  4. tr-064.0 Cannot read property 's:Envelope' of undefined
    6.7k
senvelopetr-064
5 Beiträge 2 Kommentatoren 347 Aufrufe 2 Beobachtet
  • nik82N Offline
    nik82N Offline
    nik82
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC
    Arbeitsspeicher: 16GB
    Festplattenart: SSD
    Betriebssystem: Windows10 Pro
    Node-Version: v12.20.1
    Nodejs-Version: v12.20.1
    NPM-Version: 6.14.10
    Installationsart: Iobroker Windows Setup
    CCU3: aktuelle RaspberryMatic mit 3.55.5.20201226
    TR-064 Adapter: v4.2.2
    bekomme mehrmals am Tag die Fehlermeldung "tr-064.0 (50556) uncaught exception: Cannot read property 's:Envelope' of undefined" beim tr-064 Adapter:
    2021-01-11 02:16:22.286 - error: tr-064.0 (50556) uncaught exception: Cannot read property 's:Envelope' of undefined
    2021-01-11 02:16:22.292 - error: tr-064.0 (50556) TypeError: Cannot read property 's:Envelope' of undefined
    at C:\iobroker\Iobroker4\node_modules\tr-O64\lib\Service.js:217:33
    at Parser. (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:308:18)
    at Parser.emit (events.js:314:20)
    at Parser.EventEmitter.emit (domain.js:483:12)
    at SAXParser.onerror (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:123:26)
    at emit (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:624:35)
    at error (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:653:5)
    at strictFail (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:677:7)
    at end (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:658:47)
    at SAXParser.write (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:975:14)
    2021-01-11 02:16:22.344 - error: host.IOBROKER(Iobroker) Caught by controller[0]: TypeError: Cannot read property 's:Envelope' of undefined
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at C:\iobroker\Iobroker4\node_modules\tr-O64\lib\Service.js:217:33
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at Parser. (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:308:18)
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at Parser.emit (events.js:314:20)
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at Parser.EventEmitter.emit (domain.js:483:12)
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at SAXParser.onerror (C:\iobroker\Iobroker4\node_modules\xml2js\lib\parser.js:123:26)
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at emit (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:624:35)
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at error (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:653:5)
    2021-01-11 02:16:22.347 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at strictFail (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:677:7)
    2021-01-11 02:16:22.348 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at end (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:658:47)
    2021-01-11 02:16:22.348 - error: host.IOBROKER(Iobroker) Caught by controller[0]: at SAXParser.write (C:\iobroker\Iobroker4\node_modules\xml2js\node_modules\sax\lib\sax.js:975:14)
    2021-01-11 02:16:22.348 - error: host.IOBROKER(Iobroker) instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2021-01-11 02:16:22.348 - info: host.IOBROKER(Iobroker) Restart adapter system.adapter.tr-064.0 because enabled
    2021-01-11 02:16:52.386 - info: host.IOBROKER(Iobroker) instance system.adapter.tr-064.0 started with pid 38480
    2021-01-11 02:16:53.292 - info: tr-064.0 (38480) starting. Version 4.2.2 in C:/iobroker/Iobroker4/node_modules/iobroker.tr-064, node: v12.20.1, js-controller: 3.1.6
    Irgendjemand eine Idee an was das liegen kann?
    Danke im Voraus.
    • nik82N nik82
      Hardwaresystem: NUC
      Festplattenart: SSD
      Danke im Voraus.
      @nik82 sagte in tr-064.0 Cannot read property 's:Envelope' of undefined:
      tr-O64
      Steht da wirklich tr-O64?
      Ich würde da eher tr-064 erwarten.
      nik82N 1 Antwort Letzte Antwort
        tr-O64
        nik82N Offline
        nik82N Offline
        nik82
        Krass, da steht wirklich ein O (Buchstabe) und keine 0 (Zahl) :
        Hab das jetzt mal umbenannt, das könnte doch schon der Fehler sein oder?
        • nik82N nik82
          nik82N Offline
          nik82N Offline
          nik82
          Nein, das geht nicht mit umbennen, dann findet er es nicht mehr:
          • nik82N nik82
            nik82N Offline
            nik82N Offline
            nik82
            schrieb am zuletzt editiert von nik82
            Falls es wen interessiert, im Github gehts weiter:
            Github Issue
