  4. Installation schlägt immer fehl..
    6.6k
24 Beiträge 3 Kommentatoren 2.6k Aufrufe 2 Beobachtet
    @timy
    Der Fixer war vermutlich unnötig.
    Aber schadet auch nix.
    timy
    @thomas-braun der fixer hat das dann gerade gerückt.
    danach konnte ich iobroker den status auslesen usw
    • T timy
      und wieder der Fehler...
      pi@raspberrypi:~ $ curl -sLf https://iobroker.net/install.sh | bash
      library: loaded
      Library version=2021-01-23
          Welcome to the ioBroker installer!
          Installer version: 2020-12-07
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
      Holen:3 http://packages.microsoft.com/repos/code stable InRelease [10,4 kB]
      Holen:4 http://packages.microsoft.com/repos/code stable/main armhf Packages [15,6 kB]
      Holen:5 http://packages.microsoft.com/repos/code stable/main arm64 Packages [15,8 kB]
      Holen:6 http://packages.microsoft.com/repos/code stable/main amd64 Packages [15,2 kB]
      Es wurden 72,0 kB in 2 s geholt (38,1 kB/s).
          Node.js not found. Installing...
      ## Installing the NodeSource Node.js 12.x repo...
      ## Populating apt-get cache...
      + apt-get update
      OK:1 http://packages.microsoft.com/repos/code stable InRelease
      OK:3 http://archive.raspberrypi.org/debian buster InRelease
      ## Confirming "buster" is supported...
      + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_12.x/dists/buster/Release'
      ## Adding the NodeSource signing key to your keyring...
      + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
      OK
      ## Creating apt sources list file for the NodeSource Node.js 12.x repo...
      + echo 'deb https://deb.nodesource.com/node_12.x buster main' > /etc/apt/sources.list.d/nodesource.list
      + echo 'deb-src https://deb.nodesource.com/node_12.x buster main' >> /etc/apt/sources.list.d/nodesource.list
      ## Running `apt-get update` for you...
      + apt-get update
      OK:3 http://packages.microsoft.com/repos/code stable InRelease
      Holen:4 https://deb.nodesource.com/node_12.x buster InRelease [4.584 B]
      Holen:5 https://deb.nodesource.com/node_12.x buster/main armhf Packages [774 B]
      Es wurden 5.358 B in 2 s geholt (2.248 B/s).
      ## Run `sudo apt-get install -y nodejs` to install Node.js 12.x and npm
      ## You may also need development tools to build native addons:
           sudo apt-get install gcc g++ make
      ## To install the Yarn package manager, run:
           curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
           echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
           sudo apt-get update && sudo apt-get install yarn
      Installed nodejs
      Node.js Installed successfully!
      Changing npm registry to https://registry.npmjs.org
      Installed gcc-c++
      Installed libavahi-compat-libdnssd-dev
      Installed libudev-dev
      Installed libpam0g-dev
      Installed libcairo2-dev
      Installed libpango1.0-dev
      Installed libjpeg-dev
      Installed libgif-dev
      Installed librsvg2-dev
          Creating ioBroker user and directory (2/4)
      User iobroker created
      Created /etc/sudoers.d/iobroker
      Directory /opt/iobroker created
          Installing ioBroker (3/4)
      In file included from ../../nan/nan.h:56,
                       from ../src/main.cpp:3:
      /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
             (node::addon_register_func) (regfunc),                          \
      /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:771:3: note: in expansion of macro ‘NODE_MODULE_X’
         NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(diskusage, Init)
                       from ../src/unix_dgram.cc:5:
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(unix_dgram, Initialize)
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:271:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:316:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:366:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:412:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
       SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
      ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
       SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      In file included from ../../../nan/nan.h:56,
                       from ../src/./serialport.h:6,
                       from ../src/serialport.cpp:1:
      /home/pi/.cache/node-gyp/12.21.0/include/node/node.h:737:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
       NODE_MODULE(serialport, init);
      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
      ../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
           snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
      ../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
           snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
      ATTENTION: Error reporting via Sentry will be activated on next start of ioBroker
      ioBroker wants to make sure to deliver the most stable smart home system.
      To allow this we decided to implement an automatic error and crash reporting solution into the js-controller and also into adapters.
      THIS REPORTING WILL BE ENABLED WITH THE NEXT START OF YOUR IOBROKER!
      For any error that leads to the crash of the js-controller or one of the relevant adapters the error details are send to a server. For the js-controller and core adapters this server is located and operated in germany. For community adapters please check the Github Readme of the affected adapter for details which Sentry server is used.
      If you want to disable the error reporting you can use the command
      'iobroker plugin disable sentry'
      This command will also make sure that no adapter that runs on this host will send crash reporting data to sentry.
      Danach habe ich ein reboot durchgeführt aber gestartet wurde da nichts...
      @timy sagte in Installation schlägt immer fehl..:
      da war er noch nicht fertig!
      Er ist fertig wenn das da auch steht:
      Installation fertig, öffne IP:801...
      Oder so ähnlich
        Oder so ähnlich
        timy
        @homoran der war fertig...
        es kam danach die bash und nichts weiter.
        • T timy
          der war fertig...
          dann hast du nicht alles gepostet
