  4. Installation schlägt immer fehl..
    6.6k
24 Beiträge 3 Kommentatoren 2.6k Aufrufe 2 Beobachtet
    timy
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Raspberry 3 B+
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte 16Gb
    Betriebssystem: Raspberry
    Node-Version: 12
    Nodejs-Version: 12
    NPM-Version: 6
    Installationsart: wie auf der Homepage Anleitung
    Image genutzt: Nein
    Ort/Name der Imagedatei: kein Image
    Ich bekomme immer diesen Fehler... Danach bricht es ab. System ist auf dem neuesten Stand. Node sowie NBM auch
    Kann damit wenig anfangen...
    Installing ioBroker (3/4)
    In file included from ../../nan/nan.h:56,
    from ../src/main.cpp:3:
    /root/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void ()(v8::Localv8::Object)’ to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void*)’} [-Wcast-function-type]
    (node::addon_register_func) (regfunc),
    /root/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
    NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
    ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
    NODE_MODULE(diskusage, Init)
    from ../src/unix_dgram.cc:5:
    ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
    NODE_MODULE(unix_dgram, Initialize)
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
    ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
    uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
    ../src/serialport.cpp: At global scope:
    ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
    SerialPortParity NAN_INLINE(ToParityEnum(const v8::Localv8::String& v8str)) {
    ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
    SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
    In file included from ../../../nan/nan.h:56,
    from ../src/./serialport.h:6,
    from ../src/serialport.cpp:1:
    /root/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void ()(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void ()(v8::Localv8::Object)’} to ‘node::addon_register_func’ {aka ‘void ()(v8::Localv8::Object, v8::Localv8::Value, void)’} [-Wcast-function-type]
    ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
    NODE_MODULE(serialport, init);
    ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
    ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
    snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
    ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
    ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
    snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
    ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
    ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
    ioBroker wants to make sure to deliver the most stable smart home system.
    To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
    THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
    For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
    If you want to disable the error reporting you can use the command
    'iobroker plugin disable sentry'
    This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
    • T timy
      Node-Version: 12
      Nodejs-Version: 12
      NPM-Version: 6
      Image genutzt: Nein
      @timy sagte in Installation schlägt immer fehl..:
      /root/.ca
      Du hampelst da als root rum.
        /root/.ca
        timy
        @thomas-braun ist egal ob root oder nicht...
        Fehlermeldung kommt trotzdem
        • T timy
          @timy
          Was machst du denn genau?
          Die Installation erfolgt in einem Einzeiler als user pi.
          Da kann man eigentlich gar nix falsch machen.
          Die Anmeldung als root ist allerdings schon ein grundlegender Fehler. Einfach nicht machen!
            @timy
            timy
            ich habe die Installation so gemacht wie es hier steht für die Beere
            Aber jedesmal kommt Fehler.
            https://www.iobroker.net/#de/documentation/install/linux.md
            Selbst wenn ich es von hier hole geht es nicht.
            https://www.iobroker.net/#de/download
            Die installation vom OS ist frisch ein update wurde auch gemacht.
            • T timy
              @timy
              Mach die Kiste platt und dann NIE als root anmelden.
              Als user pi
              curl -sLf https://iobroker.net/install.sh | bash -
              eingeben, fertig.
                @timy
                Als user pi
                eingeben, fertig.
                timy
                @thomas-braun habe ich gemacht...
                Auch Fehler...
                • T timy
                  Auch Fehler...
                  @timy Das ist Schade.
                  Komplette Ausgabe posten, in CodeTags!
                  Und ich will da nix von /root drin lesen.
                    timy
                    @thomas-braun mehr zeigt es nicht...
                    Das was ich gepostet habe ist schon komplett
                    • T timy
                      @timy Dann nochmal...
                      System plattmachen.
                      System installieren, updaten, rebooten,
                      eingeben, fertig. Nicht root werden. Nie.
                        System plattmachen.
                        timy
                        @thomas-braun den nodejs nicht vorher installieren?
                        Ansonsten einfach nur den curl Befehl?
                        • T timy
                          @timy
                          Nur diese eine kleine Zeile. Mehr ist gar nicht erforderlich, auf einem sauberen Grundsystem.
                            @timy
                            timy
                            @thomas-braun okay.
                            update läuft gerade noch auf neuem System.
                            ich probiere es.
                            • T timy
                              Auch Fehler...
                              Auch Fehler...
                              Vielleicht kann ich da mehr sehen, wenn es in code-tags ist, aber ich meine da ist kein Fehler!
                                Auch Fehler...
                                Außer der Installation als root ist da ja auch keiner. 🕶
                                  timy
                                  und wieder der Fehler...
                                  pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash
                                  library: loaded
                                  Library version=2021-01-23
                                      Welcome to the ioBroker installer!
                                      Installer version: 2020-12-07
                                      You might need to enter your password a couple of times.
                                      Installing prerequisites (1/4)
                                  Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                                  Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
                                  Holen:4 http://packages.microsoft.com/repos/code stable/main armhf Packages [15,6 kB]
                                  Holen:5 http://packages.microsoft.com/repos/code stable/main arm64 Packages [15,8 kB]
                                  Holen:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [15,2 kB]
                                  Es wurden 72,0 kB in 2 s geholt (38,1 kB/s).
                                      Node.js not found. Installing...
                                  ## Installing the NodeSource Node.js 12.x repo...
                                  ## Populating apt-get cache...
                                  + apt-get update
                                  OK:1 http://packages.microsoft.com/repos/code stable InRelease
                                  OK:3 http://archive.raspberrypi.org/debian buster InRelease
                                  ## Confirming "buster" is supported...
                                  + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
                                  ## Adding the NodeSource signing key to your keyring...
                                  + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                                  OK
                                  ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
                                  + echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
                                  + echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
                                  ## Running `apt-get update` for you...
                                  + apt-get update
                                  OK:3 http://packages.microsoft.com/repos/code stable InRelease
                                  Holen:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
                                  Holen:5 https://deb.nodesource.com/node_12.x buster/main armhf Packages [774 B]
                                  Es wurden 5.358 B in 2 s geholt (2.248 B/s).
                                  ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
                                  ## You may also need development tools to build native addons:
                                       sudo apt-get install gcc g++ make
                                  ## To install the Yarn package manager, run:
                                       curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                                       echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                                       sudo apt-get update && sudo apt-get install yarn
                                  Installed nodejs
                                  Node.js Installed successfully!
                                  Changing npm registry to https://registry.npmjs.org
                                  Installed gcc-c++
                                  Installed libavahi-compat-libdnssd-dev
                                  Installed libudev-dev
                                  Installed libpam0g-dev
                                  Installed libcairo2-dev
                                  Installed libpango1.0-dev
                                  Installed libjpeg-dev
                                  Installed libgif-dev
                                  Installed librsvg2-dev
                                      Creating ioBroker user and directory (2/4)
                                  User iobroker created
                                  Created /etc/sudoers.d/iobroker
                                  Directory /opt/iobroker created
                                  /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                         (node::addon_register_func) (regfunc),                          \
                                  /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
                                  ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                  ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
                                   SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
                                  /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                                  Danach habe ich ein reboot durchgeführt aber gestartet wurde da nichts...
                                  Thomas BraunT T HomoranH 3 Antworten Letzte Antwort
                                  • T timy
                                    library: loaded
                                    + apt-get update
                                    OK
                                    + apt-get update
                                    Installed nodejs
                                    Installed gcc-c++
                                    @timy
                                    iobroker status
                                    • T timy
                                      library: loaded
                                      + apt-get update
                                      OK
                                      + apt-get update
                                      Installed nodejs
                                      Installed gcc-c++
                                      timy
                                      habe noch
                                      durchgeführt danach
                                      ibroker start
                                      danach ist es gestartet...
                                      Aber irgendwie schon sehr komisch
                                        @timy
                                        iobroker status
                                        timy
                                        @thomas-braun da kam das..
                                        pi@raspberrypi:~ $ iobroker status
                                        -bash: iobroker: Kommando nicht gefunden.
                                        wie gesagt mit der reparatur hat es dann geklappt.
                                        • T timy
                                          habe noch
                                          durchgeführt danach
                                          ibroker start
                                          @timy
                                          Der Fixer war vermutlich unnötig.
                                          Aber schadet auch nix.
