. Now I will recreate the container and check.
                Anzic
                #287
                @apollon77 no luck. after recreating the container, the objects.jsonl file is still overwritten
                immediately after creating the container:
                total 112
                drwxrwxr-x 1 iobroker users      590 May 12 12:46 .
                drwxrwxr-x 1 iobroker users      764 May 12 12:38 ..
                drwxrwxr-x 1 iobroker users     1968 May 12 12:38 backup-objects
                -rw-rwxr-- 1 iobroker users     3601 May 12 12:43 iobroker.json
                -rw-r--r-- 1 iobroker iobroker 23624 May 12 12:38 objects.json.bak.migrated
                -rw-r--r-- 1 iobroker iobroker 24253 May 12 12:43 objects.jsonl
                -rw-r--r-- 1 iobroker iobroker 23624 May 12 12:38 objects.json.migrated
                • Fix_FlixF Offline
                  Fix_FlixF Offline
                  Fix_Flix
                  #288
                  meine Backups sind leider zu alt sprich die Datein sind zu alt und alle kaputt ssssssss2022-05-31 214910.png ich habe aber noch Scrssssssssssseenshot 2022-05-31 215000.png hilft das?
                  LG Felix
                  Thomas BraunT R 2 Antworten Letzte Antwort
                  • Fix_FlixF Fix_Flix
                    LG Felix
                    #289
                    @fix_flix
                    Bilder von Konsolentext kann man nicht lesen oder gar daraus was kopieren.
                    Stell TEXT auch als TEXT (in CodeTags eingebettet) hier rein.
                    Fix_FlixF 1 Antwort Letzte Antwort
                      LG Felix
                      rieders
                      #290
                      Hallo
                      In meinem Verzeichnis vom IOBroker fehlt die objects.jsonl Datei.
                      Unter iobrker staus bekomme ich diese Meldung.
                      Objects type: jsonl
                      States type: jsonl
                      Wie kann ich die jsonl Datei wieder herstellen?
                      André
                      Thomas BraunT apollon77A 2 Antworten Letzte Antwort
                      • R rieders
                        Hallo
                        Objects type: jsonl
                        States type: jsonl
                        André
                        #291
                        @rieders sagte in Mini-HowTo: Cannot find view "system" for search "host":
                        In welchem? Die Verzeichnisse haben sich nicht geändert, lediglich die Datei-Endung.
                        R 1 Antwort Letzte Antwort
                        • R rieders
                          Hallo
                          Objects type: jsonl
                          States type: jsonl
                          André
                          #292
                          @rieders Welche Files haste denn? und was ist so in backup-objects verzeichnis?
                            rieders
                            #293
                            Die Datei hat sich wieder angelegt!!!!
                            Ich habe aber noch probleme das sich Objekte von Fhem nicht importieren lassen.
                            Die laufen über MQTT.
                            Unter Iobroker erhalte ich diese Meldung
                            fhem.0.Wasserzaehler_garten.: Error: The id "fhem.0.Wasserzaehler_garten." is invalid. Ids are not allowed to end in "." [main] [eventFHEM] [processEvent] [parseEvent] [eventOK] [setState] [processSetState] [setStateDoWrite]
                            Vielen Dank für die schnellen Antworten
                            André
                            • R rieders
                              André
                              #294
                              Aber bitte in einen anderen/eigenen Thread. Das hat mit dem Thema hier nix zu tun.
                              • R rieders
                                André
                                #295
                                @rieders Dann schau bei den Issues zum FHEM Adapter oder leg was an oder wenn du nen namen mit nem punkt am ende definiert hast oder irgendwie ein name fehlt in FHEM fixe vllt das
                                  @fix_flix
                                  Fix_FlixF Offline
                                  Fix_FlixF Offline
                                  Fix_Flix
                                  schrieb am zuletzt editiert von Fix_Flix
                                  #296
                                  @thomas-braun ```
                                  pi@raspberrypi:~ $ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:00 2022-06-06_00-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:01 2022-06-06_00-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:03 2022-06-06_00-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:04 2022-06-06_00-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:05 2022-06-06_00-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:07 2022-06-06_00-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:08 2022-06-06_00-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:09 2022-06-06_00-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:10 2022-06-06_00-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:11 2022-06-06_00-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:12 2022-06-06_00-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:13 2022-06-06_00-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:15 2022-06-06_00-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:16 2022-06-06_00-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:17 2022-06-06_00-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:18 2022-06-06_00-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:19 2022-06-06_00-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:20 2022-06-06_00-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:22 2022-06-06_00-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:24 2022-06-06_00-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:25 2022-06-06_00-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:26 2022-06-06_00-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:27 2022-06-06_00-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:29 2022-06-06_00-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:30 2022-06-06_00-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:31 2022-06-06_00-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:33 2022-06-06_00-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:35 2022-06-06_00-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:36 2022-06-06_00-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:37 2022-06-06_00-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:38 2022-06-06_00-38_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:39 2022-06-06_00-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:40 2022-06-06_00-40_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:41 2022-06-06_00-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:42 2022-06-06_00-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:44 2022-06-06_00-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:45 2022-06-06_00-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:46 2022-06-06_00-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:47 2022-06-06_00-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:49 2022-06-06_00-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:50 2022-06-06_00-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:51 2022-06-06_00-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:52 2022-06-06_00-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:53 2022-06-06_00-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:55 2022-06-06_00-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:56 2022-06-06_00-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:57 2022-06-06_00-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:58 2022-06-06_00-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 00:59 2022-06-06_00-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:00 2022-06-06_01-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:01 2022-06-06_01-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:03 2022-06-06_01-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:04 2022-06-06_01-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:05 2022-06-06_01-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:07 2022-06-06_01-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:08 2022-06-06_01-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:09 2022-06-06_01-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:10 2022-06-06_01-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:11 2022-06-06_01-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:13 2022-06-06_01-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:15 2022-06-06_01-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:16 2022-06-06_01-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:18 2022-06-06_01-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:20 2022-06-06_01-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:21 2022-06-06_01-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:23 2022-06-06_01-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:24 2022-06-06_01-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:25 2022-06-06_01-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:26 2022-06-06_01-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:27 2022-06-06_01-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:28 2022-06-06_01-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:30 2022-06-06_01-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:31 2022-06-06_01-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:32 2022-06-06_01-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:33 2022-06-06_01-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:34 2022-06-06_01-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:35 2022-06-06_01-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:36 2022-06-06_01-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:37 2022-06-06_01-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:38 2022-06-06_01-38_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:39 2022-06-06_01-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:41 2022-06-06_01-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:42 2022-06-06_01-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:43 2022-06-06_01-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:45 2022-06-06_01-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:46 2022-06-06_01-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:47 2022-06-06_01-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:48 2022-06-06_01-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:49 2022-06-06_01-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:50 2022-06-06_01-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:51 2022-06-06_01-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:52 2022-06-06_01-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:53 2022-06-06_01-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:54 2022-06-06_01-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:55 2022-06-06_01-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:56 2022-06-06_01-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:57 2022-06-06_01-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:58 2022-06-06_01-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 01:59 2022-06-06_01-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:00 2022-06-06_02-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:01 2022-06-06_02-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:02 2022-06-06_02-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:03 2022-06-06_02-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:04 2022-06-06_02-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:05 2022-06-06_02-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:06 2022-06-06_02-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:07 2022-06-06_02-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:08 2022-06-06_02-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:10 2022-06-06_02-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:12 2022-06-06_02-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:14 2022-06-06_02-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:15 2022-06-06_02-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:17 2022-06-06_02-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:18 2022-06-06_02-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:19 2022-06-06_02-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:20 2022-06-06_02-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:22 2022-06-06_02-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:24 2022-06-06_02-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:25 2022-06-06_02-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:26 2022-06-06_02-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:27 2022-06-06_02-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:28 2022-06-06_02-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:29 2022-06-06_02-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:30 2022-06-06_02-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:32 2022-06-06_02-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:33 2022-06-06_02-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:34 2022-06-06_02-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:35 2022-06-06_02-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:36 2022-06-06_02-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:37 2022-06-06_02-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:39 2022-06-06_02-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:40 2022-06-06_02-40_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:41 2022-06-06_02-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:42 2022-06-06_02-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:43 2022-06-06_02-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:45 2022-06-06_02-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:46 2022-06-06_02-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:47 2022-06-06_02-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:48 2022-06-06_02-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:49 2022-06-06_02-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:50 2022-06-06_02-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:51 2022-06-06_02-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:52 2022-06-06_02-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:54 2022-06-06_02-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:55 2022-06-06_02-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:56 2022-06-06_02-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:57 2022-06-06_02-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:58 2022-06-06_02-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 02:59 2022-06-06_02-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:00 2022-06-06_03-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:01 2022-06-06_03-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:03 2022-06-06_03-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:05 2022-06-06_03-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:07 2022-06-06_03-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:08 2022-06-06_03-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:09 2022-06-06_03-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:10 2022-06-06_03-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:11 2022-06-06_03-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:12 2022-06-06_03-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:13 2022-06-06_03-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:14 2022-06-06_03-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:15 2022-06-06_03-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:16 2022-06-06_03-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:18 2022-06-06_03-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:19 2022-06-06_03-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:20 2022-06-06_03-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:21 2022-06-06_03-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:22 2022-06-06_03-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:24 2022-06-06_03-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:25 2022-06-06_03-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:26 2022-06-06_03-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:27 2022-06-06_03-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:28 2022-06-06_03-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:29 2022-06-06_03-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:30 2022-06-06_03-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:31 2022-06-06_03-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:32 2022-06-06_03-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:34 2022-06-06_03-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:35 2022-06-06_03-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:37 2022-06-06_03-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:38 2022-06-06_03-38_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:39 2022-06-06_03-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:41 2022-06-06_03-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:42 2022-06-06_03-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:43 2022-06-06_03-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:44 2022-06-06_03-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:45 2022-06-06_03-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:46 2022-06-06_03-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:47 2022-06-06_03-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:48 2022-06-06_03-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:49 2022-06-06_03-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:50 2022-06-06_03-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:51 2022-06-06_03-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:52 2022-06-06_03-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:53 2022-06-06_03-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:54 2022-06-06_03-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:55 2022-06-06_03-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:57 2022-06-06_03-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:58 2022-06-06_03-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 03:59 2022-06-06_03-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:00 2022-06-06_04-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:02 2022-06-06_04-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:03 2022-06-06_04-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:04 2022-06-06_04-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:05 2022-06-06_04-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:06 2022-06-06_04-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:07 2022-06-06_04-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:08 2022-06-06_04-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:09 2022-06-06_04-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:10 2022-06-06_04-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:11 2022-06-06_04-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:13 2022-06-06_04-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:14 2022-06-06_04-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:15 2022-06-06_04-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:16 2022-06-06_04-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:17 2022-06-06_04-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:18 2022-06-06_04-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:19 2022-06-06_04-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:20 2022-06-06_04-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:21 2022-06-06_04-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:22 2022-06-06_04-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:23 2022-06-06_04-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:24 2022-06-06_04-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:25 2022-06-06_04-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:26 2022-06-06_04-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:27 2022-06-06_04-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:28 2022-06-06_04-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:30 2022-06-06_04-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:31 2022-06-06_04-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:32 2022-06-06_04-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:33 2022-06-06_04-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:34 2022-06-06_04-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:35 2022-06-06_04-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:36 2022-06-06_04-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:37 2022-06-06_04-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:39 2022-06-06_04-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:40 2022-06-06_04-40_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:42 2022-06-06_04-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:43 2022-06-06_04-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:44 2022-06-06_04-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:46 2022-06-06_04-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:48 2022-06-06_04-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:49 2022-06-06_04-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:50 2022-06-06_04-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:51 2022-06-06_04-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:52 2022-06-06_04-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:53 2022-06-06_04-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:54 2022-06-06_04-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:55 2022-06-06_04-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:56 2022-06-06_04-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:57 2022-06-06_04-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:58 2022-06-06_04-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 04:59 2022-06-06_04-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:00 2022-06-06_05-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:01 2022-06-06_05-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:02 2022-06-06_05-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:03 2022-06-06_05-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:04 2022-06-06_05-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:05 2022-06-06_05-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:06 2022-06-06_05-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:07 2022-06-06_05-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:08 2022-06-06_05-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:09 2022-06-06_05-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:10 2022-06-06_05-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:11 2022-06-06_05-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:13 2022-06-06_05-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:14 2022-06-06_05-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:15 2022-06-06_05-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:17 2022-06-06_05-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:18 2022-06-06_05-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:19 2022-06-06_05-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:20 2022-06-06_05-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:21 2022-06-06_05-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:22 2022-06-06_05-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:23 2022-06-06_05-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:24 2022-06-06_05-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:25 2022-06-06_05-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:26 2022-06-06_05-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:27 2022-06-06_05-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:28 2022-06-06_05-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:29 2022-06-06_05-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:30 2022-06-06_05-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:31 2022-06-06_05-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:32 2022-06-06_05-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:33 2022-06-06_05-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:34 2022-06-06_05-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:35 2022-06-06_05-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:36 2022-06-06_05-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:37 2022-06-06_05-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:39 2022-06-06_05-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:41 2022-06-06_05-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:42 2022-06-06_05-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:43 2022-06-06_05-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:44 2022-06-06_05-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:45 2022-06-06_05-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:46 2022-06-06_05-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:48 2022-06-06_05-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:49 2022-06-06_05-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:50 2022-06-06_05-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:51 2022-06-06_05-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:53 2022-06-06_05-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:54 2022-06-06_05-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:55 2022-06-06_05-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:56 2022-06-06_05-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:57 2022-06-06_05-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:58 2022-06-06_05-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 05:59 2022-06-06_05-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:00 2022-06-06_06-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:01 2022-06-06_06-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:02 2022-06-06_06-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:03 2022-06-06_06-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:04 2022-06-06_06-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:05 2022-06-06_06-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:06 2022-06-06_06-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:07 2022-06-06_06-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:09 2022-06-06_06-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:11 2022-06-06_06-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:12 2022-06-06_06-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:13 2022-06-06_06-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:14 2022-06-06_06-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:15 2022-06-06_06-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:16 2022-06-06_06-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:17 2022-06-06_06-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:18 2022-06-06_06-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:19 2022-06-06_06-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:20 2022-06-06_06-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:21 2022-06-06_06-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:23 2022-06-06_06-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:24 2022-06-06_06-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:25 2022-06-06_06-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:26 2022-06-06_06-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:27 2022-06-06_06-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:28 2022-06-06_06-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:29 2022-06-06_06-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:30 2022-06-06_06-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:31 2022-06-06_06-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:33 2022-06-06_06-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:34 2022-06-06_06-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:35 2022-06-06_06-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:37 2022-06-06_06-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:38 2022-06-06_06-38_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:39 2022-06-06_06-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:41 2022-06-06_06-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:42 2022-06-06_06-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:43 2022-06-06_06-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:44 2022-06-06_06-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:45 2022-06-06_06-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:46 2022-06-06_06-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:47 2022-06-06_06-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:48 2022-06-06_06-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:49 2022-06-06_06-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:50 2022-06-06_06-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:51 2022-06-06_06-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:52 2022-06-06_06-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:53 2022-06-06_06-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:55 2022-06-06_06-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:56 2022-06-06_06-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:57 2022-06-06_06-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:58 2022-06-06_06-58_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 06:59 2022-06-06_06-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:00 2022-06-06_07-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:01 2022-06-06_07-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:03 2022-06-06_07-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:04 2022-06-06_07-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:05 2022-06-06_07-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:06 2022-06-06_07-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:07 2022-06-06_07-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:08 2022-06-06_07-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:09 2022-06-06_07-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:10 2022-06-06_07-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:12 2022-06-06_07-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:13 2022-06-06_07-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:14 2022-06-06_07-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:15 2022-06-06_07-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:16 2022-06-06_07-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:17 2022-06-06_07-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:18 2022-06-06_07-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:19 2022-06-06_07-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:20 2022-06-06_07-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:21 2022-06-06_07-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:22 2022-06-06_07-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:23 2022-06-06_07-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:25 2022-06-06_07-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:26 2022-06-06_07-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:28 2022-06-06_07-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:30 2022-06-06_07-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:31 2022-06-06_07-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:33 2022-06-06_07-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:34 2022-06-06_07-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:35 2022-06-06_07-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:36 2022-06-06_07-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:37 2022-06-06_07-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:38 2022-06-06_07-38_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:39 2022-06-06_07-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:40 2022-06-06_07-40_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:41 2022-06-06_07-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:42 2022-06-06_07-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:43 2022-06-06_07-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:44 2022-06-06_07-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:45 2022-06-06_07-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:46 2022-06-06_07-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:47 2022-06-06_07-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:48 2022-06-06_07-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:49 2022-06-06_07-49_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:50 2022-06-06_07-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:51 2022-06-06_07-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:52 2022-06-06_07-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:53 2022-06-06_07-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:54 2022-06-06_07-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:55 2022-06-06_07-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:56 2022-06-06_07-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:57 2022-06-06_07-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 07:59 2022-06-06_07-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:00 2022-06-06_08-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:01 2022-06-06_08-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:02 2022-06-06_08-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:03 2022-06-06_08-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:04 2022-06-06_08-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:05 2022-06-06_08-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:06 2022-06-06_08-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:07 2022-06-06_08-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:08 2022-06-06_08-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:09 2022-06-06_08-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:10 2022-06-06_08-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:11 2022-06-06_08-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:12 2022-06-06_08-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:13 2022-06-06_08-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:14 2022-06-06_08-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:15 2022-06-06_08-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:17 2022-06-06_08-17_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:19 2022-06-06_08-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:20 2022-06-06_08-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:21 2022-06-06_08-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:22 2022-06-06_08-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:23 2022-06-06_08-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:24 2022-06-06_08-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:25 2022-06-06_08-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:27 2022-06-06_08-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:28 2022-06-06_08-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:29 2022-06-06_08-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:30 2022-06-06_08-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:32 2022-06-06_08-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:33 2022-06-06_08-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:34 2022-06-06_08-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:35 2022-06-06_08-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:36 2022-06-06_08-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:37 2022-06-06_08-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:39 2022-06-06_08-39_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:40 2022-06-06_08-40_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:41 2022-06-06_08-41_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:43 2022-06-06_08-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:44 2022-06-06_08-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:45 2022-06-06_08-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:46 2022-06-06_08-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:47 2022-06-06_08-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:48 2022-06-06_08-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:50 2022-06-06_08-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:51 2022-06-06_08-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:52 2022-06-06_08-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:53 2022-06-06_08-53_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:54 2022-06-06_08-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:55 2022-06-06_08-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:57 2022-06-06_08-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 08:59 2022-06-06_08-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:00 2022-06-06_09-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:01 2022-06-06_09-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:02 2022-06-06_09-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:04 2022-06-06_09-04_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:05 2022-06-06_09-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:06 2022-06-06_09-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:07 2022-06-06_09-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:08 2022-06-06_09-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:09 2022-06-06_09-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:10 2022-06-06_09-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:11 2022-06-06_09-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:12 2022-06-06_09-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:13 2022-06-06_09-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:14 2022-06-06_09-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:15 2022-06-06_09-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:16 2022-06-06_09-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:18 2022-06-06_09-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:19 2022-06-06_09-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:20 2022-06-06_09-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:22 2022-06-06_09-22_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:23 2022-06-06_09-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:24 2022-06-06_09-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:25 2022-06-06_09-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:26 2022-06-06_09-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:27 2022-06-06_09-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:28 2022-06-06_09-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:30 2022-06-06_09-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:31 2022-06-06_09-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:32 2022-06-06_09-32_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:34 2022-06-06_09-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:35 2022-06-06_09-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:36 2022-06-06_09-36_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:37 2022-06-06_09-37_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:38 2022-06-06_09-38_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:40 2022-06-06_09-40_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:42 2022-06-06_09-42_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:43 2022-06-06_09-43_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:44 2022-06-06_09-44_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:45 2022-06-06_09-45_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:46 2022-06-06_09-46_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:47 2022-06-06_09-47_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:48 2022-06-06_09-48_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:50 2022-06-06_09-50_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:51 2022-06-06_09-51_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:52 2022-06-06_09-52_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:54 2022-06-06_09-54_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:55 2022-06-06_09-55_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:56 2022-06-06_09-56_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:57 2022-06-06_09-57_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 09:59 2022-06-06_09-59_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:00 2022-06-06_10-00_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:01 2022-06-06_10-01_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:02 2022-06-06_10-02_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:03 2022-06-06_10-03_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:05 2022-06-06_10-05_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:06 2022-06-06_10-06_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:07 2022-06-06_10-07_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:08 2022-06-06_10-08_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:09 2022-06-06_10-09_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:10 2022-06-06_10-10_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:11 2022-06-06_10-11_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:12 2022-06-06_10-12_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:13 2022-06-06_10-13_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:14 2022-06-06_10-14_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:15 2022-06-06_10-15_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:16 2022-06-06_10-16_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:18 2022-06-06_10-18_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:19 2022-06-06_10-19_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:20 2022-06-06_10-20_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:21 2022-06-06_10-21_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:23 2022-06-06_10-23_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:24 2022-06-06_10-24_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:25 2022-06-06_10-25_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:26 2022-06-06_10-26_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:27 2022-06-06_10-27_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:28 2022-06-06_10-28_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:29 2022-06-06_10-29_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:30 2022-06-06_10-30_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:31 2022-06-06_10-31_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:33 2022-06-06_10-33_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:34 2022-06-06_10-34_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:35 2022-06-06_10-35_objects.json.gz
                                  -rw-rw-r--+ 1 iobroker iobroker 1.1K Jun  6 10:37 2022-06-06_10-37_objects.json.gz
                                    @thomas-braun ```
                                    #297
                                    @fix_flix
                                    Und nun?
                                      @thomas-braun ```
                                      #298
                                      @fix_flix Tja dann such mal ein Backup raus
                                        User, die plötzlich nicht mehr in den ioBroker kommen und auf der Kommandozeile auf ein freundliches
                                        iobroker status
                                        so frech begrüßt werden:
                                        iobroker status
                                        können mal folgendes versuchen:
                                        Mit
                                        bekommt man so etwas in der Art zu sehen:
                                        total 19240
                                        -rw-rwxr--+ 1 iobroker iobroker 895277 Mar 16 16:23 2021-03-16_16-23_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 113674 Mar 16 16:23 2021-03-16_16-23_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 113571 Mar 16 16:47 2021-03-16_16-47_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 895066 Mar 16 16:48 2021-03-16_16-48_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 112795 Mar 16 16:51 2021-03-16_16-51_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker      0 Mar 16 16:53 2021-03-16_16-53_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   3505 Mar 16 16:56 2021-03-16_16-56_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker      0 Mar 16 16:56 2021-03-16_16-56_states.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker   3505 Mar 16 16:57 2021-03-16_16-57_objects.json.gz
                                        -rw-rwxr--+ 1 iobroker iobroker 112864 Mar 16 16:57 2021-03-16_16-57_states.json.gz
                                        Man schaut wann zuerst 'auffällige' Dateien mit Dateigröße 0 oder auffälligem Schwund zwischen zwei Dateien auftauchen, wie hier:
                                        -rw-rw-r--+ 1 iobroker iobroker 1681373 Mar 16 18:00 2021-03-16_18-00_objects.json.gz
                                        -rw-rw-r--+ 1 iobroker iobroker    3504 Mar 16 18:11 2021-03-16_18-11_objects.json.gz
                                        und guckt sich die letzten intakten Dateien davor aus. Im Beispiel diese:
                                        Die gleiche Übung muss ggf. auch für die states-Datenbank durchgeführt werden.
                                        Mit
                                        ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
                                        sieht man die, dann weiter wie oben mit den objects schon geschehen.
                                        Mit folgender Befehlsfolge kann man u. U. den ioBroker wieder beleben:
                                        (Bei Verwendung von jsonl ändern sich die Dateinamen entsprechend! Dann also json durch jsonl ersetzen!)
                                        iobroker stop
                                        cd /opt/iobroker/iobroker-data/
                                        mv objects.json objects.json.old
                                        mv states.json states.json.old
                                        cd backup-objects/
                                        gunzip -ck INTAKTE_DATEI_objects.json.gz > /opt/iobroker/iobroker-data/objects.json
                                        gunzip -ck INTAKTE_DATEI_states.json.gz > /opt/iobroker/iobroker-data/states.json
                                        iobroker start
                                        INTAKTE_DATEI dabei mit dem zuvor ausgeguckten Dateinamen ersetzen.
                                        Mit freundlicher Empfehlung von @wendy2702
                                        frank62
                                        #299
                                        @thomas-braun said in Mini-HowTo: Cannot find view "system" for search "host":
                                        Moin,
                                        wenn ich diese Befehle ausführe, steht da nix drin...
                                        pi@pi-unten:/opt/iobroker $ iobroker version
                                        4.0.23
                                        pi@pi-unten:/opt/iobroker $ iobroker status
                                        iobroker is not running on this host.
                                        Objects type: jsonl
                                        States  type: jsonl
                                        pi@pi-unten:/opt/iobroker $ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep objects
                                        pi@pi-unten:/opt/iobroker $ ls -lh /opt/iobroker/iobroker-data/backup-objects/ | grep states
                                        MfG
                                        Frank62
                                        • F frank62
                                          Moin,
                                          4.0.23
                                          Objects type: jsonl
                                          States  type: jsonl
                                          #300
                                          @frank62
                                          Dann liegen da keine Dateien mit 'states' oder 'objects' im Namen drin.
                                          Sollten aber eigentlich. Warum das bei dir nicht der Fall ist: Keine Ahnung.
                                          Was liegt denn da überhaupt drin?
