  5. [Vorlage] Tasmota One Click Firmware Update Vis Javascript.
    2.8k
    4.9k
    4.1k
120 Beiträge 11 Kommentatoren 22.6k Aufrufe 17 Beobachtet
  • fischi87F Offline
    fischi87F Offline
    fischi87
    #61
    Hallo, ich finde es ein tolles Skript nur leider habe ich 2 fragen.
    1. ich habe devices eingepflegt die es jetzt nicht mehr gibt, das Skript bringt mir trotzdem noch die alten DEVICES bzw das er diese nicht findet, wie kann es dies beheben?
    2345) Error in request callback: TypeError: Cannot read property 'trim' of null
    javascript.0	2020-12-07 19:14:21.230	warn	(2345) at processTicksAndRejections (internal/process/task_queues.js:84:21)
    javascript.0	2020-12-07 19:14:21.230	warn	(2345) at endReadableNT (_stream_readable.js:1223:12)
    javascript.0	2020-12-07 19:14:21.229	warn	(2345) at IncomingMessage.EventEmitter.emit (domain.js:483:12)
    javascript.0	2020-12-07 19:14:21.229	warn	(2345) at IncomingMessage.emit (events.js:326:22)
    javascript.0	2020-12-07 19:14:21.229	warn	(2345) at Object.onceWrapper (events.js:420:28)
    javascript.0	2020-12-07 19:14:21.229	warn	(2345) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1076:12)
    javascript.0	2020-12-07 19:14:21.229	warn	(2345) at Request.EventEmitter.emit (domain.js:483:12)
    javascript.0	2020-12-07 19:14:21.228	warn	(2345) at Request.emit (events.js:314:20)
    javascript.0	2020-12-07 19:14:21.228	warn	(2345) at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1154:10)
    javascript.0	2020-12-07 19:14:21.228	warn	(2345) at Request.EventEmitter.emit (domain.js:483:12)
    javascript.0	2020-12-07 19:14:21.228	warn	(2345) at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
    javascript.0	2020-12-07 19:14:21.227	warn	(2345) at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
    javascript.0	2020-12-07 19:14:21.227	warn	(2345) at script.js.System.Tasmota_Update:213:42
    javascript.0	2020-12-07 19:14:21.227	warn	(2345) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:785:29)
    javascript.0	2020-12-07 19:14:21.227	warn	(2345) at script.js.System.Tasmota_Update:215:41
    javascript.0	2020-12-07 19:14:21.224	warn	(2345) getState "sonoff.0.Flur Unten.INFO.Version" not found (3)
    1. bekomme ich in den Objekte keine updates angezeigt obwohl das Skript beim start mir sagt es hätte 2 geräte gefunden?
    2345) script.js.System.Tasmota_Update: Tasmota: Firmwaredownload tasmota-sensors.bin gestartet
    javascript.0	2020-12-07 19:21:42.615	info	(2345) script.js.System.Tasmota_Update: Tasmota: Firmwaredownload tasmota.bin gestartet
    javascript.0	2020-12-07 19:21:42.255	info	(2345) script.js.System.Tasmota_Update: Tasmota: Firmwaredownload tasmota-minimal.bin gestartet
    javascript.0	2020-12-07 19:21:32.845	info	(2345) script.js.System.Tasmota_Update: Tasmota: 2 Geräte gefunden
    danke grüße Axel
    smartboartS 1 Antwort Letzte Antwort
    • fischi87F fischi87
      danke grüße Axel
      smartboartS Offline
      smartboartS Offline
      smartboart
      #62
      @fischi87
      hallo...
      lief denn das script schonmal bei dir und du hast nun 2 Geräte entfernt?
      Dann musst du sicher stellen, dass du diese im Konfigbereich herausnimmst und das diese Geräte nicht mehr im Sonoff Adapter im Objektbaum aufgelistet sind.
      Dann das script wieder neu starten.
      Updates bekommst du nur angezeigt, wenn sich die Version welche online verfügbar ist neuer ist als die installierte...
      Wenn es noch nicht lief, akribisch an die Kommentare im Konfigbereich achten...
      fischi87F 1 Antwort Letzte Antwort
      • smartboartS smartboart
        @fischi87
        hallo...
        fischi87F Offline
        fischi87F Offline
        fischi87
        #63
        @smartboart
        ja das skript lief bereits einmal und es ist richtig ich habe 2 entfernt aber sowohl aus dem skript als auch aus den objekten des sonoff adapters.
          @smartboart
          smartboartS Offline
          smartboartS Offline
          smartboart
          schrieb am zuletzt editiert von smartboart
          #64
          @fischi87 sieht fast so aus als waeren ip Adressen falsch eingetragen...haben deine geräte ne feste ip?
            fischi87F Offline
            fischi87F Offline
            fischi87
            schrieb am zuletzt editiert von fischi87
            #65
            @smartboart
            ja haben sie. hab gerade nochmal alles nachgeschaut, die ips passen.
            mir ist gerade aufgefallen dass das Skript mir ein gerät anzeigt was ich noch gar nicht in der Skript eingepflegt haben?1
              @smartboart
              smartboartS Offline
              smartboartS Offline
              smartboart
              #66
              @fischi87 ja....das kann sein, das liegt an der cacheselector Funktion. Hiermit habe ich begonnen das Skript ein Stück weit unabhängig von User Eingaben zu machen. Das Script zählt hier selbstständig die anzahl der geräte welche im Objektbaum hinterlegt sind. Mir fehlt halt im Moment die Zeit das durchgängig in allen Bereichen umzusetzen. Ziel ist, dass gar keine User Eingaben im Konfigberecih mehr nötig sind um bei Hardwareänderungen neuen oder gelöschten Geräten keine manuellen Eingriffe im Script machen zu müssen.
              Aber im Momemt habe ich andere Projekte..
              Für dich heist das, oder generell. Alle vorhandenen Tasmota Geräte müssen im Script manuell gepflegt sein.
                Dragon
                schrieb am zuletzt editiert von Dragon
                #67
                Soooo
                Heute gab es ein neues tasmota und was soll ich sagen... Der Supergau... Er zeigt Updates an per Mail. Ich klicke auf den Button Update all... Er bleibt in einer Schleife hängen, weil ich dussel die falschen ips angegeben hatte, denn ich musste die Fritz Box neu machen. Also IP Adressen korrigiert und neu versuchen... Im Log sagt er die Versionen der Geräte sind alt, eine Nachricht verschickt er aber nicht. Der Datenpunkt Update verfügbar wird nicht true und wenn ich trotzdem ein Update Versuche heißt es immer in der Console "Upgrade failed server did not report size"
                Ich bin etwas ratlos...
                In den Codezeilen ab 362 stehen nur zwanzig Geräte, wenn ich mehr als die habe muss ich dann die Anzahl anpassen? ich weis steht zwar unterhalb von ab hier nichts meh ändern, aber würde sonst für mich keinen Sinn ergeben....
                Es wird auch ein Fehler angezeigt. Er sagt in der entsprechende Zeile Cannot find module node-ssh. Es ist aber in die Module mit aufgenommen...
                • D Dragon
                  Soooo
                  smartboartS Offline
                  smartboartS Offline
                  smartboart
                  #68
                  @Dragon sagte in [Vorlage] Tasmota One Click Firmware Update Vis Javascript.:
                  Die IP Adressen sollten schon stimmen.
                  Ja..Die Zeilen danach kannst du generell an deine Anzahl Geräte angepassen.Wenn es mehr sind ist es sogar zwingend nötig.
                  Bei Weniger nicht..
                  Aber die Abarbeiteung wird hiermit beendet...
                      if(count === AnzahlDevice){
                      clearSchedule(trigger);
                  Das Skript kann man bestimmt auch so schreiben , dass es alles automatisch macht. Dazu bin ich nicht mehr gekommen. Weil es bei mir aber nun so tut, stecke ich da keine Zeit mehr rein.
                  Überlege ob ich es noch um das sichern der Konfig erweitere . also Backup ablegen.
                  Wegen Cannot find module node-ssh....
                  Den Hinweis habe ich auch im Script...sollte nix machen...
                  • C Offline
                    CruziX
                    #69
                    @smartboart Hab mal das Skript ein wenig überarbeitet, aber nicht getestet:
                    von Smartboart / ioBroker Forum
                    https://forum.iobroker.net/topic/38118/tasmota-one-click-firmware-update-vis-javascript
                    31.10.2020
                    Tasmota One Click Firmware Update Vis.extra auch für Geräte die für das internet gesperrt sind.
                    automatischer Download der firmware / minimal , sensors, tasmota und speichern auf dem file system.
                    Starten eines lokalen http: Servers (python) per ssh und einleiten des OTA download der Tasmota Firmware.
                    für selektierbare Geräte über Vis.
                    Nötige Addons im javascript adapter: node-ssh und fs
                    inspiriert durch das script um auf neue Tasmota Version zu prüfen von forummitglied Machinima..
                    https://forum.iobroker.net/topic/22389/skript-um-auf-neue-tasmota-version-zu-pr%C3%BCfen/11
                    31.10.2020 Beta release
                    V0.0.1  Automatisches Tasmota Firmwaredownload bei Update Benachrichtigung:
                           onclickupdate mit http Server Start (python) über ssh inkl Vorwahl des abzudatenden Teilnehmers.
                    {1}
                    31.10.2020
                    V0.0.2  Konfigurationsteil überarbeitet http source.
                    {1}
                    03.11.2020
                    V0.0.3  Kommentare ergänzt um mölichen Missverständnissen entgegen zu wirken.
                           Beim Scriptstart immer die bins runterladen, auch wenn kein Update verfügbar um sicher zu stellen, dass immer was im Download Ordner liegt.
                    {1}
                    06.11.2020
                    V0.0.4  Implementierung der Funktion Update All
                           Im Bereich der Device Zuordnung mussten anpassungen vorgenommen werden umd diese beim Updat All der Reihe nach abarbeiten zu können.
                           Dazu wurde auch der Userconfig Bereich angepasst.
                           Anzahl Geräte wird Automatisch ermittelt und gesetzt. Device 1 - n / AnzahlSensors ist für Sensor reserviert.
                           AnzahlSensors muss im Konfigbereich eingetragen werden. Standart Tasmota Firmware Geräte sind dann automatisch gesetzt von
                           Anzahl Sensors bis automatisch ermittelte Geräte.
                    {1}
                           Hinweis: damit nicht während des Update Prozess durch Eingabe in Vis beim derDevice Auswahl die Schrittkette durcheinander gebract wird, sollte
                           das widget für die DeviceAuswahl nur Sichtbar sein wenn der neue State javascript.0.Status.Tasmota.Tasmota_Firmware.UpdateAll false ist.
                           Um alle Geräte upzudaten muss nun einfach der State UpdateAll auf true gesetzt werden und dann mit dem State UpdateStart das Update eingeleitet
                           werden. Das einzeln Update der Geräte bleibt natürlich erhalten und ist aktiv wenn UpdateAll false ist.
                           Nach Update All wird automatisch die Funktion funcVersion gestartet um alle Geräte nach der installierten Version zu befragen. Im Log kann nun
                           alles nachvollzogen werden.
                    {1}
                    17.12.2020
                    V0.0.4 kleine Fehlerkorrekturen
                    {1}
                    To do....Wenn es die Zeit zulässt..
                    zusätzlich den Changelog in den Versionsinfostate schreiben.
                    createState('javascript.0.Status.Tasmota.Tasmota_Firmware.Update', {
                     def: false,
                     type: 'boolean',
                     name: 'Tasmota Update verfügbar'
                    createState('javascript.0.Status.Tasmota.Tasmota_Firmware.Version', {
                     type: 'string',
                     read: true,
                     write: true,
                     desc: 'Tasmota Firmware Version online',
                     name: 'Tasmota Firmware Update Version'
                    createState('javascript.0.Status.Tasmota.Tasmota_Firmware.Updatestart', {
                     def: false,
                     type: 'boolean',
                     name: 'Tasmota Firmware Update starten'
                    createState('javascript.0.Status.Tasmota.Tasmota_Firmware.UpdateAll', {
                     def: false,
                     type: 'boolean',
                     name: 'Tasmota Firmware Update Alle starten'
                    const fc = true; // force creation zum aktualisieren des Auswahl state
                    //  1 - AnzahlSensors (bei mir 17) müssen Sensor Geräte zugeordnet haben
                    //  > AnzahlSensors +  sind Standart Firmware Geräten vorbehalten.
                    createState('javascript.0.Status.Tasmota.Tasmota_Firmware.Auswahl', 0, fc, {
                     def: 0,
                     type: 'number',
                     name: 'Auswahl Teilnehmer fuer Tasmota Firmware Update',
                     min: 0,
                     max: 100,
                     role: 'value',
                     states: {
                         0: 'keine Vorwahl',
                         1: 'Wemo Pro Test',
                         2: 'Wemo Pro Garage',
                         3: 'Wemo Schuppen',
                         4: 'Wemo Schlafzimmer',
                         5: 'Wemo Keller',
                         6: 'Wemo Huette',
                         7: 'Wemo Fitttnessraum',
                         8: 'Wemo Eingang',
                         9: 'Wemo Dachboden',
                         10: 'Steckdose Waschmaschine',
                         11: 'Steckdose Trockner',
                         12: 'Steckdose Spülmaschine',
                         13: 'Steckdose Dunstabzug',
                         14: 'Steckdose 4',
                         15: 'Steckdose 3',
                         16: 'Steckdose 2',
                         17: 'Steckdose 1',
                         18: 'Steckdosenleiste WZ',
                         19: 'Steckdosenleiste FR',
                         20: 'RGBW Briefkasren',
                         21: 'RGBW Bad',
                         22: 'Reserve',
                         23: 'Reserve',
                         24: 'Reserve',
                         25: 'Reserve',
                         26: 'Reserve',
                         27: 'Reserve',
                         28: 'Reserve',
                         29: 'Reserve',
                         30: 'Reserve',
                         31: 'Reserve',
                         32: 'Reserve',
                         33: 'Reserve',
                         34: 'Reserve',
                         35: 'Reserve',
                         36: 'Reserve',
                         37: 'Reserve',
                         38: 'Reserve',
                         39: 'Reserve',
                         40: 'Reserve',
                    // User konfig
                    const WARTEZEIT = '*/1 * * * *'; // jede Minute Trigger Wartezeit zwischen den Updates der Tasmota Geräte
                    const TIMEOUT = 45 * 1000; // Wartezeit zwischen dem upgrade von minimal auf sensors oder tasmota
                    const TIMEOUT2 = 1000; // Wartezeit zwischen URL Set und Upgrade bzw. http start und URL minimal set
                    const DOWNLOAD = true; // automatischer Firmware download wenn update verfügbar
                    const LOGGING = true;
                    const DEBUG = false;
                    const SEND_TELEGRAM = true;
                    const SEND_MAIL = true;
                    const ANZAHL_SENSORS = 17; // Hier die Anzahl der TasmotaSensor Geräte eintragen Entspicht Devices 1-17
                    // ssh Konfigbereich
                    // sudo python3 -m http.server 8000 im Terminal testen. Startet den minimal http server
                    const SSH_IP = '192.168.xx.xx';
                    const SSH_USR = 'deinUser';
                    const SSH_PWD = 'deinPasswort';
                    const SSH_CMD = 'python3 -m http.server 8000';
                    // Ordner müssen angelegt werden unter dem ssh Benutzer home/pi und muss schreibrechte für iobroker haben
                    // sudo chmod -R 777 /home/pi/Tasmota
                    const DEST_PATH1 = 'home/pi/Tasmota/tasmota-sensors.bin.gz';
                    const DEST_PATH2 = 'home/pi/Tasmota/tasmota.bin.gz';
                    const DEST_PATH3 = 'home/pi/Tasmota/tasmota-minimal.bin.gz';
                    //http IP Downloadlink muss auch im Browser funktionieren wenn die bins dort liegen
                    const SOURCE_SENSORS = '192.168.xx.xx:8000/Tasmota/tasmota-sensors.bin.gz';
                    const SOURCE_MINIMAL = '192.168.xx.xx:8000/Tasmota/tasmota-minimal.bin.gz';
                    const SOURCE_TASMOTA = '192.168.xx.xx:8000/Tasmota/tasmota.bin.gz';
                    // download Quelle der tasmota firmware
                    const DOWNLOAD_LINK1 = 'http://ota.tasmota.com/tasmota/release/tasmota-sensors.bin.gz'; //downloadlink für bin file
                    const DOWNLOAD_LINK2 = 'http://ota.tasmota.com/tasmota/release/tasmota.bin.gz'; //downloadlink für bin file
                    const DOWNLOAD_LINK3 = 'http://ota.tasmota.com/tasmota/release/tasmota-minimal.bin.gz'; //downloadlink für bin file
                    //Sensors Tasmota Firmware
                    // Device 1 - AnzahlSensors müssen Sensor Geräte zugeordnet haben. >Anzahl Sensors bis AnzahlDevice ist für Standart Tasmota Firmware
                    const DEVICES = [
                     '192.168.x.xx', //NodeMCUTest
                     '192.168.x.xx', //WemoProGarage
                     '192.168.x.xx', //WemoSchuppen
                     '192.168.x.xx', //WemoSchlafzimmer
                     '192.168.x.xx', //WemoKeller
                     '192.168.x.xx', //WemoHuette
                     '192.168.x.xx', //WemoFitttnesraum
                     '192.168.x.xx', //WemoEingang
                     '192.168.x.xx', //WemoDachboden
                     '192.168.x.xx', //SteckdoseWama
                     '192.168.x.xx', //SteckdoseTrockner
                     '192.168.x.xx', //SteckdoseSpülmaschine
                     '192.168.x.xx', //SteckdoseDunstabzug
                     '192.168.x.xx', //Steckdose4
                     '192.168.x.xx', //Steckdose3
                     '192.168.x.xx', //Steckdose2
                     '192.168.x.xx', //Steckdose1
                     // Device 18 +  sind Standart Firmware Geräten vorbehalten
                     '192.168.x.xx', //SteckdosenleisteWZ
                     '192.168.x.xx', //SteckdosenleisteFR
                     '192.168.x.xx', //RGBW1
                     '192.168.x.xx' //RGBWBad
                    // User States / Objekte
                    const idUpdate = 'javascript.0.Status.Tasmota.Tasmota_Firmware.Update';
                    const id_Version_Internet = 'javascript.0.Status.Tasmota.Tasmota_Firmware.Version';
                    const idUpdatestart = 'javascript.0.Status.Tasmota.Tasmota_Firmware.Updatestart';
                    const idAuswahl = 'javascript.0.Status.Tasmota.Tasmota_Firmware.Auswahl';
                    const idUpdateAll = 'javascript.0.Status.Tasmota.Tasmota_Firmware.UpdateAll';
                    let cacheSelectorTasmotaVersions = $('channel[state.id=sonoff.0.*.Version]');
                    // fs und node-ssh unter Einstellungen im javascript Adapter hinzufügen
                    const fs = require('fs');
                    const request = require('request');
                    const node_ssh = require('node-ssh').NodeSSH;
                    let select = '';
                    let sshcommand = false;
                    let Sensor = null;
                    let Tasmota = null;
                    let trigger = null;
                    let AnzahlDevice = 0; //Anzahl der Tasmota Geräte. Wichtig für Update aller Geräte
                    let _message = '';
                    let _message_tmp = '';
                    function bLOG(str) {
                     if (LOGGING) log(str);
                    function bDEBUG(str) {
                       if (DEBUG) console.debug(`[DEBUG] ${str}`);
                    function func_Version() {
                     let options = {
                         url: 'https://api.github.com/repos/arendst/Tasmota/releases/latest',
                         headers: {
                             'User-Agent': 'ioBroker Tasmota Firmware Check'
                     request(options, async function(error, response, body) {
                         const availableFirmware = getState(id_Version_Internet).val;
                         if (error) {
                             log('error: ' + error);
                         } else {
                             let tasmotaJson = JSON.parse(body);
                             let tasmotaTagName = tasmotaJson.tag_name;
                             let tasmotaVersion = tasmotaTagName.replace(/v/i, "").trim();
                             if (availableFirmware.length === 0) {
                                 bLOG(`Ausgewähltes Objekt leer. Firmware wird erstmalig gesetzt. Firmware: ${tasmotaVersion}`); // +' Zentrale: ' +Version[3]);
                                 await setStateAsync(id_Version_Internet, tasmotaVersion);
                             let devices = [];
                             cacheSelectorTasmotaVersions.each(async function(id, i) {
                                 AnzahlDevice++;
                                 const installedFirmware = getState(id).val.trim().
                                   .replace('(sonoff)', '').trim()
                                   .replace('(tasmota)', '').trim()
                                   .replace('(sensors)', '').trim();
                                 let infoId = id.substring(0, id.lastIndexOf("."));
                                 let hostName = getState(infoId + '.Hostname').val;
                                 if (installedFirmware == tasmotaVersion) {
                                     bLOG(`Tasmota: Installierte Firmware für Gerät ${hostName} ist aktuell.`);
                                 } else {
                                     bLOG(`Tasmota: Installierte Firmware für Gerät ' + hostName + ' (${installedFirmware}) ist nicht aktuell. Aktuell verfügbare Version: ${tasmotaVersion}`);
                                     if (availableFirmware == tasmotaVersion) {
                                       await setStateAsync(idUpdate, false, true);
                                       bDEBUG('Tasmota: Version Internet hat sich nicht verändert');
                                     } else {
                                         setState(idUpdate, true, true);
                                         bDEBUG('Tasmota: Installierte Firmware ist nicht aktuell.');
                                         devices.push(hostName + ' (' + installedFirmware + ')');
                             if (devices.length > 0) {
                                 _message_tmp = `Neue Tasmota-Firmware ${tasmotaVersion} für folgende Geräte verfügbar:\n${devices.join('\n')}`;
                                 if (SEND_TELEGRAM) {
                                     _message = _message_tmp;
                                     send_telegram();
                                 if (SEND_MAIL) {
                                     send_mail();
                    function send_telegram() {
                     sendTo('telegram.0', {
                         text: _message
                    function send_mail() {
                     sendTo("email", {
                         subject: "Servicemeldung",
                         text: _message
                    // um 12:01 Uhr prüfen
                    schedule({
                     hour: 12,
                     minute: 1
                    }, func_Version);
                    function downloadFile(link) {
                     request.get({
                         url: DOWNLOAD_LINK1,
                         encoding: 'binary'
                     }, function(err, response, body) {
                         if (err) {
                             return log(`Tasmota: Fehler beim Download: ${err}`);
                         fs.writeFile(DEST_PATH1, body, 'binary', function(err) {
                             const fileName = DOWNLOAD_LINK1.split('/').pop();
                             if (err) {
                                 return log(`Tasmota: Fehler beim Speichern: ${err}`);
                             bLOG(`Tasmota: Firmwaredownload ${fileName} gestartet `);
                    // http Server starten
                    on({
                     val: true,
                     change: 'ne'
                    }, async function() {
                     let UpdateAll = getState(idUpdateAll).val;
                     if (UpdateAll === false) {
                         setTimeout(function() {
                             minimalURLset();
                             await setStateAsync(idUpdatestart, false, true);
                         }, TIMEOUT2);
                     } else {
                         startUpdateAll();
                     if (!sshcommand) {
                         sshcommand = true;
                         let ssh = new node_ssh();
                         ssh.connect({
                             host: SSH_IP,
                             username: SSH_USR,
                             password: SSH_PWD
                         }).then(() => {
                             ssh.execCommand(SSH_CMD);
                    // Alles updaten Alle Geräte werden von 1 an durchgezählt
                    async function startUpdateAll() {
                     let count = 1;
                     await setStateAsync(idAuswahl, 1, true);
                     bLOG(`Tasmota: Update aller Geräte gestartet. Aktuell wird das Update für Device ${count} gestartet.`);
                     setTimeout(minimalURLset, 100);
                     trigger = schedule(WARTEZEIT, function() {
                         count++;
                         await setStateAsync(idAuswahl, count, true);
                         bLOG(`Tasmota: Aktuell wird das Update für Device ${count} gestartet.`);
                         if (count === AnzahlDevice) {
                             setTimeout(asnc function() {
                                 func_Version();
                                 await setStateAsync(idAuswahl, 0, true);
                             }, 2 * TIMEOUT);
                             setTimeout(async function() {
                               await setStateAsync(idUpdateAll, false, true);
                                 count = 0;
                             }, TIMEOUT2);
                    // Entscheiden ob Sensor oder Tasmota aktiv für Upgrade und Device Vorwahl
                    on(idAuswahl, function(dp) {
                     if (dp.state.val > 0 && dp.state.val <= ANZAHL_SENSORS) {
                         Sensor = true;
                         Tasmota = false;
                     if (dp.state.val > ANZAHL_SENSORS) {
                         Sensor = false;
                         Tasmota = true;
                     if (DEVICES.length >= dp.state.val) {
                         select = DEVICES[dp.state.val - 1];
                     bLOG(`Tasmota: Folgende IP wurde für das Update vorgewählt: ${select}`);
                    // minimal URL setzen und update
                    function minimalURLset() {
                     let Auswahl = getState(idAuswahl).val;
                     if (DOWNLOAD && Auswahl > 0)
                         request(`http://${select}/cm?cmnd=OtaUrl%20http://${SOURCE_MINIMAL}`, function(error, response, body) {
                             if (error) {
                                 log(`Tasmota: Fehler beim  setzen der OTA Minimal URL für: ${select} ${error}`);
                             } else {
                                 bLOG(`Tasmota: OTA Firmware URL auf Minimal gesetzt für IP: ${select}`);
                                 setTimeout(minimalUpgrade, TIMEOUT2);
                    function minimalUpgrade() {
                     request(`http://${select}/cm?cmnd=upgrade%201`, function(error, response) {
                         if (error) {
                             log('Tasmota: Fehler beim setzen des Minimal Upgrade Befehl für: ' + select + ' ' + error);
                         } else {
                             bLOG('Tasmota: OTA Firmware upgrade Minimal für IP: ' + select);
                                 if (Sensor) sensorURLset();
                                 if (Tasmota) TasmotaURLset();
                             }, TIMEOUT);
                    // Sensor URL setzen und update
                    function sensorURLset() {
                     request(`http://${select}/cm?cmnd=OtaUrl%20http://${SOURCE_SENSORS}`, function(error, response) {
                         if (error) {
                             log('Fehler beim  setzen der OTA Sensor URL für: ' + select + ' ' + error);
                         } else {
                             bLOG('Tasmota: OTA Firmware URL auf Sensor gesetzt für IP: ' + select);
                             setTimeout(sensorUpgrade, TIMEOUT2);
                    function sensorUpgrade() {
                         if (error) {
                             log('Tasmota: Fehler beim setzen des Sensor Upgrade Befehl für: ' + select + ' ' + error);
                         } else {
                             bLOG('Tasmota: OTA Firmware upgrade Sensors für IP: ' + select);
                    // Tasmota URL setzen und update
                    function TasmotaURLset() {
                     request(`http://${select}/cm?cmnd=OtaUrl%20http://${SOURCE_TASMOTA}`, function(error, response) {
                         if (error) {
                             log('Fehler beim  setzen der OTA Tasmota URL: ' + error);
                         } else {
                             bLOG('Tasmota: OTA Firmware URL auf Tasmota gesetzt für IP: ' + select);
                             setTimeout(tasmotaUpgrade, TIMEOUT2);
                    function tasmotaUpgrade() {
                     request(`http://${select}/cm?cmnd=upgrade%201`, function(error, respnsoe) {
                         if (error) {
                             log('Tasmota: Fehler beim setzen des Tasmota Upgrade Befehl für: ' + select + ' ' + error);
                         } else {
                             bLOG('Tasmota: OTA Firmware upgrade Tasmota für IP: ' + select);
                    // Firmware automatisch herunter laden
                    on({
                     val: true,
                     change: 'ne'
                    }, function(dp) {
                     if (DOWNLOAD) {
                         downloadFile(DOWNLOAD_LINK1);
                         downloadFile(DOWNLOAD_LINK2);
                         downloadFile(DOWNLOAD_LINK3);
                    //beim SkriptStart
                    func_Version();
                    if (DOWNLOAD) {
                         let Update = getState(idUpdate).val;
                         if (Update === false) {
                     }, 10 * 1000);
                     bLOG('Tasmota: ' + AnzahlDevice + ' Geräte gefunden');
                    }, 1000);
                    smartboartS 2 Antworten Letzte Antwort
                    • C CruziX
                      31.10.2020
                      {1}
                      31.10.2020
                      {1}
                      03.11.2020
                      {1}
                      06.11.2020
                      {1}
                      {1}
                      17.12.2020
                      {1}
                       def: false,
                       type: 'boolean',
                       type: 'string',
                       read: true,
                       write: true,
                       def: false,
                       type: 'boolean',
                       def: false,
                       type: 'boolean',
                       def: 0,
                       type: 'number',
                       min: 0,
                       max: 100,
                       role: 'value',
                       states: {
                           0: 'keine Vorwahl',
                           1: 'Wemo Pro Test',
                           3: 'Wemo Schuppen',
                           5: 'Wemo Keller',
                           6: 'Wemo Huette',
                           8: 'Wemo Eingang',
                           14: 'Steckdose 4',
                           15: 'Steckdose 3',
                           16: 'Steckdose 2',
                           17: 'Steckdose 1',
                           21: 'RGBW Bad',
                           22: 'Reserve',
                           23: 'Reserve',
                           24: 'Reserve',
                           25: 'Reserve',
                           26: 'Reserve',
                           27: 'Reserve',
                           28: 'Reserve',
                           29: 'Reserve',
                           30: 'Reserve',
                           31: 'Reserve',
                           32: 'Reserve',
                           33: 'Reserve',
                           34: 'Reserve',
                           35: 'Reserve',
                           36: 'Reserve',
                           37: 'Reserve',
                           38: 'Reserve',
                           39: 'Reserve',
                           40: 'Reserve',
                      // User konfig
                      const DEVICES = [
                      let select = '';
                      let Sensor = null;
                      let Tasmota = null;
                      let trigger = null;
                      let _message = '';
                       let options = {
                           headers: {
                           if (error) {
                           } else {
                               let devices = [];
                                   AnzahlDevice++;
                                   } else {
                                       } else {
                                       send_telegram();
                                   if (SEND_MAIL) {
                                       send_mail();
                           text: _message
                       sendTo("email", {
                           text: _message
                      schedule({
                       hour: 12,
                       minute: 1
                      }, func_Version);
                       request.get({
                           encoding: 'binary'
                           if (err) {
                               if (err) {
                      on({
                       val: true,
                       change: 'ne'
                               minimalURLset();
                           }, TIMEOUT2);
                       } else {
                           startUpdateAll();
                       if (!sshcommand) {
                           sshcommand = true;
                           ssh.connect({
                               host: SSH_IP,
                               username: SSH_USR,
                               password: SSH_PWD
                           }).then(() => {
                       let count = 1;
                           count++;
                                   func_Version();
                               }, 2 * TIMEOUT);
                                   count = 0;
                               }, TIMEOUT2);
                           Sensor = true;
                           Tasmota = false;
                           Sensor = false;
                           Tasmota = true;
                               if (error) {
                               } else {
                           if (error) {
                           } else {
                               }, TIMEOUT);
                           if (error) {
                           } else {
                           if (error) {
                           } else {
                           if (error) {
                           } else {
                           if (error) {
                           } else {
                      on({
                       val: true,
                       change: 'ne'
                      }, function(dp) {
                       if (DOWNLOAD) {
                      //beim SkriptStart
                      func_Version();
                      if (DOWNLOAD) {
                       }, 10 * 1000);
                      }, 1000);
                      smartboartS Offline
                      smartboartS Offline
                      smartboart
                      #70
                      @cruzix Hi,
                      danke für das Update, den post hatte ich schon fast aus den Augen verloren. Hatte bei mir auch noch Kleinigkeiten geändert aber nicht mehr großartig daran weiter gearbeit. Meine Änderungen wollte ich bei Gelegenheit hier noch einstellen, bin aber gerade anderweitig bei nem größßeren Projekt im Garten stark eingebunden.
                      Seit den letzetn Updates haben sich ja auch die Info states im sonoff namentlich geändert. Das hast natürlich clever gelöst. Ich hatte noch ein state bei der Update Vorwahl eingespart und mit Vorwahl 0 alle selektiert. Damit ist es dann auch ein klick weniger und das one click im Namen passt dann auch.
                      Bei nächster Gelegenheit schaue ich mir das mal genauer an. Wenn du es getestet hast oder andere sag bescheid ansosnten lass ich es nochmal durchlaufen und aktualisiere dann den 1. post...
                      falke69F C 2 Antworten Letzte Antwort
                        @cruzix Hi,
                        falke69F Offline
                        falke69F Offline
                        falke69
                        schrieb am zuletzt editiert von falke69
                        #71
                        habe das Script bei mir auch teilweise zum laufen gebracht. Da bei mir derzeit alle Geräte bereits auf den aktuellen Stand sind, habe ich halt ein "test" Gerät mit der 9.1.0 installiert.
                        Die Firmware wird auch in den entsprechenden Ordner heruntergeladen und ist über den Browser erreichbar.
                        Leider erkennt das Script nicht das Gerät und meldet, dass hier noch eine ältere Firmware auf dem Gerät ist.
                        Hat jemand eine Idee?
                        Ich habe hier auch mal den direkten Pfad eingestellt - ohne Erfolg
                        //var cacheSelectorTasmotaVersions = $('channel[state.id=sonoff.0.*.Version]');
                        var cacheSelectorTasmotaVersions = $('channel[state.id=sonoff.0.test.INFO.Version]');
                        Es soll sich hier um ein "normales" Gerät mit Standart Firmware handeln
                        // Device 18 +  sind Standart Firmware Geräten vorbehalten.
                        var Device18 = '192.168.178.23';//SteckdosenleisteWZ
                        @smartboart tolle Arbeit!
                        Edit: jetzt läuft es. Ich habe mal alle NPM-Module aus dem JS Adapter rausgelöscht und wieder
                        eingetragen. Keine Ahnung, warum - aber es geht. Ein Einfacher Neustart vom JS Adapter
                        hatte leider nichts gebracht.
                          @cruzix Hi,
                          CruziX
                          #72
                          @smartboart Tatsächlich hab ich das gesamte Skript bisher noch nie laufen, weil ich normaler Weise die Updates mit Tasmoadmin mache.
                          Bin noch nicht dazu gekommen mal zu überlegen inwieweit das Skript für mich einen Mehrwert hat, da ich den tasmoadmin server eh schon laufen habe :P
                          Hab nur gerade mal aus Interesse und etw Zeit dein Skript gefunden und ein wenig "optimiert"
                          • falke69F falke69
                            smartboartS Offline
                            smartboartS Offline
                            smartboart
                            #73
                            @falke69 Freut mich. Du musst nun darauf achten, wenn du die aktuellste Version geladen hast, dass sich mit der aktuellen Version die Statebezeichner geändert haben.
                            ich habe des bereits geändert aber noch nicht oben aktualisiert.
                            5f446f17-f748-4968-b453-07fbfca1a381-grafik.png e7f6d3a0-a522-40d2-9024-96cabb861d21-grafik.png
                            falke69F 1 Antwort Letzte Antwort
                            • C CruziX
                              smartboartS Offline
                              smartboartS Offline
                              smartboart
                              #74
                              @cruzix sagte in [Vorlage] Tasmota One Click Firmware Update Vis Javascript.:
                              Ja wenn der Server bei dir eh läuft brauchst es ja net unbedingt. Aber finde es gerade deshalb toll das du trotzdem optimiert hast. Hoffe ich finde bald Zeit das zu testen..
                              • smartboartS Offline
                                smartboartS Offline
                                smartboart
                                #75
                                So ich habe oben jetzt mal aktualisiert um die Version wie es gerade bei mir läuft.
                                24.02.2021
                                V0.0.5 State UpdateAll kann entfallen Auswahl Update all erfolgt nun über den State Auswahl
                                Bei Update All Nach Ende Update sicher beenden if (count >= AnzahlDevice)
                                01.03.2021
                                V0.0.6 Tasmota Statebezeichner haben sich geändert, dies habe ich nun berücksichtigt.
                                Anzahl Device wieder manuell in der Konfig angeben. Autozählung Hat unter bestimmten umständen zu Fehlern geführt.
                                Die Optimierung von cruzix muss ich erst noch testen. Danke @CruziX .
                                Sobald ich bestätigen kann dass die läuft werde ich sie ebenfalls um meine letzten Änderungen anpassen und oben bereit stellen. Wenn es vorher jemand testet, gebt bescheid.
                                • C CruziX
                                  31.10.2020
                                  {1}
                                  31.10.2020
                                  {1}
                                  03.11.2020
                                  {1}
                                  06.11.2020
                                  {1}
                                  {1}
                                  17.12.2020
                                  {1}
                                   def: false,
                                   type: 'boolean',
                                   type: 'string',
                                   read: true,
                                   write: true,
                                   def: false,
                                   type: 'boolean',
                                   def: false,
                                   type: 'boolean',
                                   def: 0,
                                   type: 'number',
                                   min: 0,
                                   max: 100,
                                   role: 'value',
                                   states: {
                                       0: 'keine Vorwahl',
                                       1: 'Wemo Pro Test',
                                       3: 'Wemo Schuppen',
                                       5: 'Wemo Keller',
                                       6: 'Wemo Huette',
                                       8: 'Wemo Eingang',
                                       14: 'Steckdose 4',
                                       15: 'Steckdose 3',
                                       16: 'Steckdose 2',
                                       17: 'Steckdose 1',
                                       21: 'RGBW Bad',
                                       22: 'Reserve',
                                       23: 'Reserve',
                                       24: 'Reserve',
                                       25: 'Reserve',
                                       26: 'Reserve',
                                       27: 'Reserve',
                                       28: 'Reserve',
                                       29: 'Reserve',
                                       30: 'Reserve',
                                       31: 'Reserve',
                                       32: 'Reserve',
                                       33: 'Reserve',
                                       34: 'Reserve',
                                       35: 'Reserve',
                                       36: 'Reserve',
                                       37: 'Reserve',
                                       38: 'Reserve',
                                       39: 'Reserve',
                                       40: 'Reserve',
                                  // User konfig
                                  const DEVICES = [
                                  let select = '';
                                  let Sensor = null;
                                  let Tasmota = null;
                                  let trigger = null;
                                  let _message = '';
                                   let options = {
                                       headers: {
                                       if (error) {
                                       } else {
                                           let devices = [];
                                               AnzahlDevice++;
                                               } else {
                                                   } else {
                                                   send_telegram();
                                               if (SEND_MAIL) {
                                                   send_mail();
                                       text: _message
                                   sendTo("email", {
                                       text: _message
                                  schedule({
                                   hour: 12,
                                   minute: 1
                                  }, func_Version);
                                   request.get({
                                       encoding: 'binary'
                                       if (err) {
                                           if (err) {
                                  on({
                                   val: true,
                                   change: 'ne'
                                           minimalURLset();
                                       }, TIMEOUT2);
                                   } else {
                                       startUpdateAll();
                                   if (!sshcommand) {
                                       sshcommand = true;
                                       ssh.connect({
                                           host: SSH_IP,
                                           username: SSH_USR,
                                           password: SSH_PWD
                                       }).then(() => {
                                   let count = 1;
                                       count++;
                                               func_Version();
                                           }, 2 * TIMEOUT);
                                               count = 0;
                                           }, TIMEOUT2);
                                       Sensor = true;
                                       Tasmota = false;
                                       Sensor = false;
                                       Tasmota = true;
                                           if (error) {
                                           } else {
                                       if (error) {
                                       } else {
                                           }, TIMEOUT);
                                       if (error) {
                                       } else {
                                       if (error) {
                                       } else {
                                       if (error) {
                                       } else {
                                       if (error) {
                                       } else {
                                  on({
                                   val: true,
                                   change: 'ne'
                                  }, function(dp) {
                                   if (DOWNLOAD) {
                                  //beim SkriptStart
                                  func_Version();
                                  if (DOWNLOAD) {
                                   }, 10 * 1000);
                                  }, 1000);
                                  smartboartS Offline
                                  smartboartS Offline
                                  smartboart
                                  #76
                                  @cruzix So jetzt hab ich mich doch gleich mit deiner Optimierung beschaäftigt.
                                  Ich habe meine Aktualisierungen noch gleich mit eingearbeitet. Hier und da hast ein async vergessen, weshalb es beim await noch zu Fehlermeldungen beim Abspeichern kam. Bei der Pfadangabe muss der totale Pfad also mit / voran gestellt werden. Hattest noch vergessen.
                                  trim().
                                  trim(). war ein Punkt zu viel.. weshalb er .replace noch angemeckert hat..
                                  Das mit dem Download klappt so nicht. Man muss jeden link separat downloaden und nen separaten Destpath zuweisen, weil das mit dem abspeichern sonst nicht klappt. In deiner version wurde 3 mal die selbe Datei beschrieben. Mit der Funktion habe ich mich damals lange rumgeärgert und ausprobiert bis das mit dem download geklappt hat.Wenn man das in einer Funktion machen möchte, muss man immer den Destpath 1 -3 und den Downloadlink 1 -3 mit ändern und ein delay zwischen den aufrufen einbauen.
                                  Ansonsten sieht das richtig gut aus. Toll gelöst auch das mit der Hostname Darstellung.
                                  Einen Durchlauf habe ich jetzt noch nicht getestet. Mache ich später...
                                  Habe jetzt schon bei mehreren gesehen, das anstatt var const verwendet wird. Welche Vorteile hat das?
                                  Habe die Kleinigkeiten nun mal korrigiert und auf aktuellen stand gebracht. Das Script zum weiter Testen hier.
                                  31.10.2020
                                  31.10.2020
                                  03.11.2020
                                  06.11.2020
                                  17.12.2020
                                  24.02.2021
                                        Bei Update All Nach Ende Update sicher beenden if (count >= ANZAHL_DEVICES)
                                  01.03.2021
                                  16.07.2021
                                  V0.0.7  Optimierungen von cruzix (iobroker-forum) integriert.
                                     	Danke @ cruzix
                                     	Komplett Test noch offen. Testversion.
                                  def: false,
                                  type: 'boolean',
                                  type: 'string',
                                  read: true,
                                  write: true,
                                  def: false,
                                  type: 'boolean',
                                  def: 0,
                                  type: 'number',
                                  min: 0,
                                  max: 100,
                                  role: 'value',
                                  states: {
                                  0:'Update All',
                                  1:'NodeMCU Garage',
                                  2:'Wemo Schuppen',
                                  3:'Wemo Keller',
                                  4:'NodeMCU Huette',
                                  5:'Wemo Fitttnessraum',
                                  6:'Wemo Eingang',
                                  7:'NodeMCU Dachboden',
                                  8:'Steckdose Waschmaschine',
                                  9:'Steckdose Trockner',
                                  10:'Steckdose Spülmaschine',
                                  11:'Steckdose Dunstabzug',
                                  12:'Steckdose 4',
                                  13:'Steckdose 3',
                                  14:'Steckdose 2',
                                  15:'Steckdose 1',
                                  16:'Wemo Ankleidezimmer',
                                  17:'Wemo Bad',
                                  18:'Steckdosenleiste WZ',
                                  19:'Steckdosenleiste FR',
                                  20:'RGBW Briefkasren',
                                  21:'RGBW Bad',
                                  22:'Reserve',
                                  23:'Reserve',
                                  24:'Reserve',
                                  25:'Reserve',
                                  26:'Reserve',
                                  27:'Reserve',
                                  28:'Reserve',
                                  29:'Reserve',
                                  30:'Reserve',
                                  31:'Reserve',
                                  32:'Reserve',
                                  33:'Reserve',
                                  34:'Reserve',
                                  35:'Reserve',
                                  36:'Reserve',
                                  37:'Reserve',
                                  38:'Reserve',
                                  39:'Reserve',
                                  40:'Reserve',
                                  // User konfig
                                  const WARTEZEIT = '*/3 * * * *'; // jede Minute Trigger Wartezeit zwischen den Updates der Tasmota Geräte
                                  const TIMEOUT = 90 * 1000; // Wartezeit zwischen dem upgrade von minimal auf sensors oder tasmota
                                  const TIMEOUT2 = 3*1000; // Wartezeit zwischen URL Set und Upgrade bzw. http start und URL minimal set
                                  const ANZAHL_DEVICES = 21; //Anzahl der Tasmota Geräte. Wichtig für Update aller Geräte
                                  const SSH_IP = '192.168.XXX.XXX';
                                  const SSH_USR = 'User';
                                  const SSH_PWD = 'passwd';
                                  const DEST_PATH1 = '/home/pi/Tasmota/tasmota-sensors.bin.gz';
                                  const DEST_PATH2 = '/home/pi/Tasmota/tasmota.bin.gz';
                                  const DEST_PATH3 = '/home/pi/Tasmota/tasmota-minimal.bin.gz';
                                  const SOURCE_SENSORS = '192.168.XXX.XXX:8000/Tasmota/tasmota-sensors.bin.gz';
                                  const SOURCE_MINIMAL = '192.168.XXX.XXX:8000/Tasmota/tasmota-minimal.bin.gz';
                                  const SOURCE_TASMOTA = '192.168.XXX.XXX:8000/Tasmota/tasmota.bin.gz';
                                  const DEVICES = [
                                  // Device 1 - AnzahlSensors müssen Sensor Geräte zugeordnet haben. >Anzahl Sensors bis ANZAHL_DEVICES ist für Standart Tasmota Firmware
                                  '192.168.XXX.XXX',//NodeMCUGarage
                                  '192.168.XXX.XXX',//WemoSchuppen
                                  '192.168.XXX.XXX',//WemoKeller
                                  '192.168.XXX.XXX',//NodeMCUHuette
                                  '192.168.XXX.XXX',//WemoFitttnesraum
                                  '192.168.XXX.XXX',//WemoEingang
                                  '192.168.XXX.XXX',//NodeMCUDachboden
                                  '192.168.XXX.XXX',//SteckdoseWama
                                  '192.168.XXX.XXX',//SteckdoseTrockner
                                  '192.168.XXX.XXX',//SteckdoseSpülmaschine
                                  '192.168.XXX.XXX',//SteckdoseDunstabzug
                                  '192.168.XXX.XXX',//Steckdose4
                                  '192.168.XXX.XXX',//Steckdose3
                                  '192.168.XXX.XXX',//Steckdose2
                                  '192.168.XXX.XXX',//Steckdose1
                                  '192.168.XXX.XXX',//Wemo Ankleidezimmer
                                  '192.168.XXX.XXX',//Wemo Bad
                                  // Tasmota Firmware
                                  '192.168.XXX.XXX',//SteckdosenleisteWZ
                                  '192.168.XXX.XXX',//SteckdosenleisteFR
                                  '192.168.XXX.XXX',//RGBW1
                                  '192.168.XXX.XXX',//RGBWBad
                                  let cacheSelectorTasmotaVersions = $('channel[state.id=sonoff.0.*.Info1_Version]');
                                  let select = '';
                                  let Sensor = null;
                                  let Tasmota = null;
                                  let trigger = null;
                                  //let ANZAHL_DEVICES = 0; //Anzahl der Tasmota Geräte. Wichtig für Update aller Geräte
                                  let _message = '';
                                  let options = {
                                      headers: {
                                      if (error) {
                                      } else {
                                          let devices = [];
                                              let hostName = getState(infoId + '.Info2_Hostname').val;
                                              } else {
                                                  bLOG(`Tasmota: Installierte Firmware für Gerät  ${hostName}  (${installedFirmware}) ist nicht aktuell. Aktuell verfügbare Version: ${tasmotaVersion}`);
                                                  } else {
                                                  send_telegram();
                                              if (SEND_MAIL) {
                                                  send_mail();
                                      text: _message
                                  sendTo("email", {
                                      text: _message
                                  // um 12:45 Uhr prüfen
                                  schedule({
                                  hour: 12,
                                  minute: 45
                                  }, func_Version);
                                  function downloadFile1() {
                                  request.get({
                                      encoding: 'binary'
                                      if (err) {
                                          if (err) {
                                  function downloadFile2() {
                                  request.get({
                                      url: DOWNLOAD_LINK2,
                                      encoding: 'binary'
                                      if (err) {
                                      fs.writeFile(DEST_PATH2, body, 'binary', function(err) {
                                          const fileName = DOWNLOAD_LINK2.split('/').pop();
                                          if (err) {
                                  function downloadFile3() {
                                  request.get({
                                      url: DOWNLOAD_LINK3,
                                      encoding: 'binary'
                                      if (err) {
                                      fs.writeFile(DEST_PATH3, body, 'binary', function(err) {
                                          const fileName = DOWNLOAD_LINK3.split('/').pop();
                                          if (err) {
                                  on({
                                  val: true,
                                  change: 'ne'
                                  let UpdateAll = getState(idAuswahl).val;
                                  if (UpdateAll != 0) {
                                          minimalURLset();
                                      }, TIMEOUT2);
                                  } else {
                                      startUpdateAll();
                                  if (!sshcommand) {
                                      sshcommand = true;
                                      ssh.connect({
                                          host: SSH_IP,
                                          username: SSH_USR,
                                          password: SSH_PWD
                                      }).then(() => {
                                  let count = 0;
                                  bLOG(`Tasmota: Update aller Geräte gestartet.`);
                                  trigger = schedule(WARTEZEIT, async function() {
                                      count++;
                                      setTimeout(minimalURLset, 500);
                                      if (count >= ANZAHL_DEVICES) {
                                              func_Version();
                                          }, 2 * TIMEOUT);
                                              count = 0;
                                          }, TIMEOUT2);
                                      Sensor = true;
                                      Tasmota = false;
                                      Sensor = false;
                                      Tasmota = true;
                                          if (error) {
                                          } else {
                                      if (error) {
                                      } else {
                                          }, TIMEOUT);
                                      if (error) {
                                      } else {
                                      if (error) {
                                      } else {
                                      if (error) {
                                      } else {
                                      if (error) {
                                      } else {
                                  on({
                                  val: true,
                                  change: 'ne'
                                  }, function(dp) {
                                  if (DOWNLOAD) {
                                      downloadFile1();
                                      downloadFile2();
                                      downloadFile3();
                                  //beim SkriptStart
                                  func_Version();
                                  if (DOWNLOAD) {
                                          downloadFile1();
                                          downloadFile2();
                                          downloadFile3();
                                  }, 10 * 1000);
                                  Noch ein kleinen Fehler korrigiert...'+Hostname+ ' bei nicht aktuellen Geräten ersetzt mit ${hostName} damit dieserr auch richtig angezeigt wird..
                                  Einzelne Updates funktionieren schon mal.
                                  Es wäre glaube ich noch von Vorteil, wenn im Updateprozess zusätlich zur IP im Log auch noch der Hostname steht...
                                    falke69F Offline
                                    falke69F Offline
                                    falke69
                                    #77
                                    @smartboart
                                    ok. Danke für den Hinweis!
                                    Habe gerade mal Deinen Hinweis umgesetzt.
                                    var cacheSelectorTasmotaVersions = $('channel[state.id=sonoff.0.*.Info1_Version]');
                                    Da erhalte ich für all meine Geräte diese Fehlermeldung:
                                    javascript.0	2021-07-16 06:12:08.887	warn	(4523) at processTicksAndRejections (internal/process/task_queues.js:84:21)
                                    javascript.0	2021-07-16 06:12:08.887	warn	(4523) at endReadableNT (_stream_readable.js:1241:12)
                                    javascript.0	2021-07-16 06:12:08.887	warn	(4523) at IncomingMessage.emit (events.js:326:22)
                                    javascript.0	2021-07-16 06:12:08.886	warn	(4523) at Object.onceWrapper (events.js:420:28)
                                    javascript.0	2021-07-16 06:12:08.886	warn	(4523) at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1076:12)
                                    javascript.0	2021-07-16 06:12:08.886	warn	(4523) at Request.emit (events.js:314:20)
                                    javascript.0	2021-07-16 06:12:08.885	warn	(4523) at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1154:10)
                                    javascript.0	2021-07-16 06:12:08.885	warn	(4523) at Request.emit (events.js:314:20)
                                    javascript.0	2021-07-16 06:12:08.884	warn	(4523) at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22)
                                    javascript.0	2021-07-16 06:12:08.884	warn	(4523) at Request._callback (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:27:17)
                                    javascript.0	2021-07-16 06:12:08.883	warn	(4523) at script.js.Test.Tasmota_Update:430:42
                                    javascript.0	2021-07-16 06:12:08.883	warn	(4523) at Object.result.each (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:801:29)
                                    javascript.0	2021-07-16 06:12:08.883	warn	(4523) at script.js.Test.Tasmota_Update:446:32
                                    javascript.0	2021-07-16 06:12:08.881	warn	(4523) getState "sonoff.0.Waschmaschiene.INFO.Hostname" not found (3)
                                    javascript.0	2021-07-16 06:12:08.881	info	(4523) script.js.Test.Tasmota_Update: Tasmota: Installierte Firmware für Gerät null ist aktuell.
                                    • falke69F falke69
                                      @smartboart
                                      smartboartS Offline
                                      smartboartS Offline
                                      smartboart
                                      #78
                                      @falke69 ja, du musst das an mehreren Stellen anpassen . Vergleich es mit meiner aktualisierten Version , habe ich oben mittlerweile eingefügt. Die Namensänderung kam mit V 9.5.0 oder eine Version früher...natürlich müssen die states bei dir auch entsprechend *.Info1_Version angelegt worden sein, also auch die neue Verfsion geladen sein.
                                        falke69F Offline
                                        falke69F Offline
                                        falke69
                                        #79
                                        @smartboart
                                        vielen Dank!
                                        Die neue Version habe ich jetzt geladen und soweit eingerichtet.
                                        Aktuell werden mir im Log Geräte als Warnung angezeigt, die derzeit nicht
                                        erreichbar sind (Weihnachtsbeleuchtung. :-) ).
                                        Leider habe ich das Problem, dass die OTA URL nicht in das entsprechende Gerät abgesetzt werden kann. Wenn ich das richtig im Script deute, sollten doch die IP Adressen für die entsprechenden Geräte ausgelesen werden sollte.
                                        javascript.0	2021-07-16 13:28:38.831	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Fehler beim setzen der OTA Minimal URL für: Error: Invalid URI "http:///cm?cmnd=OtaUrl%20http://192.168.178.xxx:8000/Tasmota/tasmota-minimal
                                        javascript.0	2021-07-16 13:28:21.713	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Folgende IP wurde für das Update vorgewählt:
                                        javascript.0	2021-07-16 13:28:18.128	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Folgende IP wurde für das Update vorgewählt:
                                        javascript.0	2021-07-16 13:28:02.246	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Fehler beim setzen der OTA Minimal URL für: Error: Invalid URI "http:///cm?cmnd=OtaUrl%20http://192.168.178.xxx:8000/Tasmota/tasmota-minima
                                        javascript.0	2021-07-16 13:27:51.423	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Firmwaredownload tasmota-sensors.bin gestartet. /home/pi/Tasmota/tasmota-sensors.bin.gz
                                        javascript.0	2021-07-16 13:27:51.400	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Firmwaredownload tasmota.bin gestartet. /home/pi/Tasmota/tasmota.bin.gz
                                        javascript.0	2021-07-16 13:27:51.367	info	(22536) script.js.Tasmota_Update.Tasmota_Update: Tasmota: Firmwaredownload tasmota-minimal.bin gestartet. /home/pi/Tasmota/tasmota-minimal.bin.gz
                                        • falke69F falke69
                                          @smartboart
                                          vielen Dank!
                                          smartboartS Offline
                                          smartboartS Offline
                                          smartboart
                                          #80
                                          @falke69 sagte in [Vorlage] Tasmota One Click Firmware Update Vis Javascript.:
                                          erreichbar sind (Weihnachtsbeleuchtung. ).
                                          Nicht erreichbar für das skript oder generell offline? Also nicht im wlan?
                                          Aktuell gibt es kein mechanismus der erreichbare und nicht erreichbare geräte unterscheidet. Es wird davon ausgegangen dass alle konfigurierten Geräte auch erreichbar sind.
                                          Welche version hast du jetzt laufen? Die Testversion oder die von ganz oben? Die Testversion aus den threat vorher habe ich nur mit einzelnen Geräten lauffähig gemacht und getestet noch nicht update all.
