  3. Entwicklung
  4. Zigbee bleibt gelb nach upgrade auf 1.4
    5.4k
zigbee
22 Beiträge 2 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    @Mr-X Lass den Stick immer stecken! Was ist das genau für eine Hardware?
    lsusb -v
    Wie verhält es sich, wenn du das System sauber rebootest?
    sudo reboot
    Mr.X
    @Thomas-Braun
    Bus 002 Device 002: ID 0781:5581 SanDisk Corp. Ultra
    Couldn't open device, some information will be missing
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               3.00
      bDeviceClass            0
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0         9
      idVendor           0x0781 SanDisk Corp.
      idProduct          0x5581 Ultra
      bcdDevice            1.00
      iManufacturer           1
      iProduct                2
      iSerial                 3
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x002c
        bNumInterfaces          1
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower              896mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass         8 Mass Storage
          bInterfaceSubClass      6 SCSI
          bInterfaceProtocol     80 Bulk-Only
          iInterface              0
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x81  EP 1 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0400  1x 1024 bytes
            bInterval               0
            bMaxBurst               1
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x02  EP 2 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bMaxBurst              15
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               3.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         3
      bMaxPacketSize0         9
      idVendor           0x1d6b Linux Foundation
      idProduct          0x0003 3.0 root hub
      bcdDevice            5.04
      iManufacturer           3
      iProduct                2
      iSerial                 1
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x001f
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         9 Hub
          bInterfaceSubClass      0
          bInterfaceProtocol      0 Full speed (or root) hub
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0004  1x 4 bytes
            bInterval              12
            bMaxBurst               0
    Bus 001 Device 003: ID 0451:16a8 Texas Instruments, Inc.
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            2 Communications
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        32
      idVendor           0x0451 Texas Instruments, Inc.
      idProduct          0x16a8
      bcdDevice            0.09
      iManufacturer           1
      iProduct                2
      iSerial                 3
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x0043
        bNumInterfaces          2
        iConfiguration          0
        bmAttributes         0x80
          (Bus Powered)
        MaxPower               50mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         2 Communications
          bInterfaceSubClass      2 Abstract (modem)
          bInterfaceProtocol      1 AT-commands (v.25ter)
          iInterface              0
          CDC Header:
            bcdCDC               1.10
          CDC ACM:
            bmCapabilities       0x02
              line coding and serial state
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
          CDC Call Management:
            bmCapabilities       0x00
            bDataInterface          1
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  1x 64 bytes
            bInterval              64
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass        10 CDC Data
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x84  EP 4 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x04  EP 4 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.10
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bDeviceProtocol         1 Single TT
      bMaxPacketSize0        64
      idVendor           0x2109 VIA Labs, Inc.
      idProduct          0x3431 Hub
      bcdDevice            4.21
      iManufacturer           0
      iProduct                1
      iSerial                 0
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x0019
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0001  1x 1 bytes
            bInterval              12
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               2.00
      bDeviceClass            9 Hub
      bDeviceSubClass         0
      bMaxPacketSize0        64
      idProduct          0x0002 2.0 root hub
      bcdDevice            5.04
      iManufacturer           3
      iProduct                2
      iSerial                 1
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x0019
        bNumInterfaces          1
        iConfiguration          0
        bmAttributes         0xe0
          Self Powered
          Remote Wakeup
        MaxPower                0mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              12
      Mr.X
      Das kommt nach einen reboot im Log:
      Adapter ist nun grün. aber nach 10min. bis 1 Stunde wird der gelb
      zigbee.0
      2020-12-15 21:25:16.898
      error
      (1805) Device 0x90fd9ffffe8a09d4 "undefined" not described in statesMapping.
      zigbee.0
      2020-12-15 21:25:16.676
      info
      (1805) Zigbee started
      zigbee.0
      2020-12-15 21:25:16.675
      info
      (1805) 0xbc33acfffe0ebcf2 (addr 65202): HG06337 - Lidl Silvercrest smart plug (Router)
      zigbee.0
      2020-12-15 21:25:16.667
      info
      (1805) 0xbc33acfffe0ebd34 (addr 45265): HG06337 - Lidl Silvercrest smart plug (Router)
      zigbee.0
      2020-12-15 21:25:16.664
      info
      (1805) 0x842e14fffe556652 (addr 44502): HG06338 - Lidl Silvercrest 3 gang switch, possibly with USB (Router)
      zigbee.0
      2020-12-15 21:25:16.661
      info
      (1805) 0x0017880108b7ba14 (addr 55123): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
      zigbee.0
      2020-12-15 21:25:16.659
      info
      (1805) 0x90fd9ffffe8a09d4 (addr 21330): Not supported (model undefined)(Unknown)
      zigbee.0
      2020-12-15 21:25:16.658
      info
      (1805) 0x000b57fffec367c3 (addr 26913): LED1545G12 - IKEA TRADFRI LED bulb E26/E27 980 lumen, dimmable, white spectrum, opal white (Router)
      zigbee.0
      2020-12-15 21:25:16.656
      info
      (1805) 0x00158d0004041f71 (addr 53371): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.654
      info
      (1805) 0x005043c903241a3e (addr 47918): HS1SA - HEIMAN Smoke detector (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.651
      info
      (1805) 0x005043c9032455a3 (addr 41038): HS1SA - HEIMAN Smoke detector (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.650
      info
      (1805) 0x005043c90324538e (addr 39166): HS1SA - HEIMAN Smoke detector (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.648
      info
      (1805) 0x005043c903245474 (addr 6269): HS1SA - HEIMAN Smoke detector (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.646
      info
      (1805) 0x005043c903386694 (addr 44701): HS1SA - HEIMAN Smoke detector (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.644
      info
      (1805) 0x00158d0004042192 (addr 65354): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.643
      info
      (1805) 0x000b57fffec1f6ec (addr 28034): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.640
      info
      (1805) 0x000b57fffe9e650d (addr 38936): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
      zigbee.0
      2020-12-15 21:25:16.637
      info
      (1805) 0x000b57fffe2b7dea (addr 5574): ICTC-G-1 - IKEA TRADFRI wireless dimmer (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.635
      info
      (1805) 0x84182600000f74b5 (addr 9139): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
      zigbee.0
      2020-12-15 21:25:16.633
      info
      (1805) 0x90fd9ffffe6d32bc (addr 34524): LED1546G12 - IKEA TRADFRI LED bulb E26/E27 950 lumen, dimmable, white spectrum, clear (Router)
      zigbee.0
      2020-12-15 21:25:16.631
      info
      (1805) 0x00158d0003f045f4 (addr 42828): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.629
      info
      (1805) 0x00158d0004252ae8 (addr 42379): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.627
      info
      (1805) 0x00158d000425298b (addr 62172): WSDCGQ01LM - Xiaomi MiJia temperature & humidity sensor (Unknown)
      zigbee.0
      2020-12-15 21:25:16.625
      info
      (1805) 0x00158d0002a374e8 (addr 51270): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.617
      info
      (1805) 0x00158d00041cd4e6 (addr 37917): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
      zigbee.0
      2020-12-15 21:25:16.603
      info
      (1805) Currently 23 devices are joined:
      zigbee.0
      2020-12-15 21:25:16.592
      info
      (1805) --> transmitPower : high
      zigbee.0
      2020-12-15 21:25:16.578
      info
      (1805) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}
      • M Mr.X
        @Thomas-Braun
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               3.00
          bDeviceClass            0
          bDeviceSubClass         0
          bDeviceProtocol         0
          bMaxPacketSize0         9
          bcdDevice            1.00
          iManufacturer           1
          iProduct                2
          iSerial                 3
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x002c
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0x80
              (Bus Powered)
            MaxPower              896mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           2
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
                bMaxBurst               1
                bLength                 7
                bDescriptorType         5
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
                bMaxBurst              15
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               3.00
          bDeviceClass            9 Hub
          bDeviceSubClass         0
          bDeviceProtocol         3
          bMaxPacketSize0         9
          bcdDevice            5.04
          iManufacturer           3
          iProduct                2
          iSerial                 1
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x001f
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0xe0
              Self Powered
              Remote Wakeup
            MaxPower                0mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                bInterval              12
                bMaxBurst               0
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               2.00
          bDeviceSubClass         0
          bDeviceProtocol         0
          bMaxPacketSize0        32
          idProduct          0x16a8
          bcdDevice            0.09
          iManufacturer           1
          iProduct                2
          iSerial                 3
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x0043
            bNumInterfaces          2
            iConfiguration          0
            bmAttributes         0x80
              (Bus Powered)
            MaxPower               50mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              iInterface              0
              CDC Header:
                bcdCDC               1.10
              CDC ACM:
                bmCapabilities       0x02
              CDC Union:
                bMasterInterface        0
                bSlaveInterface         1
                bmCapabilities       0x00
                bDataInterface          1
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                bInterval              64
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        1
              bAlternateSetting       0
              bNumEndpoints           2
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
                bLength                 7
                bDescriptorType         5
                bmAttributes            2
                  Transfer Type            Bulk
                  Synch Type               None
                  Usage Type               Data
                bInterval               0
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               2.10
          bDeviceClass            9 Hub
          bDeviceSubClass         0
          bMaxPacketSize0        64
          bcdDevice            4.21
          iManufacturer           0
          iProduct                1
          iSerial                 0
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x0019
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0xe0
              Self Powered
              Remote Wakeup
            MaxPower              100mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                bInterval              12
        Device Descriptor:
          bLength                18
          bDescriptorType         1
          bcdUSB               2.00
          bDeviceClass            9 Hub
          bDeviceSubClass         0
          bMaxPacketSize0        64
          bcdDevice            5.04
          iManufacturer           3
          iProduct                2
          iSerial                 1
            bLength                 9
            bDescriptorType         2
            wTotalLength       0x0019
            bNumInterfaces          1
            iConfiguration          0
            bmAttributes         0xe0
              Self Powered
              Remote Wakeup
            MaxPower                0mA
              bLength                 9
              bDescriptorType         4
              bInterfaceNumber        0
              bAlternateSetting       0
              bNumEndpoints           1
              iInterface              0
                bLength                 7
                bDescriptorType         5
                bmAttributes            3
                  Synch Type               None
                  Usage Type               Data
                bInterval              12
        @Mr-X Das System liegt auf dem SanDisk Datenträger? Boot über USB?
          Mr.X
          @Thomas-Braun Ja, genau.
          Und grün wurde er erst jetzt nach dem zweiten boot.
          Momentan geht's, auch die Lidl Sachen.
          Sobald ich merke dass er aussteigt, kann ich den Log posten.
          Drehe jetzt ne Runde mit Doggi, und wenn ich wieder komme ist meist alles platt.
          • M Mr.X
            zigbee.0
            error
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            zigbee.0
            info
            @Mr-X Das ist der 2531-Stick, oder? Der kann mit 23 Geräten überfordert sein.
              Mr.X
              schrieb am zuletzt editiert von Mr.X
              @Thomas-Braun Ja, das stimmt.
              Mich wundert aber dass dann mit 1.3.1 alles läuft.
              habe jetzt 3 Lidl Sachen angelernt, davor lief alles Tipi topi unter 1.3.1
              • M Mr.X
                @Mr-X Kann ja sein, dass die drei neuen Geräte genau die drei sind, bei denen der Stick ausgereizt ist.
                  Mr.X
                  @Thomas-Braun und das würde dann die errors kreieren?
                  Könnte jetzt noch die drei neue löschen und auf 1.4 bleiben.
                  • M Mr.X
                    @Mr-X Nicht alle.
                      @Mr-X Nicht alle.
                      Mr.X
                      @Thomas-Braun
                      So, da wären wir wieder.
                      Ich habe gestern drei Geräte gelöscht. Gestern abend und heute früh vor der Arbeit lief alles.
                      Nun habe ich eben nachgeschaut: Adapter gelb.
                      Nach dem Adapter Neustart kommt das:
                      zigbee.0	2020-12-16 11:19:50.275	info	(1803) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      zigbee.0	2020-12-16 11:19:50.274	info	(1803) terminating
                      zigbee.0	2020-12-16 11:19:50.273	error	at /opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:27:71)
                      zigbee.0	2020-12-16 11:19:50.273	error	at Generator.next (<anonymous>)
                      zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:453:28)
                      zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.dataRequestExtended (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:800:16)
                      zigbee.0	2020-12-16 11:19:50.273	error	at __awaiter (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:23:12)
                      zigbee.0	2020-12-16 11:19:50.273	error	at new Promise (<anonymous>)
                      zigbee.0	2020-12-16 11:19:50.273	error	at ZStackAdapter.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:804:28)
                      zigbee.0	2020-12-16 11:19:50.273	error	at Znp.request (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:273:19)
                      zigbee.0	2020-12-16 11:19:50.273	error	(1803) Failed to stop zigbee (Error: Cannot request when znp has not been initialized yet
                      zigbee.0	2020-12-16 11:19:50.143	info	(1803) Zigbee: disabling joining new devices.
                      zigbee.0	2020-12-16 11:19:50.141	info	(1803) cleaned everything up...
                      zigbee.0	2020-12-16 11:19:50.139	info	(1803) Got terminate signal TERMINATE_YOURSELF
                      host.raspberrypi	2020-12-16 11:19:50.135	info	stopInstance system.adapter.zigbee.0 send kill signal
                      host.raspberrypi	2020-12-16 11:19:50.129	info	stopInstance system.adapter.zigbee.0 (force=false, process=true)
                      • M Mr.X
                        @Thomas-Braun
                        @Mr-X
                        Scheint mir an der Hardware zu liegen.
                        https://www.zigbee2mqtt.io/information/FAQ.html#modemmanager-is-installed
                        Was sagt eigentlich
                        dmesg
                        zu dem Stick? Irgendwo Meldungen zu undervoltage?
                          @Mr-X
                          Was sagt eigentlich
                          dmesg
                          Mr.X
                          @Thomas-Braun Ne, nichts gesehen.
                          irgendwie scheint es jetzt mal einen Tag zu laufen.
                          Ich denke, ich belasse es erstmal so wie es ist, und warte auf den neuen Stick von Arteck.
                          Hoffe die Post braucht nicht allzulange.
                          Vielen Dank nochmals für deine Bemühungen !!!
