  4. Adapter lassen sich nicht aktualisieren
    5.8k
iobroker update
55 Beiträge 6 Kommentatoren 10.2k Aufrufe 5 Beobachtet
  • K Karacho
    @Homoran
    Passt die Rückmeldung
    pi@raspberrypi4-iob:~ $ sudo npm i canvas@latest
    > canvas@2.6.1 install /home/pi/node_modules/canvas
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp WARN Using needle for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/node-gfx/node-canvas-prebuilt/releases/download/v2.6.1/canvas-v2.6.1-node-v72-linux-glibc-arm.tar.gz
    node-pre-gyp WARN Pre-built binaries not found for canvas@2.6.1 and node@12.20.0 (node-v72 ABI, glibc) (falling back to source compile with node-gyp)
    gyp WARN EACCES current user ("pi") does not have permission to access the dev dir "/root/.cache/node-gyp/12.20.0"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/home/pi/node_modules/canvas/.node-gyp"
    Package pixman-1 was not found in the pkg-config search path.
    Perhaps you should add the directory containing `pixman-1.pc'
    to the PKG_CONFIG_PATH environment variable
    No package 'pixman-1' found
    gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.79-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/home/pi/node_modules/canvas/build/Release" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v72"
    gyp ERR! cwd /home/pi/node_modules/canvas
    gyp ERR! node -v v12.20.0
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/home/pi/node_modules/canvas/build/Release --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v72' (1)
    node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:1022:16)
    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)
    node-pre-gyp ERR! System Linux 5.4.79-v7l+
    node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /home/pi/node_modules/canvas
    node-pre-gyp ERR! node -v v12.20.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the canvas@2.6.1 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /root/.npm/_logs/2020-12-07T16_44_28_879Z-debug.log
    #41
    @Karacho
    Nein, du standst im falschen Verzeichnis.
    Und die dev-Pakete fehlten noch dazu.
    Und npm tunlichst nicht in Verbindung mit sudo verwenden.
    K 1 Antwort Letzte Antwort
      @Karacho
      Karacho
      #42
      @Thomas-Braun
      Ich geh dann jetzt mal Deinen Weg...
        @Homoran @Karacho
        sudo apt update
        sudo apt install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev libpixman-1-dev
        sudo apt dist-upgrade
        sudo reboot
        Dann
        iobroker update
        iobroker upgrade
        Unter Buster sollte das dann genügen.
        Karacho
        #43
        @Thomas-Braun
        Dein Weg hat geklappt
        iobroker upgrade
        ist ohne Fehler durchgelaufen.
        Hat alle stable Adapter aktualisiert
        Werde jetzt mal ein bisschen rumprobieren...
        Vielen Dank
        • K Karacho
          @Thomas-Braun
          iobroker upgrade
          Vielen Dank
          #44
          @Karacho sagte in Adapter lassen sich nicht aktualisieren:
          Alles andere hätte mich auch gewundert auf einem gesunden System.
          • J Offline
            Joshude
            #45
            Ich hole den alten Thread mal hoch, da ich die gleichen Probleme habe und die hier vorgeschlagenen Lösungsversuche nicht funktionieren.
            /opt/iobroker $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v12.22.12
            /usr/bin/node
            v12.22.12
            /usr/bin/npm
            6.14.16
            nodejs:
              Installiert:           12.22.12-deb-1nodesource1
              Installationskandidat: 12.22.12-deb-1nodesource1
              Versionstabelle:
             *** 12.22.12-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
                    500 https://archive.raspbian.org/raspbian buster/main armhf Packages
            /opt/iobroker $ iobroker update
            Used repository: stable
            Adapter    "admin"        : 5.3.8    , installed 5.3.8
            Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
            Adapter    "backitup"     : 2.4.9    , installed 2.4.6  [Updatable]
            Adapter    "ble"          : 0.12.0   , installed 0.12.0
            Adapter    "bring"        : 1.8.1    , installed 1.7.13 [Updatable]
            Adapter    "cloud"        : 4.1.1    , installed 4.1.1
            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter    "daswetter"    : 3.1.2    , installed 3.0.9  [Updatable]
            Adapter    "devices"      : 1.0.12   , installed 1.0.10 [Updatable]
            Adapter    "discovery"    : 3.0.3    , installed 3.0.3
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "echarts"      : 1.0.7    , installed 1.0.3  [Updatable]
            Adapter    "fahrplan"     : 1.2.0    , installed 1.2.0
            Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
            Adapter    "flot"         : 1.11.0   , installed 1.10.7 [Updatable]
            Adapter    "geofency"     : 1.1.1    , installed 1.1.1
            Adapter    "ham"          : 4.0.2    , installed 4.0.2
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "history"      : 1.11.1   , installed 1.11.1
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.39 [Updatable]
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "hue"          : 3.7.0    , installed 3.6.5  [Updatable]
            Adapter    "ical"         : 1.12.1   , installed 1.12.1
            Adapter    "influxdb"     : 2.6.3    , installed 2.6.3
            Adapter    "info"         : 1.9.19   , installed 1.9.18 [Updatable]
            Adapter    "iot"          : 1.11.4   , installed 1.11.4
            Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
            Adapter    "jarvis"       : 3.0.11   , installed 3.0.11
            Adapter    "javascript"   : 5.7.0    , installed 5.2.21 [Updatable]
            Adapter    "jeelink"      : 0.1.4    , installed 0.1.4
            Controller "js-controller": 4.0.23   , installed 4.0.19 [Updatable]
            Adapter    "lovelace"     : 2.2.0    , installed 2.1.4  [Updatable]
            Adapter    "material"     : 1.1.2    , installed 1.1.2
            Adapter    "mihome-vacuum": 3.4.2    , installed 3.3.1  [Updatable]
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "mqtt"         : 3.0.6    , installed 2.7.4  [Updatable]
            Adapter    "nuki-extended": 2.3.1    , installed 2.4.0
            Adapter    "nut"          : 1.5.1    , installed 1.5.1
            Adapter    "octoprint"    : 4.0.0    , installed 3.2.0  [Updatable]
            Adapter    "onvif"        : 0.4.4    , installed 0.4.4
            Adapter    "ping"         : 1.5.3    , installed 1.5.3
            Adapter    "proxy"        : 1.3.1    , installed 1.2.2  [Updatable]
            Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
            Adapter    "ring"         : 3.0.4    , installed 1.2.8  [Updatable]
            Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
            Adapter    "scenes"       : 2.3.9    , installed 2.3.9
            Adapter    "shelly"       : 5.3.2    , installed 5.3.2
            Adapter    "shuttercontrol": 1.4.12  , installed 1.4.12
            Adapter    "simple-api"   : 2.7.0    , installed 2.6.4  [Updatable]
            Adapter    "socketio"     : 4.2.0    , installed 4.2.0
            Adapter    "sonoff"       : 2.5.1    , installed 2.5.0  [Updatable]
            Adapter    "spotify-premium": 1.2.1  , installed 1.0.0  [Updatable]
            Adapter    "statistics"   : 2.1.1    , installed 1.0.10 [Updatable]
            Adapter    "synology"     : 2.1.7    , installed 2.1.6  [Updatable]
            Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
            Adapter    "telegram"     : 1.13.0   , installed 1.12.2 [Updatable]
            Adapter    "tesla-motors" : 1.3.0    , installed 1.3.0
            Adapter    "text2command" : 2.2.1    , installed 2.2.1
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "trashschedule": 2.0.2    , installed 1.4.5  [Updatable]
            Adapter    "upnp"         : 1.0.21   , installed 1.0.21
            Adapter    "vis"          : 1.4.15   , installed 1.4.5  [Updatable]
            Adapter    "web"          : 4.3.0    , installed 4.2.3  [Updatable]
            Adapter    "wifilight"    : 1.1.3    , installed 1.1.0  [Updatable]
            Adapter    "wled"         : 0.6.7    , installed 0.6.3  [Updatable]
            Adapter    "ws"           : 1.3.0    , installed 1.3.0
            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
            Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
            iobroker upgrade exemplarisch nur für den ersten Adapter, Zigbee, das Changelog habe ich rausgenommen:
            /opt/iobroker $ iobroker upgrade
            This upgrade of "zigbee" will introduce the following changes:
            Would you like to upgrade zigbee from @1.6.16 to @1.7.5 now? [(y)es, (n)o]: y
            Update zigbee from @1.6.16 to @1.7.5
            host.iobroker Adapter "system.adapter.zigbee.0" is stopped.
            NPM version: 6.14.16
            Installing iobroker.zigbee@1.7.5... (System call)
            upload [311] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
            upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
            upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/bitron_motion_a.png img/bitron_motion_a.png image/png
            upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hs1ht.png img/hs1ht.png image/png
            upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_air-sensor.png img/lifecontrol_air-sensor.png image/png
            upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_ensis.png img/philips_ensis.png image/png
            upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_2.png img/philips_hue_argenta_2.png image/png
            upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_fuzo.png img/philips_hue_fuzo.png image/png
            upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwo001.png img/philips_hue_lwo001.png image/png
            upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/q-flag_led_panel.png img/q-flag_led_panel.png image/png
            upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_switch_aq2.png img/sensor_switch_aq2.png image/png
            upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smoke.png img/smoke.png image/png
            upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_RH3052.png img/tuya_RH3052.png image/png
            upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
            upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
            upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
            upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
            upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
            upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
            upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
            upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
            upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_remote.png img/zbt_remote.png image/png
            upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
            upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
            upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
            upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
            upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
            upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
            upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
            upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
            upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
            upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
            upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
            upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
            host.iobroker Adapter "system.adapter.zigbee.0" is started
            /opt/iobroker $ dmesg | grep -i ext4
            [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:22:D7:29 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
            [    2.042068] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
            [    2.042166] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
            [    3.749501] EXT4-fs (sda2): re-mounted. Opts: (null)
            /opt/iobroker $ sudo apt update
            Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
            Holen:2 http://phoscon.de/apt/deconz buster InRelease [2.869 B]
            OK:3 https://deb.nodesource.com/node_12.x buster InRelease
            Holen:4 https://repos.influxdata.com/debian buster InRelease [4.737 B]
            Holen:5 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
            Holen:6 https://archive.raspbian.org/raspbian buster InRelease [15,0 kB]
            Holen:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
            Holen:8 http://phoscon.de/apt/deconz buster/main armhf Packages [734 B]
            Holen:9 https://repos.influxdata.com/debian buster/stable armhf Packages [937 B]
            Holen:10 http://archive.raspberrypi.org/debian buster/main armhf Packages [391 kB]
            Holen:11 https://archive.raspbian.org/raspbian buster/main Sources [11,4 MB]
            Holen:12 https://archive.raspbian.org/raspbian buster/main armhf Packages [13,0 MB]
            Es wurden 37,8 MB in 16 s geholt (2.336 kB/s).
            Aktualisierung für 7 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
            /opt/iobroker $ sudo apt full-upgrade
            Paketaktualisierung (Upgrade) wird berechnet... Fertig
            Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
              libjemalloc2
            Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
            Die folgenden Pakete werden aktualisiert (Upgrade):
              deconz libntfs-3g883 libssl-dev libssl1.1 ntfs-3g openssl tzdata
            7 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            Es müssen 10,8 MB an Archiven heruntergeladen werden.
            Nach dieser Operation werden 1.229 kB Plattenplatz freigegeben.
            Möchten Sie fortfahren? [J/n] j
            Holen:1 http://phoscon.de/apt/deconz buster/main armhf deconz armhf 2.17.01-raspbian-buster-stable [6.352 kB]
            Holen:2 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf ntfs-3g armhf 1:2017.3.23AR.3-3+deb10u2 [379 kB]
            Holen:3 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libntfs-3g883 armhf 1:2017.3.23AR.3-3+deb10u2 [170 kB]
            Holen:4 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf tzdata all 2021a-0+deb10u5 [266 kB]
            Holen:5 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libssl-dev armhf 1.1.1n-0+deb10u3 [1.579 kB]
            Holen:6 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf libssl1.1 armhf 1.1.1n-0+deb10u3 [1.273 kB]
            Holen:7 http://mirror.netzwerge.de/raspbian/raspbian buster/main armhf openssl armhf 1.1.1n-0+deb10u3 [817 kB]
            Es wurden 10,8 MB in 1 s geholt (7.514 kB/s).
            Changelogs werden gelesen... Fertig
            Vorkonfiguration der Pakete ...
            (Lese Datenbank ... 77984 Dateien und Verzeichnisse sind derzeit installiert.)
            Vorbereitung zum Entpacken von .../0-ntfs-3g_1%3a2017.3.23AR.3-3+deb10u2_armhf.deb ...
            Entpacken von ntfs-3g (1:2017.3.23AR.3-3+deb10u2) über (1:2017.3.23AR.3-3+deb10u1) ...
            Vorbereitung zum Entpacken von .../1-libntfs-3g883_1%3a2017.3.23AR.3-3+deb10u2_armhf.deb ...
            Entpacken von libntfs-3g883 (1:2017.3.23AR.3-3+deb10u2) über (1:2017.3.23AR.3-3+deb10u1) ...
            Vorbereitung zum Entpacken von .../2-tzdata_2021a-0+deb10u5_all.deb ...
            Entpacken von tzdata (2021a-0+deb10u5) über (2021a-0+deb10u4) ...
            Vorbereitung zum Entpacken von .../3-libssl-dev_1.1.1n-0+deb10u3_armhf.deb ...
            Entpacken von libssl-dev:armhf (1.1.1n-0+deb10u3) über (1.1.1n-0+deb10u2) ...
            Vorbereitung zum Entpacken von .../4-libssl1.1_1.1.1n-0+deb10u3_armhf.deb ...
            Entpacken von libssl1.1:armhf (1.1.1n-0+deb10u3) über (1.1.1n-0+deb10u2) ...
            Vorbereitung zum Entpacken von .../5-openssl_1.1.1n-0+deb10u3_armhf.deb ...
            Entpacken von openssl (1.1.1n-0+deb10u3) über (1.1.1n-0+deb10u2) ...
            Vorbereitung zum Entpacken von .../6-deconz_2.17.01-raspbian-buster-stable_armhf.deb ...
            Attention: To install missing dependencies and finish the installation please run:
                    sudo apt install -f
            Entpacken von deconz (2.17.01-raspbian-buster-stable) über (2.16.01-raspbian-buster-stable) ...
            libssl1.1:armhf (1.1.1n-0+deb10u3) wird eingerichtet ...
            libntfs-3g883 (1:2017.3.23AR.3-3+deb10u2) wird eingerichtet ...
            ntfs-3g (1:2017.3.23AR.3-3+deb10u2) wird eingerichtet ...
            tzdata (2021a-0+deb10u5) wird eingerichtet ...
            Current default time zone: 'Europe/Berlin'
            Local time is now:      Mon Jul  4 10:46:50 CEST 2022.
            Universal Time is now:  Mon Jul  4 08:46:50 UTC 2022.
            Run 'dpkg-reconfigure tzdata' if you wish to change it.
            libssl-dev:armhf (1.1.1n-0+deb10u3) wird eingerichtet ...
            deconz (2.17.01-raspbian-buster-stable) wird eingerichtet ...
            openssl (1.1.1n-0+deb10u3) wird eingerichtet ...
            Trigger für initramfs-tools (0.133+deb10u1) werden verarbeitet ...
            Trigger für libc-bin (2.28-10+rpt2+rpi1) werden verarbeitet ...
            Trigger für man-db (2.8.5-2) werden verarbeitet ...
            Trigger für mime-support (3.62) werden verarbeitet ...
            /opt/iobroker $ iobroker list adapters
            system.adapter.admin                   : admin          - v5.3.8
            system.adapter.alexa2                  : alexa2         - v3.11.2
            system.adapter.backitup                : backitup       - v2.4.6
            system.adapter.ble                     : ble            - v0.12.0
            system.adapter.blink4home              : blink4home     - v0.1.1
            system.adapter.bring                   : bring          - v1.7.13
            system.adapter.cloud                   : cloud          - v4.1.1
            system.adapter.coronavirus-statistics  : coronavirus-statistics - v0.8.7
            system.adapter.daswetter               : daswetter      - v3.0.9
            system.adapter.devices                 : devices        - v1.0.10
            system.adapter.discovery               : discovery      - v3.0.3
            system.adapter.dwd                     : dwd            - v2.8.3
            system.adapter.echarts                 : echarts        - v1.0.3
            system.adapter.fahrplan                : fahrplan       - v1.2.0
            system.adapter.feiertage               : feiertage      - v1.1.0
            system.adapter.flot                    : flot           - v1.10.7
            system.adapter.geofency                : geofency       - v1.1.1
            system.adapter.ham                     : ham            - v4.0.2
            system.adapter.harmony                 : harmony        - v1.2.2
            system.adapter.history                 : history        - v1.11.1
            system.adapter.hm-rega                 : hm-rega        - v3.0.39
            system.adapter.hm-rpc                  : hm-rpc         - v1.15.12
            system.adapter.homepilot               : homepilot      - v1.0.3
            system.adapter.hue                     : hue            - v3.6.5
            system.adapter.ical                    : ical           - v1.12.1
            system.adapter.influxdb                : influxdb       - v2.6.3
            system.adapter.info                    : info           - v1.9.18
            system.adapter.iot                     : iot            - v1.11.4
            system.adapter.iqontrol                : iqontrol       - v2.0.0
            system.adapter.jarvis                  : jarvis         - v3.0.11
            system.adapter.javascript              : javascript     - v5.2.21
            system.adapter.jeelink                 : jeelink        - v0.1.4
            system.adapter.lovelace                : lovelace       - v2.1.4
            system.adapter.material                : material       - v1.1.2
            system.adapter.mihome-vacuum           : mihome-vacuum  - v3.3.1
            system.adapter.mobile                  : mobile         - v1.0.1
            system.adapter.mqtt                    : mqtt           - v2.7.4
            system.adapter.nuki-extended           : nuki-extended  - v2.4.0
            system.adapter.nut                     : nut            - v1.5.1
            system.adapter.octoprint               : octoprint      - v3.2.0
            system.adapter.onvif                   : onvif          - v0.4.4
            system.adapter.ping                    : ping           - v1.5.3
            system.adapter.proxy                   : proxy          - v1.2.2
            system.adapter.pushover                : pushover       - v1.1.1
            system.adapter.rickshaw                : rickshaw       - v1.0.0
            system.adapter.ring                    : ring           - v1.2.8
            system.adapter.rpi2                    : rpi2           - v1.3.2
            system.adapter.scenes                  : scenes         - v2.3.9
            system.adapter.shelly                  : shelly         - v5.3.2
            system.adapter.shuttercontrol          : shuttercontrol - v1.4.12
            system.adapter.simple-api              : simple-api     - v2.6.4
            system.adapter.socketio                : socketio       - v4.2.0
            system.adapter.sonoff                  : sonoff         - v2.5.0
            system.adapter.sourceanalytix          : sourceanalytix - v0.4.12
            system.adapter.spotify-premium         : spotify-premium - v1.0.0
            system.adapter.statistics              : statistics     - v1.0.10
            system.adapter.synology                : synology       - v2.1.6
            system.adapter.tankerkoenig            : tankerkoenig   - v2.1.1
            system.adapter.telegram                : telegram       - v1.12.2
            system.adapter.tesla-motors            : tesla-motors   - v1.3.0
            system.adapter.text2command            : text2command   - v2.2.1
            system.adapter.tr-064                  : tr-064         - v4.2.16
            system.adapter.trashschedule           : trashschedule  - v1.4.5
            system.adapter.upnp                    : upnp           - v1.0.21
            system.adapter.vis                     : vis            - v1.4.5
            system.adapter.web                     : web            - v4.2.3
            system.adapter.wifilight               : wifilight      - v1.1.0
            system.adapter.wled                    : wled           - v0.6.3
            system.adapter.yahka                   : yahka          - v0.13.1
            system.adapter.zigbee                  : zigbee         - v1.6.16
            /opt/iobroker $ iobroker list instances
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.ble.0                    : ble                   : iobroker                                 -  enabled
            + system.adapter.bring.0                  : bring                 : iobroker                                 - disabled
              system.adapter.devices.0                : devices               : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
            + system.adapter.fahrplan.0               : fahrplan              : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
            + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999
            + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
            + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : iobroker                                 - disabled
            + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.lovelace.0               : lovelace              : iobroker                                 -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
            + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
              system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
              system.adapter.nut.1                    : nut                   : iobroker                                 - disabled
            + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
              system.adapter.proxy.0                  : proxy                 : iobroker                                 -  enabled
              system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
              system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
            + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 - disabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
              system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 - disabled
              system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
            + system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.telegram.1               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 - disabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wifilight.0              : wifilight             : iobroker                                 -  enabled
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
            + instance is alive
            Das hat auch nichts gebracht:
            sudo apt update
            sudo reboot
            iobroker update
            iobroker upgrade
            Wäre für jedliche Hilfe dankbar :)
            • J Joshude
              /usr/bin/nodejs
              v12.22.12
              /usr/bin/node
              v12.22.12
              /usr/bin/npm
              6.14.16
              nodejs:
                Versionstabelle:
                libjemalloc2
                      sudo apt install -f
              + instance is alive
              sudo apt update
              sudo reboot
              iobroker update
              iobroker upgrade
              #46
              @joshude
              cd /opt/iobroker
              npm ls | grep -E 'github.com|ERR'
              Dann auf node16 springen.
              J 1 Antwort Letzte Antwort
                @joshude
                cd /opt/iobroker
                Joshude
                schrieb am zuletzt editiert von Joshude
                #47
                Erstmal die Ausgabe, nu beginn ich mit dem Upgrade von node nach der Anleitung in deiner Signatur.
                Ich könnte theoretisch auch den Pi platt machen und neu installieren, ich hab aber leider 2-3 andere Dinge auf dem Pi laufen und versuche das daher erstmal zu umgehen :)
                pi@iobroker:/opt/iobroker $ npm ls | grep -E 'github.com|ERR'
                npm ERR! missing: homebridge-blink-for-home@^3.9.1, required by iobroker.ham@4.0.2
                npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
                npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
                npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
                npm ERR! extraneous: eslint@8.9.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                npm ERR! extraneous: eslint-plugin-jest@26.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
                npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
                npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
                │ └─┬ syno@3.0.0 (git+https://github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                GlasfaserG 2 Antworten Letzte Antwort
                • J Joshude
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  #48
                  @joshude sagte in Adapter lassen sich nicht aktualisieren:
                  Erstmal die Ausgabe
                  Bitte vollständige Ein.-/ Ausgabe posten ... nichts kürzen !
                  Zeige auch mal das Ganze hiervon :
                  uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                  • GlasfaserG Glasfaser
                    Erstmal die Ausgabe
                    Joshude
                    #49
                    @glasfaser said in Adapter lassen sich nicht aktualisieren:
                    Da ist nichts gekürzt, die Ausgabe hat nur irgendwie ein paar Tabstops drin. Bearbeite ich gleich
                    pi@iobroker:/opt/iobroker $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                    pi@iobroker:/opt/iobroker $ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v12.22.12
                    v12.22.12
                    6.14.16
                    pi
                    /opt/iobroker
                    OK:1 http://phoscon.de/apt/deconz buster InRelease
                    OK:3 https://repos.influxdata.com/debian buster InRelease
                    OK:4 http://archive.raspberrypi.org/debian buster InRelease
                    OK:5 https://deb.nodesource.com/node_12.x buster InRelease
                    OK:6 https://archive.raspbian.org/raspbian buster InRelease
                    Alle Pakete sind aktuell.
                    nodejs:
                      Versionstabelle:
                    • Thomas BraunT Online
                      #50
                      @Joshude
                      Dann bringe das Ganze auf nodeJS@16.
                      Zuvor würde ich noch schauen, dass du den iobroker.ham sauber installiert hast, ohne fehlende Abhängigkeit.
                        @Joshude
                        Joshude
                        #51
                        Den hab ich eigentlich schon deinstalliert vorhin. Der läuft eh nicht, also hab ich den rausgeschmissen. Genau wie den Synology-Adapter, der scheinbar für die Meldung in der letzten Zeile verantwortlich ist.
                        Kann ich die Fehlermeldungen dann ignorieren und deine Anleitung befolgen? Da steht ja, dass der Tree sauber und ohne Fehler sein soll.
                        • J Joshude
                          #52
                          @joshude
                          Schau vorher nochmal den tree an.
                          Meldungen zu 'extraneous' spielen keine Rolle.
                          • J Joshude
                            GlasfaserG Offline
                            GlasfaserG Offline
                            Glasfaser
                            #53
                            Das ist nicht der Synology Adapter !
                            Diesen Adapter SYNO hast du nicht über den normalen Weg installiert.
                            Das ist der Synology Adapter :
                            https://github.com/iobroker-community-adapters/ioBroker.synology
                            dann wird der SYNO noch drin sein , wenn du den Synology Adapter deinstalliert hast
                              #54
                              @glasfaser @Joshude
                              Da müsste man Mal schauen wo der drunterhängt.
                              Der liegt ja auf der zweiten Ebene im tree.
                              Dürfte aber vom synology-Adapter stammen. Der hat eine Dep ins GitHub.
                                @glasfaser @Joshude
                                GlasfaserG Offline
                                GlasfaserG Offline
                                Glasfaser
                                #55
                                @thomas-braun sagte in Adapter lassen sich nicht aktualisieren:
                                Nö ..
                                ( das war mal ein Versuch ... vom Adapter )
                                MeisterTR hat den Offizellen Support vom Synology Adapter mal übernommen , seit dem er in der
                                iobroker-community-adapters gekommen ist .
                                Der Adapter wurde mal von instalator entwickelt und gelöscht
                                apollon77 hat ihn wieder geholt in die iobroker-community.
