  4. Seit ical 1.7.5 funktioniert Kalender nicht mehr
    6.3k
ical adapter
8 Beiträge 4 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • SBorgS Offline
    SBorgS Offline
    SBorg
    Mit 1.7.5 und 1.8.0 geht einer meiner Kalender nicht mehr.
    Log, danach nichts mehr:
    ical.1	2020-11-14 16:36:18.908	debug	(25417) File read successfully http://192.168.1.30:32500/Kalender2020.ics
    ical.1	2020-11-14 16:36:18.894	silly	(25417) States system redis pmessage system.adapter.ical.1.logLevel/system.adapter.ical.1.logLevel:{"val":"silly","ack":true,"ts":1605368178860,"q":0,"from":"system.adapter.ical.1","lc":1605368178860
    ical.1	2020-11-14 16:36:18.866	debug	(25417) reading calendar from URL: http://192.168.1.30:32500/Kalender2020.ics, color: #000000
    ical.1	2020-11-14 16:36:18.811	info	(25417) starting. Version 1.8.0 in /opt/iobroker/node_modules/iobroker.ical, node: v12.19.0, js-controller: 3.1.6
    ical.1	2020-11-14 16:36:18.610	debug	(25417) Plugin sentry Initialize Plugin (enabled=true)
    ical.1	2020-11-14 16:36:12.922	debug	(25417) statesDB connected
    ical.1	2020-11-14 16:36:12.922	debug	(25417) States connected to redis: 127.0.0.1:9000
    ical.1	2020-11-14 16:36:12.907	debug	(25417) States create System PubSub Client
    ical.1	2020-11-14 16:36:12.895	debug	(25417) States create User PubSub Client
    ical.1	2020-11-14 16:36:12.889	debug	(25417) Redis States: Use Redis connection: 127.0.0.1:9000
    ical.1	2020-11-14 16:36:12.887	debug	(25417) objectDB connected
    ical.1	2020-11-14 16:36:12.885	debug	(25417) Objects connected to redis: 127.0.0.1:9001
    ical.1	2020-11-14 16:36:12.646	debug	(25417) Objects client initialize lua scripts
    ical.1	2020-11-14 16:36:12.646	debug	(25417) Objects create User PubSub Client
    ical.1	2020-11-14 16:36:12.645	debug	(25417) Objects create System PubSub Client
    ical.1	2020-11-14 16:36:11.446	debug	(25417) Objects client ready ... initialize now
    ical.1	2020-11-14 16:36:10.940	debug	(25417) Redis Objects: Use Redis connection: 127.0.0.1:9001
    Mit 1.7.4 funktioniert der Kalender noch. Beispiel:
    BEGIN:VEVENT
    CATEGORIES:Abfallkalender 2020
    CLASS:PUBLIC
    CREATED:20200111T095953Z
    DTSTAMP:20200111T103410Z
    DTSTART:20201223T070000
    DTEND:20201223T180000
    LAST-MODIFIED:20200111T100157Z
    PRIORITY:5
    SEQUENCE:0
    SUMMARY:<span style="color: grey">Restmülltonne</span>
    TRANSP:TRANSPARENT
    UID:ical-202087469
    END:VEVENT
    Kann es sein, dass in der SUMMARY stört? Falls ja, gewollt oder Mistake :)
    LG SBorg ( SBorg auf GitHub)
    • SBorgS SBorg
      BEGIN:VEVENT
      CLASS:PUBLIC
      PRIORITY:5
      SEQUENCE:0
      TRANSP:TRANSPARENT
      UID:ical-202087469
      END:VEVENT
      ChaotC Offline
      ChaotC Offline
      Chaot
      @SBorg Bei mir funktioniert der Kalender einwandfrei.
      Dein Log verstehe ich aber nicht. Der meldet doch in der letzten Zeile
      Also funktioniert er doch. Oder sehe ich das falsch?
      • ChaotC Chaot
        SBorgS Offline
        SBorgS Offline
        SBorg
        @Chaot 3 funktionieren auch noch, nur der vierte obige ließt ihn ein, meldet keinerlei Fehler, aber leider auch keinerlei Termine mehr :)
        Selber Kalender funktioniert mit 1.7.4 aber noch ohne jegliche Änderung.
        ChaotC O 2 Antworten Letzte Antwort
        • SBorgS SBorg
          ChaotC Offline
          ChaotC Offline
          Chaot
          @SBorg Was steht denn in den Objekten drin? Hast du die mal Instanz mal neu gestartet?
          Wenn 3 Kalenderinstanzen funktionieren und eine nicht denke ich mal das da die ankommenden Daten nicht passen.
          Hast du die Einstellungen der Instanz geprüft?
          Dein Beispielkalender zeigt ein Ereignis am 23.12.2020. Geht deine Kalendereinstellung so weit vor?
          In den Änderungen fallen mir auch ein Punkt auf auf den du deine Eingangsdatei prüfen solltest:
          Only handle events with a start date
          • 4 Offline
            4 Offline
            4-Real
            schrieb am zuletzt editiert von 4-Real
            Ich klinke mich mal mit ein..
            Meine Kalendar werden zwar regelmäßig aktualisiert, und auch in meiner VIS Angezeigt.
            Habe vier ICAL Instanzen um zu trennen.
            Lasse in meiner VIS immer nur 2 Termine anzeigen. Sobald in meinem gesamten Icloud Kalender nur noch 2 Einträge vorhanden sind, ich den letzten dann z.B. Lösche, wird der Eintrag der nur noch als einziger vorhandenen ist, doppelt in meiner VIS angezeigt.
            Beispiel:
            2 Termine:
            -Arzt
            -Auto
            Es sind, außer diesen beiden, keine weiteren Einträge fürs restliche Jahr vorhanden.
            Lösche ich nun aber den Termin Auto, also den letzten, das im gesamten restlichen Jahr nur noch Arzt ansteht, wird komischerweise Arzt doppelt in meiner VIS angezeigt..
            Hat jemand auch dieses Problem?
            • SBorgS SBorg
              O Online
              O Online
              Oli
              @SBorg
              Hast du das Problem bei dir lösen können? Habe nämlich das gleiche Phänomen
              Oliver
              • O Oli
                @SBorg
                SBorgS Offline
                SBorgS Offline
                SBorg
                schrieb am zuletzt editiert von SBorg
                @Oli Ja, konnte ich. Bis 1.7.4 waren die "" kein Problem, seit 1.7.5 hängt sich aber bei mir der kpl. Ical weg und produziert 100% Systemlast (fiel mir gar nicht auf).
                Da es bei mir "nur" der Müllkalender ist (=erscheint 1x jährlich) patche ich mir mittels sed die SUMMARY zu Recht:
                falsch, hängt seit > 1.7.5
                funktioniert:
                SUMMARY:<span style='color: grey'>Restmülltonne</span>
                O 1 Antwort Letzte Antwort
                • SBorgS SBorg
                  funktioniert:
                  O Online
                  O Online
                  Oli
                  @SBorg
                  Super danke, werde ich testen, bei mir ist es auch der Müllkalender
                  Oliver
