  5. DeviceCounter - Anzahl der Meldungen zusammenfassen
    6.3k
1 Beiträge 1 Kommentatoren 230 Aufrufe 1 Beobachtet
    baluderbär
    schrieb am zuletzt editiert von baluderbär
    ich benutze folgendes Skript, was ich im Forum gefunden habe. Erst einmal vielen Dank an den mir unbekannten Verfasser.
    //Add device rules
    addDeviceCounter("lowbat",         $('channel[state.id=*.LOWBAT]'),                      true);
    addDeviceCounter("sticky_unreach", $('channel[state.id=*.STICKY_UNREACH]'),              true);
    addDeviceCounter("unreach",        $('channel[state.id=*.UNREACH]'),                     true);
    addDeviceCounter("config_pending", $('channel[state.id=*.CONFIG_PENDING]'),              true);
    //addDeviceCounter("open_windows",   $('channel{TYPE=SHUTTER_CONTACT}[state.id=*.STATE]'), true);
    //addDeviceCounter("on_lights",      $('channel{TYPE=DIMMER}[state.id=*.LEVEL]'),          function(state){return state>0;});
    //addDeviceCounter("open_shutters",  $('channel{TYPE=BLIND}[state.id=*.LEVEL]'),           function(state){return state>0;});
    //addDeviceCounter("playing_music",  $('channel[state.id=*audio-*.playing]'),              true);
     * Code - do not change anything bellow this line *
    function addDeviceCounter(name, selector, val_to_count) {
        //Total amount of devices found by selector
        var state_total = 'deviceCounter.' + name + '.total';
        createState(state_total, 0);
        //List of devices that match condition
        var state_list = 'deviceCounter.' + name + '.list';
        createState(state_list, "");
        //Number of devices that match condition
        var state_counter = 'deviceCounter.' + name + '.counter';
        createState(state_counter, 0);
        function countDevs(obj) {
            var d_count = 0;
            var d_list  = [];
            selector.each(function (id, i) {
                var status = getState(id).val;
                var obj    = getObject(id);
                if ((typeof val_to_count === 'function' && val_to_count(status)) ||
                    (typeof val_to_count === 'boolean'  && val_to_count == status)) {
                    //Get parent object
                    var parentChannelId = id.slice(id.lastIndexOf("."));
                    var parentDevicelId = id.split(".").slice(0,-2).join(".");
                    var deviceObject = getObject(parentDevicelId);
                    //remember device name
                    d_list.push(deviceObject.common.name);
                ++d_count;                                                 // Zählt die Anzahl der vorhandenen Geräte unabhängig vom Status
            log(name + "(" + d_count + "): " + d_list);
            setState(state_list,     d_list.join(''));
            setState(state_counter,  d_list.length);
            setState(state_total,    d_count);
        //Re-evaluate when a device status changes
        selector.on(function(obj) {    // bei Zustandänderung *. LOWBAT in allen Gewerken
            countDevs(obj);
        //Re-evaluate each 5 Minutes
        schedule("*/5 * * * *", countDevs);
        //Evaluate for the first time
        countDevs();
    Die Zeilen 6-9 habe ich auskommentiert, da ich sie nicht benötige. Aktuell erhalte ich pro Zeile (2-5) je einen Wert für deviceCounter.config_pending.counter, deviceCounter.lowbat.counter, deviceCounter.sticky_unreach.counter und deviceCounter.unreach.counter. Ist es möglich, einen Gesamtwert für die 4 Einzelwerte zu erhalten? In dem Zusammenhang wäre es auch toll, wenn dann die entsprechenden Auflistungen in einer Liste zusammengefasst werden würden. Vorab vielen Dank.
    ioBroker auf VM Proxmox (Intel NUC-Kit i3-7100U 2.4GHz HD620 NUC7I3BNH)
