  4. Plötzliche adapter fehler
    6.6k
34 Beiträge 2 Kommentatoren 2.1k Aufrufe 2 Beobachtet
    Billy 0
    schrieb am zuletzt editiert von Billy 0
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC/Pi3/etc. Pi 4b
    Arbeitsspeicher: 1GB 4GB
    Festplattenart: SD-Karte/SSD/HDD SD
    Betriebssystem: Ubuntu/Windows/Mac Debian
    Node-Version: 10.x.x 12.20.1
    Nodejs-Version: 10.x.x 12.20.1
    NPM-Version: 6.x.x 6.xx
    Installationsart: Skript/Manuell Manuell
    Image genutzt: Ja/Nein Nein
    Ort/Name der Imagedatei: Link
    Hi, ich habe nach einem Neustart das Problem das ein paar instanzen nicht grün werden .
    folgendes wird im Log ausgegeben:
    host.raspberrypi	2021-02-21 11:45:18.154	error	instance system.adapter.mihome-vacuum.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at internal/main/run_main_module.js:17:47
    host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:60:12)
    host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:708:14)
    host.raspberrypi	2021-02-21 11:45:18.154	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:863:32)
    host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
    host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:999:30)
    host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:1932:5)
    host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at startAdapter (/opt/iobroker/node_modules/iobroker.mihome-vacuum/main.js:479:15)
    host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at new Adapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:393:32)
    host.raspberrypi	2021-02-21 11:45:18.153	error	Caught by controller[0]: at JSON.parse (<anonymous>)
    host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: SyntaxError: Unexpected token $ in JSON at position 8443
    host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: ^
    host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: }$
    host.raspberrypi	2021-02-21 11:45:18.152	error	Caught by controller[0]: undefined:155
    host.raspberrypi	2021-02-21 11:45:16.722	info	instance system.adapter.mihome-vacuum.0 started with pid 25670
    host.raspberrypi	2021-02-21 11:45:16.487	info	Restart adapter system.adapter.ping.0 because enabled
    Betroffen sind der mii vacuum adapter, der Ping adapter und der Fronius adapter. Vor dem Neustart lief alles reibungslos.
    Ich hoffe mir kann jemand Helfen!
    Besten dank
    • B Billy 0
      Besten dank
      @billy-0
      dmesg | grep -i ext4
      sagt?
      B 1 Antwort Letzte Antwort
        @billy-0
        sagt?
        Billy 0
        pi@raspberrypi:~ $ dmesg | grep -i ext4
        [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:50:FA:7C vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=115200 console=tty1 root=PARTUUID=fee304eb-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [    1.383751] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.383841] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [    4.899179] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        pi@raspberrypi:~ $
        • B Billy 0
          pi@raspberrypi:~ $
          @billy-0
          Okay, das ist sauber.
          iobroker -v
          iobroker status
          iobroker update
          iobroker upgrade
            @billy-0
            iobroker -v
            iobroker status
            iobroker update
            iobroker upgrade
            Billy 0
            pi@raspberrypi:~ $ iobroker -v
            3.1.6
            pi@raspberrypi:~ $ iobroker status
            Objects type: file
            States  type: file
            • B Billy 0
              3.1.6
              Objects type: file
              States  type: file
              @billy-0
              iobroker stop
              iobroker update
              iobroker upgrade self
              iobroker upgrade
              iobroker start
              • B Billy 0
                3.1.6
                Objects type: file
                States  type: file
                @billy-0
                which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                  @billy-0
                  iobroker stop
                  iobroker update
                  iobroker upgrade
                  iobroker start
                  Billy 0
                  zu spät, update läuft schon ohne iobroker stop
                  • B Billy 0
                    @billy-0
                    Das macht nix.
                    Nur das
                    erfordert zuvor den Stop des Servers.
                      @billy-0
                      Das macht nix.
                      Nur das
                      Billy 0
                      Adapter "fritzbox"       is not installed.
                      Adapter "fritzdect"      is up to date.
                      (node:12578) UnhandledPromiseRejectionWarning: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                          at parse (<anonymous>)
                          at Object.Module._extensions..json (internal/modules/cjs/loader.js:1041:22)
                          at Module.require (internal/modules/cjs/loader.js:887:19)
                          at require (internal/modules/cjs/helpers.js:74:18)
                          at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:237:27)
                          at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:50:14)
                          at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:57:41)
                          at processImmediate (internal/timers.js:461:21)
                      (node:12578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      (node:12578) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                      scheinabgebrochen zu haben
                      • B Billy 0
                        Billy 0
                        @billy-0
                        Adapter "foobar2000"     is not installed.
                        Uncaught Rejection: SyntaxError: /opt/iobroker/node_modules/iobroker.fronius/io-package.json: Unexpected token ( in JSON at position 931
                            at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:279:27)
                            at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:68:14)
                            at Immediate.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:75:41)
                        pi@raspberrypi:~ $
                        dasselbe...
                        • B Billy 0
                          @billy-0
                          pi@raspberrypi:~ $
                          dasselbe...
                          @billy-0
                            @billy-0
                            Billy 0
                            pi@raspberrypi:~ $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                            /usr/bin/nodejs
                            v12.20.1
                            /usr/bin/node
                            v12.20.1
                            /usr/bin/npm
                            7.5.4
                            nodejs:
                              Installed: 12.20.1-1nodesource1
                              Candidate: 12.20.2-1nodesource1
                              Version table:
                                 12.20.2-1nodesource1 500
                                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                             *** 12.20.1-1nodesource1 100
                                    100 /var/lib/dpkg/status
                                 10.23.1~dfsg-1~deb10u1 500
                            pi@raspberrypi:~ $
                            npm hab ich eben ausversehen update gemacht
                            • B Billy 0
                              /usr/bin/nodejs
                              v12.20.1
                              /usr/bin/node
                              v12.20.1
                              /usr/bin/npm
                              7.5.4
                              nodejs:
                                Version table:
                              pi@raspberrypi:~ $
                              @billy-0 sagte in Plötzliche adapter fehler:
                              Das solltest du wieder rückgängig machen. npm@7 passt nicht zum ioBroker.
                              sudo apt update
                              sudo apt upgrade
                                sudo apt update
                                sudo apt upgrade
                                Billy 0
                                @thomas-braun Ok ist durchgelaufen
                                /usr/bin/nodejs
                                v12.20.2
                                /usr/bin/node
                                v12.20.2
                                /usr/bin/npm
                                6.14.11
                                nodejs:
                                  Installed: 12.20.2-1nodesource1
                                  Version table:
                                 *** 12.20.2-1nodesource1 500
                                pi@raspberrypi:~ $
                                • B Billy 0
                                  /usr/bin/nodejs
                                  v12.20.2
                                  /usr/bin/node
                                  v12.20.2
                                  /usr/bin/npm
                                  6.14.11
                                  nodejs:
                                    Version table:
                                  pi@raspberrypi:~ $
                                  Billy 0
                                  @billy-0 log vom broker
                                  host.raspberrypi-Server	2021-02-21 12:49:06.918	error	Cannot parse /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: /opt/iobroker/iobroker-data/files/mihome-vacuum.admin/_data.json: Unexpected token b in JSON at position 2195
                                  • B Billy 0
                                    Billy 0
                                    @billy-0 beim upgrade self bleibts beim fehler
                                    Thomas BraunT B 2 Antworten Letzte Antwort
                                    • B Billy 0
                                      @billy-0
                                      Lösch den Adapter mal und installier den danach neu.
                                      • B Billy 0
                                        Billy 0
                                        Hmm, habe gerade festgestellt das mir die betreffenden Adapter gar nicht mehr in der Adapter ansicht vom iobroker angezeigt werden. Sind nur in der Instanzen ansicht sichtbar... Hilft uns das weiter?
                                          @billy-0
                                          Billy 0
                                          @thomas-braun finde nix zum neu installieren!?
