  4. tr-064 startet nicht
    6.7k
tr-064tr-064 adapter fehleradapterneu hieriobrokerfritzbox
9 Beiträge 5 Kommentatoren 672 Aufrufe 3 Beobachtet
    Trusit
    Ich bin gerade neu mit dem Thema ioBroker angefangen und wollte den Adapter tr-064 installieren.
    Dieser startet aber nur einmal ganz kurz und wird dann sofort wieder rot.
    Das Log gibt mir folgende Fehler raus
    host.raspberrypi	2020-11-26 16:40:42.687	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.raspberrypi	2020-11-26 16:40:42.686	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    tr-064.0	2020-11-26 16:40:42.155	warn	(5229) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-11-26 16:40:42.153	error	(5229) ~
    tr-064.0	2020-11-26 16:40:42.153	error	(5229) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
    tr-064.0	2020-11-26 16:40:42.153	error	(5229) ~~ Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-11-26 16:40:42.152	error	(5229) ~
    tr-064.0	2020-11-26 16:40:42.151	error	(5229) !device - "!device"
    tr-064.0	2020-11-26 16:40:42.046	info	(5229) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.1.6
    host.raspberrypi	2020-11-26 16:40:39.726	info	instance system.adapter.tr-064.0 started with pid 5229
    host.raspberrypi	2020-11-26 16:40:09.702	info	Restart adapter system.adapter.tr-064.0 because enabled
    host.raspberrypi	2020-11-26 16:40:09.702	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    tr-064.0	2020-11-26 16:40:09.170	warn	(5214) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-11-26 16:40:09.169	error	(5214) ~
    tr-064.0	2020-11-26 16:40:09.169	error	(5214) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
    tr-064.0	2020-11-26 16:40:09.168	error	(5214) ~~ Fatal error. Can not connect to your FritzBox.
    tr-064.0	2020-11-26 16:40:09.167	error	(5214) !device - "!device"
    tr-064.0	2020-11-26 16:40:09.056	info	(5214) starting. Version 4.2.1 in /opt/iobroker/node_modules/iobroker.tr-064, node: v10.17.0, js-controller: 3.1.6
    host.raspberrypi	2020-11-26 16:40:07.095	info	instance system.adapter.tr-064.0 started with pid 5214
    Ich habe schon in anderen Forenbeiträgen gelesen dass man in den Adapter einstellungen die IP-Adresse des Routers direkt einstellen soll und neu starten, leider hat dies auch nichts gebacht.
    Ich hoffe ihr könnt mir helfen.
    Lg
    |Systemdata| Bitte Ausfüllen|
    |Hardwaresystem:| Pi 4|
    |Arbeitsspeicher:| 4GB |
    |Nodejs-Version:| 10.17.0 |
    |NPM-Version:| 6.11.3 |
    • T Trusit
      Lg
      sigi234S Online
      sigi234S Online
      sigi234
      @Trusit
      Immer Daten sichern!
      • sigi234S sigi234
        @Trusit
        Trusit
        @sigi234
        Super vielen dank!
        Der Adapter startet nun.
        • T Trusit
          @sigi234
          Super vielen dank!
          @Trusit
          node: v10.17.0
          Würde ich mal auf node12 heben, mindestens aber aktuell halten: nodeJS 10.23.0
          Du hast da ohnehin eine schräge Version drin, die kleinste Version die mit einem aktuellen Raspberry OS mitkommt ist nämlich 10.21.0.
          Was hast du denn da installiert?
            @Trusit
            node: v10.17.0
            Trusit
            @Thomas-Braun
            Hallo Thomas, ich habe mir die aktuelle Version von der ioBroker seite runtergeladen und installiert.
            Ich dachte dies wäre die aktuelle Version.
            Für die Node JS Version ist bei mir auch eine Nachricht, dass es eine aktuellere Version gibt aber ich habe leider noch keine Ahnung wie ich diese update.
            Lg
            • T Trusit
              @Thomas-Braun
              Lg
              @Trusit
              Ein vorgekochtes Image?
              Die sind 'steinalt'.
              Schau dir hier an, wie man nodeJS und auch das restliche System aktuell hält:
                @Trusit
                Trusit
                @Thomas-Braun
                Vielen Dank für deine Hilfe Thomas.
                Ich bin leider ganz neu in diesem Thema und arbeite mich gerade langsam rein.
                Ich würde zwar sagen dass ich nicht gerade doof bin was Technik angeht aber ich hatte leider vorher noch gar keine Berührungspunkte mit diesen Themen aber ich gebe mein bestes mich da rein zu fuchsen.
                Ich danke euch schon jetzt für die ganzen hilfreichen Antworten.
                LG
                  Termina
                  schrieb am zuletzt editiert von Termina
                  Ich habe tatsächlich ein ähnliches Problem.
                  System: Proxmox -> Iobroker in einer VM
                  Node.js v14.15.1
                  NPM 6.14.8
                  In der Fritzbox ist der Haken für die Anwendungen gesetzt. Fritzbox neustart ebenfalls schon erledigt.
                  Folgende Fehlermeldung erhalte ich im Log:
                  tr-064.0	2020-12-04 17:47:01.870	warn	(28985) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
                  tr-064.0	2020-12-04 17:47:01.867	error	(28985) ~
                  tr-064.0	2020-12-04 17:47:01.866	error	(28985) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
                  tr-064.0	2020-12-04 17:47:01.865	error	(28985) ~~ Fatal error. Can not connect to your FritzBox.
                  tr-064.0	2020-12-04 17:47:01.864	error	(28985) ~
                  tr-064.0	2020-12-04 17:47:01.862	error	(28985) Error: connect ETIMEDOUT 192.168.178.1:49000 - {"errno":-110,"code":"ETIMEDOUT","syscall":"connect","address":"192.168.178.1","port":49000}
                  tr-064.0	2020-12-04 17:46:30.204	info	(28985) starting. Version 4.0.13 in /opt/iobroker/node_modules/iobroker.tr-064, node: v14.15.1, js-controller: 3.1.6
                  • T Termina
                    Node.js v14.15.1
                    NPM 6.14.8
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @Termina
                    Als erstes auf die empfohlene Nodejs Version wechseln (V12)
                    @Thomas-Braun hat da ein How To zu gemacht.
                    Dann könntest du auf die Latest gehen. Aber dran denken, ist eine Beta.
                    4.2.1 ist das momentan.
                    Und dann in den Einstellungen die IP der Box eingeben ( wenn nicht schon geschehen). Nicht fritz.box.
                    Und dann Iobroker neu starten und dann die Fritzbox.
                    Das wäre so meine Vorgehensweise.
