  3. Entwicklung
  4. Zigbee bleibt gelb nach upgrade auf 1.4
    5.4k
zigbee
22 Beiträge 2 Kommentatoren 2.3k Aufrufe 3 Beobachtet
  • M Mr.X
    @Thomas-Braun
    So, da wären wir wieder.
    Ich habe gestern drei Geräte gelöscht. Gestern abend und heute früh vor der Arbeit lief alles.
    Nun habe ich eben nachgeschaut: Adapter gelb.
    Nach dem Adapter Neustart kommt das:
    zigbee.0	2020-12-16 11:19:50.275	info	(1803) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2020-12-16 11:19:50.274	info	(1803) terminating
    zigbee.0	2020-12-16 11:19:50.273	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:27:71)
    zigbee.0	2020-12-16 11:19:50.273	error	at Generator.next (<anonymous>)
    zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:453:28)
    zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:800:16)
    zigbee.0	2020-12-16 11:19:50.273	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:23:12)
    zigbee.0	2020-12-16 11:19:50.273	error	at new Promise (<anonymous>)
    zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:804:28)
    zigbee.0	2020-12-16 11:19:50.273	error	at Znp.request (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:273:19)
    zigbee.0	2020-12-16 11:19:50.273	error	(1803) Failed to stop zigbee (Error: Cannot request when znp has not been initialized yet
    zigbee.0	2020-12-16 11:19:50.143	info	(1803) Zigbee: disabling joining new devices.
    zigbee.0	2020-12-16 11:19:50.141	info	(1803) cleaned everything up...
    zigbee.0	2020-12-16 11:19:50.139	info	(1803) Got terminate signal TERMINATE_YOURSELF
    host.raspberrypi	2020-12-16 11:19:50.135	info	stopInstance system.adapter.zigbee.0 send kill signal
    host.raspberrypi	2020-12-16 11:19:50.129	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
    @Mr-X
    Scheint mir an der Hardware zu liegen.
    https://www.zigbee2mqtt.io/information/FAQ.html#modemmanager-is-installed
    Was sagt eigentlich
    dmesg
    zu dem Stick? Irgendwo Meldungen zu undervoltage?
      @Mr-X
      Was sagt eigentlich
      dmesg
      Mr.X
      @Thomas-Braun Ne, nichts gesehen.
      irgendwie scheint es jetzt mal einen Tag zu laufen.
      Ich denke, ich belasse es erstmal so wie es ist, und warte auf den neuen Stick von Arteck.
      Hoffe die Post braucht nicht allzulange.
      Vielen Dank nochmals für deine Bemühungen !!!
