  5. Skript MiHome Error
    6.3k
Skript MiHome Error
11 Beiträge 4 Kommentatoren 970 Aufrufe 3 Beobachtet
  • Jonas 0J Offline
    Jonas 0J Offline
    Jonas 0
    ich möchte folgendes Skript in ioBroker nutzen:
    https://github.com/Pittini/iobroker-nodemihome
    System Infos:
    DebianGNU auf i3-3110M, 64-bit, 4GB RAM
    Node v.10.23.2
    NPM v.7.5.2
    Scriptengine v.4.8.4
    Dies zeigt der LOG an:
    javascript.0	2021-02-04 18:18:48.488	error	(1224) at process._tickCallback (internal/process/next_tick.js:68:7)
    javascript.0	2021-02-04 18:18:48.488	error	(1224) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
    javascript.0	2021-02-04 18:18:48.488	error	(1224) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at client.get (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:616:17)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at adapter.getForeignState (/opt/iobroker/node_modules/iobroker.javascript/main.js:1238:17)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at createProblemObject (/opt/iobroker/node_modules/iobroker.javascript/main.js:1722:17)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1621:37)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1383:28)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at Object.createScript (vm.js:277:10)
    javascript.0	2021-02-04 18:18:48.487	error	(1224) at new Script (vm.js:83:7)
    javascript.0	2021-02-04 18:18:48.486	error	(1224) SyntaxError: Unexpected string
    javascript.0	2021-02-04 18:18:48.486	error	(1224) ^^^^^^^^^^^^^
    javascript.0	2021-02-04 18:18:48.486	error	(1224) const mihome = require'node-mihome';
    javascript.0	2021-02-04 18:18:48.486	error	at script.js.node-mihome:2
    javascript.0	2021-02-04 18:18:48.486	error	(1224) script.js.node-mihome compile failed:
    Danke!!!
    Problemmeldung: (https://github.com/Pittini/iobroker-nodemihome/issues/9)
    Thomas BraunT paul53P 2 Antworten Letzte Antwort
    • Jonas 0J Jonas 0
      System Infos:
      Node v.10.23.2
      NPM v.7.5.2
      Danke!!!
      @jonas-0 sagte in Skript MiHome Error:
      NPM v.7.5.2
      Sorgt für Trouble. Besser npm@6 verwenden.
      Insbesondere wenn node10 verwendet wird.
      (Was ich am Rande auf node12 heben würde)
      Jonas 0J 1 Antwort Letzte Antwort
      • Jonas 0J Jonas 0
        System Infos:
        Node v.10.23.2
        NPM v.7.5.2
        Danke!!!
        @jonas-0 sagte: const mihome = require'node-mihome';
        Richtig:
        const mihome = require('node-mihome');
        Jonas 0J ? 2 Antworten Letzte Antwort
          NPM v.7.5.2
          Jonas 0J Offline
          Jonas 0J Offline
          Jonas 0
          Ist jetzt auf 6, trotzdem gleicher Fehler.
            Richtig:
            Jonas 0J Offline
            Jonas 0J Offline
            Jonas 0
            Ist geändert:
            javascript.0	2021-02-04 19:21:33.232	error	(1448) at Script.runInContext (vm.js:133:20)
            javascript.0	2021-02-04 19:21:33.232	error	(1448) at script.js.node-mihome:842:3
            javascript.0	2021-02-04 19:21:33.232	error	(1448) at script.js.node-mihome:64:1
            javascript.0	2021-02-04 19:21:33.232	error	(1448) at Init (script.js.node-mihome:570:12)
            javascript.0	2021-02-04 19:21:33.232	error	(1448) script.js.node-mihome: TypeError: Cannot read property 'miioProtocol' of undefined
              Richtig:
              Das steht schon richtig im Script auf Git.. :-) aber @Jonas-0 vielleicht bei Copy+Paste was schief gelaufen?
              Hast du node-mihome auch im Adapter eingetragen, damit es installiert wird?
              Und deine Node-Installation mal gerade gezogen?
              NPM7 vermurkst recht viel...
                Jonas 0J Offline
                Jonas 0J Offline
                Jonas 0
                @ilovegym
                Habs nochmal neu reinkopiert und nur user und Passwort eingetragen.
                node-mihome steht auch im Script Adapter.
                @ilovegym said in Skript MiHome Error:
                Was meinst du damit?
                • Jonas 0J Jonas 0
                  @ilovegym
                  Jonas 0J Offline
                  Jonas 0J Offline
                  Jonas 0
                  schrieb am zuletzt editiert von Jonas 0
                  Danach immer noch gleicher Log:
                  javascript.0	2021-02-04 19:26:30.545	error	(1448) at Script.runInContext (vm.js:133:20)
                  javascript.0	2021-02-04 19:26:30.544	error	(1448) at script.js.node-mihome:844:3
                  javascript.0	2021-02-04 19:26:30.544	error	(1448) at script.js.node-mihome:66:1
                  javascript.0	2021-02-04 19:26:30.544	error	(1448) at Init (script.js.node-mihome:572:12)
                  javascript.0	2021-02-04 19:26:30.544	error	(1448) script.js.node-mihome: TypeError: Cannot read property 'miioProtocol' of undefined
                  • Jonas 0J Jonas 0
                    @ilovegym
                    Das hier vom netten Kollegen @Thomas-Braun , richtig? :-) Node gerade ziehen
                      Jonas 0J Offline
                      Jonas 0J Offline
                      Jonas 0
                      @ilovegym Hat geklappt. Läuft! Danke euch allen!
                      • Jonas 0J Jonas 0
                        @jonas-0
                        Was spuckt denn
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        nun aus?
