  4. [Gelöst] Zigbee >1.2.0 funktioniert nicht
    6.0k
zigbee-adapter
35 Beiträge 4 Kommentatoren 2.8k Aufrufe 4 Beobachtet
  • amg_666A amg_666
    @asgothian Über den Adapter gelöscht (war ok) und dann versucht zu installieren...
    $ ./iobroker add zigbee  --host iomaster
    NPM version: 6.14.10
    npm install iobroker.zigbee@1.4.2 --loglevel error --prefix "/opt/iobroker" (System call)
    ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':
    ../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);        ^~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);        ^~~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);        ^~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:270:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);        ^~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:314:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);        ^~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:363:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);        ^~~~~~~~~~~~~~~~~~~~../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':../src/serialport.cpp:409:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);        ^~~~~~~~~~~~~~../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {                            ^../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {                              ^In file included from ../../../nan/nan.h:56,                 from ../src/./serialport.h:6,                 from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:771:3: note: in expansion of macro 'NODE_MODULE_X'   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(serialport, init); ^~~~~~~~~~~
    Killed
    ERROR: host.iomaster Cannot install iobroker.zigbee@1.4.2: 137
    ../src/serialport_unix.cpp: In function 'int setup(int, OpenBaton*)':../src/serialport_unix.cpp:176:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: 'snprintf' output 20 or more bytes (assuming 1043) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp: In function 'void EIO_Open(uv_work_t*)':../src/serialport_unix.cpp:86:60: warning: '%s' directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);                                                            ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: 'snprintf' output 22 or more bytes (assuming 1045) into a destination of size 1024     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);     ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @amg_666 bist du sicher das du node 12.19 nutzt ? serialport 9 sollte mit node 12 gehen.
    mach mal bitte npm list serialport
    A.
    • AsgothianA Asgothian
      A.
      amg_666A Offline
      amg_666A Offline
      amg_666
      @asgothian said in Zigbee >1.2.0 funktioniert nicht:
      npm list serialport
      node.js 12.20.1
      pi@iomaster:/opt/iobroker $  npm list serialport
      iobroker.inst@2.0.3 /opt/iobroker
      `-- iobroker.discovery@2.5.0
        `-- serialport@9.0.4
      • amg_666A amg_666
        npm list serialport
        node.js 12.20.1
        amg_666A Offline
        amg_666A Offline
        amg_666
        @amg_666 Sehr merkwürdig. Ich habe jetzt nochmal in der Konsole "npm install iobroker.zigbee" eingegeben, das lief dann durch. Aber jetzt sind im Log wieder die ganz oben genannten Fehlermeldungen. Offensichtlich ist hier noch irgendwas im falsch, aber der Adapter war ja komplett gelöscht. Hat hier noch jemand eine Idee?
        Thomas BraunT AsgothianA 2 Antworten Letzte Antwort
        • amg_666A amg_666
          @amg_666
          Ich denke zwar dass es passt, schau aber nochmal nach nodejs:
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            @amg_666
            amg_666A Offline
            amg_666A Offline
            amg_666
            @thomas-braun said in Zigbee >1.2.0 funktioniert nicht:
            pi@iomaster:/opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.20.1
            /usr/bin/node
            v12.20.1
            /usr/bin/npm
            6.14.10
            nodejs:
              Installiert:           12.20.1-1nodesource1
              Installationskandidat: 12.20.1-1nodesource1
              Versionstabelle:
             *** 12.20.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.23.1~dfsg-1~deb10u1 500
            • amg_666A amg_666
              /usr/bin/nodejs
              v12.20.1
              /usr/bin/node
              v12.20.1
              /usr/bin/npm
              6.14.10
              nodejs:
                Versionstabelle:
              @amg_666
              Ja, das passt.
              Ich denke da müssen die Dependencies vom zigbee-Adapter und/oder zigbee-herdsman geprüft werden.
              Wenn ich bei mir den zigbee-Adapter reinziehe haut mir
              npm list
              recht viele Errors um die Ohren. Sobald der wieder deinstalliert wird ist auch die npm list wieder sauber.
              amg_666A AsgothianA 2 Antworten Letzte Antwort
                @amg_666
                Ja, das passt.
                npm list
                amg_666A Offline
                amg_666A Offline
                amg_666
                @thomas-braun Deinstallation und Neu installieren habe ich ja gemacht, hat nix gebracht (Fehler wie ganz oben gepostet).
                Wie gehe ich vor wenn ich den Adapter deinstalliere und sicherstelle, dass auch wirklich ALLES gelöscht wird? Würd ich gerne als letzten Versuch unternehmen
                  @amg_666
                  Ja, das passt.
                  npm list
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  @thomas-braun sagte in Zigbee >1.2.0 funktioniert nicht:
                  Das seh ich anders.. Die Meldungen besagen das gepinnte Pakete extra installiert werden. Warum das beim Herdsman und converter so ist weiss ich nicht - es ist aber nur dann ein Problem wenn da manuell dran herum gefummelt wird.
                  A.
                  • amg_666A amg_666
                    AsgothianA Offline
                    AsgothianA Offline
                    Asgothian
                    @amg_666
                    • Adapter löschen
                    • per npm list verifizieren das weder zigbee-herdsman noch zigbee-herdsman-converters installiert sind. Wenn sie doch da sind - beseitigen
                    • Adapter installieren
                    A.
                      A.
                      @asgothian
                      Ende von npm list:
                      ├── function-bind@1.1.1 deduped
                            ├── has-symbols@1.0.1
                            └── object-keys@1.1.1 deduped
                      npm ERR! invalid: @types/node@12.19.15 /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
                      pi@raspberrypi:/opt/iobroker $ npm list zigbee-herdsman
                      └── (empty)
                      pi@raspberrypi:/opt/iobroker $ npm list zigbee-herdsman-converters
                      └── (empty)
                      pi@raspberrypi:/opt/iobroker $ iobroker add zigbee
                      Nach Installation von zigbee / herdsman:
                      npm ERR! peer dep missing: typedoc@>=0.19.0 < 0.20.0, required by typedoc-plugin-markdown@3.1.1
                      npm ERR! peer dep missing: typedoc@>=0.16.0, required by typedoc-plugin-no-inherit@1.2.0
                      npm ERR! peer dep missing: typedoc@>=0.16.0, required by typedoc-plugin-sourcefile-url@1.0.6
                      npm ERR! extraneous: @babel/cli@7.12.10 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                      npm ERR! extraneous: @babel/preset-env@7.12.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                      npm ERR! extraneous: @babel/preset-typescript@7.12.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                      npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                      npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                      npm ERR! extraneous: @types/jest@26.0.19 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                      npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                      npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                      npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.11.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                      npm ERR! extraneous: @typescript-eslint/parser@4.11.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                      npm ERR! extraneous: eslint@7.16.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                      npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                      npm ERR! extraneous: typedoc-plugin-markdown@3.1.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                      npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                      npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                      npm ERR! extraneous: typescript@4.1.3 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
                      npm ERR! extraneous: eslint@7.16.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                      npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                      npm ERR! extraneous: eslint-plugin-jest@24.1.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                      npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                      npm ERR! peer dep missing: typedoc@>=0.19.0 < 0.20.0, required by typedoc-plugin-markdown@3.1.0
                      npm ERR! extraneous: @babel/cli@7.12.8 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                      npm ERR! extraneous: @babel/preset-env@7.12.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                      npm ERR! extraneous: @babel/preset-typescript@7.12.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                      npm ERR! extraneous: @types/debounce@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                      npm ERR! extraneous: @types/debug@4.1.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                      npm ERR! extraneous: @types/jest@26.0.18 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                      npm ERR! extraneous: @types/nedb@1.8.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                      npm ERR! extraneous: @types/serialport@8.0.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                      npm ERR! extraneous: @typescript-eslint/eslint-plugin@4.9.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                      npm ERR! extraneous: @typescript-eslint/parser@4.9.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                      npm ERR! extraneous: eslint@7.15.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                      npm ERR! extraneous: jest@26.6.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                      npm ERR! extraneous: typedoc-plugin-markdown@3.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                      npm ERR! extraneous: typedoc-plugin-no-inherit@1.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                      npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                      npm ERR! extraneous: typescript@4.1.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
                      Die ganze 'Unruhe' kommt also von zigbee/herdsman/serialport da rein. Da ist doch irgendwas krumm, würde ich sagen.
                      Nach Deinstallation vom zigbee-Adapter sieht es nämlich wieder fein aus:
                          └─┬ object.assign@4.1.0
                            ├─┬ define-properties@1.1.3
                            │ └── object-keys@1.1.1 deduped
                        @asgothian
                        Ende von npm list:
                        └── (empty)
                        └── (empty)
                        amg_666A Offline
                        amg_666A Offline
                        amg_666
                        schrieb am zuletzt editiert von amg_666
                        Edit: Bin ja schwer begeistert, trotz der Löschaktion hat er die alten Einträge beibehalten (wie es @Asgothian oben gesagt hatte, die shepher.db sollte erhalten bleiben. Das hat nur etwas gedaurt aber jetzt sind alle Geräte im Adapter wieder angelegt und funktionieren :-)
                        @thomas-braun @Asgothian Erstmal vielen Dank für euren Support. Keine Ahnung woran es lag aber ich hab den jetzt in der Konsole deinstalliert, danach mit npm list gecheckt (war nix mehr da) und habe dann mit npm install iobroker.zigbee neu aufgesetzt. Der hat ewig gerödelt war aber letztlich erfolgreich, Adapter ist mit aktueller Version angelegt und ich konnte eine neue Instanz anlegen, die auch ohne Fehlermeldungen läuft.
                        Nochmal ne Frage: Kann ich die alten Einstellungen irgendwie manuell wieder auf den iobroker bringen (herdsman einstellungen) ? Oder soll ich per backitup adapter ein backup einspielen (da hab ich allerdings die Befürchtung dass ich wieder irgendwas kaputtes drüberinstalliere...).
                        Ach ja, Log meiner Aktion zur Info:
                        pi@iomaster:/opt/iobroker $ npm install iobroker.zigbee
                        > @serialport/bindings@9.0.3 install /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                        > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
                        prebuild-install WARN install No prebuilt binaries found (target=12.20.1 runtime=node arch=arm libc= platform=linux)
                        make: Verzeichnis ▒/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build▒ wird betreten
                          CXX(target) Release/obj.target/bindings/src/serialport.o
                          CXX(target) Release/obj.target/bindings/src/serialport_unix.o
                          CXX(target) Release/obj.target/bindings/src/poller.o
                          CXX(target) Release/obj.target/bindings/src/serialport_linux.o
                          SOLINK_MODULE(target) Release/obj.target/bindings.node
                          COPY Release/bindings.node
                        make: Verzeichnis ▒/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build▒ wird verlassen
                        > @serialport/bindings@9.0.4 install /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings
                        make: Verzeichnis ▒/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build▒ wird betreten
                        make: Verzeichnis ▒/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build▒ wird verlassen
                        > serialport@9.0.3 postinstall /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/serialport
                        > node thank-you.js
                        Thank you for using serialport!
                        If you rely on this package, please consider supporting our open collective:
                        > https://opencollective.com/serialport/donate
                        > serialport@9.0.4 postinstall /opt/iobroker/node_modules/zigbee-herdsman/node_modules/serialport
                        > node thank-you.js
                        Get▒tet      ......] \ postinstall: info lifecycle typescript@4.1.3~postinstall
                        AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
                        • amg_666A amg_666
                          > node thank-you.js
                          > node thank-you.js
                          AsgothianA Offline
                          AsgothianA Offline
                          Asgothian
                          @amg_666 Fein.. so soll es sein.
                          A.
                          • amg_666A amg_666
                            > node thank-you.js
                            > node thank-you.js
                            @amg_666
                            Wie schaut denn nun das Ende von
                            npm list
                            aus?
                              @amg_666
                              npm list
                              aus?
                              amg_666A Offline
                              amg_666A Offline
                              amg_666
                              @thomas-braun Er meckert nichts mehr an, hab jetzt nur mal die letzten Zeilen gepostet, der Rest sieht aber genauso aus.
                                |   +-- normalize-package-data@2.5.0
                                |   | +-- hosted-git-info@2.8.8
                                |   | +-- resolve@1.18.1
                                |   | | +-- is-core-module@2.0.0
                                |   | | | `-- has@1.0.3 deduped
                                |   | | `-- path-parse@1.0.6
                                |   | +-- semver@5.7.1 deduped
                                |   | `-- validate-npm-package-license@3.0.4
                                |   |   +-- spdx-correct@3.1.1
                                |   |   | +-- spdx-expression-parse@3.0.1 deduped
                                |   |   | `-- spdx-license-ids@3.0.6
                                |   |   `-- spdx-expression-parse@3.0.1
                                |   |     +-- spdx-exceptions@2.3.0
                                |   |     `-- spdx-license-ids@3.0.6 deduped
                                |   `-- path-type@1.1.0
                                |     +-- graceful-fs@4.2.4 deduped
                                |     +-- pify@2.3.0 deduped
                                |     `-- pinkie-promise@2.0.1 deduped
                                +-- require-directory@2.1.1
                                +-- require-main-filename@1.0.1
                                +-- set-blocking@2.0.0
                                +-- string-width@1.0.2
                                | +-- code-point-at@1.1.0
                                | +-- is-fullwidth-code-point@1.0.0
                                | | `-- number-is-nan@1.0.1
                                | `-- strip-ansi@3.0.1 deduped
                                +-- which-module@1.0.0
                                +-- y18n@3.2.1
                                `-- yargs-parser@5.0.0-security.0
                                  +-- camelcase@3.0.0 deduped
                                  `-- object.assign@4.1.1
                                    +-- define-properties@1.1.3
                                    | `-- object-keys@1.1.1 deduped
                                    +-- es-abstract@1.18.0-next.1
                                    | +-- es-to-primitive@1.2.1
                                    | | +-- is-callable@1.2.2 deduped
                                    | | +-- is-date-object@1.0.2
                                    | | `-- is-symbol@1.0.3
                                    | |   `-- has-symbols@1.0.1 deduped
                                    | +-- function-bind@1.1.1 deduped
                                    | +-- has@1.0.3 deduped
                                    | +-- has-symbols@1.0.1 deduped
                                    | +-- is-negative-zero@2.0.0
                                    | +-- is-regex@1.1.1
                                    | +-- object-inspect@1.8.0
                                    | +-- object-keys@1.1.1 deduped
                                    | +-- object.assign@4.1.1 deduped
                                    | +-- string.prototype.trimend@1.0.2
                                    | | +-- define-properties@1.1.3 deduped
                                    | | `-- es-abstract@1.18.0-next.1 deduped
                                    | `-- string.prototype.trimstart@1.0.2
                              • Basti97B Offline
                                Basti97B Offline
                                Basti97
                                schrieb am zuletzt editiert von Basti97
                                Der Beitrag ist schon ein bisschen älter. Ich habe zwar einen neuen aufgemacht aber vielleicht sieht man es hier schneller und zwar kommt bei mir eine ähnlicher Fehler. Ich habe den Adapter schon gelöscht und neu installiert aber trotzdem geht er nicht.
                                Ich nutze die v 1.6.16 auf einem Rp Slave. Wenn ich den Adapter starte kommt diese Meldung in der Log.
                                host.Media04
                                	2022-02-22 18:26:37.232	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                host.Media04
                                	2022-02-22 18:26:37.231	error	Caught by controller[0]: }
                                host.Media04
                                	2022-02-22 18:26:37.231	error	Caught by controller[0]: ]
                                host.Media04
                                	2022-02-22 18:26:37.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/main.js'
                                host.Media04
                                	2022-02-22 18:26:37.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js',
                                host.Media04
                                	2022-02-22 18:26:37.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js',
                                host.Media04
                                	2022-02-22 18:26:37.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js',
                                host.Media04
                                	2022-02-22 18:26:37.229	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.229	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/controller.js',
                                host.Media04
                                	2022-02-22 18:26:37.229	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/model/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.228	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/model/device.js',
                                host.Media04
                                	2022-02-22 18:26:37.228	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js',
                                host.Media04
                                	2022-02-22 18:26:37.228	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/zcl/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.227	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/zcl/zclFrame.js',
                                host.Media04
                                	2022-02-22 18:26:37.227	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/zcl/buffaloZcl.js',
                                host.Media04
                                	2022-02-22 18:26:37.227	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/buffalo/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.226	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/buffalo/buffalo.js',
                                host.Media04
                                	2022-02-22 18:26:37.226	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/utils/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.226	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/utils/backup.js',
                                host.Media04
                                	2022-02-22 18:26:37.225	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/mz/index.js',
                                host.Media04
                                	2022-02-22 18:26:37.225	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/mz/fs.js',
                                host.Media04
                                	2022-02-22 18:26:37.225	error	Caught by controller[0]: requireStack: [
                                host.Media04
                                	2022-02-22 18:26:37.224	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                host.Media04
                                	2022-02-22 18:26:37.224	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19) {
                                host.Media04
                                	2022-02-22 18:26:37.224	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
                                host.Media04
                                	2022-02-22 18:26:37.223	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
                                host.Media04
                                	2022-02-22 18:26:37.223	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
                                host.Media04
                                	2022-02-22 18:26:37.223	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
                                host.Media04
                                	2022-02-22 18:26:37.222	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/mz/fs.js:2:15)
                                host.Media04
                                	2022-02-22 18:26:37.222	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:101:18)
                                host.Media04
                                	2022-02-22 18:26:37.222	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
                                host.Media04
                                	2022-02-22 18:26:37.221	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
                                host.Media04
                                	2022-02-22 18:26:37.221	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
                                host.Media04
                                	2022-02-22 18:26:37.221	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                host.Media04
                                	2022-02-22 18:26:37.220	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js
                                host.Media04
                                	2022-02-22 18:26:37.220	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.zigbee/lib/utils.js
                                host.Media04
                                	2022-02-22 18:26:37.220	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/index.js
                                host.Media04
                                	2022-02-22 18:26:37.219	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/converters/toZigbee.js
                                host.Media04
                                	2022-02-22 18:26:37.219	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/index.js
                                host.Media04
                                	2022-02-22 18:26:37.219	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/controller.js
                                host.Media04
                                	2022-02-22 18:26:37.218	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/model/index.js
                                host.Media04
                                	2022-02-22 18:26:37.218	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/model/device.js
                                host.Media04
                                	2022-02-22 18:26:37.218	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js
                                host.Media04
                                	2022-02-22 18:26:37.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/zcl/index.js
                                host.Media04
                                	2022-02-22 18:26:37.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/zcl/zclFrame.js
                                host.Media04
                                	2022-02-22 18:26:37.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/zcl/buffaloZcl.js
                                host.Media04
                                	2022-02-22 18:26:37.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/buffalo/index.js
                                host.Media04
                                	2022-02-22 18:26:37.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/buffalo/buffalo.js
                                host.Media04
                                	2022-02-22 18:26:37.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/utils/index.js
                                host.Media04
                                	2022-02-22 18:26:37.215	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/dist/utils/backup.js
                                host.Media04
                                	2022-02-22 18:26:37.215	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/mz/index.js
                                host.Media04
                                	2022-02-22 18:26:37.214	error	Caught by controller[0]: - /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/mz/fs.js
                                host.Media04
                                	2022-02-22 18:26:37.214	error	Caught by controller[0]: Require stack:
                                host.Media04
                                	2022-02-22 18:26:37.214	error	Caught by controller[0]: Error: Cannot find module 'any-promise'
                                host.Media04
                                	2022-02-22 18:26:37.213	error	Caught by controller[0]: ^
                                host.Media04
                                	2022-02-22 18:26:37.213	error	Caught by controller[0]: throw err;
                                host.Media04
                                	2022-02-22 18:26:37.212	error	Caught by controller[0]: internal/modules/cjs/loader.js:905
                                Beitrag zum neuen Post
                                https://forum.iobroker.net/topic/52805/zigbee-adapter-funktoniert-nicht
                                Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
