  4. [gelöst] keine Adapter Updates mehr möglich
gelöst
45 Beiträge 4 Kommentatoren 5.0k Aufrufe 2 Beobachtet
  • DiginixD Offline
    DiginixD Offline
    Diginix
    schrieb am zuletzt editiert von Diginix
    Bei der iobroker Installation war es noch npm 7.5 was ich dan auf 6.14 gedowngraded habe. Ob es daran liegt, kann ich nicht erkennen.
    Systemdata
    Hardwaresystem: NUC7i3
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu
    Node-Version: 12.21.0
    Nodejs-Version: 12.21.0
    NPM-Version: 6.14.11
    Installationsart: Skript
    Image genutzt: Nein
    Ausgabe beim Update übe die GUI:
    $ ./iobroker upgrade mqtt
    Update mqtt from @2.3.4 to @2.3.5
    NPM version: 6.14.11
    npm install iobroker.mqtt@2.3.5 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! Error while executing:
    npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/halloamt/ioBroker.frontier_silicon.gitnpm ERR!
    npm ERR! Host key verification failed.
    npm ERR! fatal: Could not read from remote repository.npm ERR! npm ERR! Please make sure you have the correct access rightsnpm ERR! and the repository exists.
    npm ERR! npm ERR! exited with error code: 128
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2021-02-27T11_33_42_632Z-debug.log
    upload [3] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
    upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
    upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index_m.html index_m.html text/html
    upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/index.html index.html text/html
    Adapter "mqtt" updated
    process exited with code 0
    Ausgabe bei Update über Kommandozeile:
    iobroker@iobroker:/opt/iobroker$ iob upgrade mqtt
    This upgrade of "mqtt" will introduce the following changes:
    -> 2.3.5:
    js-controller 2.0 is now required at least
    change default subscribe to mqtt.0.*
    Would you like to upgrade mqtt from @2.3.4 to @2.3.5 now? [(y)es, (n)o]: y
    The authenticity of host 'github.com (140.82.121.3)' can't be established.
    RSA key fingerprint is SHA256:nThbg6kXUpJWGl7E1IGOCspRomTxdCARLviKw6E5SY8.
    Are you sure you want to continue connecting (yes/no/[fingerprint])? y
    Please type 'yes', 'no' or the fingerprint: yes
    npm ERR!
    npm ERR! Warning: Permanently added 'github.com,140.82.121.3' (RSA) to the list of known hosts.
    npm ERR! git@github.com: Permission denied (publickey).
    npm ERR!
    npm ERR!
    npm ERR!     /home/iobroker/.npm/_logs/2021-02-27T11_49_14_936Z-debug.log
    iob fix und npm rebuild liefen durch, aber die Ausgabe von npm rebuild ist länger als die max erlaubten Zeichen hier.
    Installer Info:
    Installer version: 2020-12-07
    Installation date 2021-02-18
    Platform: linux
    init system: systemd
    Autostart: systemd
    ACL enabled: true
    Fixer version: 2020-12-07
    Fix date 2021-02-24
    ACL enabled: true
    Autostart: systemd
    Fix date 2021-02-27
    ACL enabled: true
    Autostart: systemd
    nodejs, node, npm:
    iobroker@iobroker:/opt/iobroker$ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    /usr/bin/nodejs
    v12.21.0
    /usr/bin/node
    v12.21.0
    /usr/bin/npm
    6.14.11
    nodejs:
      Installed: 12.21.0-deb-1nodesource1
      Candidate: 12.21.0-deb-1nodesource1
      Version table:
     *** 12.21.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x focal/main amd64 Packages
            100 /var/lib/dpkg/status
         10.19.0~dfsg-3ubuntu1 500
            500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
    ..:: So long! Tom ::..
    FredFF 1 Antwort Letzte Antwort
    • DiginixD Diginix
      Systemdata
      Festplattenart: SSD
      Image genutzt: Nein
      -> 2.3.5:
      npm ERR!
      npm ERR!
      npm ERR!
      Installer Info:
      Platform: linux
      Autostart: systemd
      ACL enabled: true
      Fix date 2021-02-24
      ACL enabled: true
      Autostart: systemd
      Fix date 2021-02-27
      ACL enabled: true
      Autostart: systemd
      nodejs, node, npm:
      /usr/bin/nodejs
      v12.21.0
      /usr/bin/node
      v12.21.0
      /usr/bin/npm
      6.14.11
      nodejs:
        Version table:
      FredFF Online
      FredFF Online
      FredF
      Most Active Forum Testing
      @diginix sagte in keine Adapter Updates mehr möglich:
      Anscheinend erreichst du die Github Seite nicht.
      Gib mal die 140.82.121.3 im Browser ein.
      • FredFF FredF
        DiginixD Offline
        DiginixD Offline
        Diginix
        @fredf Ist ein Ubuntu Server ohne GUI. Ping liefert das:
        iobroker@iobroker:/opt/iobroker$  ping -c 1 github.com
        PING github.com (140.82.121.3) 56(84) bytes of data.
        64 bytes from lb-140-82-121-3-fra.github.com (140.82.121.3): icmp_seq=1 ttl=54 time=37.1 ms
        --- github.com ping statistics ---
        1 packets transmitted, 1 received, 0% packet loss, time 0ms
        rtt min/avg/max/mdev = 37.123/37.123/37.123/0.000 ms
        • DiginixD Diginix
          FredFF Online
          FredFF Online
          FredF
          @diginix
          hmm, es wird aber auch erfolg gemeldet
          • FredFF FredF
            @diginix
            DiginixD Offline
            DiginixD Offline
            Diginix
            @fredf Bleibt aber auf der alten Ver. Gleiches auch bei einem anderen Adapter.
            package.json und io-package.json enthalten auch die alte Ver.Nr
            • DiginixD Diginix
              @diginix
              npm7 benötigt tw. eine andere Syntax in den jsons.
              Daher sollte das noch nicht in Verbindung mit ioBroker genutzt werden.
              sagt?
                @diginix
                sagt?
                DiginixD Offline
                DiginixD Offline
                Diginix
                @thomas-braun steht im op letzter Spoiler.
                Und ich bin ja deswegen zurück auf npm 6.
                FredFF Thomas BraunT 3 Antworten Letzte Antwort
                • DiginixD Diginix
                  FredFF Online
                  FredFF Online
                  FredF
                  @diginix dann klinke ich mich mal aus @Thomas-Braun wirds schon richten 👍
                  • DiginixD Diginix
                    @diginix
                    Spoiler haken auf meinem Handy, deswegen klicke ich die nie auf.
                    • DiginixD Diginix
                      @diginix
                      iobroker update
                      iobroker upgrade
                        @diginix
                        iobroker update
                        iobroker upgrade
                        DiginixD Offline
                        DiginixD Offline
                        Diginix
                        @thomas-braun auch schon gemacht
                        Da werden mir eben die Updates für die mqtt und lupusec angeboten, die sich bisher auf keine Weise installieren lassen.
                        Hier nochmal alle Details:
                        /usr/bin/nodejs
                        v12.21.0
                        /usr/bin/node
                        v12.21.0
                        /usr/bin/npm
                        6.14.11
                        nodejs:
                          Version table:
                        Ich könnte alles sauber neu aufsetzen, aber das is irgendwie nicht befiedigend. Für mich wäre interessant ob beim Downgrad von npm noch was zu beachten ist.
                        Müssen alle Adapter neu gebaut werden?
                        • DiginixD Diginix
                          /usr/bin/nodejs
                          v12.21.0
                          /usr/bin/node
                          v12.21.0
                          /usr/bin/npm
                          6.14.11
                          nodejs:
                            Version table:
                          @diginix
                          Wie bist du eigentlich an npm@7 gekommen? Händisch global in das System gekleistert?
                            @diginix
                            DiginixD Offline
                            DiginixD Offline
                            Diginix
                            @thomas-braun sudo npm install -g npm@latest
                            und zurück mit sudo npm install -g npm@6
                            • DiginixD Diginix
                              @diginix
                              Macht man nicht...
                              sudo which npm -v
                                @diginix
                                Macht man nicht...
                                sudo which npm -v
                                DiginixD Offline
                                DiginixD Offline
                                Diginix
                                @thomas-braun sagte in keine Adapter Updates mehr möglich:
                                sudo which npm -v
                                iobroker@iobroker:/opt/iobroker$ sudo which npm -v
                                /usr/bin/npm
                                iobroker@iobroker:/opt/iobroker$ sudo npm -v
                                6.14.11
                                Was macht man nicht? Das NPM installieren?
                                Die Frage ist ja auch ob es überhaupt daran liegt oder doch an Netzwerk Dingen. Weil ja der Hinweis von Fred kam mit:
                                • DiginixD Diginix
                                  sudo which npm -v
                                  /usr/bin/npm
                                  6.14.11
                                  @diginix
                                  Ja, npm aktualisiert man besser nicht von Hand.
                                  Kommt meist nix gescheites bei herum, wie man sieht.
                                  Vollständige Ausgabe von
                                  iobroker update && iobroker upgrade
                                  iobroker ist auch kein guter Username für einen Standard-User. Der ist eigentlich für den gleichnamigen Systemuser vorgesehen.
                                    @diginix
                                    DiginixD Offline
                                    DiginixD Offline
                                    Diginix
                                    iobroker@iobroker:/opt/iobroker$ iobroker update && iobroker upgrade
                                    Used repository: beta
                                    hash unchanged, use cached sources
                                    update done
                                    Adapter    "accuweather"   : 1.1.5
                                    Adapter    "adb"           : 0.0.5
                                    Adapter    "admin"         : 4.2.1    , installed 4.2.1
                                    Adapter    "alarm"         : 1.9.0
                                    Adapter    "alexa2"        : 3.8.1    , installed 3.8.1
                                    Adapter    "alias-manager" : 0.0.6
                                    Adapter    "alpha2"        : 1.0.0
                                    Adapter    "amazon-dash"   : 1.1.0
                                    Adapter    "artnet"        : 1.2.2
                                    Adapter    "asterisk"      : 1.0.6
                                    Adapter    "asuswrt"       : 1.0.1
                                    Adapter    "b-control-em"  : 0.2.1
                                    Adapter    "backitup"      : 2.0.0    , installed 2.0.1
                                    Adapter    "beckhoff"      : 1.4.0
                                    Adapter    "benq"          : 0.2.4
                                    Adapter    "binance"       : 1.1.3
                                    Adapter    "ble"           : 0.12.0
                                    Adapter    "blink4home"    : 0.1.1
                                    Adapter    "bmw"           : 1.4.0
                                    Adapter    "boblight"      : 0.0.1
                                    Adapter    "bosesoundtouch": 0.9.3
                                    Adapter    "botvac"        : 1.0.0
                                    Adapter    "bring"         : 1.7.7
                                    Adapter    "broadlink2"    : 2.1.5
                                    Adapter    "bsblan"        : 0.2.0
                                    Adapter    "bshb"          : 0.1.13
                                    Adapter    "calendar"      : 1.2.0
                                    Adapter    "cameras"       : 0.1.3
                                    Adapter    "canbus"        : 1.0.0
                                    Adapter    "cec2"          : 0.1.0
                                    Adapter    "chromecast"    : 2.3.1
                                    Adapter    "cloud"         : 4.0.10
                                    Adapter    "comfoair"      : 1.1.3
                                    Adapter    "contact"       : 1.1.3
                                    Adapter    "contactid"     : 1.0.2
                                    Adapter    "coronavirus-statistics": 0.6.8
                                    Adapter    "corrently"     : 0.0.2
                                    Adapter    "countdown"     : 1.1.0
                                    Adapter    "cul"           : 1.3.4
                                    Adapter    "daikin"        : 1.3.0
                                    Adapter    "daswetter"     : 3.0.4    , installed 3.0.4
                                    Adapter    "deconz"        : 1.3.11
                                    Adapter    "denon"         : 1.10.4
                                    Adapter    "device-reminder": 1.0.6
                                    Adapter    "devices"       : 0.3.15
                                    Adapter    "diashow"       : 0.1.0
                                    Adapter    "digitalstrom"  : 2.0.5
                                    Adapter    "discovergy"    : 0.5.4
                                    Adapter    "discovery"     : 2.5.0    , installed 2.5.0
                                    Adapter    "doorbird"      : 0.1.5
                                    Adapter    "doorio"        : 1.1.2
                                    Adapter    "ds18b20"       : 1.4.0
                                    Adapter    "dwd"           : 2.7.5    , installed 2.7.5
                                    Adapter    "dysonairpurifier": 0.8.0-pre
                                    Adapter    "ebus"          : 2.2.4
                                    Adapter    "echarts"       : 0.4.11
                                    Adapter    "ecovacs-deebot": 1.1.1
                                    Adapter    "egigeozone"    : 0.1.2
                                    Adapter    "ekey"          : 1.1.0
                                    Adapter    "email"         : 1.0.9    , installed 1.0.9
                                    Adapter    "emby"          : 1.0.2
                                    Adapter    "energymanager" : 1.2.3
                                    Adapter    "enet"          : 1.0.1
                                    Adapter    "epson_ecotank_et_2750": 0.0.4
                                    Adapter    "epson_stylus_px830": 0.2.1
                                    Adapter    "eventlist"     : 0.4.2
                                    Adapter    "exchangerates" : 0.0.14
                                    Adapter    "fahrplan"      : 1.0.5
                                    Adapter    "fakeroku"      : 0.2.1
                                    Adapter    "fb-checkpresence": 1.1.0   , installed 1.1.2
                                    Adapter    "feiertage"     : 1.0.19   , installed 1.0.19
                                    Adapter    "fhem"          : 1.5.3
                                    Adapter    "find-my-iphone": 0.2.17
                                    Adapter    "firetv"        : 1.0.0
                                    Adapter    "fitbit-api"    : 0.1.1
                                    Adapter    "flot"          : 1.10.6   , installed 1.10.6
                                    Adapter    "followthesun"  : 0.3.2
                                    Adapter    "foobar2000"    : 2.0.4
                                    Adapter    "fritzbox"      : 0.2.1
                                    Adapter    "fritzdect"     : 2.1.7
                                    Adapter    "fronius"       : 1.1.1
                                    Adapter    "frontier_silicon": 0.0.10  , installed 0.0.10
                                    Adapter    "fuelpricemonitor": 0.1.4
                                    Adapter    "fullcalendar"  : 1.1.0
                                    Adapter    "fullybrowser"  : 2.0.5
                                    Adapter    "g-homa"        : 0.5.3
                                    Adapter    "geofency"      : 1.0.0
                                    Adapter    "go-e"          : 1.0.2
                                    Adapter    "growatt"       : 1.0.0
                                    Adapter    "gruenbeck"     : 0.0.28
                                    Adapter    "haassohn"      : 1.0.3
                                    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
                                    Adapter    "haier"         : 1.0.4
                                    Adapter    "ham"           : 3.0.2
                                    Adapter    "ham-wemo"      : 1.1.0
                                    Adapter    "harmony"       : 1.2.2
                                    Adapter    "hass"          : 1.0.0
                                    Adapter    "hass-mqtt"     : 0.0.7
                                    Adapter    "heatingcontrol": 2.2.0
                                    Adapter    "heos"          : 1.7.7
                                    Adapter    "heytech"       : 1.0.1
                                    Adapter    "hid"           : 0.1.17
                                    Adapter    "hilink"        : 0.2.7
                                    Adapter    "history"       : 1.9.12   , installed 1.9.12
                                    Adapter    "hm-rega"       : 3.0.16
                                    Adapter    "hm-rpc"        : 1.14.35
                                    Adapter    "hmip"          : 1.9.0
                                    Adapter    "hombot"        : 0.1.3
                                    Adapter    "homeconnect"   : 0.0.32
                                    Adapter    "homee"         : 1.1.0
                                    Adapter    "homepilot"     : 1.1.4
                                    Adapter    "hp-ilo"        : 1.0.6
                                    Adapter    "hs100"         : 2.0.3
                                    Adapter    "hue"           : 3.5.2
                                    Adapter    "hue-extended"  : 2.0.0
                                    Adapter    "hyperion"      : 0.0.9
                                    Adapter    "i2c"           : 1.1.1
                                    Adapter    "ical"          : 1.9.1    , installed 1.9.1
                                    Adapter    "icons-addictive-flavour-png": 0.1.0
                                    Adapter    "icons-fatcow-hosting": 0.1.0
                                    Adapter    "icons-icons8"  : 0.0.1
                                    Adapter    "icons-material-png": 0.1.0
                                    Adapter    "icons-material-svg": 0.1.0
                                    Adapter    "icons-mfd-png" : 1.0.2
                                    Adapter    "icons-mfd-svg" : 1.0.2
                                    Adapter    "icons-open-icon-library-png": 0.1.2
                                    Adapter    "icons-ultimate-png": 1.0.1
                                    Adapter    "influxdb"      : 1.9.4
                                    Adapter    "info"          : 1.7.15   , installed 1.7.15
                                    Adapter    "innogy-smarthome": 0.3.6
                                    Adapter    "intesishome"   : 0.1.2
                                    Adapter    "iogo"          : 0.6.6
                                    Adapter    "iot"           : 1.8.13   , installed 1.8.13
                                    Adapter    "iqontrol"      : 1.6.1
                                    Adapter    "jarvis"        : 2.2.0    , installed 2.2.0
                                    Adapter    "javascript"    : 4.11.0   , installed 4.11.0
                                    Adapter    "jeelink"       : 0.1.3
                                    Controller "js-controller" : 3.2.16   , installed 3.2.16
                                    Adapter    "js2fs"         : 0.1.5
                                    Adapter    "kecontact"     : 1.0.1
                                    Adapter    "klf200"        : 1.0.1
                                    Adapter    "km200"         : 2.0.3
                                    Adapter    "knmi-weather"  : 1.0.0
                                    Adapter    "knx"           : 1.0.44
                                    Adapter    "kodi"          : 2.0.5
                                    Adapter    "kostal-piko-ba": 1.1.5
                                    Adapter    "kress"         : 2.5.5
                                    Adapter    "lametric"      : 1.2.0
                                    Adapter    "landroid"      : 1.0.3
                                    Adapter    "lcn"           : 1.0.2
                                    Adapter    "legrand-ecocompteur": 1.0.0
                                    Adapter    "letrika_comgw" : 0.0.5
                                    Adapter    "lg-ess-home"   : 0.0.8
                                    Adapter    "lgtv"          : 1.1.10
                                    Adapter    "lgtv-rs"       : 0.1.1
                                    Adapter    "lgtv11"        : 1.0.5
                                    Adapter    "lifx"          : 0.1.1
                                    Adapter    "lightify"      : 0.2.16
                                    Adapter    "link"          : 0.5.10
                                    Adapter    "linkeddevices" : 1.4.2
                                    Adapter    "linktap"       : 0.1.7
                                    Adapter    "linux-control" : 1.1.2
                                    Adapter    "logparser"     : 1.1.0
                                    Adapter    "lovelace"      : 1.4.3
                                    Adapter    "loxone"        : 2.1.0
                                    Adapter    "luftdaten"     : 1.0.2
                                    Adapter    "lupusec"       : 1.3.3    , installed 1.3.2 [Updateable]
                                    Adapter    "luxtronik1"    : 0.3.0
                                    Adapter    "material"      : 0.13.9   , installed 0.13.9
                                    Adapter    "maxcube"       : 1.0.2
                                    Adapter    "maxcul"        : 1.3.1
                                    Adapter    "mbus"          : 2.3.2
                                    Adapter    "mclighting"    : 0.1.2
                                    Adapter    "megad"         : 1.2.1
                                    Adapter    "megadd"        : 0.2.0
                                    Adapter    "megaesp"       : 0.1.0
                                    Adapter    "melcloud"      : 1.1.1
                                    Adapter    "mercedesme"    : 0.0.45
                                    Adapter    "mercury"       : 0.1.4
                                    Adapter    "meross"        : 1.5.1
                                    Adapter    "meteoalarm"    : 1.1.1
                                    Adapter    "midea"         : 0.0.6
                                    Adapter    "miele"         : 0.1.5
                                    Adapter    "mielecloudservice": 3.0.0-beta
                                    Adapter    "mihome"        : 1.3.7    , installed 1.3.7
                                    Adapter    "mihome-airpurifier": 0.1.8
                                    Adapter    "mihome-lamp"   : 1.1.0
                                    Adapter    "mihome-plug"   : 0.2.1    , installed 0.2.1
                                    Adapter    "mihome-vacuum" : 2.1.1    , installed 2.2.4
                                    Adapter    "miio"          : 0.0.13
                                    Adapter    "mikrotik"      : 1.0.16
                                    Adapter    "milight"       : 0.3.6
                                    Adapter    "milight-smart-light": 1.2.0
                                    Adapter    "minuvis"       : 1.3.1
                                    Adapter    "mobile"        : 1.0.1
                                    Adapter    "modbus"        : 3.2.4    , installed 3.2.4
                                    Adapter    "moma"          : 1.2.7
                                    Adapter    "mpd"           : 1.0.6
                                    Adapter    "mqtt"          : 2.3.5    , installed 2.3.4 [Updateable]
                                    Adapter    "mqtt-client"   : 1.3.1
                                    Adapter    "multicast"     : 0.1.5
                                    Adapter    "musiccast"     : 0.1.5
                                    Adapter    "mydlink"       : 1.1.7
                                    Adapter    "myq"           : 0.1.1
                                    Adapter    "mysensors"     : 2.0.1
                                    Adapter    "mystrom"       : 0.0.2
                                    Adapter    "mytime"        : 0.6.1
                                    Adapter    "myvbus"        : 0.0.6
                                    Adapter    "nanoleaf-lightpanels": 1.2.0
                                    Adapter    "net-tools"     : 0.1.2
                                    Adapter    "netatmo"       : 1.3.3
                                    Adapter    "netatmo-crawler": 0.3.9
                                    Adapter    "nibeuplink"    : 0.4.0
                                    Adapter    "nina"          : 0.0.24
                                    Adapter    "node-red"      : 2.1.0
                                    Adapter    "noolitef"      : 0.0.2
                                    Adapter    "nuki"          : 1.4.3
                                    Adapter    "nuki-extended" : 2.3.0
                                    Adapter    "nut"           : 1.4.3
                                    Adapter    "octoprint"     : 1.0.8
                                    Adapter    "odl"           : 1.1.4
                                    Adapter    "oilfox"        : 2.1.0
                                    Adapter    "omnicomm-lls"  : 0.0.7
                                    Adapter    "omron-fins"    : 0.0.1
                                    Adapter    "onkyo"         : 2.0.3    , installed 2.0.3
                                    Adapter    "onvif"         : 0.4.4
                                    Adapter    "openhab"       : 1.1.0
                                    Adapter    "openligadb"    : 1.2.0
                                    Adapter    "opentherm"     : 0.1.9
                                    Adapter    "openweathermap": 0.1.0
                                    Adapter    "opi"           : 0.1.1
                                    Adapter    "oppoplayer"    : 0.2.1
                                    Adapter    "owfs"          : 0.6.4
                                    Adapter    "owntracks"     : 1.0.0
                                    Adapter    "palazzetti"    : 0.0.6
                                    Adapter    "panasonic-viera": 1.0.2
                                    Adapter    "parser"        : 1.0.7    , installed 1.0.7
                                    Adapter    "paw"           : 0.3.2
                                    Adapter    "phantomjs"     : 1.1.2
                                    Adapter    "philips-air"   : 0.1.0
                                    Adapter    "pi-hole"       : 1.3.1
                                    Adapter    "piface"        : 1.0.0
                                    Adapter    "pimatic"       : 0.3.0
                                    Adapter    "ping"          : 1.4.12   , installed 1.4.12
                                    Adapter    "places"        : 1.0.0
                                    Adapter    "plenticore"    : 2.1.7    , installed 2.1.7
                                    Adapter    "plex"          : 0.9.1
                                    Adapter    "plexconnect"   : 0.0.7
                                    Adapter    "pollenflug"    : 1.0.6
                                    Adapter    "procon-ip"     : 1.0.2
                                    Adapter    "proxmox"       : 1.2.0    , installed 1.2.0
                                    Adapter    "proxy"         : 1.2.1
                                    Adapter    "pushbullet"    : 0.0.11
                                    Adapter    "pushover"      : 2.0.3
                                    Adapter    "pushsafer"     : 1.0.3
                                    Adapter    "radar2"        : 2.0.1    , installed 2.0.1
                                    Adapter    "radiohead"     : 1.1.1
                                    Adapter    "rainbird"      : 0.2.2
                                    Adapter    "rflink"        : 2.1.6
                                    Adapter    "rickshaw"      : 1.0.0
                                    Adapter    "ring"          : 1.1.3
                                    Adapter    "roadtraffic"   : 0.2.0
                                    Adapter    "robonect"      : 0.1.4
                                    Adapter    "roomba"        : 1.1.1
                                    Adapter    "rpi2"          : 1.2.0
                                    Adapter    "rssfeed"       : 0.0.30
                                    Adapter    "s7"            : 1.2.4
                                    Adapter    "samsung"       : 0.2.9    , installed 0.2.9
                                    Adapter    "sanext"        : 0.0.5
                                    Adapter    "sayit"         : 1.12.2
                                    Adapter    "sbfspot"       : 4.0.4
                                    Adapter    "scenes"        : 2.3.6
                                    Adapter    "schoolfree"    : 0.7.0
                                    Adapter    "schwoerer-ventcube": 1.3.0
                                    Adapter    "senec"         : 1.1.0
                                    Adapter    "seq"           : 0.2.9
                                    Adapter    "shelly"        : 4.0.7-beta-1, installed 4.0.7-beta-1
                                    Adapter    "shuttercontrol": 1.1.5
                                    Adapter    "sia"           : 1.0.4
                                    Adapter    "siegenia"      : 1.1.0
                                    Adapter    "simple-api"    : 2.5.3    , installed 2.5.3
                                    Adapter    "sma-em"        : 0.6.1-beta.0
                                    Adapter    "smappee"       : 0.2.4
                                    Adapter    "smartcontrol"  : 1.2.1
                                    Adapter    "smartgarden"   : 1.0.4
                                    Adapter    "smartmeter"    : 3.2.0
                                    Adapter    "snips"         : 1.5.1
                                    Adapter    "snmp"          : 0.5.0
                                    Adapter    "socketio"      : 3.1.4    , installed 3.1.4
                                    Adapter    "solarlog"      : 2.0.1
                                    Adapter    "solarviewdatareader": 0.2.1
                                    Adapter    "solarwetter"   : 1.0.0
                                    Adapter    "sonnen"        : 1.7.0
                                    Adapter    "sonoff"        : 2.4.0    , installed 2.4.0
                                    Adapter    "sonos"         : 2.1.1
                                    Adapter    "sonus"         : 0.1.1
                                    Adapter    "sony-bravia"   : 1.0.3
                                    Adapter    "sourceanalytix": 0.4.8
                                    Adapter    "spotify-premium": 1.0.0
                                    Adapter    "sprinklecontrol": 0.1.2
                                    Adapter    "sql"           : 1.15.5
                                    Adapter    "squeezebox"    : 1.0.0
                                    Adapter    "squeezeboxrpc" : 1.3.3
                                    Adapter    "starline"      : 1.1.3
                                    Adapter    "statistics"    : 1.0.2    , installed 0.2.2 [Updateable]
                                    Adapter    "stiebel-isg"   : 1.6.0
                                    Adapter    "stockmarket"   : 0.0.2
                                    Adapter    "sunnyportal"   : 0.1.5
                                    Adapter    "swiss-weather-api": 0.3.2
                                    Adapter    "synology"      : 0.1.20
                                    Adapter    "systeminfo"    : 0.3.1
                                    Adapter    "tado"          : 0.2.5
                                    Adapter    "tahoma"        : 0.3.3
                                    Adapter    "tankerkoenig"  : 2.0.10
                                    Adapter    "telegram"      : 1.8.0    , installed 1.8.0
                                    Adapter    "terminal"      : 0.1.2
                                    Adapter    "tesla-motors"  : 0.3.2
                                    Adapter    "text2command"  : 2.0.7    , installed 2.0.7
                                    Adapter    "tileboard"     : 0.3.1
                                    Adapter    "time-switch"   : 2.2.1
                                    Adapter    "tinker"        : 1.1.0
                                    Adapter    "tino"          : 1.0.0
                                    Adapter    "tinyrx4"       : 1.0.0
                                    Adapter    "todoist2"      : 0.8.5
                                    Adapter    "tr-064"        : 4.2.6    , installed 4.2.6
                                    Adapter    "tradfri"       : 2.7.0
                                    Adapter    "trashschedule" : 1.1.1
                                    Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                    Adapter    "tuya"          : 3.5.6
                                    Adapter    "tvprogram"     : 0.0.31
                                    Adapter    "tvspielfilm"   : 2.0.1
                                    Adapter    "twinkly"       : 0.1.8
                                    Adapter    "unifi"         : 0.5.8
                                    Adapter    "unifi-protect" : 0.0.11
                                    Adapter    "upnp"          : 1.0.17
                                    Adapter    "vaillant"      : 0.0.11
                                    Adapter    "valloxmv"      : 1.1.2
                                    Adapter    "valuetrackerovertime": 0.6.0
                                    Adapter    "vcard"         : 0.0.9
                                    Adapter    "vedirect"      : 0.1.2
                                    Adapter    "velux"         : 0.0.7
                                    Adapter    "viessmann"     : 1.3.3
                                    Adapter    "viessmannapi"  : 1.3.2
                                    Adapter    "virtualpowermeter": 1.4.2
                                    Adapter    "vis"           : 1.3.7
                                    Adapter    "vis-bars"      : 0.1.4
                                    Adapter    "vis-canvas-gauges": 0.1.5
                                    Adapter    "vis-colorpicker": 1.2.0
                                    Adapter    "vis-fancyswitch": 1.1.0
                                    Adapter    "vis-google-fonts": 0.1.0
                                    Adapter    "vis-history"   : 1.0.0
                                    Adapter    "vis-hqwidgets" : 1.1.7
                                    Adapter    "vis-icontwo"   : 0.45.0
                                    Adapter    "vis-inventwo"  : 2.7.11
                                    Adapter    "vis-jqui-mfd"  : 1.0.12
                                    Adapter    "vis-justgage"  : 1.0.2
                                    Adapter    "vis-keyboard"  : 0.0.2
                                    Adapter    "vis-lcars"     : 1.0.4
                                    Adapter    "vis-map"       : 1.0.4
                                    Adapter    "vis-material"  : 0.1.3
                                    Adapter    "vis-material-advanced": 1.3.0
                                    Adapter    "vis-material-webfont": 0.0.3
                                    Adapter    "vis-materialdesign": 0.4.2
                                    Adapter    "vis-metro"     : 1.1.2
                                    Adapter    "vis-players"   : 0.1.6
                                    Adapter    "vis-plumb"     : 1.0.2
                                    Adapter    "vis-rgraph"    : 0.0.2
                                    Adapter    "vis-timeandweather": 1.1.7
                                    Adapter    "vis-weather"   : 2.5.2
                                    Adapter    "vodafone-speedtest": 0.0.6
                                    Adapter    "volvo"         : 0.0.3
                                    Adapter    "vr200"         : 1.0.0
                                    Adapter    "vw-connect"    : 0.0.30
                                    Adapter    "weatherflow_udp": 0.0.15
                                    Adapter    "weatherunderground": 3.3.0
                                    Adapter    "web"           : 3.3.0    , installed 3.3.0
                                    Adapter    "web-speedy"    : 0.2.0
                                    Adapter    "weishaupt-wem" : 0.0.9
                                    Adapter    "whatsapp-cmb"  : 0.1.6
                                    Adapter    "wiffi-wz"      : 2.2.0
                                    Adapter    "wifilight"     : 1.1.0
                                    Adapter    "windows-control": 0.1.5
                                    Adapter    "wlanthermo-nano": 0.1.1
                                    Adapter    "wled"          : 0.5.6
                                    Adapter    "wm-bus"        : 0.3.1
                                    Adapter    "wolf"          : 1.2.1
                                    Adapter    "worx"          : 1.2.7
                                    Adapter    "xbox"          : 0.7.3
                                    Adapter    "xs1"           : 1.0.2
                                    Adapter    "yahka"         : 0.13.1
                                    Adapter    "yamaha"        : 0.4.0
                                    Adapter    "yeelight-2"    : 1.0.3    , installed 1.0.3
                                    Adapter    "youtube"       : 1.0.3
                                    Adapter    "yr"            : 2.0.3
                                    Adapter    "zigbee"        : 1.4.4
                                    Adapter    "zoneminder"    : 0.3.3
                                    Adapter    "zont"          : 0.5.4
                                    Adapter    "zwave"         : 2.0.1
                                    Adapter    "zwave2"        : 1.8.12
                                    Adapter "accuweather"    is not installed.
                                    Adapter "adb"            is not installed.
                                    Adapter "admin"          is up to date.
                                    Adapter "alarm"          is not installed.
                                    Adapter "alexa2"         is up to date.
                                    Adapter "alias-manager"  is not installed.
                                    Adapter "alpha2"         is not installed.
                                    Adapter "amazon-dash"    is not installed.
                                    Adapter "artnet"         is not installed.
                                    Adapter "asterisk"       is not installed.
                                    Adapter "asuswrt"        is not installed.
                                    Adapter "b-control-em"   is not installed.
                                    Adapter "backitup"       is up to date.
                                    Adapter "beckhoff"       is not installed.
                                    Adapter "benq"           is not installed.
                                    Adapter "binance"        is not installed.
                                    Adapter "ble"            is not installed.
                                    Adapter "blink4home"     is not installed.
                                    Adapter "bmw"            is not installed.
                                    Adapter "boblight"       is not installed.
                                    Adapter "bosesoundtouch" is not installed.
                                    Adapter "botvac"         is not installed.
                                    Adapter "bring"          is not installed.
                                    Adapter "broadlink2"     is not installed.
                                    Adapter "bsblan"         is not installed.
                                    Adapter "bshb"           is not installed.
                                    Adapter "calendar"       is not installed.
                                    Adapter "cameras"        is not installed.
                                    Adapter "canbus"         is not installed.
                                    Adapter "cec2"           is not installed.
                                    Adapter "chromecast"     is not installed.
                                    Adapter "cloud"          is not installed.
                                    Adapter "comfoair"       is not installed.
                                    Adapter "contact"        is not installed.
                                    Adapter "contactid"      is not installed.
                                    Adapter "coronavirus-statistics" is not installed.
                                    Adapter "corrently"      is not installed.
                                    Adapter "countdown"      is not installed.
                                    Adapter "cul"            is not installed.
                                    Adapter "daikin"         is not installed.
                                    Adapter "daswetter"      is up to date.
                                    Adapter "deconz"         is not installed.
                                    Adapter "denon"          is not installed.
                                    Adapter "device-reminder" is not installed.
                                    Adapter "devices"        is not installed.
                                    Adapter "diashow"        is not installed.
                                    Adapter "digitalstrom"   is not installed.
                                    Adapter "discovergy"     is not installed.
                                    Adapter "discovery"      is up to date.
                                    Adapter "doorbird"       is not installed.
                                    Adapter "doorio"         is not installed.
                                    Adapter "ds18b20"        is not installed.
                                    Adapter "dwd"            is up to date.
                                    Adapter "dysonairpurifier" is not installed.
                                    Adapter "ebus"           is not installed.
                                    Adapter "echarts"        is not installed.
                                    Adapter "ecovacs-deebot" is not installed.
                                    Adapter "egigeozone"     is not installed.
                                    Adapter "ekey"           is not installed.
                                    Adapter "email"          is up to date.
                                    Adapter "emby"           is not installed.
                                    Adapter "energymanager"  is not installed.
                                    Adapter "enet"           is not installed.
                                    Adapter "epson_ecotank_et_2750" is not installed.
                                    Adapter "epson_stylus_px830" is not installed.
                                    Adapter "eventlist"      is not installed.
                                    Adapter "exchangerates"  is not installed.
                                    Adapter "fahrplan"       is not installed.
                                    Adapter "fakeroku"       is not installed.
                                    Adapter "fb-checkpresence" is up to date.
                                    Adapter "feiertage"      is up to date.
                                    Adapter "fhem"           is not installed.
                                    Adapter "find-my-iphone" is not installed.
                                    Adapter "firetv"         is not installed.
                                    Adapter "fitbit-api"     is not installed.
                                    Adapter "flot"           is up to date.
                                    Adapter "followthesun"   is not installed.
                                    Adapter "foobar2000"     is not installed.
                                    Adapter "fritzbox"       is not installed.
                                    Adapter "fritzdect"      is not installed.
                                    Adapter "fronius"        is not installed.
                                    Adapter "frontier_silicon" is up to date.
                                    Adapter "fuelpricemonitor" is not installed.
                                    Adapter "fullcalendar"   is not installed.
                                    Adapter "fullybrowser"   is not installed.
                                    Adapter "g-homa"         is not installed.
                                    Adapter "geofency"       is not installed.
                                    Adapter "go-e"           is not installed.
                                    Adapter "growatt"        is not installed.
                                    Adapter "gruenbeck"      is not installed.
                                    Adapter "haassohn"       is not installed.
                                    Adapter "habpanel"       is up to date.
                                    Adapter "haier"          is not installed.
                                    Adapter "ham"            is not installed.
                                    Adapter "ham-wemo"       is not installed.
                                    Adapter "harmony"        is not installed.
                                    Adapter "hass"           is not installed.
                                    Adapter "hass-mqtt"      is not installed.
                                    Adapter "heatingcontrol" is not installed.
                                    Adapter "heos"           is not installed.
                                    Adapter "heytech"        is not installed.
                                    Adapter "hid"            is not installed.
                                    Adapter "hilink"         is not installed.
                                    Adapter "history"        is up to date.
                                    Adapter "hm-rega"        is not installed.
                                    Adapter "hm-rpc"         is not installed.
                                    Adapter "hmip"           is not installed.
                                    Adapter "hombot"         is not installed.
                                    Adapter "homeconnect"    is not installed.
                                    Adapter "homee"          is not installed.
                                    Adapter "homepilot"      is not installed.
                                    Adapter "hp-ilo"         is not installed.
                                    Adapter "hs100"          is not installed.
                                    Adapter "hue"            is not installed.
                                    Adapter "hue-extended"   is not installed.
                                    Adapter "hyperion"       is not installed.
                                    Adapter "i2c"            is not installed.
                                    Adapter "ical"           is up to date.
                                    Adapter "icons-addictive-flavour-png" is not installed.
                                    Adapter "icons-fatcow-hosting" is not installed.
                                    Adapter "icons-icons8"   is not installed.
                                    Adapter "icons-material-png" is not installed.
                                    Adapter "icons-material-svg" is not installed.
                                    Adapter "icons-mfd-png"  is not installed.
                                    Adapter "icons-mfd-svg"  is not installed.
                                    Adapter "icons-open-icon-library-png" is not installed.
                                    Adapter "icons-ultimate-png" is not installed.
                                    Adapter "influxdb"       is not installed.
                                    Adapter "info"           is up to date.
                                    Adapter "innogy-smarthome" is not installed.
                                    Adapter "intesishome"    is not installed.
                                    Adapter "iogo"           is not installed.
                                    Adapter "iot"            is up to date.
                                    Adapter "iqontrol"       is not installed.
                                    Adapter "jarvis"         is up to date.
                                    Adapter "javascript"     is up to date.
                                    Adapter "jeelink"        is not installed.
                                    Adapter "js2fs"          is not installed.
                                    Adapter "kecontact"      is not installed.
                                    Adapter "klf200"         is not installed.
                                    Adapter "km200"          is not installed.
                                    Adapter "knmi-weather"   is not installed.
                                    Adapter "knx"            is not installed.
                                    Adapter "kodi"           is not installed.
                                    Adapter "kostal-piko-ba" is not installed.
                                    Adapter "kress"          is not installed.
                                    Adapter "lametric"       is not installed.
                                    Adapter "landroid"       is not installed.
                                    Adapter "lcn"            is not installed.
                                    Adapter "legrand-ecocompteur" is not installed.
                                    Adapter "letrika_comgw"  is not installed.
                                    Adapter "lg-ess-home"    is not installed.
                                    Adapter "lgtv"           is not installed.
                                    Adapter "lgtv-rs"        is not installed.
                                    Adapter "lgtv11"         is not installed.
                                    Adapter "lifx"           is not installed.
                                    Adapter "lightify"       is not installed.
                                    Adapter "link"           is not installed.
                                    Adapter "linkeddevices"  is not installed.
                                    Adapter "linktap"        is not installed.
                                    Adapter "linux-control"  is not installed.
                                    Adapter "logparser"      is not installed.
                                    Adapter "lovelace"       is not installed.
                                    Adapter "loxone"         is not installed.
                                    Adapter "luftdaten"      is not installed.
                                    This upgrade of "lupusec" will introduce the following changes:
                                    -> 1.3.3:
                                    Bugfixing
                                    Would you like to upgrade lupusec from @1.3.2 to @1.3.3 now? [(y)es, (n)o]: y
                                    Update lupusec from @1.3.2 to @1.3.3
                                    npm install iobroker.lupusec@1.3.3 --loglevel error --prefix "/opt/iobroker" (System call)
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!     /home/iobroker/.npm/_logs/2021-02-27T12_56_58_315Z-debug.log
                                    upload [30] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/sms.png icons/sms.png image/png
                                    upload [20] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/58.png icons/58.png image/png
                                    upload [19] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/57.png icons/57.png image/png
                                    upload [18] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/54.png icons/54.png image/png
                                    upload [17] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/52.png icons/52.png image/png
                                    upload [16] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/50.png icons/50.png image/png
                                    upload [15] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/5.png icons/5.png image/png
                                    upload [14] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/48.png icons/48.png image/png
                                    upload [13] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/46.png icons/46.png image/png
                                    upload [12] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/45.png icons/45.png image/png
                                    upload [11] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/4.png icons/4.png image/png
                                    upload [10] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/39.png icons/39.png image/png
                                    upload [9] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/37.png icons/37.png image/png
                                    upload [8] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/26.png icons/26.png image/png
                                    upload [7] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/24.png icons/24.png image/png
                                    upload [6] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/23.png icons/23.png image/png
                                    upload [5] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/22.png icons/22.png image/png
                                    upload [4] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/20.png icons/20.png image/png
                                    upload [3] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/2.png icons/2.png image/png
                                    upload [2] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/19.png icons/19.png image/png
                                    upload [1] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/13.png icons/13.png image/png
                                    upload [0] lupusec.admin /opt/iobroker/node_modules/iobroker.lupusec/admin/icons/11.png icons/11.png image/png
                                    Adapter "lupusec" updated
                                    Adapter "luxtronik1"     is not installed.
                                    Adapter "material"       is up to date.
                                    Adapter "maxcube"        is not installed.
                                    Adapter "maxcul"         is not installed.
                                    Adapter "mbus"           is not installed.
                                    Adapter "mclighting"     is not installed.
                                    Adapter "megad"          is not installed.
                                    Adapter "megadd"         is not installed.
                                    Adapter "megaesp"        is not installed.
                                    Adapter "melcloud"       is not installed.
                                    Adapter "mercedesme"     is not installed.
                                    Adapter "mercury"        is not installed.
                                    Adapter "meross"         is not installed.
                                    Adapter "meteoalarm"     is not installed.
                                    Adapter "midea"          is not installed.
                                    Adapter "miele"          is not installed.
                                    Adapter "mielecloudservice" is not installed.
                                    Adapter "mihome"         is up to date.
                                    Adapter "mihome-airpurifier" is not installed.
                                    Adapter "mihome-lamp"    is not installed.
                                    Adapter "mihome-plug"    is up to date.
                                    Adapter "mihome-vacuum"  is up to date.
                                    Adapter "miio"           is not installed.
                                    Adapter "mikrotik"       is not installed.
                                    Adapter "milight"        is not installed.
                                    Adapter "milight-smart-light" is not installed.
                                    Adapter "minuvis"        is not installed.
                                    Adapter "mobile"         is not installed.
                                    Adapter "modbus"         is up to date.
                                    Adapter "moma"           is not installed.
                                    Adapter "mpd"            is not installed.
                                    -> 2.3.5:
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!
                                    npm ERR!     /home/iobroker/.npm/_logs/2021-02-27T12_57_23_997Z-debug.log
                                    Adapter "mqtt-client"    is not installed.
                                    Adapter "multicast"      is not installed.
                                    Adapter "musiccast"      is not installed.
                                    Adapter "mydlink"        is not installed.
                                    Adapter "myq"            is not installed.
                                    Adapter "mysensors"      is not installed.
                                    Adapter "mystrom"        is not installed.
                                    Adapter "mytime"         is not installed.
                                    Adapter "myvbus"         is not installed.
                                    Adapter "nanoleaf-lightpanels" is not installed.
                                    Adapter "net-tools"      is not installed.
                                    Adapter "netatmo"        is not installed.
                                    Adapter "netatmo-crawler" is not installed.
                                    Adapter "nibeuplink"     is not installed.
                                    Adapter "nina"           is not installed.
                                    Adapter "node-red"       is not installed.
                                    Adapter "noolitef"       is not installed.
                                    Adapter "nuki"           is not installed.
                                    Adapter "nuki-extended"  is not installed.
                                    Adapter "nut"            is not installed.
                                    Adapter "octoprint"      is not installed.
                                    Adapter "odl"            is not installed.
                                    Adapter "oilfox"         is not installed.
                                    Adapter "omnicomm-lls"   is not installed.
                                    Adapter "omron-fins"     is not installed.
                                    Adapter "onkyo"          is up to date.
                                    Adapter "onvif"          is not installed.
                                    Adapter "openhab"        is not installed.
                                    Adapter "openligadb"     is not installed.
                                    Adapter "opentherm"      is not installed.
                                    Adapter "openweathermap" is not installed.
                                    Adapter "opi"            is not installed.
                                    Adapter "oppoplayer"     is not installed.
                                    Adapter "owfs"           is not installed.
                                    Adapter "owntracks"      is not installed.
                                    Adapter "palazzetti"     is not installed.
                                    Adapter "panasonic-viera" is not installed.
                                    Adapter "parser"         is up to date.
                                    Adapter "paw"            is not installed.
                                    Adapter "phantomjs"      is not installed.
                                    Adapter "philips-air"    is not installed.
                                    Adapter "pi-hole"        is not installed.
                                    Adapter "piface"         is not installed.
                                    Adapter "pimatic"        is not installed.
                                    Adapter "ping"           is up to date.
                                    Adapter "places"         is not installed.
                                    Adapter "plenticore"     is up to date.
                                    Adapter "plex"           is not installed.
                                    Adapter "plexconnect"    is not installed.
                                    Adapter "pollenflug"     is not installed.
                                    Adapter "procon-ip"      is not installed.
                                    Adapter "proxmox"        is up to date.
                                    Adapter "proxy"          is not installed.
                                    Adapter "pushbullet"     is not installed.
                                    Adapter "pushover"       is not installed.
                                    Adapter "pushsafer"      is not installed.
                                    Adapter "radar2"         is up to date.
                                    Adapter "radiohead"      is not installed.
                                    Adapter "rainbird"       is not installed.
                                    Adapter "rflink"         is not installed.
                                    Adapter "rickshaw"       is not installed.
                                    Adapter "ring"           is not installed.
                                    Adapter "roadtraffic"    is not installed.
                                    Adapter "robonect"       is not installed.
                                    Adapter "roomba"         is not installed.
                                    Adapter "rpi2"           is not installed.
                                    Adapter "rssfeed"        is not installed.
                                    Adapter "s7"             is not installed.
                                    Adapter "samsung"        is up to date.
                                    Adapter "sanext"         is not installed.
                                    Adapter "sayit"          is not installed.
                                    Adapter "sbfspot"        is not installed.
                                    Adapter "scenes"         is not installed.
                                    Adapter "schoolfree"     is not installed.
                                    Adapter "schwoerer-ventcube" is not installed.
                                    Adapter "senec"          is not installed.
                                    Adapter "seq"            is not installed.
                                    Adapter "shelly"         is up to date.
                                    Adapter "shuttercontrol" is not installed.
                                    Adapter "sia"            is not installed.
                                    Adapter "siegenia"       is not installed.
                                    Adapter "simple-api"     is up to date.
                                    Adapter "sma-em"         is not installed.
                                    Adapter "smappee"        is not installed.
                                    Adapter "smartcontrol"   is not installed.
                                    Adapter "smartgarden"    is not installed.
                                    Adapter "smartmeter"     is not installed.
                                    Adapter "snips"          is not installed.
                                    Adapter "snmp"           is not installed.
                                    Adapter "socketio"       is up to date.
                                    Adapter "solarlog"       is not installed.
                                    Adapter "solarviewdatareader" is not installed.
                                    Adapter "solarwetter"    is not installed.
                                    Adapter "sonnen"         is not installed.
                                    Adapter "sonoff"         is up to date.
                                    Adapter "sonos"          is not installed.
                                    Adapter "sonus"          is not installed.
                                    Adapter "sony-bravia"    is not installed.
                                    Adapter "sourceanalytix" is not installed.
                                    Adapter "spotify-premium" is not installed.
                                    Adapter "sprinklecontrol" is not installed.
                                    Adapter "sql"            is not installed.
                                    Adapter "squeezebox"     is not installed.
                                    Adapter "squeezeboxrpc"  is not installed.
                                    Adapter "starline"       is not installed.
                                    This upgrade of "statistics" will introduce the following changes:
                                    -> 1.0.2:
                                    errohandling in cronjobs
                                    -> 1.0.1:
                                    Precision of rounding
                                    -> 1.0.0:
                                    Caught error if structure is invalid
                                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                    Would you like to upgrade statistics from @0.2.2 to @1.0.2 now? [(y)es, (n)o]: n
                                    No upgrade of "statistics" desired.
                                    Adapter "stiebel-isg"    is not installed.
                                    Adapter "stockmarket"    is not installed.
                                    Adapter "sunnyportal"    is not installed.
                                    Adapter "swiss-weather-api" is not installed.
                                    Adapter "synology"       is not installed.
                                    Adapter "systeminfo"     is not installed.
                                    Adapter "tado"           is not installed.
                                    Adapter "tahoma"         is not installed.
                                    Adapter "tankerkoenig"   is not installed.
                                    Adapter "telegram"       is up to date.
                                    Adapter "terminal"       is not installed.
                                    Adapter "tesla-motors"   is not installed.
                                    Adapter "text2command"   is up to date.
                                    Adapter "tileboard"      is not installed.
                                    Adapter "time-switch"    is not installed.
                                    Adapter "tinker"         is not installed.
                                    Adapter "tino"           is not installed.
                                    Adapter "tinyrx4"        is not installed.
                                    Adapter "todoist2"       is not installed.
                                    Adapter "tr-064"         is up to date.
                                    Adapter "tradfri"        is not installed.
                                    Adapter "trashschedule"  is not installed.
                                    Adapter "tunnelbroker-endpoint-updater" is not installed.
                                    Adapter "tuya"           is not installed.
                                    Adapter "tvprogram"      is not installed.
                                    Adapter "tvspielfilm"    is not installed.
                                    Adapter "twinkly"        is not installed.
                                    Adapter "unifi"          is not installed.
                                    Adapter "unifi-protect"  is not installed.
                                    Adapter "upnp"           is not installed.
                                    Adapter "vaillant"       is not installed.
                                    Adapter "valloxmv"       is not installed.
                                    Adapter "valuetrackerovertime" is not installed.
                                    Adapter "vcard"          is not installed.
                                    Adapter "vedirect"       is not installed.
                                    Adapter "velux"          is not installed.
                                    Adapter "viessmann"      is not installed.
                                    Adapter "viessmannapi"   is not installed.
                                    Adapter "virtualpowermeter" is not installed.
                                    Adapter "vis"            is not installed.
                                    Adapter "vis-bars"       is not installed.
                                    Adapter "vis-canvas-gauges" is not installed.
                                    Adapter "vis-colorpicker" is not installed.
                                    Adapter "vis-fancyswitch" is not installed.
                                    Adapter "vis-google-fonts" is not installed.
                                    Adapter "vis-history"    is not installed.
                                    Adapter "vis-hqwidgets"  is not installed.
                                    Adapter "vis-icontwo"    is not installed.
                                    Adapter "vis-inventwo"   is not installed.
                                    Adapter "vis-jqui-mfd"   is not installed.
                                    Adapter "vis-justgage"   is not installed.
                                    Adapter "vis-keyboard"   is not installed.
                                    Adapter "vis-lcars"      is not installed.
                                    Adapter "vis-map"        is not installed.
                                    Adapter "vis-material"   is not installed.
                                    Adapter "vis-material-advanced" is not installed.
                                    Adapter "vis-material-webfont" is not installed.
                                    Adapter "vis-materialdesign" is not installed.
                                    Adapter "vis-metro"      is not installed.
                                    Adapter "vis-players"    is not installed.
                                    Adapter "vis-plumb"      is not installed.
                                    Adapter "vis-rgraph"     is not installed.
                                    Adapter "vis-timeandweather" is not installed.
                                    Adapter "vis-weather"    is not installed.
                                    Adapter "vodafone-speedtest" is not installed.
                                    Adapter "volvo"          is not installed.
                                    Adapter "vr200"          is not installed.
                                    Adapter "vw-connect"     is not installed.
                                    Adapter "weatherflow_udp" is not installed.
                                    Adapter "weatherunderground" is not installed.
                                    Adapter "web"            is up to date.
                                    Adapter "web-speedy"     is not installed.
                                    Adapter "weishaupt-wem"  is not installed.
                                    Adapter "whatsapp-cmb"   is not installed.
                                    Adapter "wiffi-wz"       is not installed.
                                    Adapter "wifilight"      is not installed.
                                    Adapter "windows-control" is not installed.
                                    Adapter "wlanthermo-nano" is not installed.
                                    Adapter "wled"           is not installed.
                                    Adapter "wm-bus"         is not installed.
                                    Adapter "wolf"           is not installed.
                                    Adapter "worx"           is not installed.
                                    Adapter "xbox"           is not installed.
                                    Adapter "xs1"            is not installed.
                                    Adapter "yahka"          is not installed.
                                    Adapter "yamaha"         is not installed.
                                    Adapter "yeelight-2"     is up to date.
                                    Adapter "youtube"        is not installed.
                                    Adapter "yr"             is not installed.
                                    Adapter "zigbee"         is not installed.
                                    Adapter "zoneminder"     is not installed.
                                    Adapter "zont"           is not installed.
                                    Adapter "zwave"          is not installed.
                                    Adapter "zwave2"         is not installed.
                                    Auch wenn da updated steht, bleiben alle Adapter auf der alten Version.
                                    Im npm Log steht zB sowas:
                                    15 warn read-shrinkwrap This version of npm is compatible with lockfileVersion@1, but package-lock.json was generated for lockfileVersion@2. I'll try to do my best with it!
                                    • DiginixD Diginix
                                      update done
                                      -> 1.3.3:
                                      Bugfixing
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      -> 2.3.5:
                                      npm ERR!
                                      npm ERR!
                                      npm ERR!
                                      -> 1.0.2:
                                      -> 1.0.1:
                                      -> 1.0.0:
                                      @diginix
                                      cd /opt/iobroker
                                      npm cache clear --force
                                        @diginix
                                        cd /opt/iobroker
                                        DiginixD Offline
                                        DiginixD Offline
                                        Diginix
                                        iobroker@iobroker:/opt/iobroker$ npm cache clear --force
                                        npm WARN using --force I sure hope you know what you are doing.
                                        Müsste da mehr passieren?
                                        Hab nochmal in der GUI ein Update probiert:
                                        $ ./iobroker upgrade lupusec
                                        npm ERR! /usr/bin/git ls-remote -h -t ssh://git@github.com/halloamt/ioBroker.frontier_silicon.gitnpm ERR! npm ERR! git@github.com: Permission denied (publickey).npm ERR! fatal: Could not read from remote repository.npm ERR! npm ERR! Please make sure you have the correct access rightsnpm ERR! and the repository exists.npm ERR! npm ERR! exited with error code: 128
                                        npm ERR!     /home/iobroker/.npm/_logs/2021-02-27T13_11_12_462Z-debug.log
                                        Ist diese Zeile ggf relevant:
                                        • DiginixD Diginix
                                          @diginix Schmeiß den frontier silicon mal aus dem System.
