  4. [SOLVED] Scripte Bereich im WebUI nach 0,5 sec. ausgeblendet
    2.3k
    4.2k
javaskript unsichtbarjavascript adapterblockly
31 Beiträge 3 Kommentatoren 4.6k Aufrufe 3 Beobachtet
    @mrMuppet Bitte vollständige Ausgaben (inkl. des login prompts) posten, nicht nur eine Zeile.
    mrMuppet
    @Thomas-Braun
    das war zu viel für mein normales "putty-scrollback" . aber hier ist es.
    Reading package lists...
    Building dependency tree...
    Reading state information...
    Package 'node-table' is not installed, so not removed
    Package 'node-mgrs' is not installed, so not removed
    Package 'node-proj4' is not installed, so not removed
    Package 'node-rbush' is not installed, so not removed
    Package 'node-kosmtik' is not installed, so not removed
    Package 'node-openlayers' is not installed, so not removed
    Package 'node-osmium' is not installed, so not removed
    Package 'node-acorn-object-spread' is not installed, so not removed
    Package 'node-babel' is not installed, so not removed
    Package 'node-rdf-canonize-native' is not installed, so not removed
    Package 'node-nyc' is not installed, so not removed
    Package 'node-uglify-to-browserify' is not installed, so not removed
    Package 'node-jquery' is not installed, so not removed
    Package 'node-abab' is not installed, so not removed
    Package 'node-abbrev' is not installed, so not removed
    Package 'node-absolute-path' is not installed, so not removed
    Package 'node-abstract-leveldown' is not installed, so not removed
    Package 'node-accepts' is not installed, so not removed
    Package 'node-active-x-obfuscator' is not installed, so not removed
    Package 'node-address' is not installed, so not removed
    Package 'node-addressparser' is not installed, so not removed
    Package 'node-after' is not installed, so not removed
    Package 'node-ajv' is not installed, so not removed
    Package 'node-ajv-keywords' is not installed, so not removed
    Package 'node-almond' is not installed, so not removed
    Package 'node-amdefine' is not installed, so not removed
    Package 'node-ansi' is not installed, so not removed
    Package 'node-ansi-align' is not installed, so not removed
    Package 'node-ansi-color-table' is not installed, so not removed
    Package 'node-ansi-colors' is not installed, so not removed
    Package 'node-ansi-escapes' is not installed, so not removed
    Package 'node-ansi-font' is not installed, so not removed
    Package 'node-ansi-regex' is not installed, so not removed
    Package 'node-ansi-styles' is not installed, so not removed
    Package 'node-ansi-up' is not installed, so not removed
    Package 'node-ansistyles' is not installed, so not removed
    Package 'node-any-promise' is not installed, so not removed
    Package 'node-anymatch' is not installed, so not removed
    Package 'node-ap' is not installed, so not removed
    Package 'node-applause' is not installed, so not removed
    Package 'node-aproba' is not installed, so not removed
    Package 'node-archy' is not installed, so not removed
    Package 'node-are-we-there-yet' is not installed, so not removed
    Package 'node-argparse' is not installed, so not removed
    Package 'node-argv' is not installed, so not removed
    Package 'node-arr-diff' is not installed, so not removed
    Package 'node-arr-flatten' is not installed, so not removed
    Package 'node-arr-union' is not installed, so not removed
    Package 'node-array-differ' is not installed, so not removed
    Package 'node-array-equal' is not installed, so not removed
    Package 'node-array-find-index' is not installed, so not removed
    Package 'node-array-flatten' is not installed, so not removed
    Package 'node-array-from' is not installed, so not removed
    Package 'node-array-parallel' is not installed, so not removed
    Package 'node-array-series' is not installed, so not removed
    Package 'node-array-union' is not installed, so not removed
    Package 'node-array-uniq' is not installed, so not removed
    Package 'node-array-unique' is not installed, so not removed
    Package 'node-arrify' is not installed, so not removed
    Package 'node-asap' is not installed, so not removed
    Package 'node-asn1' is not installed, so not removed
    Package 'node-asn1.js' is not installed, so not removed
    Package 'node-assert' is not installed, so not removed
    Package 'node-assert-plus' is not installed, so not removed
    Package 'node-assertion-error' is not installed, so not removed
    Package 'node-assertive' is not installed, so not removed
    Package 'node-ast-types' is not installed, so not removed
    Package 'node-ast-util' is not installed, so not removed
    Package 'node-astw' is not installed, so not removed
    Package 'node-async' is not installed, so not removed
    Package 'node-async-each' is not installed, so not removed
    Package 'node-async-limiter' is not installed, so not removed
    Package 'node-async-stacktrace' is not installed, so not removed
    Package 'node-asynckit' is not installed, so not removed
    Package 'node-auth-header' is not installed, so not removed
    Package 'node-auto-bind' is not installed, so not removed
    Package 'node-autolinker' is not installed, so not removed
    Package 'node-autoprefixer' is not installed, so not removed
    Package 'node-autosize' is not installed, so not removed
    Package 'node-aws-sign2' is not installed, so not removed
    Package 'node-aws4' is not installed, so not removed
    Package 'node-axios' is not installed, so not removed
    Package 'node-babel-cli' is not installed, so not removed
    Package 'node-babel-code-frame' is not installed, so not removed
    Package 'node-babel-core' is not installed, so not removed
    Package 'node-babel-eslint' is not installed, so not removed
    Package 'node-babel-generator' is not installed, so not removed
    Package 'node-babel-helper-bindify-decorators' is not installed, so not removed
    Package 'node-babel-helper-builder-binary-assignment-operator-visitor' is not installed, so not removed
    Package 'node-babel-helper-builder-react-jsx' is not installed, so not removed
    Package 'node-babel-helper-call-delegate' is not installed, so not removed
    Package 'node-babel-helper-define-map' is not installed, so not removed
    Package 'node-babel-helper-explode-assignable-expression' is not installed, so not removed
    Package 'node-babel-helper-explode-class' is not installed, so not removed
    Package 'node-babel-helper-function-name' is not installed, so not removed
    Package 'node-babel-helper-get-function-arity' is not installed, so not removed
    Package 'node-babel-helper-hoist-variables' is not installed, so not removed
    Package 'node-babel-helper-optimise-call-expression' is not installed, so not removed
    Package 'node-babel-helper-regex' is not installed, so not removed
    Package 'node-babel-helper-remap-async-to-generator' is not installed, so not removed
    Package 'node-babel-helper-replace-supers' is not installed, so not removed
    Package 'node-babel-helpers' is not installed, so not removed
    Package 'node-babel-loader' is not installed, so not removed
    Package 'node-babel-messages' is not installed, so not removed
    Package 'node-babel-plugin-add-module-exports' is not installed, so not removed
    Package 'node-babel-plugin-array-includes' is not installed, so not removed
    Package 'node-babel-plugin-external-helpers' is not installed, so not removed
    Package 'node-babel-plugin-syntax-async-functions' is not installed, so not removed
    Package 'node-babel-plugin-syntax-async-generators' is not installed, so not removed
    Package 'node-babel-plugin-syntax-class-constructor-call' is not installed, so not removed
    Package 'node-babel-plugin-syntax-class-properties' is not installed, so not removed
    Package 'node-babel-plugin-syntax-decorators' is not installed, so not removed
    Package 'node-babel-plugin-syntax-do-expressions' is not installed, so not removed
    Package 'node-babel-plugin-syntax-dynamic-import' is not installed, so not removed
    Package 'node-babel-plugin-syntax-exponentiation-operator' is not installed, so not removed
    Package 'node-babel-plugin-syntax-export-extensions' is not installed, so not removed
    Package 'node-babel-plugin-syntax-flow' is not installed, so not removed
    Package 'node-babel-plugin-syntax-function-bind' is not installed, so not removed
    Package 'node-babel-plugin-syntax-jsx' is not installed, so not removed
    Package 'node-babel-plugin-syntax-object-rest-spread' is not installed, so not removed
    Package 'node-babel-plugin-syntax-trailing-function-commas' is not installed, so not removed
    Package 'node-babel-plugin-transform-async-generator-functions' is not installed, so not removed
    Package 'node-babel-plugin-transform-async-to-generator' is not installed, so not removed
    Package 'node-babel-plugin-transform-builtin-extend' is not installed, so not removed
    Package 'node-babel-plugin-transform-class-constructor-call' is not installed, so not removed
    Package 'node-babel-plugin-transform-class-properties' is not installed, so not removed
    Package 'node-babel-plugin-transform-decorators' is not installed, so not removed
    Package 'node-babel-plugin-transform-do-expressions' is not installed, so not removed
    Package 'node-babel-plugin-transform-es3-member-expression-literals' is not installed, so not removed
    Package 'node-babel-plugin-transform-es3-property-literals' is not installed, so not removed
    Package 'node-babel-plugin-transform-exponentiation-operator' is not installed, so not removed
    Package 'node-babel-plugin-transform-export-extensions' is not installed, so not removed
    Package 'node-babel-plugin-transform-flow-strip-types' is not installed, so not removed
    Package 'node-babel-plugin-transform-function-bind' is not installed, so not removed
    Package 'node-babel-plugin-transform-jscript' is not installed, so not removed
    Package 'node-babel-plugin-transform-object-rest-spread' is not installed, so not removed
    Package 'node-babel-plugin-transform-proto-to-assign' is not installed, so not removed
    Package 'node-babel-plugin-transform-react-display-name' is not installed, so not removed
    Package 'node-babel-plugin-transform-react-jsx' is not installed, so not removed
    Package 'node-babel-plugin-transform-react-jsx-self' is not installed, so not removed
    Package 'node-babel-plugin-transform-react-jsx-source' is not installed, so not removed
    Package 'node-babel-plugin-transform-regenerator' is not installed, so not removed
    Package 'node-babel-plugin-transform-runtime' is not installed, so not removed
    Package 'node-babel-plugin-transform-strict-mode' is not installed, so not removed
    Package 'node-babel-plugin-transform-vue-jsx' is not installed, so not removed
    Package 'node-babel-polyfill' is not installed, so not removed
    Package 'node-babel-preset-env' is not installed, so not removed
    Package 'node-babel-preset-es2015' is not installed, so not removed
    Package 'node-babel-preset-es2016' is not installed, so not removed
    Package 'node-babel-preset-es2017' is not installed, so not removed
    Package 'node-babel-preset-flow' is not installed, so not removed
    Package 'node-babel-preset-latest' is not installed, so not removed
    Package 'node-babel-preset-react' is not installed, so not removed
    Package 'node-babel-preset-stage-0' is not installed, so not removed
    Package 'node-babel-preset-stage-1' is not installed, so not removed
    Package 'node-babel-preset-stage-2' is not installed, so not removed
    Package 'node-babel-preset-stage-3' is not installed, so not removed
    Package 'node-babel-register' is not installed, so not removed
    Package 'node-babel-runtime' is not installed, so not removed
    Package 'node-babel-template' is not installed, so not removed
    Package 'node-babel-traverse' is not installed, so not removed
    Package 'node-babel-types' is not installed, so not removed
    Package 'node-babel7' is not installed, so not removed
    Package 'node-babylon' is not installed, so not removed
    Package 'node-backbone' is not installed, so not removed
    Package 'node-balanced-match' is not installed, so not removed
    Package 'node-base' is not installed, so not removed
    Package 'node-base62' is not installed, so not removed
    Package 'node-base64-js' is not installed, so not removed
    Package 'node-base64id' is not installed, so not removed
    Package 'node-base64url' is not installed, so not removed
    Package 'node-bash' is not installed, so not removed
    Package 'node-bash-match' is not installed, so not removed
    Package 'node-basic-auth' is not installed, so not removed
    Package 'node-batch' is not installed, so not removed
    Package 'node-bcrypt-pbkdf' is not installed, so not removed
    Package 'node-beeper' is not installed, so not removed
    Package 'node-big.js' is not installed, so not removed
    Package 'node-bignumber' is not installed, so not removed
    Package 'node-binary-extensions' is not installed, so not removed
    Package 'node-bindings' is not installed, so not removed
    Package 'node-bl' is not installed, so not removed
    Package 'node-blob' is not installed, so not removed
    Package 'node-block-stream' is not installed, so not removed
    Package 'node-bluebird' is not installed, so not removed
    Package 'node-bn.js' is not installed, so not removed
    Package 'node-body-parser' is not installed, so not removed
    Package 'node-boolbase' is not installed, so not removed
    Package 'node-boom' is not installed, so not removed
    Package 'node-bootstrap-sass' is not installed, so not removed
    Package 'node-boxen' is not installed, so not removed
    Package 'node-brace-expansion' is not installed, so not removed
    Package 'node-braces' is not installed, so not removed
    Package 'node-brfs' is not installed, so not removed
    Package 'node-brorand' is not installed, so not removed
    Package 'node-browser-pack' is not installed, so not removed
    Package 'node-browser-resolve' is not installed, so not removed
    Package 'node-browser-stdout' is not installed, so not removed
    Package 'node-browser-unpack' is not installed, so not removed
    Package 'node-browserify-aes' is not installed, so not removed
    Package 'node-browserify-cipher' is not installed, so not removed
    Package 'node-browserify-des' is not installed, so not removed
    Package 'node-browserify-lite' is not installed, so not removed
    Package 'node-browserify-rsa' is not installed, so not removed
    Package 'node-browserify-sign' is not installed, so not removed
    Package 'node-browserify-zlib' is not installed, so not removed
    Package 'node-browserslist' is not installed, so not removed
    Package 'node-buble' is not installed, so not removed
    Package 'node-buf-compare' is not installed, so not removed
    Package 'node-buffer' is not installed, so not removed
    Package 'node-buffer-crc32' is not installed, so not removed
    Package 'node-buffer-equal' is not installed, so not removed
    Package 'node-buffer-shims' is not installed, so not removed
    Package 'node-buffer-xor' is not installed, so not removed
    Package 'node-bufferjs' is not installed, so not removed
    Package 'node-bufferlist' is not installed, so not removed
    Package 'node-buffers' is not installed, so not removed
    Package 'node-builtin-modules' is not installed, so not removed
    Package 'node-builtin-status-codes' is not installed, so not removed
    Package 'node-builtins' is not installed, so not removed
    Package 'node-bytes' is not installed, so not removed
    Package 'node-cacache' is not installed, so not removed
    Package 'node-cache-base' is not installed, so not removed
    Package 'node-cache-loader' is not installed, so not removed
    Package 'node-cached-path-relative' is not installed, so not removed
    Package 'node-call-limit' is not installed, so not removed
    Package 'node-callback-stream' is not installed, so not removed
    Package 'node-caller' is not installed, so not removed
    Package 'node-camelcase' is not installed, so not removed
    Package 'node-camelcase-keys' is not installed, so not removed
    Package 'node-caniuse-api' is not installed, so not removed
    Package 'node-caniuse-db' is not installed, so not removed
    Package 'node-caniuse-lite' is not installed, so not removed
    Package 'node-capture-stream' is not installed, so not removed
    Package 'node-carto' is not installed, so not removed
    Package 'node-caseless' is not installed, so not removed
    Package 'node-catty' is not installed, so not removed
    Package 'node-chai-as-promised' is not installed, so not removed
    Package 'node-chainsaw' is not installed, so not removed
    Package 'node-chalk' is not installed, so not removed
    Package 'node-channels' is not installed, so not removed
    Package 'node-character-parser' is not installed, so not removed
    Package 'node-charm' is not installed, so not removed
    Package 'node-chart.js' is not installed, so not removed
    Package 'node-check-error' is not installed, so not removed
    Package 'node-chokidar' is not installed, so not removed
    Package 'node-chownr' is not installed, so not removed
    Package 'node-chrome-trace-event' is not installed, so not removed
    Package 'node-chrono' is not installed, so not removed
    Package 'node-ci-info' is not installed, so not removed
    Package 'node-cipher-base' is not installed, so not removed
    Package 'node-cjson' is not installed, so not removed
    Package 'node-clarinet' is not installed, so not removed
    Package 'node-class-utils' is not installed, so not removed
    Package 'node-clean-css' is not installed, so not removed
    Package 'node-clean-yaml-object' is not installed, so not removed
    Package 'node-cli-boxes' is not installed, so not removed
    Package 'node-cli-cursor' is not installed, so not removed
    Package 'node-cli-spinners' is not installed, so not removed
    Package 'node-cli-table' is not installed, so not removed
    Package 'node-cli-truncate' is not installed, so not removed
    Package 'node-cli-width' is not installed, so not removed
    Package 'node-client-sessions' is not installed, so not removed
    Package 'node-clipboard' is not installed, so not removed
    Package 'node-cliui' is not installed, so not removed
    Package 'node-clone' is not installed, so not removed
    Package 'node-clone-buffer' is not installed, so not removed
    Package 'node-clone-deep' is not installed, so not removed
    Package 'node-clone-stats' is not installed, so not removed
    Package 'node-cloneable-readable' is not installed, so not removed
    Package 'node-co' is not installed, so not removed
    Package 'node-coa' is not installed, so not removed
    Package 'node-code' is not installed, so not removed
    Package 'node-coffee-loader' is not installed, so not removed
    Package 'node-coffeeify' is not installed, so not removed
    Package 'node-collection-visit' is not installed, so not removed
    Package 'node-color' is not installed, so not removed
    Package 'node-color-convert' is not installed, so not removed
    Package 'node-color-name' is not installed, so not removed
    Package 'node-color-string' is not installed, so not removed
    Package 'node-colormin' is not installed, so not removed
    Package 'node-colors' is not installed, so not removed
    Package 'node-columnify' is not installed, so not removed
    Package 'node-combine-source-map' is not installed, so not removed
    Package 'node-combined-stream' is not installed, so not removed
    Package 'node-commander' is not installed, so not removed
    Package 'node-commist' is not installed, so not removed
    Package 'node-commondir' is not installed, so not removed
    Package 'node-compare-versions' is not installed, so not removed
    Package 'node-component-consoler' is not installed, so not removed
    Package 'node-component-emitter' is not installed, so not removed
    Package 'node-compressible' is not installed, so not removed
    Package 'node-compression' is not installed, so not removed
    Package 'node-compression-webpack-plugin' is not installed, so not removed
    Package 'node-concat-map' is not installed, so not removed
    Package 'node-concat-stream' is not installed, so not removed
    Package 'node-concat-with-sourcemaps' is not installed, so not removed
    Package 'node-config-chain' is not installed, so not removed
    Package 'node-configstore' is not installed, so not removed
    Package 'node-connect' is not installed, so not removed
    Package 'node-connect-timeout' is not installed, so not removed
    Package 'node-console-browserify' is not installed, so not removed
    Package 'node-console-control-strings' is not installed, so not removed
    Package 'node-console-group' is not installed, so not removed
    Package 'node-consolidate' is not installed, so not removed
    Package 'node-constantinople' is not installed, so not removed
    Package 'node-constants-browserify' is not installed, so not removed
    Package 'node-content-disposition' is not installed, so not removed
    Package 'node-content-type' is not installed, so not removed
    Package 'node-convert-source-map' is not installed, so not removed
    Package 'node-cookie' is not installed, so not removed
    Package 'node-cookie-jar' is not installed, so not removed
    Package 'node-cookie-parser' is not installed, so not removed
    Package 'node-cookie-signature' is not installed, so not removed
    Package 'node-cookiejar' is not installed, so not removed
    Package 'node-cookies' is not installed, so not removed
    Package 'node-copy-concurrently' is not installed, so not removed
    Package 'node-copy-descriptor' is not installed, so not removed
    Package 'node-copy-webpack-plugin' is not installed, so not removed
    Package 'node-core-js' is not installed, so not removed
    Package 'node-core-util-is' is not installed, so not removed
    Package 'node-cors' is not installed, so not removed
    Package 'node-cosmiconfig' is not installed, so not removed
    Package 'node-coveralls' is not installed, so not removed
    Package 'node-cpr' is not installed, so not removed
    Package 'node-crc' is not installed, so not removed
    Package 'node-crc32' is not installed, so not removed
    Package 'node-create-ecdh' is not installed, so not removed
    Package 'node-create-hash' is not installed, so not removed
    Package 'node-create-hmac' is not installed, so not removed
    Package 'node-cross-spawn' is not installed, so not removed
    Package 'node-cross-spawn-async' is not installed, so not removed
    Package 'node-cryptiles' is not installed, so not removed
    Package 'node-crypto-browserify' is not installed, so not removed
    Package 'node-crypto-cacerts' is not installed, so not removed
    Package 'node-crypto-random-string' is not installed, so not removed
    Package 'node-cson-parser' is not installed, so not removed
    Package 'node-css' is not installed, so not removed
    Package 'node-css-color-names' is not installed, so not removed
    Package 'node-css-loader' is not installed, so not removed
    Package 'node-css-select' is not installed, so not removed
    Package 'node-css-selector-tokenizer' is not installed, so not removed
    Package 'node-css-what' is not installed, so not removed
    Package 'node-cssom' is not installed, so not removed
    Package 'node-cssstyle' is not installed, so not removed
    Package 'node-csv-spectrum' is not installed, so not removed
    Package 'node-cuint' is not installed, so not removed
    Package 'node-currently-unhandled' is not installed, so not removed
    Package 'node-cyclist' is not installed, so not removed
    Package 'node-d' is not installed, so not removed
    Package 'node-d3' is not installed, so not removed
    Package 'node-d3-array' is not installed, so not removed
    Package 'node-d3-axis' is not installed, so not removed
    Package 'node-d3-brush' is not installed, so not removed
    Package 'node-d3-chord' is not installed, so not removed
    Package 'node-d3-collection' is not installed, so not removed
    Package 'node-d3-color' is not installed, so not removed
    Package 'node-d3-contour' is not installed, so not removed
    Package 'node-d3-dispatch' is not installed, so not removed
    Package 'node-d3-drag' is not installed, so not removed
    Package 'node-d3-dsv' is not installed, so not removed
    Package 'node-d3-ease' is not installed, so not removed
    Package 'node-d3-fetch' is not installed, so not removed
    Package 'node-d3-force' is not installed, so not removed
    Package 'node-d3-format' is not installed, so not removed
    Package 'node-d3-geo' is not installed, so not removed
    Package 'node-d3-hierarchy' is not installed, so not removed
    Package 'node-d3-interpolate' is not installed, so not removed
    Package 'node-d3-path' is not installed, so not removed
    Package 'node-d3-polygon' is not installed, so not removed
    Package 'node-d3-quadtree' is not installed, so not removed
    Package 'node-d3-queue' is not installed, so not removed
    Package 'node-d3-random' is not installed, so not removed
    Package 'node-d3-request' is not installed, so not removed
    Package 'node-d3-scale' is not installed, so not removed
    Package 'node-d3-scale-chromatic' is not installed, so not removed
    Package 'node-d3-selection' is not installed, so not removed
    Package 'node-d3-shape' is not installed, so not removed
    Package 'node-d3-time' is not installed, so not removed
    Package 'node-d3-time-format' is not installed, so not removed
    Package 'node-d3-timer' is not installed, so not removed
    Package 'node-d3-transition' is not installed, so not removed
    Package 'node-d3-voronoi' is not installed, so not removed
    Package 'node-d3-zoom' is not installed, so not removed
    Package 'node-daemon' is not installed, so not removed
    Package 'node-dagre-d3-renderer' is not installed, so not removed
    Package 'node-dagre-layout' is not installed, so not removed
    Package 'node-dargs' is not installed, so not removed
    Package 'node-dashdash' is not installed, so not removed
    Package 'node-databank' is not installed, so not removed
    Package 'node-date-now' is not installed, so not removed
    Package 'node-date-time' is not installed, so not removed
    Package 'node-dateformat' is not installed, so not removed
    Package 'node-de-indent' is not installed, so not removed
    Package 'node-death' is not installed, so not removed
    Package 'node-debbundle-acorn' is not installed, so not removed
    Package 'node-debbundle-es-to-primitive' is not installed, so not removed
    Package 'node-debbundle-insert-module-globals' is not installed, so not removed
    Package 'node-debug' is not installed, so not removed
    Package 'node-debug-fabulous' is not installed, so not removed
    Package 'node-decamelize' is not installed, so not removed
    Package 'node-decompress-response' is not installed, so not removed
    Package 'node-deep-eql' is not installed, so not removed
    Package 'node-deep-equal' is not installed, so not removed
    Package 'node-deep-extend' is not installed, so not removed
    Package 'node-deep-for-each' is not installed, so not removed
    Package 'node-deep-is' is not installed, so not removed
    Package 'node-defaults' is not installed, so not removed
    Package 'node-define-properties' is not installed, so not removed
    Package 'node-define-property' is not installed, so not removed
    Package 'node-defined' is not installed, so not removed
    Package 'node-deflate-js' is not installed, so not removed
    Package 'node-del' is not installed, so not removed
    Package 'node-delayed-stream' is not installed, so not removed
    Package 'node-delegates' is not installed, so not removed
    Package 'node-delve' is not installed, so not removed
    Package 'node-depd' is not installed, so not removed
    Package 'node-deprecated' is not installed, so not removed
    Package 'node-deps-sort' is not installed, so not removed
    Package 'node-dequeue' is not installed, so not removed
    Package 'node-des.js' is not installed, so not removed
    Package 'node-detect-file' is not installed, so not removed
    Package 'node-detect-indent' is not installed, so not removed
    Package 'node-detect-newline' is not installed, so not removed
    Package 'node-detective' is not installed, so not removed
    Package 'node-diacritics' is not installed, so not removed
    Package 'node-diff' is not installed, so not removed
    Package 'node-difflet' is not installed, so not removed
    Package 'node-dirty' is not installed, so not removed
    Package 'node-doctrine' is not installed, so not removed
    Package 'node-dom-serializer' is not installed, so not removed
    Package 'node-domain-browser' is not installed, so not removed
    Package 'node-domelementtype' is not installed, so not removed
    Package 'node-domhandler' is not installed, so not removed
    Package 'node-domino' is not installed, so not removed
    Package 'node-domutils' is not installed, so not removed
    Package 'node-dot' is not installed, so not removed
    Package 'node-dot-prop' is not installed, so not removed
    Package 'node-dottie' is not installed, so not removed
    Package 'node-dryice' is not installed, so not removed
    Package 'node-dtrace-provider' is not installed, so not removed
    Package 'node-duplexer' is not installed, so not removed
    Package 'node-duplexer3' is not installed, so not removed
    Package 'node-duplexify' is not installed, so not removed
    Package 'node-ebnf-parser' is not installed, so not removed
    Package 'node-ecc-jsbn' is not installed, so not removed
    Package 'node-editor' is not installed, so not removed
    Package 'node-ejs' is not installed, so not removed
    Package 'node-electron-to-chromium' is not installed, so not removed
    Package 'node-elliptic' is not installed, so not removed
    Package 'node-emoji' is not installed, so not removed
    Package 'node-emojis-list' is not installed, so not removed
    Package 'node-encodeurl' is not installed, so not removed
    Package 'node-encoding' is not installed, so not removed
    Package 'node-end-of-stream' is not installed, so not removed
    Package 'node-enhanced-resolve' is not installed, so not removed
    Package 'node-entities' is not installed, so not removed
    Package 'node-err-code' is not installed, so not removed
    Package 'node-errno' is not installed, so not removed
    Package 'node-error-ex' is not installed, so not removed
    Package 'node-errorhandler' is not installed, so not removed
    Package 'node-errs' is not installed, so not removed
    Package 'node-es5-ext' is not installed, so not removed
    Package 'node-es5-shim' is not installed, so not removed
    Package 'node-es6-error' is not installed, so not removed
    Package 'node-es6-iterator' is not installed, so not removed
    Package 'node-es6-map' is not installed, so not removed
    Package 'node-es6-promise' is not installed, so not removed
    Package 'node-es6-set' is not installed, so not removed
    Package 'node-es6-shim' is not installed, so not removed
    Package 'node-es6-symbol' is not installed, so not removed
    Package 'node-es6-weak-map' is not installed, so not removed
    Package 'node-escape-html' is not installed, so not removed
    Package 'node-escape-string-regexp' is not installed, so not removed
    Package 'node-escodegen' is not installed, so not removed
    Package 'node-escope' is not installed, so not removed
    Package 'node-eslint-plugin-eslint-plugin' is not installed, so not removed
    Package 'node-eslint-plugin-flowtype' is not installed, so not removed
    Package 'node-eslint-plugin-html' is not installed, so not removed
    Package 'node-eslint-plugin-node' is not installed, so not removed
    Package 'node-eslint-plugin-requirejs' is not installed, so not removed
    Package 'node-eslint-scope' is not installed, so not removed
    Package 'node-eslint-utils' is not installed, so not removed
    Package 'node-eslint-visitor-keys' is not installed, so not removed
    Package 'node-espree' is not installed, so not removed
    Package 'node-esprima' is not installed, so not removed
    Package 'node-esprima-fb' is not installed, so not removed
    Package 'node-esquery' is not installed, so not removed
    Package 'node-esrecurse' is not installed, so not removed
    Package 'node-estraverse' is not installed, so not removed
    Package 'node-estree-walker' is not installed, so not removed
    Package 'node-esutils' is not installed, so not removed
    Package 'node-etag' is not installed, so not removed
    Package 'node-event-emitter' is not installed, so not removed
    Package 'node-eventemitter2' is not installed, so not removed
    Package 'node-eventemitter3' is not installed, so not removed
    Package 'node-events' is not installed, so not removed
    Package 'node-eventsource' is not installed, so not removed
    Package 'node-everything.js' is not installed, so not removed
    Package 'node-evp-bytestokey' is not installed, so not removed
    Package 'node-execa' is not installed, so not removed
    Package 'node-exit' is not installed, so not removed
    Package 'node-exit-hook' is not installed, so not removed
    Package 'node-expand-brackets' is not installed, so not removed
    Package 'node-expand-tilde' is not installed, so not removed
    Package 'node-expect.js' is not installed, so not removed
    Package 'node-exports-loader' is not installed, so not removed
    Package 'node-express' is not installed, so not removed
    Package 'node-express-generator' is not installed, so not removed
    Package 'node-extend' is not installed, so not removed
    Package 'node-extend-shallow' is not installed, so not removed
    Package 'node-external-editor' is not installed, so not removed
    Package 'node-extglob' is not installed, so not removed
    Package 'node-extract-text-webpack-plugin' is not installed, so not removed
    Package 'node-extract-zip' is not installed, so not removed
    Package 'node-extsprintf' is not installed, so not removed
    Package 'node-eyes' is not installed, so not removed
    Package 'node-falafel' is not installed, so not removed
    Package 'node-fancy-log' is not installed, so not removed
    Package 'node-fast-deep-equal' is not installed, so not removed
    Package 'node-fast-levenshtein' is not installed, so not removed
    Package 'node-fastcgi' is not installed, so not removed
    Package 'node-fastcgi-stream' is not installed, so not removed
    Package 'node-faye-websocket' is not installed, so not removed
    Package 'node-fbjs' is not installed, so not removed
    Package 'node-fd-slicer' is not installed, so not removed
    Package 'node-fetch' is not installed, so not removed
    Package 'node-file-entry-cache' is not installed, so not removed
    Package 'node-file-loader' is not installed, so not removed
    Package 'node-file-sync-cmp' is not installed, so not removed
    Package 'node-filename-regex' is not installed, so not removed
    Package 'node-filesize' is not installed, so not removed
    Package 'node-fill-range' is not installed, so not removed
    Package 'node-finalhandler' is not installed, so not removed
    Package 'node-find-cache-dir' is not installed, so not removed
    Package 'node-find-up' is not installed, so not removed
    Package 'node-findit2' is not installed, so not removed
    Package 'node-findup-sync' is not installed, so not removed
    Package 'node-fined' is not installed, so not removed
    Package 'node-first-chunk-stream' is not installed, so not removed
    Package 'node-flagged-respawn' is not installed, so not removed
    Package 'node-flat-cache' is not installed, so not removed
    Package 'node-flatted' is not installed, so not removed
    Package 'node-flow-remove-types' is not installed, so not removed
    Package 'node-flush-write-stream' is not installed, so not removed
    Package 'node-fn-name' is not installed, so not removed
    Package 'node-follow-redirects' is not installed, so not removed
    Package 'node-for-in' is not installed, so not removed
    Package 'node-for-own' is not installed, so not removed
    Package 'node-foreground-child' is not installed, so not removed
    Package 'node-forever-agent' is not installed, so not removed
    Package 'node-form-data' is not installed, so not removed
    Package 'node-formatio' is not installed, so not removed
    Package 'node-formidable' is not installed, so not removed
    Package 'node-fragment-cache' is not installed, so not removed
    Package 'node-fresh' is not installed, so not removed
    Package 'node-from2' is not installed, so not removed
    Package 'node-fs-exists-sync' is not installed, so not removed
    Package 'node-fs-extra' is not installed, so not removed
    Package 'node-fs-readdir-recursive' is not installed, so not removed
    Package 'node-fs-vacuum' is not installed, so not removed
    Package 'node-fs-write-stream-atomic' is not installed, so not removed
    Package 'node-fs.realpath' is not installed, so not removed
    Package 'node-fstream' is not installed, so not removed
    Package 'node-fstream-ignore' is not installed, so not removed
    Package 'node-function-bind' is not installed, so not removed
    Package 'node-functional-red-black-tree' is not installed, so not removed
    Package 'node-fuzzaldrin-plus' is not installed, so not removed
    Package 'node-fuzzysort' is not installed, so not removed
    Package 'node-gauge' is not installed, so not removed
    Package 'node-generator-supported' is not installed, so not removed
    Package 'node-generic-pool' is not installed, so not removed
    Package 'node-genfun' is not installed, so not removed
    Package 'node-geographiclib' is not installed, so not removed
    Package 'node-get' is not installed, so not removed
    Package 'node-get-caller-file' is not installed, so not removed
    Package 'node-get-func-name' is not installed, so not removed
    Package 'node-get-stdin' is not installed, so not removed
    Package 'node-get-stream' is not installed, so not removed
    Package 'node-get-value' is not installed, so not removed
    Package 'node-getobject' is not installed, so not removed
    Package 'node-getpass' is not installed, so not removed
    Package 'node-gettext-parser' is not installed, so not removed
    Package 'node-gettext.js' is not installed, so not removed
    Package 'node-github-url-from-git' is not installed, so not removed
    Package 'node-glob' is not installed, so not removed
    Package 'node-glob-base' is not installed, so not removed
    Package 'node-glob-parent' is not installed, so not removed
    Package 'node-glob-stream' is not installed, so not removed
    Package 'node-global-modules' is not installed, so not removed
    Package 'node-global-prefix' is not installed, so not removed
    Package 'node-globals' is not installed, so not removed
    Package 'node-globby' is not installed, so not removed
    Package 'node-globule' is not installed, so not removed
    Package 'node-glogg' is not installed, so not removed
    Package 'node-googlediff' is not installed, so not removed
    Package 'node-got' is not installed, so not removed
    Package 'node-graceful-fs' is not installed, so not removed
    Package 'node-graphlibrary' is not installed, so not removed
    Package 'node-growl' is not installed, so not removed
    Package 'node-grunt-babel' is not installed, so not removed
    Package 'node-grunt-cli' is not installed, so not removed
    Package 'node-grunt-contrib-clean' is not installed, so not removed
    Package 'node-grunt-contrib-coffee' is not installed, so not removed
    Package 'node-grunt-contrib-concat' is not installed, so not removed
    Package 'node-grunt-contrib-copy' is not installed, so not removed
    Package 'node-grunt-contrib-internal' is not installed, so not removed
    Package 'node-grunt-contrib-nodeunit' is not installed, so not removed
    Package 'node-grunt-contrib-requirejs' is not installed, so not removed
    Package 'node-grunt-contrib-uglify' is not installed, so not removed
    Package 'node-grunt-known-options' is not installed, so not removed
    Package 'node-grunt-legacy-log' is not installed, so not removed
    Package 'node-grunt-legacy-log-utils' is not installed, so not removed
    Package 'node-grunt-legacy-util' is not installed, so not removed
    Package 'node-grunt-replace' is not installed, so not removed
    Package 'node-grunt-sass' is not installed, so not removed
    Package 'node-grunt-webpack' is not installed, so not removed
    Package 'node-gulp-babel' is not installed, so not removed
    Package 'node-gulp-changed' is not installed, so not removed
    Package 'node-gulp-coffee' is not installed, so not removed
    Package 'node-gulp-concat' is not installed, so not removed
    Package 'node-gulp-flatten' is not installed, so not removed
    Package 'node-gulp-load-plugins' is not installed, so not removed
    Package 'node-gulp-newer' is not installed, so not removed
    Package 'node-gulp-plumber' is not installed, so not removed
    Package 'node-gulp-rename' is not installed, so not removed
    Package 'node-gulp-sourcemaps' is not installed, so not removed
    Package 'node-gulp-util' is not installed, so not removed
    Package 'node-gulplog' is not installed, so not removed
    Package 'node-gyp' is not installed, so not removed
    Package 'node-gzip-size' is not installed, so not removed
    Package 'node-har-schema' is not installed, so not removed
    Package 'node-har-validator' is not installed, so not removed
    Package 'node-has-ansi' is not installed, so not removed
    Package 'node-has-binary' is not installed, so not removed
    Package 'node-has-cors' is not installed, so not removed
    Package 'node-has-flag' is not installed, so not removed
    Package 'node-has-gulplog' is not installed, so not removed
    Package 'node-has-symbol-support-x' is not installed, so not removed
    Package 'node-has-to-string-tag-x' is not installed, so not removed
    Package 'node-has-unicode' is not installed, so not removed
    Package 'node-has-value' is not installed, so not removed
    Package 'node-has-values' is not installed, so not removed
    Package 'node-hash-base' is not installed, so not removed
    Package 'node-hash-sum' is not installed, so not removed
    Package 'node-hash-test-vectors' is not installed, so not removed
    Package 'node-hash.js' is not installed, so not removed
    Package 'node-hashish' is not installed, so not removed
    Package 'node-hawk' is not installed, so not removed
    Package 'node-he' is not installed, so not removed
    Package 'node-help-me' is not installed, so not removed
    Package 'node-highlight' is not installed, so not removed
    Package 'node-highlight.js' is not installed, so not removed
    Package 'node-hmac-drbg' is not installed, so not removed
    Package 'node-hoek' is not installed, so not removed
    Package 'node-hook-std' is not installed, so not removed
    Package 'node-hooker' is not installed, so not removed
    Package 'node-hosted-git-info' is not installed, so not removed
    Package 'node-html-comment-regex' is not installed, so not removed
    Package 'node-html5shiv' is not installed, so not removed
    Package 'node-htmlescape' is not installed, so not removed
    Package 'node-htmlparser' is not installed, so not removed
    Package 'node-htmlparser2' is not installed, so not removed
    Package 'node-http-errors' is not installed, so not removed
    Package 'node-http-signature' is not installed, so not removed
    Package 'node-https-browserify' is not installed, so not removed
    Package 'node-i18next' is not installed, so not removed
    Package 'node-i18next-browser-languagedetector' is not installed, so not removed
    Package 'node-i18next-xhr-backend' is not installed, so not removed
    Package 'node-iconv' is not installed, so not removed
    Package 'node-iconv-lite' is not installed, so not removed
    Package 'node-icss-replace-symbols' is not installed, so not removed
    Package 'node-icss-utils' is not installed, so not removed
    Package 'node-ieee754' is not installed, so not removed
    Package 'node-iferr' is not installed, so not removed
    Package 'node-ignore' is not installed, so not removed
    Package 'node-ignore-by-default' is not installed, so not removed
    Package 'node-imagemagick' is not installed, so not removed
    Package 'node-immediate' is not installed, so not removed
    Package 'node-immutable' is not installed, so not removed
    Package 'node-immutable-tuple' is not installed, so not removed
    Package 'node-import-lazy' is not installed, so not removed
    Package 'node-imports-loader' is not installed, so not removed
    Package 'node-imurmurhash' is not installed, so not removed
    Package 'node-indent-string' is not installed, so not removed
    Package 'node-inflection' is not installed, so not removed
    Package 'node-inflight' is not installed, so not removed
    Package 'node-inherits' is not installed, so not removed
    Package 'node-ini' is not installed, so not removed
    Package 'node-inline-source-map' is not installed, so not removed
    Package 'node-inquirer' is not installed, so not removed
    Package 'node-interpret' is not installed, so not removed
    Package 'node-invariant' is not installed, so not removed
    Package 'node-invert-kv' is not installed, so not removed
    Package 'node-ip' is not installed, so not removed
    Package 'node-ip-address' is not installed, so not removed
    Package 'node-ip-regex' is not installed, so not removed
    Package 'node-ipaddr.js' is not installed, so not removed
    Package 'node-irregular-plurals' is not installed, so not removed
    Package 'node-is-accessor-descriptor' is not installed, so not removed
    Package 'node-is-arrayish' is not installed, so not removed
    Package 'node-is-binary-path' is not installed, so not removed
    Package 'node-is-buffer' is not installed, so not removed
    Package 'node-is-builtin-module' is not installed, so not removed
    Package 'node-is-data-descriptor' is not installed, so not removed
    Package 'node-is-descriptor' is not installed, so not removed
    Package 'node-is-directory' is not installed, so not removed
    Package 'node-is-dotfile' is not installed, so not removed
    Package 'node-is-equal-shallow' is not installed, so not removed
    Package 'node-is-extendable' is not installed, so not removed
    Package 'node-is-extglob' is not installed, so not removed
    Package 'node-is-generator-fn' is not installed, so not removed
    Package 'node-is-glob' is not installed, so not removed
    Package 'node-is-module' is not installed, so not removed
    Package 'node-is-negated-glob' is not installed, so not removed
    Package 'node-is-npm' is not installed, so not removed
    Package 'node-is-number' is not installed, so not removed
    Package 'node-is-obj' is not installed, so not removed
    Package 'node-is-object' is not installed, so not removed
    Package 'node-is-path-cwd' is not installed, so not removed
    Package 'node-is-path-in-cwd' is not installed, so not removed
    Package 'node-is-path-inside' is not installed, so not removed
    Package 'node-is-plain-obj' is not installed, so not removed
    Package 'node-is-plain-object' is not installed, so not removed
    Package 'node-is-primitive' is not installed, so not removed
    Package 'node-is-promise' is not installed, so not removed
    Package 'node-is-reference' is not installed, so not removed
    Package 'node-is-retry-allowed' is not installed, so not removed
    Package 'node-is-stream' is not installed, so not removed
    Package 'node-is-typedarray' is not installed, so not removed
    Package 'node-is-unc-path' is not installed, so not removed
    Package 'node-is-valid-glob' is not installed, so not removed
    Package 'node-is-windows' is not installed, so not removed
    Package 'node-isarray' is not installed, so not removed
    Package 'node-iscroll' is not installed, so not removed
    Package 'node-isexe' is not installed, so not removed
    Package 'node-isobject' is not installed, so not removed
    Package 'node-isomorphic-fetch' is not installed, so not removed
    Package 'node-isstream' is not installed, so not removed
    Package 'node-istanbul' is not installed, so not removed
    Package 'node-isurl' is not installed, so not removed
    Package 'node-jade' is not installed, so not removed
    Package 'node-jake' is not installed, so not removed
    Package 'node-jed' is not installed, so not removed
    Package 'node-jison-lex' is not installed, so not removed
    Package 'node-jju' is not installed, so not removed
    Package 'node-jquery-mousewheel' is not installed, so not removed
    Package 'node-jquery-textcomplete' is not installed, so not removed
    Package 'node-jquery-ui' is not installed, so not removed
    Package 'node-jquery-ujs' is not installed, so not removed
    Package 'node-jquery.waitforimages' is not installed, so not removed
    Package 'node-js-beautify' is not installed, so not removed
    Package 'node-js-cookie' is not installed, so not removed
    Package 'node-js-tokens' is not installed, so not removed
    Package 'node-js-yaml' is not installed, so not removed
    Package 'node-jsbn' is not installed, so not removed
    Package 'node-jschardet' is not installed, so not removed
    Package 'node-jsdom' is not installed, so not removed
    Package 'node-jsesc' is not installed, so not removed
    Package 'node-json-buffer' is not installed, so not removed
    Package 'node-json-loader' is not installed, so not removed
    Package 'node-json-localizer' is not installed, so not removed
    Package 'node-json-parse-better-errors' is not installed, so not removed
    Package 'node-json-parse-helpfulerror' is not installed, so not removed
    Package 'node-json-schema' is not installed, so not removed
    Package 'node-json-schema-traverse' is not installed, so not removed
    Package 'node-json-stable-stringify' is not installed, so not removed
    Package 'node-json-stringify-safe' is not installed, so not removed
    Package 'node-json2module' is not installed, so not removed
    Package 'node-json5' is not installed, so not removed
    Package 'node-jsonfile' is not installed, so not removed
    Package 'node-jsonify' is not installed, so not removed
    Package 'node-jsonld' is not installed, so not removed
    Package 'node-jsonminify' is not installed, so not removed
    Package 'node-jsonparse' is not installed, so not removed
    Package 'node-jsonselect' is not installed, so not removed
    Package 'node-jsonstream' is not installed, so not removed
    Package 'node-jsprim' is not installed, so not removed
    Package 'node-jstimezonedetect' is not installed, so not removed
    Package 'node-jsv' is not installed, so not removed
    Package 'node-jszip' is not installed, so not removed
    Package 'node-jszip-utils' is not installed, so not removed
    Package 'node-katex' is not installed, so not removed
    Package 'node-keese' is not installed, so not removed
    Package 'node-kew' is not installed, so not removed
    Package 'node-keygrip' is not installed, so not removed
    Package 'node-keypress' is not installed, so not removed
    Package 'node-kind-of' is not installed, so not removed
    Package 'node-klaw' is not installed, so not removed
    Package 'node-knockout' is not installed, so not removed
    Package 'node-knockout-sortable' is not installed, so not removed
    Package 'node-knockout-transformations' is not installed, so not removed
    Package 'node-labeled-stream-splicer' is not installed, so not removed
    Package 'node-lastfm' is not installed, so not removed
    Package 'node-latest-version' is not installed, so not removed
    Package 'node-lazy-cache' is not installed, so not removed
    Package 'node-lazy-debug-legacy' is not installed, so not removed
    Package 'node-lazy-property' is not installed, so not removed
    Package 'node-lazystream' is not installed, so not removed
    Package 'node-lcid' is not installed, so not removed
    Package 'node-lcov-parse' is not installed, so not removed
    Package 'node-leaflet' is not installed, so not removed
    Package 'node-leaflet-formbuilder' is not installed, so not removed
    Package 'node-leaflet-hash' is not installed, so not removed
    Package 'node-leaflet-image' is not installed, so not removed
    Package 'node-leaflet.markercluster' is not installed, so not removed
    Package 'node-leche' is not installed, so not removed
    Package 'node-less' is not installed, so not removed
    Package 'node-less-loader' is not installed, so not removed
    Package 'node-leveldown' is not installed, so not removed
    Package 'node-leven' is not installed, so not removed
    Package 'node-levn' is not installed, so not removed
    Package 'node-lex-parser' is not installed, so not removed
    Package 'node-lexical-scope' is not installed, so not removed
    Package 'node-libnpx' is not installed, so not removed
    Package 'node-libravatar' is not installed, so not removed
    Package 'node-libs-browser' is not installed, so not removed
    Package 'node-lie' is not installed, so not removed
    Package 'node-liftoff' is not installed, so not removed
    Package 'node-lightgallery' is not installed, so not removed
    Package 'node-load-grunt-tasks' is not installed, so not removed
    Package 'node-load-json-file' is not installed, so not removed
    Package 'node-loader-runner' is not installed, so not removed
    Package 'node-loader-utils' is not installed, so not removed
    Package 'node-locate-character' is not installed, so not removed
    Package 'node-locate-path' is not installed, so not removed
    Package 'node-lockfile' is not installed, so not removed
    Package 'node-lodash' is not installed, so not removed
    Package 'node-lodash-compat' is not installed, so not removed
    Package 'node-lodash-packages' is not installed, so not removed
    Package 'node-lodash-reescape' is not installed, so not removed
    Package 'node-lodash-reevaluate' is not installed, so not removed
    Package 'node-log-driver' is not installed, so not removed
    Package 'node-log4js' is not installed, so not removed
    Package 'node-lolex' is not installed, so not removed
    Package 'node-loose-envify' is not installed, so not removed
    Package 'node-loud-rejection' is not installed, so not removed
    Package 'node-lowercase-keys' is not installed, so not removed
    Package 'node-lru-cache' is not installed, so not removed
    Package 'node-ltx' is not installed, so not removed
    Package 'node-lunr' is not installed, so not removed
    Package 'node-macaddress' is not installed, so not removed
    Package 'node-magic-string' is not installed, so not removed
    Package 'node-make-dir' is not installed, so not removed
    Package 'node-map-cache' is not installed, so not removed
    Package 'node-map-obj' is not installed, so not removed
    Package 'node-map-visit' is not installed, so not removed
    Package 'node-markdown-it' is not installed, so not removed
    Package 'node-marked' is not installed, so not removed
    Package 'node-marked-man' is not installed, so not removed
    Package 'node-match-at' is not installed, so not removed
    Package 'node-matcher' is not installed, so not removed
    Package 'node-matrix-js-sdk' is not installed, so not removed
    Package 'node-mbtiles' is not installed, so not removed
    Package 'node-md5-hex' is not installed, so not removed
    Package 'node-md5-o-matic' is not installed, so not removed
    Package 'node-md5.js' is not installed, so not removed
    Package 'node-mdn-data' is not installed, so not removed
    Package 'node-media-typer' is not installed, so not removed
    Package 'node-mem' is not installed, so not removed
    Package 'node-memory-fs' is not installed, so not removed
    Package 'node-meow' is not installed, so not removed
    Package 'node-merge' is not installed, so not removed
    Package 'node-merge-descriptors' is not installed, so not removed
    Package 'node-merge-stream' is not installed, so not removed
    Package 'node-mess' is not installed, so not removed
    Package 'node-methods' is not installed, so not removed
    Package 'node-micromatch' is not installed, so not removed
    Package 'node-miller-rabin' is not installed, so not removed
    Package 'node-millstone' is not installed, so not removed
    Package 'node-mime' is not installed, so not removed
    Package 'node-mime-types' is not installed, so not removed
    Package 'node-mimic-fn' is not installed, so not removed
    Package 'node-mimic-response' is not installed, so not removed
    Package 'node-minimalistic-crypto-utils' is not installed, so not removed
    Package 'node-minimatch' is not installed, so not removed
    Package 'node-minimist' is not installed, so not removed
    Package 'node-mississippi' is not installed, so not removed
    Package 'node-mithril' is not installed, so not removed
    Package 'node-mixin-deep' is not installed, so not removed
    Package 'node-mkdirp' is not installed, so not removed
    Package 'node-mocha-lcov-reporter' is not installed, so not removed
    Package 'node-mock-fs' is not installed, so not removed
    Package 'node-mocks-http' is not installed, so not removed
    Package 'node-modern-syslog' is not installed, so not removed
    Package 'node-modify-babel-preset' is not installed, so not removed
    Package 'node-module-deps' is not installed, so not removed
    Package 'node-moment' is not installed, so not removed
    Package 'node-moment-timezone' is not installed, so not removed
    Package 'node-mongodb' is not installed, so not removed
    Package 'node-monocle' is not installed, so not removed
    Package 'node-mousetrap' is not installed, so not removed
    Package 'node-move-concurrently' is not installed, so not removed
    Package 'node-mqtt' is not installed, so not removed
    Package 'node-mqtt-connection' is not installed, so not removed
    Package 'node-mqtt-packet' is not installed, so not removed
    Package 'node-ms' is not installed, so not removed
    Package 'node-multimatch' is not installed, so not removed
    Package 'node-multiparty' is not installed, so not removed
    Package 'node-multipipe' is not installed, so not removed
    Package 'node-music-library-index' is not installed, so not removed
    Package 'node-mustache' is not installed, so not removed
    Package 'node-mutate-fs' is not installed, so not removed
    Package 'node-mute-stream' is not installed, so not removed
    Package 'node-mysql' is not installed, so not removed
    Package 'node-mz' is not installed, so not removed
    Package 'node-n3' is not installed, so not removed
    Package 'node-nan' is not installed, so not removed
    Package 'node-ncp' is not installed, so not removed
    Package 'node-negotiator' is not installed, so not removed
    Package 'node-neo-async' is not installed, so not removed
    Package 'node-node-dir' is not installed, so not removed
    Package 'node-node-expat' is not installed, so not removed
    Package 'node-node-forge' is not installed, so not removed
    Package 'node-node-localstorage' is not installed, so not removed
    Package 'node-node-rest-client' is not installed, so not removed
    Package 'node-node-rsa' is not installed, so not removed
    Package 'node-node-sass' is not installed, so not removed
    Package 'node-node-stringprep' is not installed, so not removed
    Package 'node-node-uuid' is not installed, so not removed
    Package 'node-nodedbi' is not installed, so not removed
    Package 'node-nodemailer' is not installed, so not removed
    Package 'node-nomnom' is not installed, so not removed
    Package 'node-nopt' is not installed, so not removed
    Package 'node-normalize-git-url' is not installed, so not removed
    Package 'node-normalize-package-data' is not installed, so not removed
    Package 'node-normalize-path' is not installed, so not removed
    Package 'node-normalize-range' is not installed, so not removed
    Package 'node-normalize.css' is not installed, so not removed
    Package 'node-npm-bundled' is not installed, so not removed
    Package 'node-npm-package-arg' is not installed, so not removed
    Package 'node-npm-run-path' is not installed, so not removed
    Package 'node-npmlog' is not installed, so not removed
    Package 'node-npmrc' is not installed, so not removed
    Package 'node-nth-check' is not installed, so not removed
    Package 'node-number-is-nan' is not installed, so not removed
    Package 'node-nwmatcher' is not installed, so not removed
    Package 'node-oauth-sign' is not installed, so not removed
    Package 'node-obj-util' is not installed, so not removed
    Package 'node-object-assign' is not installed, so not removed
    Package 'node-object-copy' is not installed, so not removed
    Package 'node-object-inspect' is not installed, so not removed
    Package 'node-object-key' is not installed, so not removed
    Package 'node-object-path' is not installed, so not removed
    Package 'node-object-visit' is not installed, so not removed
    Package 'node-object.omit' is not installed, so not removed
    Package 'node-on-finished' is not installed, so not removed
    Package 'node-on-headers' is not installed, so not removed
    Package 'node-once' is not installed, so not removed
    Package 'node-opencv' is not installed, so not removed
    Package 'node-opener' is not installed, so not removed
    Package 'node-openid' is not installed, so not removed
    Package 'node-opentip' is not installed, so not removed
    Package 'node-optimist' is not installed, so not removed
    Package 'node-optionator' is not installed, so not removed
    Package 'node-orchestrator' is not installed, so not removed
    Package 'node-ordered-read-streams' is not installed, so not removed
    Package 'node-original' is not installed, so not removed
    Package 'node-os-browserify' is not installed, so not removed
    Package 'node-os-locale' is not installed, so not removed
    Package 'node-os-tmpdir' is not installed, so not removed
    Package 'node-osenv' is not installed, so not removed
    Package 'node-output-file-sync' is not installed, so not removed
    Package 'node-p-cancelable' is not installed, so not removed
    Package 'node-p-finally' is not installed, so not removed
    Package 'node-p-is-promise' is not installed, so not removed
    Package 'node-p-limit' is not installed, so not removed
    Package 'node-p-locate' is not installed, so not removed
    Package 'node-p-map' is not installed, so not removed
    Package 'node-p-timeout' is not installed, so not removed
    Package 'node-package' is not installed, so not removed
    Package 'node-package-json' is not installed, so not removed
    Package 'node-package-preamble' is not installed, so not removed
    Package 'node-pako' is not installed, so not removed
    Package 'node-parallel-transform' is not installed, so not removed
    Package 'node-parents' is not installed, so not removed
    Package 'node-parse-asn1' is not installed, so not removed
    Package 'node-parse-base64vlq-mappings' is not installed, so not removed
    Package 'node-parse-filepath' is not installed, so not removed
    Package 'node-parse-glob' is not installed, so not removed
    Package 'node-parse-json' is not installed, so not removed
    Package 'node-parse-ms' is not installed, so not removed
    Package 'node-parseurl' is not installed, so not removed
    Package 'node-pascalcase' is not installed, so not removed
    Package 'node-passport' is not installed, so not removed
    Package 'node-path-browserify' is not installed, so not removed
    Package 'node-path-dirname' is not installed, so not removed
    Package 'node-path-exists' is not installed, so not removed
    Package 'node-path-is-absolute' is not installed, so not removed
    Package 'node-path-is-inside' is not installed, so not removed
    Package 'node-path-root' is not installed, so not removed
    Package 'node-path-root-regex' is not installed, so not removed
    Package 'node-path-to-regexp' is not installed, so not removed
    Package 'node-path-type' is not installed, so not removed
    Package 'node-pathval' is not installed, so not removed
    Package 'node-pause' is not installed, so not removed
    Package 'node-pbkdf2' is not installed, so not removed
    Package 'node-pegjs' is not installed, so not removed
    Package 'node-pend' is not installed, so not removed
    Package 'node-performance-now' is not installed, so not removed
    Package 'node-pg' is not installed, so not removed
    Package 'node-pify' is not installed, so not removed
    Package 'node-pikaday' is not installed, so not removed
    Package 'node-pinkie' is not installed, so not removed
    Package 'node-pinkie-promise' is not installed, so not removed
    Package 'node-pinkyswear' is not installed, so not removed
    Package 'node-pkg-dir' is not installed, so not removed
    Package 'node-pkg-up' is not installed, so not removed
    Package 'node-platform' is not installed, so not removed
    Package 'node-plugin-error' is not installed, so not removed
    Package 'node-plur' is not installed, so not removed
    Package 'node-po2json' is not installed, so not removed
    Package 'node-policyfile' is not installed, so not removed
    Package 'node-posix-character-classes' is not installed, so not removed
    Package 'node-posix-getopt' is not installed, so not removed
    Package 'node-postcss' is not installed, so not removed
    Package 'node-postcss-filter-plugins' is not installed, so not removed
    Package 'node-postcss-load-config' is not installed, so not removed
    Package 'node-postcss-load-options' is not installed, so not removed
    Package 'node-postcss-load-plugins' is not installed, so not removed
    Package 'node-postcss-minify-font-values' is not installed, so not removed
    Package 'node-postcss-modules-extract-imports' is not installed, so not removed
    Package 'node-postcss-modules-values' is not installed, so not removed
    Package 'node-postcss-reporter' is not installed, so not removed
    Package 'node-postcss-value-parser' is not installed, so not removed
    Package 'node-pre-gyp' is not installed, so not removed
    Package 'node-preact' is not installed, so not removed
    Package 'node-prelude-ls' is not installed, so not removed
    Package 'node-prepend-http' is not installed, so not removed
    Package 'node-preserve' is not installed, so not removed
    Package 'node-pretty-bytes' is not installed, so not removed
    Package 'node-pretty-hrtime' is not installed, so not removed
    Package 'node-pretty-ms' is not installed, so not removed
    Package 'node-prismjs' is not installed, so not removed
    Package 'node-private' is not installed, so not removed
    Package 'node-process' is not installed, so not removed
    Package 'node-process-nextick-args' is not installed, so not removed
    Package 'node-progress' is not installed, so not removed
    Package 'node-promise' is not installed, so not removed
    Package 'node-promise-inflight' is not installed, so not removed
    Package 'node-promise-retry' is not installed, so not removed
    Package 'node-promzard' is not installed, so not removed
    Package 'node-prop-types' is not installed, so not removed
    Package 'node-proper-lockfile' is not installed, so not removed
    Package 'node-prosemirror-markdown' is not installed, so not removed
    Package 'node-prosemirror-model' is not installed, so not removed
    Package 'node-proto-list' is not installed, so not removed
    Package 'node-proxy-addr' is not installed, so not removed
    Package 'node-proxy-from-env' is not installed, so not removed
    Package 'node-proxyquire' is not installed, so not removed
    Package 'node-prr' is not installed, so not removed
    Package 'node-pseudomap' is not installed, so not removed
    Package 'node-pseudorandombytes' is not installed, so not removed
    Package 'node-psl' is not installed, so not removed
    Package 'node-public-encrypt' is not installed, so not removed
    Package 'node-puka' is not installed, so not removed
    Package 'node-pump' is not installed, so not removed
    Package 'node-pumpify' is not installed, so not removed
    Package 'node-punycode' is not installed, so not removed
    Package 'node-q' is not installed, so not removed
    Package 'node-qrcode-generator' is not installed, so not removed
    Package 'node-qs' is not installed, so not removed
    Package 'node-querystring' is not installed, so not removed
    Package 'node-querystring-es3' is not installed, so not removed
    Package 'node-querystringify' is not installed, so not removed
    Package 'node-queue-async' is not installed, so not removed
    Package 'node-quick-lru' is not installed, so not removed
    Package 'node-quote-stream' is not installed, so not removed
    Package 'node-qw' is not installed, so not removed
    Package 'node-rai' is not installed, so not removed
    Package 'node-ramda' is not installed, so not removed
    Package 'node-random-bytes' is not installed, so not removed
    Package 'node-randombytes' is not installed, so not removed
    Package 'node-randomfill' is not installed, so not removed
    Package 'node-range-parser' is not installed, so not removed
    Package 'node-raven-js' is not installed, so not removed
    Package 'node-raw-body' is not installed, so not removed
    Package 'node-raw-loader' is not installed, so not removed
    Package 'node-rc' is not installed, so not removed
    Package 'node-rdf-canonize' is not installed, so not removed
    Package 'node-re2' is not installed, so not removed
    Package 'node-react' is not installed, so not removed
    Package 'node-react-audio-player' is not installed, so not removed
    Package 'node-read' is not installed, so not removed
    Package 'node-read-file' is not installed, so not removed
    Package 'node-read-only-stream' is not installed, so not removed
    Package 'node-read-package-json' is not installed, so not removed
    Package 'node-read-pkg' is not installed, so not removed
    Package 'node-read-pkg-up' is not installed, so not removed
    Package 'node-readable-stream' is not installed, so not removed
    Package 'node-readdirp' is not installed, so not removed
    Package 'node-recast' is not installed, so not removed
    Package 'node-rechoir' is not installed, so not removed
    Package 'node-redent' is not installed, so not removed
    Package 'node-redis' is not installed, so not removed
    Package 'node-redux' is not installed, so not removed
    Package 'node-regenerate' is not installed, so not removed
    Package 'node-regenerate-unicode-properties' is not installed, so not removed
    Package 'node-regenerator-runtime' is not installed, so not removed
    Package 'node-regenerator-transform' is not installed, so not removed
    Package 'node-regex-cache' is not installed, so not removed
    Package 'node-regex-not' is not installed, so not removed
    Package 'node-regexpu-core' is not installed, so not removed
    Package 'node-registry-auth-token' is not installed, so not removed
    Package 'node-registry-url' is not installed, so not removed
    Package 'node-regjsgen' is not installed, so not removed
    Package 'node-regjsparser' is not installed, so not removed
    Package 'node-reinterval' is not installed, so not removed
    Package 'node-remove-trailing-separator' is not installed, so not removed
    Package 'node-repeat-element' is not installed, so not removed
    Package 'node-repeat-string' is not installed, so not removed
    Package 'node-repeating' is not installed, so not removed
    Package 'node-replace-ext' is not installed, so not removed
    Package 'node-request' is not installed, so not removed
    Package 'node-request-capture-har' is not installed, so not removed
    Package 'node-request-promise' is not installed, so not removed
    Package 'node-request-promise-core' is not installed, so not removed
    Package 'node-require-all' is not installed, so not removed
    Package 'node-require-dir' is not installed, so not removed
    Package 'node-require-directory' is not installed, so not removed
    Package 'node-require-from-string' is not installed, so not removed
    Package 'node-require-inject' is not installed, so not removed
    Package 'node-require-main-filename' is not installed, so not removed
    Package 'node-require-relative' is not installed, so not removed
    Package 'node-requirejs' is not installed, so not removed
    Package 'node-requirejs-text' is not installed, so not removed
    Package 'node-requires-port' is not installed, so not removed
    Package 'node-reserved' is not installed, so not removed
    Package 'node-resolve' is not installed, so not removed
    Package 'node-resolve-cwd' is not installed, so not removed
    Package 'node-resolve-dir' is not installed, so not removed
    Package 'node-resolve-from' is not installed, so not removed
    Package 'node-resolve-pkg' is not installed, so not removed
    Package 'node-response-time' is not installed, so not removed
    Package 'node-restore-cursor' is not installed, so not removed
    Package 'node-resumer' is not installed, so not removed
    Package 'node-retape' is not installed, so not removed
    Package 'node-retry' is not installed, so not removed
    Package 'node-rimraf' is not installed, so not removed
    Package 'node-ripemd160' is not installed, so not removed
    Package 'node-rollup-plugin-alias' is not installed, so not removed
    Package 'node-rollup-plugin-babel' is not installed, so not removed
    Package 'node-rollup-plugin-buble' is not installed, so not removed
    Package 'node-rollup-plugin-commonjs' is not installed, so not removed
    Package 'node-rollup-plugin-json' is not installed, so not removed
    Package 'node-rollup-plugin-node-resolve' is not installed, so not removed
    Package 'node-rollup-plugin-replace' is not installed, so not removed
    Package 'node-rollup-plugin-string' is not installed, so not removed
    Package 'node-rollup-plugin-typescript' is not installed, so not removed
    Package 'node-rollup-pluginutils' is not installed, so not removed
    Package 'node-run-async' is not installed, so not removed
    Package 'node-run-queue' is not installed, so not removed
    Package 'node-rw' is not installed, so not removed
    Package 'node-rx' is not installed, so not removed
    Package 'node-safe-buffer' is not installed, so not removed
    Package 'node-samsam' is not installed, so not removed
    Package 'node-sax' is not installed, so not removed
    Package 'node-schema-utils' is not installed, so not removed
    Package 'node-schlock' is not installed, so not removed
    Package 'node-sdp-jingle-json' is not installed, so not removed
    Package 'node-security' is not installed, so not removed
    Package 'node-seedrandom' is not installed, so not removed
    Package 'node-select2' is not installed, so not removed
    Package 'node-sellside-emitter' is not installed, so not removed
    Package 'node-semver' is not installed, so not removed
    Package 'node-semver-diff' is not installed, so not removed
    Package 'node-send' is not installed, so not removed
    Package 'node-seq' is not installed, so not removed
    Package 'node-sequencify' is not installed, so not removed
    Package 'node-serve-favicon' is not installed, so not removed
    Package 'node-serve-index' is not installed, so not removed
    Package 'node-serve-static' is not installed, so not removed
    Package 'node-set-blocking' is not installed, so not removed
    Package 'node-set-getter' is not installed, so not removed
    Package 'node-set-immediate-shim' is not installed, so not removed
    Package 'node-set-value' is not installed, so not removed
    Package 'node-setimmediate' is not installed, so not removed
    Package 'node-setprototypeof' is not installed, so not removed
    Package 'node-sha' is not installed, so not removed
    Package 'node-sha.js' is not installed, so not removed
    Package 'node-shasum' is not installed, so not removed
    Package 'node-shebang-command' is not installed, so not removed
    Package 'node-shebang-regex' is not installed, so not removed
    Package 'node-shelljs' is not installed, so not removed
    Package 'node-shiny-server-client' is not installed, so not removed
    Package 'node-should' is not installed, so not removed
    Package 'node-sigmund' is not installed, so not removed
    Package 'node-signal-exit' is not installed, so not removed
    Package 'node-simple-is' is not installed, so not removed
    Package 'node-simple-swizzle' is not installed, so not removed
    Package 'node-sink-test' is not installed, so not removed
    Package 'node-sinon' is not installed, so not removed
    Package 'node-sinon-chai' is not installed, so not removed
    Package 'node-slash' is not installed, so not removed
    Package 'node-slice-ansi' is not installed, so not removed
    Package 'node-slide' is not installed, so not removed
    Package 'node-smash' is not installed, so not removed
    Package 'node-snapdragon' is not installed, so not removed
    Package 'node-snapdragon-node' is not installed, so not removed
    Package 'node-snapdragon-token' is not installed, so not removed
    Package 'node-snapdragon-util' is not installed, so not removed
    Package 'node-sntp' is not installed, so not removed
    Package 'node-socket.io-parser' is not installed, so not removed
    Package 'node-solid-keychain' is not installed, so not removed
    Package 'node-solid-rest' is not installed, so not removed
    Package 'node-sort-keys' is not installed, so not removed
    Package 'node-sorted-object' is not installed, so not removed
    Package 'node-source-list-map' is not installed, so not removed
    Package 'node-source-map' is not installed, so not removed
    Package 'node-source-map-support' is not installed, so not removed
    Package 'node-sourcemap-codec' is not installed, so not removed
    Package 'node-sparkles' is not installed, so not removed
    Package 'node-spdx-correct' is not installed, so not removed
    Package 'node-spdx-exceptions' is not installed, so not removed
    Package 'node-spdx-expression-parse' is not installed, so not removed
    Package 'node-spdx-license-ids' is not installed, so not removed
    Package 'node-sphericalmercator' is not installed, so not removed
    Package 'node-split' is not installed, so not removed
    Package 'node-split-string' is not installed, so not removed
    Package 'node-split2' is not installed, so not removed
    Package 'node-sprintf-js' is not installed, so not removed
    Package 'node-sqlite3' is not installed, so not removed
    Package 'node-srs' is not installed, so not removed
    Package 'node-sshpk' is not installed, so not removed
    Package 'node-ssri' is not installed, so not removed
    Package 'node-stable' is not installed, so not removed
    Package 'node-stack-utils' is not installed, so not removed
    Package 'node-standard-error' is not installed, so not removed
    Package 'node-standard-http-error' is not installed, so not removed
    Package 'node-starttls' is not installed, so not removed
    Package 'node-static' is not installed, so not removed
    Package 'node-static-eval' is not installed, so not removed
    Package 'node-static-extend' is not installed, so not removed
    Package 'node-static-module' is not installed, so not removed
    Package 'node-stats-webpack-plugin' is not installed, so not removed
    Package 'node-statuses' is not installed, so not removed
    Package 'node-stealthy-require' is not installed, so not removed
    Package 'node-step' is not installed, so not removed
    Package 'node-stream-array' is not installed, so not removed
    Package 'node-stream-assert' is not installed, so not removed
    Package 'node-stream-browserify' is not installed, so not removed
    Package 'node-stream-combiner2' is not installed, so not removed
    Package 'node-stream-consume' is not installed, so not removed
    Package 'node-stream-each' is not installed, so not removed
    Package 'node-stream-http' is not installed, so not removed
    Package 'node-stream-iterate' is not installed, so not removed
    Package 'node-stream-shift' is not installed, so not removed
    Package 'node-stream-splicer' is not installed, so not removed
    Package 'node-stream-to-observable' is not installed, so not removed
    Package 'node-streamtest' is not installed, so not removed
    Package 'node-strict-uri-encode' is not installed, so not removed
    Package 'node-string-decoder' is not installed, so not removed
    Package 'node-string-width' is not installed, so not removed
    Package 'node-string.prototype.codepointat' is not installed, so not removed
    Package 'node-stringmap' is not installed, so not removed
    Package 'node-stringstream' is not installed, so not removed
    Package 'node-strip-ansi' is not installed, so not removed
    Package 'node-strip-bom' is not installed, so not removed
    Package 'node-strip-bom-stream' is not installed, so not removed
    Package 'node-strip-eof' is not installed, so not removed
    Package 'node-strip-indent' is not installed, so not removed
    Package 'node-strip-json-comments' is not installed, so not removed
    Package 'node-style-loader' is not installed, so not removed
    Package 'node-stylus' is not installed, so not removed
    Package 'node-subarg' is not installed, so not removed
    Package 'node-superagent' is not installed, so not removed
    Package 'node-supertest' is not installed, so not removed
    Package 'node-supports-color' is not installed, so not removed
    Package 'node-symbol-observable' is not installed, so not removed
    Package 'node-syntax-error' is not installed, so not removed
    Package 'node-tacks' is not installed, so not removed
    Package 'node-tap' is not installed, so not removed
    Package 'node-tap-mocha-reporter' is not installed, so not removed
    Package 'node-tap-parser' is not installed, so not removed
    Package 'node-tapable' is not installed, so not removed
    Package 'node-tape' is not installed, so not removed
    Package 'node-tar' is not installed, so not removed
    Package 'node-tar-stream' is not installed, so not removed
    Package 'node-telegram-bot-api' is not installed, so not removed
    Package 'node-temp' is not installed, so not removed
    Package 'node-temporary' is not installed, so not removed
    Package 'node-term-size' is not installed, so not removed
    Package 'node-terser' is not installed, so not removed
    Package 'node-test' is not installed, so not removed
    Package 'node-text-encoding' is not installed, so not removed
    Package 'node-text-table' is not installed, so not removed
    Package 'node-thenify' is not installed, so not removed
    Package 'node-thenify-all' is not installed, so not removed
    Package 'node-three-orbit-controls' is not installed, so not removed
    Package 'node-three-stl-loader' is not installed, so not removed
    Package 'node-through' is not installed, so not removed
    Package 'node-through2' is not installed, so not removed
    Package 'node-through2-filter' is not installed, so not removed
    Package 'node-tildify' is not installed, so not removed
    Package 'node-tilejson' is not installed, so not removed
    Package 'node-tilelive' is not installed, so not removed
    Package 'node-time-stamp' is not installed, so not removed
    Package 'node-time-zone' is not installed, so not removed
    Package 'node-timeago.js' is not installed, so not removed
    Package 'node-timed-out' is not installed, so not removed
    Package 'node-timers-browserify' is not installed, so not removed
    Package 'node-tinycolor' is not installed, so not removed
    Package 'node-tippex' is not installed, so not removed
    Package 'node-tldjs' is not installed, so not removed
    Package 'node-tmatch' is not installed, so not removed
    Package 'node-tmp' is not installed, so not removed
    Package 'node-to-absolute-glob' is not installed, so not removed
    Package 'node-to-arraybuffer' is not installed, so not removed
    Package 'node-to-fast-properties' is not installed, so not removed
    Package 'node-to-object-path' is not installed, so not removed
    Package 'node-to-regex' is not installed, so not removed
    Package 'node-to-regex-range' is not installed, so not removed
    Package 'node-toidentifier' is not installed, so not removed
    Package 'node-tough-cookie' is not installed, so not removed
    Package 'node-transformers' is not installed, so not removed
    Package 'node-traverse' is not installed, so not removed
    Package 'node-trim-newlines' is not installed, so not removed
    Package 'node-trust-json-document' is not installed, so not removed
    Package 'node-trust-keyto' is not installed, so not removed
    Package 'node-trust-webcrypto' is not installed, so not removed
    Package 'node-tslib' is not installed, so not removed
    Package 'node-tty-browserify' is not installed, so not removed
    Package 'node-tunein' is not installed, so not removed
    Package 'node-tunnel-agent' is not installed, so not removed
    Package 'node-turbolinks' is not installed, so not removed
    Package 'node-tweetnacl' is not installed, so not removed
    Package 'node-type-check' is not installed, so not removed
    Package 'node-type-detect' is not installed, so not removed
    Package 'node-type-is' is not installed, so not removed
    Package 'node-typedarray' is not installed, so not removed
    Package 'node-typedarray-to-buffer' is not installed, so not removed
    Package 'node-typescript' is not installed, so not removed
    Package 'node-typescript-types' is not installed, so not removed
    Package 'node-ua-parser-js' is not installed, so not removed
    Package 'node-uglify' is not installed, so not removed
    Package 'node-uglify-js' is not installed, so not removed
    Package 'node-uglify-save-license' is not installed, so not removed
    Package 'node-uglifyjs-webpack-plugin' is not installed, so not removed
    Package 'node-uid-number' is not installed, so not removed
    Package 'node-uid-safe' is not installed, so not removed
    Package 'node-ultron' is not installed, so not removed
    Package 'node-umd' is not installed, so not removed
    Package 'node-unbzip2-stream' is not installed, so not removed
    Package 'node-unc-path-regex' is not installed, so not removed
    Package 'node-underscore' is not installed, so not removed
    Package 'node-underscore.string' is not installed, so not removed
    Package 'node-unicode-13.0.0' is not installed, so not removed
    Package 'node-unicode-canonical-property-names-ecmascript' is not installed, so not removed
    Package 'node-unicode-loose-match' is not installed, so not removed
    Package 'node-unicode-match-property-ecmascript' is not installed, so not removed
    Package 'node-unicode-match-property-value-ecmascript' is not installed, so not removed
    Package 'node-unicode-property-aliases' is not installed, so not removed
    Package 'node-unicode-property-aliases-ecmascript' is not installed, so not removed
    Package 'node-unicode-property-value-aliases' is not installed, so not removed
    Package 'node-unicode-property-value-aliases-ecmascript' is not installed, so not removed
    Package 'node-union-value' is not installed, so not removed
    Package 'node-uniq' is not installed, so not removed
    Package 'node-uniqid' is not installed, so not removed
    Package 'node-uniqs' is not installed, so not removed
    Package 'node-unique-filename' is not installed, so not removed
    Package 'node-unique-stream' is not installed, so not removed
    Package 'node-unique-string' is not installed, so not removed
    Package 'node-universalify' is not installed, so not removed
    Package 'node-unorm' is not installed, so not removed
    Package 'node-unpipe' is not installed, so not removed
    Package 'node-unset-value' is not installed, so not removed
    Package 'node-uri-js' is not installed, so not removed
    Package 'node-uri-path' is not installed, so not removed
    Package 'node-url' is not installed, so not removed
    Package 'node-url-join' is not installed, so not removed
    Package 'node-url-loader' is not installed, so not removed
    Package 'node-url-parse' is not installed, so not removed
    Package 'node-url-parse-lax' is not installed, so not removed
    Package 'node-url-to-options' is not installed, so not removed
    Package 'node-urlgrey' is not installed, so not removed
    Package 'node-use' is not installed, so not removed
    Package 'node-util' is not installed, so not removed
    Package 'node-util-deprecate' is not installed, so not removed
    Package 'node-utilities' is not installed, so not removed
    Package 'node-utils-merge' is not installed, so not removed
    Package 'node-utml' is not installed, so not removed
    Package 'node-uuid' is not installed, so not removed
    Package 'node-v8flags' is not installed, so not removed
    Package 'node-vali-date' is not installed, so not removed
    Package 'node-validate-npm-package-license' is not installed, so not removed
    Package 'node-validate-npm-package-name' is not installed, so not removed
    Package 'node-vary' is not installed, so not removed
    Package 'node-vasync' is not installed, so not removed
    Package 'node-verror' is not installed, so not removed
    Package 'node-vhost' is not installed, so not removed
    Package 'node-vinyl' is not installed, so not removed
    Package 'node-vinyl-fs' is not installed, so not removed
    Package 'node-vinyl-sourcemaps-apply' is not installed, so not removed
    Package 'node-vlq' is not installed, so not removed
    Package 'node-vm-browserify' is not installed, so not removed
    Package 'node-vows' is not installed, so not removed
    Package 'node-vue' is not installed, so not removed
    Package 'node-vue-hot-reload-api' is not installed, so not removed
    Package 'node-vue-resource' is not installed, so not removed
    Package 'node-vue-style-loader' is not installed, so not removed
    Package 'node-watchpack' is not installed, so not removed
    Package 'node-wcwidth.js' is not installed, so not removed
    Package 'node-webassemblyjs' is not installed, so not removed
    Package 'node-webfinger' is not installed, so not removed
    Package 'node-webidl-conversions' is not installed, so not removed
    Package 'node-webpack-merge' is not installed, so not removed
    Package 'node-webpack-sources' is not installed, so not removed
    Package 'node-webpack-stats-plugin' is not installed, so not removed
    Package 'node-webrtc-adapter' is not installed, so not removed
    Package 'node-websocket' is not installed, so not removed
    Package 'node-websocket-driver' is not installed, so not removed
    Package 'node-websocket-stream' is not installed, so not removed
    Package 'node-when' is not installed, so not removed
    Package 'node-which' is not installed, so not removed
    Package 'node-which-module' is not installed, so not removed
    Package 'node-wide-align' is not installed, so not removed
    Package 'node-widest-line' is not installed, so not removed
    Package 'node-wildemitter' is not installed, so not removed
    Package 'node-with' is not installed, so not removed
    Package 'node-wordwrap' is not installed, so not removed
    Package 'node-worker-loader' is not installed, so not removed
    Package 'node-wrap-ansi' is not installed, so not removed
    Package 'node-wrappy' is not installed, so not removed
    Package 'node-write' is not installed, so not removed
    Package 'node-write-file-atomic' is not installed, so not removed
    Package 'node-write-file-promise' is not installed, so not removed
    Package 'node-ws' is not installed, so not removed
    Package 'node-xdg-basedir' is not installed, so not removed
    Package 'node-xml2js' is not installed, so not removed
    Package 'node-xmldom' is not installed, so not removed
    Package 'node-xmlhttprequest' is not installed, so not removed
    Package 'node-xmlhttprequest-ssl' is not installed, so not removed
    Package 'node-xoauth2' is not installed, so not removed
    Package 'node-xtend' is not installed, so not removed
    Package 'node-xterm' is not installed, so not removed
    Package 'node-xxhashjs' is not installed, so not removed
    Package 'node-y18n' is not installed, so not removed
    Package 'node-yajsml' is not installed, so not removed
    Package 'node-yallist' is not installed, so not removed
    Package 'node-yamlish' is not installed, so not removed
    Package 'node-yargs' is not installed, so not removed
    Package 'node-yargs-parser' is not installed, so not removed
    Package 'node-yauzl' is not installed, so not removed
    Package 'node-yazl' is not installed, so not removed
    Package 'node-yn' is not installed, so not removed
    Package 'node-ytdl-core' is not installed, so not removed
    Package 'node-zen-observable' is not installed, so not removed
    Package 'node-zeparser' is not installed, so not removed
    Package 'node-zipfile' is not installed, so not removed
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    ioBroker auf NUC (Celeron mit Ubuntu-Server)
    Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
    • M mrMuppet
      @Thomas-Braun
      das war zu viel für mein normales "putty-scrollback" . aber hier ist es.
      Reading package lists...
      Building dependency tree...
      Reading state information...
      Package 'node-table' is not installed, so not removed
      Package 'node-mgrs' is not installed, so not removed
      Package 'node-proj4' is not installed, so not removed
      Package 'node-rbush' is not installed, so not removed
      Package 'node-kosmtik' is not installed, so not removed
      Package 'node-openlayers' is not installed, so not removed
      Package 'node-osmium' is not installed, so not removed
      Package 'node-acorn-object-spread' is not installed, so not removed
      Package 'node-babel' is not installed, so not removed
      Package 'node-rdf-canonize-native' is not installed, so not removed
      Package 'node-nyc' is not installed, so not removed
      Package 'node-uglify-to-browserify' is not installed, so not removed
      Package 'node-jquery' is not installed, so not removed
      Package 'node-abab' is not installed, so not removed
      Package 'node-abbrev' is not installed, so not removed
      Package 'node-absolute-path' is not installed, so not removed
      Package 'node-abstract-leveldown' is not installed, so not removed
      Package 'node-accepts' is not installed, so not removed
      Package 'node-active-x-obfuscator' is not installed, so not removed
      Package 'node-address' is not installed, so not removed
      Package 'node-addressparser' is not installed, so not removed
      Package 'node-after' is not installed, so not removed
      Package 'node-ajv' is not installed, so not removed
      Package 'node-ajv-keywords' is not installed, so not removed
      Package 'node-almond' is not installed, so not removed
      Package 'node-amdefine' is not installed, so not removed
      Package 'node-ansi' is not installed, so not removed
      Package 'node-ansi-align' is not installed, so not removed
      Package 'node-ansi-color-table' is not installed, so not removed
      Package 'node-ansi-colors' is not installed, so not removed
      Package 'node-ansi-escapes' is not installed, so not removed
      Package 'node-ansi-font' is not installed, so not removed
      Package 'node-ansi-regex' is not installed, so not removed
      Package 'node-ansi-styles' is not installed, so not removed
      Package 'node-ansi-up' is not installed, so not removed
      Package 'node-ansistyles' is not installed, so not removed
      Package 'node-any-promise' is not installed, so not removed
      Package 'node-anymatch' is not installed, so not removed
      Package 'node-ap' is not installed, so not removed
      Package 'node-applause' is not installed, so not removed
      Package 'node-aproba' is not installed, so not removed
      Package 'node-archy' is not installed, so not removed
      Package 'node-are-we-there-yet' is not installed, so not removed
      Package 'node-argparse' is not installed, so not removed
      Package 'node-argv' is not installed, so not removed
      Package 'node-arr-diff' is not installed, so not removed
      Package 'node-arr-flatten' is not installed, so not removed
      Package 'node-arr-union' is not installed, so not removed
      Package 'node-array-differ' is not installed, so not removed
      Package 'node-array-equal' is not installed, so not removed
      Package 'node-array-find-index' is not installed, so not removed
      Package 'node-array-flatten' is not installed, so not removed
      Package 'node-array-from' is not installed, so not removed
      Package 'node-array-parallel' is not installed, so not removed
      Package 'node-array-series' is not installed, so not removed
      Package 'node-array-union' is not installed, so not removed
      Package 'node-array-uniq' is not installed, so not removed
      Package 'node-array-unique' is not installed, so not removed
      Package 'node-arrify' is not installed, so not removed
      Package 'node-asap' is not installed, so not removed
      Package 'node-asn1' is not installed, so not removed
      Package 'node-asn1.js' is not installed, so not removed
      Package 'node-assert' is not installed, so not removed
      Package 'node-assert-plus' is not installed, so not removed
      Package 'node-assertion-error' is not installed, so not removed
      Package 'node-assertive' is not installed, so not removed
      Package 'node-ast-types' is not installed, so not removed
      Package 'node-ast-util' is not installed, so not removed
      Package 'node-astw' is not installed, so not removed
      Package 'node-async' is not installed, so not removed
      Package 'node-async-each' is not installed, so not removed
      Package 'node-async-limiter' is not installed, so not removed
      Package 'node-async-stacktrace' is not installed, so not removed
      Package 'node-asynckit' is not installed, so not removed
      Package 'node-auth-header' is not installed, so not removed
      Package 'node-auto-bind' is not installed, so not removed
      Package 'node-autolinker' is not installed, so not removed
      Package 'node-autoprefixer' is not installed, so not removed
      Package 'node-autosize' is not installed, so not removed
      Package 'node-aws-sign2' is not installed, so not removed
      Package 'node-aws4' is not installed, so not removed
      Package 'node-axios' is not installed, so not removed
      Package 'node-babel-cli' is not installed, so not removed
      Package 'node-babel-code-frame' is not installed, so not removed
      Package 'node-babel-core' is not installed, so not removed
      Package 'node-babel-eslint' is not installed, so not removed
      Package 'node-babel-generator' is not installed, so not removed
      Package 'node-babel-helper-bindify-decorators' is not installed, so not removed
      Package 'node-babel-helper-builder-binary-assignment-operator-visitor' is not installed, so not removed
      Package 'node-babel-helper-builder-react-jsx' is not installed, so not removed
      Package 'node-babel-helper-call-delegate' is not installed, so not removed
      Package 'node-babel-helper-define-map' is not installed, so not removed
      Package 'node-babel-helper-explode-assignable-expression' is not installed, so not removed
      Package 'node-babel-helper-explode-class' is not installed, so not removed
      Package 'node-babel-helper-function-name' is not installed, so not removed
      Package 'node-babel-helper-get-function-arity' is not installed, so not removed
      Package 'node-babel-helper-hoist-variables' is not installed, so not removed
      Package 'node-babel-helper-optimise-call-expression' is not installed, so not removed
      Package 'node-babel-helper-regex' is not installed, so not removed
      Package 'node-babel-helper-remap-async-to-generator' is not installed, so not removed
      Package 'node-babel-helper-replace-supers' is not installed, so not removed
      Package 'node-babel-helpers' is not installed, so not removed
      Package 'node-babel-loader' is not installed, so not removed
      Package 'node-babel-messages' is not installed, so not removed
      Package 'node-babel-plugin-add-module-exports' is not installed, so not removed
      Package 'node-babel-plugin-array-includes' is not installed, so not removed
      Package 'node-babel-plugin-external-helpers' is not installed, so not removed
      Package 'node-babel-plugin-syntax-async-functions' is not installed, so not removed
      Package 'node-babel-plugin-syntax-async-generators' is not installed, so not removed
      Package 'node-babel-plugin-syntax-class-constructor-call' is not installed, so not removed
      Package 'node-babel-plugin-syntax-class-properties' is not installed, so not removed
      Package 'node-babel-plugin-syntax-decorators' is not installed, so not removed
      Package 'node-babel-plugin-syntax-do-expressions' is not installed, so not removed
      Package 'node-babel-plugin-syntax-dynamic-import' is not installed, so not removed
      Package 'node-babel-plugin-syntax-exponentiation-operator' is not installed, so not removed
      Package 'node-babel-plugin-syntax-export-extensions' is not installed, so not removed
      Package 'node-babel-plugin-syntax-flow' is not installed, so not removed
      Package 'node-babel-plugin-syntax-function-bind' is not installed, so not removed
      Package 'node-babel-plugin-syntax-jsx' is not installed, so not removed
      Package 'node-babel-plugin-syntax-object-rest-spread' is not installed, so not removed
      Package 'node-babel-plugin-syntax-trailing-function-commas' is not installed, so not removed
      Package 'node-babel-plugin-transform-async-generator-functions' is not installed, so not removed
      Package 'node-babel-plugin-transform-async-to-generator' is not installed, so not removed
      Package 'node-babel-plugin-transform-builtin-extend' is not installed, so not removed
      Package 'node-babel-plugin-transform-class-constructor-call' is not installed, so not removed
      Package 'node-babel-plugin-transform-class-properties' is not installed, so not removed
      Package 'node-babel-plugin-transform-decorators' is not installed, so not removed
      Package 'node-babel-plugin-transform-do-expressions' is not installed, so not removed
      Package 'node-babel-plugin-transform-es3-member-expression-literals' is not installed, so not removed
      Package 'node-babel-plugin-transform-es3-property-literals' is not installed, so not removed
      Package 'node-babel-plugin-transform-exponentiation-operator' is not installed, so not removed
      Package 'node-babel-plugin-transform-export-extensions' is not installed, so not removed
      Package 'node-babel-plugin-transform-flow-strip-types' is not installed, so not removed
      Package 'node-babel-plugin-transform-function-bind' is not installed, so not removed
      Package 'node-babel-plugin-transform-jscript' is not installed, so not removed
      Package 'node-babel-plugin-transform-object-rest-spread' is not installed, so not removed
      Package 'node-babel-plugin-transform-proto-to-assign' is not installed, so not removed
      Package 'node-babel-plugin-transform-react-display-name' is not installed, so not removed
      Package 'node-babel-plugin-transform-react-jsx' is not installed, so not removed
      Package 'node-babel-plugin-transform-react-jsx-self' is not installed, so not removed
      Package 'node-babel-plugin-transform-react-jsx-source' is not installed, so not removed
      Package 'node-babel-plugin-transform-regenerator' is not installed, so not removed
      Package 'node-babel-plugin-transform-runtime' is not installed, so not removed
      Package 'node-babel-plugin-transform-strict-mode' is not installed, so not removed
      Package 'node-babel-plugin-transform-vue-jsx' is not installed, so not removed
      Package 'node-babel-polyfill' is not installed, so not removed
      Package 'node-babel-preset-env' is not installed, so not removed
      Package 'node-babel-preset-es2015' is not installed, so not removed
      Package 'node-babel-preset-es2016' is not installed, so not removed
      Package 'node-babel-preset-es2017' is not installed, so not removed
      Package 'node-babel-preset-flow' is not installed, so not removed
      Package 'node-babel-preset-latest' is not installed, so not removed
      Package 'node-babel-preset-react' is not installed, so not removed
      Package 'node-babel-preset-stage-0' is not installed, so not removed
      Package 'node-babel-preset-stage-1' is not installed, so not removed
      Package 'node-babel-preset-stage-2' is not installed, so not removed
      Package 'node-babel-preset-stage-3' is not installed, so not removed
      Package 'node-babel-register' is not installed, so not removed
      Package 'node-babel-runtime' is not installed, so not removed
      Package 'node-babel-template' is not installed, so not removed
      Package 'node-babel-traverse' is not installed, so not removed
      Package 'node-babel-types' is not installed, so not removed
      Package 'node-babel7' is not installed, so not removed
      Package 'node-babylon' is not installed, so not removed
      Package 'node-backbone' is not installed, so not removed
      Package 'node-balanced-match' is not installed, so not removed
      Package 'node-base' is not installed, so not removed
      Package 'node-base62' is not installed, so not removed
      Package 'node-base64-js' is not installed, so not removed
      Package 'node-base64id' is not installed, so not removed
      Package 'node-base64url' is not installed, so not removed
      Package 'node-bash' is not installed, so not removed
      Package 'node-bash-match' is not installed, so not removed
      Package 'node-basic-auth' is not installed, so not removed
      Package 'node-batch' is not installed, so not removed
      Package 'node-bcrypt-pbkdf' is not installed, so not removed
      Package 'node-beeper' is not installed, so not removed
      Package 'node-big.js' is not installed, so not removed
      Package 'node-bignumber' is not installed, so not removed
      Package 'node-binary-extensions' is not installed, so not removed
      Package 'node-bindings' is not installed, so not removed
      Package 'node-bl' is not installed, so not removed
      Package 'node-blob' is not installed, so not removed
      Package 'node-block-stream' is not installed, so not removed
      Package 'node-bluebird' is not installed, so not removed
      Package 'node-bn.js' is not installed, so not removed
      Package 'node-body-parser' is not installed, so not removed
      Package 'node-boolbase' is not installed, so not removed
      Package 'node-boom' is not installed, so not removed
      Package 'node-bootstrap-sass' is not installed, so not removed
      Package 'node-boxen' is not installed, so not removed
      Package 'node-brace-expansion' is not installed, so not removed
      Package 'node-braces' is not installed, so not removed
      Package 'node-brfs' is not installed, so not removed
      Package 'node-brorand' is not installed, so not removed
      Package 'node-browser-pack' is not installed, so not removed
      Package 'node-browser-resolve' is not installed, so not removed
      Package 'node-browser-stdout' is not installed, so not removed
      Package 'node-browser-unpack' is not installed, so not removed
      Package 'node-browserify-aes' is not installed, so not removed
      Package 'node-browserify-cipher' is not installed, so not removed
      Package 'node-browserify-des' is not installed, so not removed
      Package 'node-browserify-lite' is not installed, so not removed
      Package 'node-browserify-rsa' is not installed, so not removed
      Package 'node-browserify-sign' is not installed, so not removed
      Package 'node-browserify-zlib' is not installed, so not removed
      Package 'node-browserslist' is not installed, so not removed
      Package 'node-buble' is not installed, so not removed
      Package 'node-buf-compare' is not installed, so not removed
      Package 'node-buffer' is not installed, so not removed
      Package 'node-buffer-crc32' is not installed, so not removed
      Package 'node-buffer-equal' is not installed, so not removed
      Package 'node-buffer-shims' is not installed, so not removed
      Package 'node-buffer-xor' is not installed, so not removed
      Package 'node-bufferjs' is not installed, so not removed
      Package 'node-bufferlist' is not installed, so not removed
      Package 'node-buffers' is not installed, so not removed
      Package 'node-builtin-modules' is not installed, so not removed
      Package 'node-builtin-status-codes' is not installed, so not removed
      Package 'node-builtins' is not installed, so not removed
      Package 'node-bytes' is not installed, so not removed
      Package 'node-cacache' is not installed, so not removed
      Package 'node-cache-base' is not installed, so not removed
      Package 'node-cache-loader' is not installed, so not removed
      Package 'node-cached-path-relative' is not installed, so not removed
      Package 'node-call-limit' is not installed, so not removed
      Package 'node-callback-stream' is not installed, so not removed
      Package 'node-caller' is not installed, so not removed
      Package 'node-camelcase' is not installed, so not removed
      Package 'node-camelcase-keys' is not installed, so not removed
      Package 'node-caniuse-api' is not installed, so not removed
      Package 'node-caniuse-db' is not installed, so not removed
      Package 'node-caniuse-lite' is not installed, so not removed
      Package 'node-capture-stream' is not installed, so not removed
      Package 'node-carto' is not installed, so not removed
      Package 'node-caseless' is not installed, so not removed
      Package 'node-catty' is not installed, so not removed
      Package 'node-chai-as-promised' is not installed, so not removed
      Package 'node-chainsaw' is not installed, so not removed
      Package 'node-chalk' is not installed, so not removed
      Package 'node-channels' is not installed, so not removed
      Package 'node-character-parser' is not installed, so not removed
      Package 'node-charm' is not installed, so not removed
      Package 'node-chart.js' is not installed, so not removed
      Package 'node-check-error' is not installed, so not removed
      Package 'node-chokidar' is not installed, so not removed
      Package 'node-chownr' is not installed, so not removed
      Package 'node-chrome-trace-event' is not installed, so not removed
      Package 'node-chrono' is not installed, so not removed
      Package 'node-ci-info' is not installed, so not removed
      Package 'node-cipher-base' is not installed, so not removed
      Package 'node-cjson' is not installed, so not removed
      Package 'node-clarinet' is not installed, so not removed
      Package 'node-class-utils' is not installed, so not removed
      Package 'node-clean-css' is not installed, so not removed
      Package 'node-clean-yaml-object' is not installed, so not removed
      Package 'node-cli-boxes' is not installed, so not removed
      Package 'node-cli-cursor' is not installed, so not removed
      Package 'node-cli-spinners' is not installed, so not removed
      Package 'node-cli-table' is not installed, so not removed
      Package 'node-cli-truncate' is not installed, so not removed
      Package 'node-cli-width' is not installed, so not removed
      Package 'node-client-sessions' is not installed, so not removed
      Package 'node-clipboard' is not installed, so not removed
      Package 'node-cliui' is not installed, so not removed
      Package 'node-clone' is not installed, so not removed
      Package 'node-clone-buffer' is not installed, so not removed
      Package 'node-clone-deep' is not installed, so not removed
      Package 'node-clone-stats' is not installed, so not removed
      Package 'node-cloneable-readable' is not installed, so not removed
      Package 'node-co' is not installed, so not removed
      Package 'node-coa' is not installed, so not removed
      Package 'node-code' is not installed, so not removed
      Package 'node-coffee-loader' is not installed, so not removed
      Package 'node-coffeeify' is not installed, so not removed
      Package 'node-collection-visit' is not installed, so not removed
      Package 'node-color' is not installed, so not removed
      Package 'node-color-convert' is not installed, so not removed
      Package 'node-color-name' is not installed, so not removed
      Package 'node-color-string' is not installed, so not removed
      Package 'node-colormin' is not installed, so not removed
      Package 'node-colors' is not installed, so not removed
      Package 'node-columnify' is not installed, so not removed
      Package 'node-combine-source-map' is not installed, so not removed
      Package 'node-combined-stream' is not installed, so not removed
      Package 'node-commander' is not installed, so not removed
      Package 'node-commist' is not installed, so not removed
      Package 'node-commondir' is not installed, so not removed
      Package 'node-compare-versions' is not installed, so not removed
      Package 'node-component-consoler' is not installed, so not removed
      Package 'node-component-emitter' is not installed, so not removed
      Package 'node-compressible' is not installed, so not removed
      Package 'node-compression' is not installed, so not removed
      Package 'node-compression-webpack-plugin' is not installed, so not removed
      Package 'node-concat-map' is not installed, so not removed
      Package 'node-concat-stream' is not installed, so not removed
      Package 'node-concat-with-sourcemaps' is not installed, so not removed
      Package 'node-config-chain' is not installed, so not removed
      Package 'node-configstore' is not installed, so not removed
      Package 'node-connect' is not installed, so not removed
      Package 'node-connect-timeout' is not installed, so not removed
      Package 'node-console-browserify' is not installed, so not removed
      Package 'node-console-control-strings' is not installed, so not removed
      Package 'node-console-group' is not installed, so not removed
      Package 'node-consolidate' is not installed, so not removed
      Package 'node-constantinople' is not installed, so not removed
      Package 'node-constants-browserify' is not installed, so not removed
      Package 'node-content-disposition' is not installed, so not removed
      Package 'node-content-type' is not installed, so not removed
      Package 'node-convert-source-map' is not installed, so not removed
      Package 'node-cookie' is not installed, so not removed
      Package 'node-cookie-jar' is not installed, so not removed
      Package 'node-cookie-parser' is not installed, so not removed
      Package 'node-cookie-signature' is not installed, so not removed
      Package 'node-cookiejar' is not installed, so not removed
      Package 'node-cookies' is not installed, so not removed
      Package 'node-copy-concurrently' is not installed, so not removed
      Package 'node-copy-descriptor' is not installed, so not removed
      Package 'node-copy-webpack-plugin' is not installed, so not removed
      Package 'node-core-js' is not installed, so not removed
      Package 'node-core-util-is' is not installed, so not removed
      Package 'node-cors' is not installed, so not removed
      Package 'node-cosmiconfig' is not installed, so not removed
      Package 'node-coveralls' is not installed, so not removed
      Package 'node-cpr' is not installed, so not removed
      Package 'node-crc' is not installed, so not removed
      Package 'node-crc32' is not installed, so not removed
      Package 'node-create-ecdh' is not installed, so not removed
      Package 'node-create-hash' is not installed, so not removed
      Package 'node-create-hmac' is not installed, so not removed
      Package 'node-cross-spawn' is not installed, so not removed
      Package 'node-cross-spawn-async' is not installed, so not removed
      Package 'node-cryptiles' is not installed, so not removed
      Package 'node-crypto-browserify' is not installed, so not removed
      Package 'node-crypto-cacerts' is not installed, so not removed
      Package 'node-crypto-random-string' is not installed, so not removed
      Package 'node-cson-parser' is not installed, so not removed
      Package 'node-css' is not installed, so not removed
      Package 'node-css-color-names' is not installed, so not removed
      Package 'node-css-loader' is not installed, so not removed
      Package 'node-css-select' is not installed, so not removed
      Package 'node-css-selector-tokenizer' is not installed, so not removed
      Package 'node-css-what' is not installed, so not removed
      Package 'node-cssom' is not installed, so not removed
      Package 'node-cssstyle' is not installed, so not removed
      Package 'node-csv-spectrum' is not installed, so not removed
      Package 'node-cuint' is not installed, so not removed
      Package 'node-currently-unhandled' is not installed, so not removed
      Package 'node-cyclist' is not installed, so not removed
      Package 'node-d' is not installed, so not removed
      Package 'node-d3' is not installed, so not removed
      Package 'node-d3-array' is not installed, so not removed
      Package 'node-d3-axis' is not installed, so not removed
      Package 'node-d3-brush' is not installed, so not removed
      Package 'node-d3-chord' is not installed, so not removed
      Package 'node-d3-collection' is not installed, so not removed
      Package 'node-d3-color' is not installed, so not removed
      Package 'node-d3-contour' is not installed, so not removed
      Package 'node-d3-dispatch' is not installed, so not removed
      Package 'node-d3-drag' is not installed, so not removed
      Package 'node-d3-dsv' is not installed, so not removed
      Package 'node-d3-ease' is not installed, so not removed
      Package 'node-d3-fetch' is not installed, so not removed
      Package 'node-d3-force' is not installed, so not removed
      Package 'node-d3-format' is not installed, so not removed
      Package 'node-d3-geo' is not installed, so not removed
      Package 'node-d3-hierarchy' is not installed, so not removed
      Package 'node-d3-interpolate' is not installed, so not removed
      Package 'node-d3-path' is not installed, so not removed
      Package 'node-d3-polygon' is not installed, so not removed
      Package 'node-d3-quadtree' is not installed, so not removed
      Package 'node-d3-queue' is not installed, so not removed
      Package 'node-d3-random' is not installed, so not removed
      Package 'node-d3-request' is not installed, so not removed
      Package 'node-d3-scale' is not installed, so not removed
      Package 'node-d3-scale-chromatic' is not installed, so not removed
      Package 'node-d3-selection' is not installed, so not removed
      Package 'node-d3-shape' is not installed, so not removed
      Package 'node-d3-time' is not installed, so not removed
      Package 'node-d3-time-format' is not installed, so not removed
      Package 'node-d3-timer' is not installed, so not removed
      Package 'node-d3-transition' is not installed, so not removed
      Package 'node-d3-voronoi' is not installed, so not removed
      Package 'node-d3-zoom' is not installed, so not removed
      Package 'node-daemon' is not installed, so not removed
      Package 'node-dagre-d3-renderer' is not installed, so not removed
      Package 'node-dagre-layout' is not installed, so not removed
      Package 'node-dargs' is not installed, so not removed
      Package 'node-dashdash' is not installed, so not removed
      Package 'node-databank' is not installed, so not removed
      Package 'node-date-now' is not installed, so not removed
      Package 'node-date-time' is not installed, so not removed
      Package 'node-dateformat' is not installed, so not removed
      Package 'node-de-indent' is not installed, so not removed
      Package 'node-death' is not installed, so not removed
      Package 'node-debbundle-acorn' is not installed, so not removed
      Package 'node-debbundle-es-to-primitive' is not installed, so not removed
      Package 'node-debbundle-insert-module-globals' is not installed, so not removed
      Package 'node-debug' is not installed, so not removed
      Package 'node-debug-fabulous' is not installed, so not removed
      Package 'node-decamelize' is not installed, so not removed
      Package 'node-decompress-response' is not installed, so not removed
      Package 'node-deep-eql' is not installed, so not removed
      Package 'node-deep-equal' is not installed, so not removed
      Package 'node-deep-extend' is not installed, so not removed
      Package 'node-deep-for-each' is not installed, so not removed
      Package 'node-deep-is' is not installed, so not removed
      Package 'node-defaults' is not installed, so not removed
      Package 'node-define-properties' is not installed, so not removed
      Package 'node-define-property' is not installed, so not removed
      Package 'node-defined' is not installed, so not removed
      Package 'node-deflate-js' is not installed, so not removed
      Package 'node-del' is not installed, so not removed
      Package 'node-delayed-stream' is not installed, so not removed
      Package 'node-delegates' is not installed, so not removed
      Package 'node-delve' is not installed, so not removed
      Package 'node-depd' is not installed, so not removed
      Package 'node-deprecated' is not installed, so not removed
      Package 'node-deps-sort' is not installed, so not removed
      Package 'node-dequeue' is not installed, so not removed
      Package 'node-des.js' is not installed, so not removed
      Package 'node-detect-file' is not installed, so not removed
      Package 'node-detect-indent' is not installed, so not removed
      Package 'node-detect-newline' is not installed, so not removed
      Package 'node-detective' is not installed, so not removed
      Package 'node-diacritics' is not installed, so not removed
      Package 'node-diff' is not installed, so not removed
      Package 'node-difflet' is not installed, so not removed
      Package 'node-dirty' is not installed, so not removed
      Package 'node-doctrine' is not installed, so not removed
      Package 'node-dom-serializer' is not installed, so not removed
      Package 'node-domain-browser' is not installed, so not removed
      Package 'node-domelementtype' is not installed, so not removed
      Package 'node-domhandler' is not installed, so not removed
      Package 'node-domino' is not installed, so not removed
      Package 'node-domutils' is not installed, so not removed
      Package 'node-dot' is not installed, so not removed
      Package 'node-dot-prop' is not installed, so not removed
      Package 'node-dottie' is not installed, so not removed
      Package 'node-dryice' is not installed, so not removed
      Package 'node-dtrace-provider' is not installed, so not removed
      Package 'node-duplexer' is not installed, so not removed
      Package 'node-duplexer3' is not installed, so not removed
      Package 'node-duplexify' is not installed, so not removed
      Package 'node-ebnf-parser' is not installed, so not removed
      Package 'node-ecc-jsbn' is not installed, so not removed
      Package 'node-editor' is not installed, so not removed
      Package 'node-ejs' is not installed, so not removed
      Package 'node-electron-to-chromium' is not installed, so not removed
      Package 'node-elliptic' is not installed, so not removed
      Package 'node-emoji' is not installed, so not removed
      Package 'node-emojis-list' is not installed, so not removed
      Package 'node-encodeurl' is not installed, so not removed
      Package 'node-encoding' is not installed, so not removed
      Package 'node-end-of-stream' is not installed, so not removed
      Package 'node-enhanced-resolve' is not installed, so not removed
      Package 'node-entities' is not installed, so not removed
      Package 'node-err-code' is not installed, so not removed
      Package 'node-errno' is not installed, so not removed
      Package 'node-error-ex' is not installed, so not removed
      Package 'node-errorhandler' is not installed, so not removed
      Package 'node-errs' is not installed, so not removed
      Package 'node-es5-ext' is not installed, so not removed
      Package 'node-es5-shim' is not installed, so not removed
      Package 'node-es6-error' is not installed, so not removed
      Package 'node-es6-iterator' is not installed, so not removed
      Package 'node-es6-map' is not installed, so not removed
      Package 'node-es6-promise' is not installed, so not removed
      Package 'node-es6-set' is not installed, so not removed
      Package 'node-es6-shim' is not installed, so not removed
      Package 'node-es6-symbol' is not installed, so not removed
      Package 'node-es6-weak-map' is not installed, so not removed
      Package 'node-escape-html' is not installed, so not removed
      Package 'node-escape-string-regexp' is not installed, so not removed
      Package 'node-escodegen' is not installed, so not removed
      Package 'node-escope' is not installed, so not removed
      Package 'node-eslint-plugin-eslint-plugin' is not installed, so not removed
      Package 'node-eslint-plugin-flowtype' is not installed, so not removed
      Package 'node-eslint-plugin-html' is not installed, so not removed
      Package 'node-eslint-plugin-node' is not installed, so not removed
      Package 'node-eslint-plugin-requirejs' is not installed, so not removed
      Package 'node-eslint-scope' is not installed, so not removed
      Package 'node-eslint-utils' is not installed, so not removed
      Package 'node-eslint-visitor-keys' is not installed, so not removed
      Package 'node-espree' is not installed, so not removed
      Package 'node-esprima' is not installed, so not removed
      Package 'node-esprima-fb' is not installed, so not removed
      Package 'node-esquery' is not installed, so not removed
      Package 'node-esrecurse' is not installed, so not removed
      Package 'node-estraverse' is not installed, so not removed
      Package 'node-estree-walker' is not installed, so not removed
      Package 'node-esutils' is not installed, so not removed
      Package 'node-etag' is not installed, so not removed
      Package 'node-event-emitter' is not installed, so not removed
      Package 'node-eventemitter2' is not installed, so not removed
      Package 'node-eventemitter3' is not installed, so not removed
      Package 'node-events' is not installed, so not removed
      Package 'node-eventsource' is not installed, so not removed
      Package 'node-everything.js' is not installed, so not removed
      Package 'node-evp-bytestokey' is not installed, so not removed
      Package 'node-execa' is not installed, so not removed
      Package 'node-exit' is not installed, so not removed
      Package 'node-exit-hook' is not installed, so not removed
      Package 'node-expand-brackets' is not installed, so not removed
      Package 'node-expand-tilde' is not installed, so not removed
      Package 'node-expect.js' is not installed, so not removed
      Package 'node-exports-loader' is not installed, so not removed
      Package 'node-express' is not installed, so not removed
      Package 'node-express-generator' is not installed, so not removed
      Package 'node-extend' is not installed, so not removed
      Package 'node-extend-shallow' is not installed, so not removed
      Package 'node-external-editor' is not installed, so not removed
      Package 'node-extglob' is not installed, so not removed
      Package 'node-extract-text-webpack-plugin' is not installed, so not removed
      Package 'node-extract-zip' is not installed, so not removed
      Package 'node-extsprintf' is not installed, so not removed
      Package 'node-eyes' is not installed, so not removed
      Package 'node-falafel' is not installed, so not removed
      Package 'node-fancy-log' is not installed, so not removed
      Package 'node-fast-deep-equal' is not installed, so not removed
      Package 'node-fast-levenshtein' is not installed, so not removed
      Package 'node-fastcgi' is not installed, so not removed
      Package 'node-fastcgi-stream' is not installed, so not removed
      Package 'node-faye-websocket' is not installed, so not removed
      Package 'node-fbjs' is not installed, so not removed
      Package 'node-fd-slicer' is not installed, so not removed
      Package 'node-fetch' is not installed, so not removed
      Package 'node-file-entry-cache' is not installed, so not removed
      Package 'node-file-loader' is not installed, so not removed
      Package 'node-file-sync-cmp' is not installed, so not removed
      Package 'node-filename-regex' is not installed, so not removed
      Package 'node-filesize' is not installed, so not removed
      Package 'node-fill-range' is not installed, so not removed
      Package 'node-finalhandler' is not installed, so not removed
      Package 'node-find-cache-dir' is not installed, so not removed
      Package 'node-find-up' is not installed, so not removed
      Package 'node-findit2' is not installed, so not removed
      Package 'node-findup-sync' is not installed, so not removed
      Package 'node-fined' is not installed, so not removed
      Package 'node-first-chunk-stream' is not installed, so not removed
      Package 'node-flagged-respawn' is not installed, so not removed
      Package 'node-flat-cache' is not installed, so not removed
      Package 'node-flatted' is not installed, so not removed
      Package 'node-flow-remove-types' is not installed, so not removed
      Package 'node-flush-write-stream' is not installed, so not removed
      Package 'node-fn-name' is not installed, so not removed
      Package 'node-follow-redirects' is not installed, so not removed
      Package 'node-for-in' is not installed, so not removed
      Package 'node-for-own' is not installed, so not removed
      Package 'node-foreground-child' is not installed, so not removed
      Package 'node-forever-agent' is not installed, so not removed
      Package 'node-form-data' is not installed, so not removed
      Package 'node-formatio' is not installed, so not removed
      Package 'node-formidable' is not installed, so not removed
      Package 'node-fragment-cache' is not installed, so not removed
      Package 'node-fresh' is not installed, so not removed
      Package 'node-from2' is not installed, so not removed
      Package 'node-fs-exists-sync' is not installed, so not removed
      Package 'node-fs-extra' is not installed, so not removed
      Package 'node-fs-readdir-recursive' is not installed, so not removed
      Package 'node-fs-vacuum' is not installed, so not removed
      Package 'node-fs-write-stream-atomic' is not installed, so not removed
      Package 'node-fs.realpath' is not installed, so not removed
      Package 'node-fstream' is not installed, so not removed
      Package 'node-fstream-ignore' is not installed, so not removed
      Package 'node-function-bind' is not installed, so not removed
      Package 'node-functional-red-black-tree' is not installed, so not removed
      Package 'node-fuzzaldrin-plus' is not installed, so not removed
      Package 'node-fuzzysort' is not installed, so not removed
      Package 'node-gauge' is not installed, so not removed
      Package 'node-generator-supported' is not installed, so not removed
      Package 'node-generic-pool' is not installed, so not removed
      Package 'node-genfun' is not installed, so not removed
      Package 'node-geographiclib' is not installed, so not removed
      Package 'node-get' is not installed, so not removed
      Package 'node-get-caller-file' is not installed, so not removed
      Package 'node-get-func-name' is not installed, so not removed
      Package 'node-get-stdin' is not installed, so not removed
      Package 'node-get-stream' is not installed, so not removed
      Package 'node-get-value' is not installed, so not removed
      Package 'node-getobject' is not installed, so not removed
      Package 'node-getpass' is not installed, so not removed
      Package 'node-gettext-parser' is not installed, so not removed
      Package 'node-gettext.js' is not installed, so not removed
      Package 'node-github-url-from-git' is not installed, so not removed
      Package 'node-glob' is not installed, so not removed
      Package 'node-glob-base' is not installed, so not removed
      Package 'node-glob-parent' is not installed, so not removed
      Package 'node-glob-stream' is not installed, so not removed
      Package 'node-global-modules' is not installed, so not removed
      Package 'node-global-prefix' is not installed, so not removed
      Package 'node-globals' is not installed, so not removed
      Package 'node-globby' is not installed, so not removed
      Package 'node-globule' is not installed, so not removed
      Package 'node-glogg' is not installed, so not removed
      Package 'node-googlediff' is not installed, so not removed
      Package 'node-got' is not installed, so not removed
      Package 'node-graceful-fs' is not installed, so not removed
      Package 'node-graphlibrary' is not installed, so not removed
      Package 'node-growl' is not installed, so not removed
      Package 'node-grunt-babel' is not installed, so not removed
      Package 'node-grunt-cli' is not installed, so not removed
      Package 'node-grunt-contrib-clean' is not installed, so not removed
      Package 'node-grunt-contrib-coffee' is not installed, so not removed
      Package 'node-grunt-contrib-concat' is not installed, so not removed
      Package 'node-grunt-contrib-copy' is not installed, so not removed
      Package 'node-grunt-contrib-internal' is not installed, so not removed
      Package 'node-grunt-contrib-nodeunit' is not installed, so not removed
      Package 'node-grunt-contrib-requirejs' is not installed, so not removed
      Package 'node-grunt-contrib-uglify' is not installed, so not removed
      Package 'node-grunt-known-options' is not installed, so not removed
      Package 'node-grunt-legacy-log' is not installed, so not removed
      Package 'node-grunt-legacy-log-utils' is not installed, so not removed
      Package 'node-grunt-legacy-util' is not installed, so not removed
      Package 'node-grunt-replace' is not installed, so not removed
      Package 'node-grunt-sass' is not installed, so not removed
      Package 'node-grunt-webpack' is not installed, so not removed
      Package 'node-gulp-babel' is not installed, so not removed
      Package 'node-gulp-changed' is not installed, so not removed
      Package 'node-gulp-coffee' is not installed, so not removed
      Package 'node-gulp-concat' is not installed, so not removed
      Package 'node-gulp-flatten' is not installed, so not removed
      Package 'node-gulp-load-plugins' is not installed, so not removed
      Package 'node-gulp-newer' is not installed, so not removed
      Package 'node-gulp-plumber' is not installed, so not removed
      Package 'node-gulp-rename' is not installed, so not removed
      Package 'node-gulp-sourcemaps' is not installed, so not removed
      Package 'node-gulp-util' is not installed, so not removed
      Package 'node-gulplog' is not installed, so not removed
      Package 'node-gyp' is not installed, so not removed
      Package 'node-gzip-size' is not installed, so not removed
      Package 'node-har-schema' is not installed, so not removed
      Package 'node-har-validator' is not installed, so not removed
      Package 'node-has-ansi' is not installed, so not removed
      Package 'node-has-binary' is not installed, so not removed
      Package 'node-has-cors' is not installed, so not removed
      Package 'node-has-flag' is not installed, so not removed
      Package 'node-has-gulplog' is not installed, so not removed
      Package 'node-has-symbol-support-x' is not installed, so not removed
      Package 'node-has-to-string-tag-x' is not installed, so not removed
      Package 'node-has-unicode' is not installed, so not removed
      Package 'node-has-value' is not installed, so not removed
      Package 'node-has-values' is not installed, so not removed
      Package 'node-hash-base' is not installed, so not removed
      Package 'node-hash-sum' is not installed, so not removed
      Package 'node-hash-test-vectors' is not installed, so not removed
      Package 'node-hash.js' is not installed, so not removed
      Package 'node-hashish' is not installed, so not removed
      Package 'node-hawk' is not installed, so not removed
      Package 'node-he' is not installed, so not removed
      Package 'node-help-me' is not installed, so not removed
      Package 'node-highlight' is not installed, so not removed
      Package 'node-highlight.js' is not installed, so not removed
      Package 'node-hmac-drbg' is not installed, so not removed
      Package 'node-hoek' is not installed, so not removed
      Package 'node-hook-std' is not installed, so not removed
      Package 'node-hooker' is not installed, so not removed
      Package 'node-hosted-git-info' is not installed, so not removed
      Package 'node-html-comment-regex' is not installed, so not removed
      Package 'node-html5shiv' is not installed, so not removed
      Package 'node-htmlescape' is not installed, so not removed
      Package 'node-htmlparser' is not installed, so not removed
      Package 'node-htmlparser2' is not installed, so not removed
      Package 'node-http-errors' is not installed, so not removed
      Package 'node-http-signature' is not installed, so not removed
      Package 'node-https-browserify' is not installed, so not removed
      Package 'node-i18next' is not installed, so not removed
      Package 'node-i18next-browser-languagedetector' is not installed, so not removed
      Package 'node-i18next-xhr-backend' is not installed, so not removed
      Package 'node-iconv' is not installed, so not removed
      Package 'node-iconv-lite' is not installed, so not removed
      Package 'node-icss-replace-symbols' is not installed, so not removed
      Package 'node-icss-utils' is not installed, so not removed
      Package 'node-ieee754' is not installed, so not removed
      Package 'node-iferr' is not installed, so not removed
      Package 'node-ignore' is not installed, so not removed
      Package 'node-ignore-by-default' is not installed, so not removed
      Package 'node-imagemagick' is not installed, so not removed
      Package 'node-immediate' is not installed, so not removed
      Package 'node-immutable' is not installed, so not removed
      Package 'node-immutable-tuple' is not installed, so not removed
      Package 'node-import-lazy' is not installed, so not removed
      Package 'node-imports-loader' is not installed, so not removed
      Package 'node-imurmurhash' is not installed, so not removed
      Package 'node-indent-string' is not installed, so not removed
      Package 'node-inflection' is not installed, so not removed
      Package 'node-inflight' is not installed, so not removed
      Package 'node-inherits' is not installed, so not removed
      Package 'node-ini' is not installed, so not removed
      Package 'node-inline-source-map' is not installed, so not removed
      Package 'node-inquirer' is not installed, so not removed
      Package 'node-interpret' is not installed, so not removed
      Package 'node-invariant' is not installed, so not removed
      Package 'node-invert-kv' is not installed, so not removed
      Package 'node-ip' is not installed, so not removed
      Package 'node-ip-address' is not installed, so not removed
      Package 'node-ip-regex' is not installed, so not removed
      Package 'node-ipaddr.js' is not installed, so not removed
      Package 'node-irregular-plurals' is not installed, so not removed
      Package 'node-is-accessor-descriptor' is not installed, so not removed
      Package 'node-is-arrayish' is not installed, so not removed
      Package 'node-is-binary-path' is not installed, so not removed
      Package 'node-is-buffer' is not installed, so not removed
      Package 'node-is-builtin-module' is not installed, so not removed
      Package 'node-is-data-descriptor' is not installed, so not removed
      Package 'node-is-descriptor' is not installed, so not removed
      Package 'node-is-directory' is not installed, so not removed
      Package 'node-is-dotfile' is not installed, so not removed
      Package 'node-is-equal-shallow' is not installed, so not removed
      Package 'node-is-extendable' is not installed, so not removed
      Package 'node-is-extglob' is not installed, so not removed
      Package 'node-is-generator-fn' is not installed, so not removed
      Package 'node-is-glob' is not installed, so not removed
      Package 'node-is-module' is not installed, so not removed
      Package 'node-is-negated-glob' is not installed, so not removed
      Package 'node-is-npm' is not installed, so not removed
      Package 'node-is-number' is not installed, so not removed
      Package 'node-is-obj' is not installed, so not removed
      Package 'node-is-object' is not installed, so not removed
      Package 'node-is-path-cwd' is not installed, so not removed
      Package 'node-is-path-in-cwd' is not installed, so not removed
      Package 'node-is-path-inside' is not installed, so not removed
      Package 'node-is-plain-obj' is not installed, so not removed
      Package 'node-is-plain-object' is not installed, so not removed
      Package 'node-is-primitive' is not installed, so not removed
      Package 'node-is-promise' is not installed, so not removed
      Package 'node-is-reference' is not installed, so not removed
      Package 'node-is-retry-allowed' is not installed, so not removed
      Package 'node-is-stream' is not installed, so not removed
      Package 'node-is-typedarray' is not installed, so not removed
      Package 'node-is-unc-path' is not installed, so not removed
      Package 'node-is-valid-glob' is not installed, so not removed
      Package 'node-is-windows' is not installed, so not removed
      Package 'node-isarray' is not installed, so not removed
      Package 'node-iscroll' is not installed, so not removed
      Package 'node-isexe' is not installed, so not removed
      Package 'node-isobject' is not installed, so not removed
      Package 'node-isomorphic-fetch' is not installed, so not removed
      Package 'node-isstream' is not installed, so not removed
      Package 'node-istanbul' is not installed, so not removed
      Package 'node-isurl' is not installed, so not removed
      Package 'node-jade' is not installed, so not removed
      Package 'node-jake' is not installed, so not removed
      Package 'node-jed' is not installed, so not removed
      Package 'node-jison-lex' is not installed, so not removed
      Package 'node-jju' is not installed, so not removed
      Package 'node-jquery-mousewheel' is not installed, so not removed
      Package 'node-jquery-textcomplete' is not installed, so not removed
      Package 'node-jquery-ui' is not installed, so not removed
      Package 'node-jquery-ujs' is not installed, so not removed
      Package 'node-jquery.waitforimages' is not installed, so not removed
      Package 'node-js-beautify' is not installed, so not removed
      Package 'node-js-cookie' is not installed, so not removed
      Package 'node-js-tokens' is not installed, so not removed
      Package 'node-js-yaml' is not installed, so not removed
      Package 'node-jsbn' is not installed, so not removed
      Package 'node-jschardet' is not installed, so not removed
      Package 'node-jsdom' is not installed, so not removed
      Package 'node-jsesc' is not installed, so not removed
      Package 'node-json-buffer' is not installed, so not removed
      Package 'node-json-loader' is not installed, so not removed
      Package 'node-json-localizer' is not installed, so not removed
      Package 'node-json-parse-better-errors' is not installed, so not removed
      Package 'node-json-parse-helpfulerror' is not installed, so not removed
      Package 'node-json-schema' is not installed, so not removed
      Package 'node-json-schema-traverse' is not installed, so not removed
      Package 'node-json-stable-stringify' is not installed, so not removed
      Package 'node-json-stringify-safe' is not installed, so not removed
      Package 'node-json2module' is not installed, so not removed
      Package 'node-json5' is not installed, so not removed
      Package 'node-jsonfile' is not installed, so not removed
      Package 'node-jsonify' is not installed, so not removed
      Package 'node-jsonld' is not installed, so not removed
      Package 'node-jsonminify' is not installed, so not removed
      Package 'node-jsonparse' is not installed, so not removed
      Package 'node-jsonselect' is not installed, so not removed
      Package 'node-jsonstream' is not installed, so not removed
      Package 'node-jsprim' is not installed, so not removed
      Package 'node-jstimezonedetect' is not installed, so not removed
      Package 'node-jsv' is not installed, so not removed
      Package 'node-jszip' is not installed, so not removed
      Package 'node-jszip-utils' is not installed, so not removed
      Package 'node-katex' is not installed, so not removed
      Package 'node-keese' is not installed, so not removed
      Package 'node-kew' is not installed, so not removed
      Package 'node-keygrip' is not installed, so not removed
      Package 'node-keypress' is not installed, so not removed
      Package 'node-kind-of' is not installed, so not removed
      Package 'node-klaw' is not installed, so not removed
      Package 'node-knockout' is not installed, so not removed
      Package 'node-knockout-sortable' is not installed, so not removed
      Package 'node-knockout-transformations' is not installed, so not removed
      Package 'node-labeled-stream-splicer' is not installed, so not removed
      Package 'node-lastfm' is not installed, so not removed
      Package 'node-latest-version' is not installed, so not removed
      Package 'node-lazy-cache' is not installed, so not removed
      Package 'node-lazy-debug-legacy' is not installed, so not removed
      Package 'node-lazy-property' is not installed, so not removed
      Package 'node-lazystream' is not installed, so not removed
      Package 'node-lcid' is not installed, so not removed
      Package 'node-lcov-parse' is not installed, so not removed
      Package 'node-leaflet' is not installed, so not removed
      Package 'node-leaflet-formbuilder' is not installed, so not removed
      Package 'node-leaflet-hash' is not installed, so not removed
      Package 'node-leaflet-image' is not installed, so not removed
      Package 'node-leaflet.markercluster' is not installed, so not removed
      Package 'node-leche' is not installed, so not removed
      Package 'node-less' is not installed, so not removed
      Package 'node-less-loader' is not installed, so not removed
      Package 'node-leveldown' is not installed, so not removed
      Package 'node-leven' is not installed, so not removed
      Package 'node-levn' is not installed, so not removed
      Package 'node-lex-parser' is not installed, so not removed
      Package 'node-lexical-scope' is not installed, so not removed
      Package 'node-libnpx' is not installed, so not removed
      Package 'node-libravatar' is not installed, so not removed
      Package 'node-libs-browser' is not installed, so not removed
      Package 'node-lie' is not installed, so not removed
      Package 'node-liftoff' is not installed, so not removed
      Package 'node-lightgallery' is not installed, so not removed
      Package 'node-load-grunt-tasks' is not installed, so not removed
      Package 'node-load-json-file' is not installed, so not removed
      Package 'node-loader-runner' is not installed, so not removed
      Package 'node-loader-utils' is not installed, so not removed
      Package 'node-locate-character' is not installed, so not removed
      Package 'node-locate-path' is not installed, so not removed
      Package 'node-lockfile' is not installed, so not removed
      Package 'node-lodash' is not installed, so not removed
      Package 'node-lodash-compat' is not installed, so not removed
      Package 'node-lodash-packages' is not installed, so not removed
      Package 'node-lodash-reescape' is not installed, so not removed
      Package 'node-lodash-reevaluate' is not installed, so not removed
      Package 'node-log-driver' is not installed, so not removed
      Package 'node-log4js' is not installed, so not removed
      Package 'node-lolex' is not installed, so not removed
      Package 'node-loose-envify' is not installed, so not removed
      Package 'node-loud-rejection' is not installed, so not removed
      Package 'node-lowercase-keys' is not installed, so not removed
      Package 'node-lru-cache' is not installed, so not removed
      Package 'node-ltx' is not installed, so not removed
      Package 'node-lunr' is not installed, so not removed
      Package 'node-macaddress' is not installed, so not removed
      Package 'node-magic-string' is not installed, so not removed
      Package 'node-make-dir' is not installed, so not removed
      Package 'node-map-cache' is not installed, so not removed
      Package 'node-map-obj' is not installed, so not removed
      Package 'node-map-visit' is not installed, so not removed
      Package 'node-markdown-it' is not installed, so not removed
      Package 'node-marked' is not installed, so not removed
      Package 'node-marked-man' is not installed, so not removed
      Package 'node-match-at' is not installed, so not removed
      Package 'node-matcher' is not installed, so not removed
      Package 'node-matrix-js-sdk' is not installed, so not removed
      Package 'node-mbtiles' is not installed, so not removed
      Package 'node-md5-hex' is not installed, so not removed
      Package 'node-md5-o-matic' is not installed, so not removed
      Package 'node-md5.js' is not installed, so not removed
      Package 'node-mdn-data' is not installed, so not removed
      Package 'node-media-typer' is not installed, so not removed
      Package 'node-mem' is not installed, so not removed
      Package 'node-memory-fs' is not installed, so not removed
      Package 'node-meow' is not installed, so not removed
      Package 'node-merge' is not installed, so not removed
      Package 'node-merge-descriptors' is not installed, so not removed
      Package 'node-merge-stream' is not installed, so not removed
      Package 'node-mess' is not installed, so not removed
      Package 'node-methods' is not installed, so not removed
      Package 'node-micromatch' is not installed, so not removed
      Package 'node-miller-rabin' is not installed, so not removed
      Package 'node-millstone' is not installed, so not removed
      Package 'node-mime' is not installed, so not removed
      Package 'node-mime-types' is not installed, so not removed
      Package 'node-mimic-fn' is not installed, so not removed
      Package 'node-mimic-response' is not installed, so not removed
      Package 'node-minimalistic-crypto-utils' is not installed, so not removed
      Package 'node-minimatch' is not installed, so not removed
      Package 'node-minimist' is not installed, so not removed
      Package 'node-mississippi' is not installed, so not removed
      Package 'node-mithril' is not installed, so not removed
      Package 'node-mixin-deep' is not installed, so not removed
      Package 'node-mkdirp' is not installed, so not removed
      Package 'node-mocha-lcov-reporter' is not installed, so not removed
      Package 'node-mock-fs' is not installed, so not removed
      Package 'node-mocks-http' is not installed, so not removed
      Package 'node-modern-syslog' is not installed, so not removed
      Package 'node-modify-babel-preset' is not installed, so not removed
      Package 'node-module-deps' is not installed, so not removed
      Package 'node-moment' is not installed, so not removed
      Package 'node-moment-timezone' is not installed, so not removed
      Package 'node-mongodb' is not installed, so not removed
      Package 'node-monocle' is not installed, so not removed
      Package 'node-mousetrap' is not installed, so not removed
      Package 'node-move-concurrently' is not installed, so not removed
      Package 'node-mqtt' is not installed, so not removed
      Package 'node-mqtt-connection' is not installed, so not removed
      Package 'node-mqtt-packet' is not installed, so not removed
      Package 'node-ms' is not installed, so not removed
      Package 'node-multimatch' is not installed, so not removed
      Package 'node-multiparty' is not installed, so not removed
      Package 'node-multipipe' is not installed, so not removed
      Package 'node-music-library-index' is not installed, so not removed
      Package 'node-mustache' is not installed, so not removed
      Package 'node-mutate-fs' is not installed, so not removed
      Package 'node-mute-stream' is not installed, so not removed
      Package 'node-mysql' is not installed, so not removed
      Package 'node-mz' is not installed, so not removed
      Package 'node-n3' is not installed, so not removed
      Package 'node-nan' is not installed, so not removed
      Package 'node-ncp' is not installed, so not removed
      Package 'node-negotiator' is not installed, so not removed
      Package 'node-neo-async' is not installed, so not removed
      Package 'node-node-dir' is not installed, so not removed
      Package 'node-node-expat' is not installed, so not removed
      Package 'node-node-forge' is not installed, so not removed
      Package 'node-node-localstorage' is not installed, so not removed
      Package 'node-node-rest-client' is not installed, so not removed
      Package 'node-node-rsa' is not installed, so not removed
      Package 'node-node-sass' is not installed, so not removed
      Package 'node-node-stringprep' is not installed, so not removed
      Package 'node-node-uuid' is not installed, so not removed
      Package 'node-nodedbi' is not installed, so not removed
      Package 'node-nodemailer' is not installed, so not removed
      Package 'node-nomnom' is not installed, so not removed
      Package 'node-nopt' is not installed, so not removed
      Package 'node-normalize-git-url' is not installed, so not removed
      Package 'node-normalize-package-data' is not installed, so not removed
      Package 'node-normalize-path' is not installed, so not removed
      Package 'node-normalize-range' is not installed, so not removed
      Package 'node-normalize.css' is not installed, so not removed
      Package 'node-npm-bundled' is not installed, so not removed
      Package 'node-npm-package-arg' is not installed, so not removed
      Package 'node-npm-run-path' is not installed, so not removed
      Package 'node-npmlog' is not installed, so not removed
      Package 'node-npmrc' is not installed, so not removed
      Package 'node-nth-check' is not installed, so not removed
      Package 'node-number-is-nan' is not installed, so not removed
      Package 'node-nwmatcher' is not installed, so not removed
      Package 'node-oauth-sign' is not installed, so not removed
      Package 'node-obj-util' is not installed, so not removed
      Package 'node-object-assign' is not installed, so not removed
      Package 'node-object-copy' is not installed, so not removed
      Package 'node-object-inspect' is not installed, so not removed
      Package 'node-object-key' is not installed, so not removed
      Package 'node-object-path' is not installed, so not removed
      Package 'node-object-visit' is not installed, so not removed
      Package 'node-object.omit' is not installed, so not removed
      Package 'node-on-finished' is not installed, so not removed
      Package 'node-on-headers' is not installed, so not removed
      Package 'node-once' is not installed, so not removed
      Package 'node-opencv' is not installed, so not removed
      Package 'node-opener' is not installed, so not removed
      Package 'node-openid' is not installed, so not removed
      Package 'node-opentip' is not installed, so not removed
      Package 'node-optimist' is not installed, so not removed
      Package 'node-optionator' is not installed, so not removed
      Package 'node-orchestrator' is not installed, so not removed
      Package 'node-ordered-read-streams' is not installed, so not removed
      Package 'node-original' is not installed, so not removed
      Package 'node-os-browserify' is not installed, so not removed
      Package 'node-os-locale' is not installed, so not removed
      Package 'node-os-tmpdir' is not installed, so not removed
      Package 'node-osenv' is not installed, so not removed
      Package 'node-output-file-sync' is not installed, so not removed
      Package 'node-p-cancelable' is not installed, so not removed
      Package 'node-p-finally' is not installed, so not removed
      Package 'node-p-is-promise' is not installed, so not removed
      Package 'node-p-limit' is not installed, so not removed
      Package 'node-p-locate' is not installed, so not removed
      Package 'node-p-map' is not installed, so not removed
      Package 'node-p-timeout' is not installed, so not removed
      Package 'node-package' is not installed, so not removed
      Package 'node-package-json' is not installed, so not removed
      Package 'node-package-preamble' is not installed, so not removed
      Package 'node-pako' is not installed, so not removed
      Package 'node-parallel-transform' is not installed, so not removed
      Package 'node-parents' is not installed, so not removed
      Package 'node-parse-asn1' is not installed, so not removed
      Package 'node-parse-base64vlq-mappings' is not installed, so not removed
      Package 'node-parse-filepath' is not installed, so not removed
      Package 'node-parse-glob' is not installed, so not removed
      Package 'node-parse-json' is not installed, so not removed
      Package 'node-parse-ms' is not installed, so not removed
      Package 'node-parseurl' is not installed, so not removed
      Package 'node-pascalcase' is not installed, so not removed
      Package 'node-passport' is not installed, so not removed
      Package 'node-path-browserify' is not installed, so not removed
      Package 'node-path-dirname' is not installed, so not removed
      Package 'node-path-exists' is not installed, so not removed
      Package 'node-path-is-absolute' is not installed, so not removed
      Package 'node-path-is-inside' is not installed, so not removed
      Package 'node-path-root' is not installed, so not removed
      Package 'node-path-root-regex' is not installed, so not removed
      Package 'node-path-to-regexp' is not installed, so not removed
      Package 'node-path-type' is not installed, so not removed
      Package 'node-pathval' is not installed, so not removed
      Package 'node-pause' is not installed, so not removed
      Package 'node-pbkdf2' is not installed, so not removed
      Package 'node-pegjs' is not installed, so not removed
      Package 'node-pend' is not installed, so not removed
      Package 'node-performance-now' is not installed, so not removed
      Package 'node-pg' is not installed, so not removed
      Package 'node-pify' is not installed, so not removed
      Package 'node-pikaday' is not installed, so not removed
      Package 'node-pinkie' is not installed, so not removed
      Package 'node-pinkie-promise' is not installed, so not removed
      Package 'node-pinkyswear' is not installed, so not removed
      Package 'node-pkg-dir' is not installed, so not removed
      Package 'node-pkg-up' is not installed, so not removed
      Package 'node-platform' is not installed, so not removed
      Package 'node-plugin-error' is not installed, so not removed
      Package 'node-plur' is not installed, so not removed
      Package 'node-po2json' is not installed, so not removed
      Package 'node-policyfile' is not installed, so not removed
      Package 'node-posix-character-classes' is not installed, so not removed
      Package 'node-posix-getopt' is not installed, so not removed
      Package 'node-postcss' is not installed, so not removed
      Package 'node-postcss-filter-plugins' is not installed, so not removed
      Package 'node-postcss-load-config' is not installed, so not removed
      Package 'node-postcss-load-options' is not installed, so not removed
      Package 'node-postcss-load-plugins' is not installed, so not removed
      Package 'node-postcss-minify-font-values' is not installed, so not removed
      Package 'node-postcss-modules-extract-imports' is not installed, so not removed
      Package 'node-postcss-modules-values' is not installed, so not removed
      Package 'node-postcss-reporter' is not installed, so not removed
      Package 'node-postcss-value-parser' is not installed, so not removed
      Package 'node-pre-gyp' is not installed, so not removed
      Package 'node-preact' is not installed, so not removed
      Package 'node-prelude-ls' is not installed, so not removed
      Package 'node-prepend-http' is not installed, so not removed
      Package 'node-preserve' is not installed, so not removed
      Package 'node-pretty-bytes' is not installed, so not removed
      Package 'node-pretty-hrtime' is not installed, so not removed
      Package 'node-pretty-ms' is not installed, so not removed
      Package 'node-prismjs' is not installed, so not removed
      Package 'node-private' is not installed, so not removed
      Package 'node-process' is not installed, so not removed
      Package 'node-process-nextick-args' is not installed, so not removed
      Package 'node-progress' is not installed, so not removed
      Package 'node-promise' is not installed, so not removed
      Package 'node-promise-inflight' is not installed, so not removed
      Package 'node-promise-retry' is not installed, so not removed
      Package 'node-promzard' is not installed, so not removed
      Package 'node-prop-types' is not installed, so not removed
      Package 'node-proper-lockfile' is not installed, so not removed
      Package 'node-prosemirror-markdown' is not installed, so not removed
      Package 'node-prosemirror-model' is not installed, so not removed
      Package 'node-proto-list' is not installed, so not removed
      Package 'node-proxy-addr' is not installed, so not removed
      Package 'node-proxy-from-env' is not installed, so not removed
      Package 'node-proxyquire' is not installed, so not removed
      Package 'node-prr' is not installed, so not removed
      Package 'node-pseudomap' is not installed, so not removed
      Package 'node-pseudorandombytes' is not installed, so not removed
      Package 'node-psl' is not installed, so not removed
      Package 'node-public-encrypt' is not installed, so not removed
      Package 'node-puka' is not installed, so not removed
      Package 'node-pump' is not installed, so not removed
      Package 'node-pumpify' is not installed, so not removed
      Package 'node-punycode' is not installed, so not removed
      Package 'node-q' is not installed, so not removed
      Package 'node-qrcode-generator' is not installed, so not removed
      Package 'node-qs' is not installed, so not removed
      Package 'node-querystring' is not installed, so not removed
      Package 'node-querystring-es3' is not installed, so not removed
      Package 'node-querystringify' is not installed, so not removed
      Package 'node-queue-async' is not installed, so not removed
      Package 'node-quick-lru' is not installed, so not removed
      Package 'node-quote-stream' is not installed, so not removed
      Package 'node-qw' is not installed, so not removed
      Package 'node-rai' is not installed, so not removed
      Package 'node-ramda' is not installed, so not removed
      Package 'node-random-bytes' is not installed, so not removed
      Package 'node-randombytes' is not installed, so not removed
      Package 'node-randomfill' is not installed, so not removed
      Package 'node-range-parser' is not installed, so not removed
      Package 'node-raven-js' is not installed, so not removed
      Package 'node-raw-body' is not installed, so not removed
      Package 'node-raw-loader' is not installed, so not removed
      Package 'node-rc' is not installed, so not removed
      Package 'node-rdf-canonize' is not installed, so not removed
      Package 'node-re2' is not installed, so not removed
      Package 'node-react' is not installed, so not removed
      Package 'node-react-audio-player' is not installed, so not removed
      Package 'node-read' is not installed, so not removed
      Package 'node-read-file' is not installed, so not removed
      Package 'node-read-only-stream' is not installed, so not removed
      Package 'node-read-package-json' is not installed, so not removed
      Package 'node-read-pkg' is not installed, so not removed
      Package 'node-read-pkg-up' is not installed, so not removed
      Package 'node-readable-stream' is not installed, so not removed
      Package 'node-readdirp' is not installed, so not removed
      Package 'node-recast' is not installed, so not removed
      Package 'node-rechoir' is not installed, so not removed
      Package 'node-redent' is not installed, so not removed
      Package 'node-redis' is not installed, so not removed
      Package 'node-redux' is not installed, so not removed
      Package 'node-regenerate' is not installed, so not removed
      Package 'node-regenerate-unicode-properties' is not installed, so not removed
      Package 'node-regenerator-runtime' is not installed, so not removed
      Package 'node-regenerator-transform' is not installed, so not removed
      Package 'node-regex-cache' is not installed, so not removed
      Package 'node-regex-not' is not installed, so not removed
      Package 'node-regexpu-core' is not installed, so not removed
      Package 'node-registry-auth-token' is not installed, so not removed
      Package 'node-registry-url' is not installed, so not removed
      Package 'node-regjsgen' is not installed, so not removed
      Package 'node-regjsparser' is not installed, so not removed
      Package 'node-reinterval' is not installed, so not removed
      Package 'node-remove-trailing-separator' is not installed, so not removed
      Package 'node-repeat-element' is not installed, so not removed
      Package 'node-repeat-string' is not installed, so not removed
      Package 'node-repeating' is not installed, so not removed
      Package 'node-replace-ext' is not installed, so not removed
      Package 'node-request' is not installed, so not removed
      Package 'node-request-capture-har' is not installed, so not removed
      Package 'node-request-promise' is not installed, so not removed
      Package 'node-request-promise-core' is not installed, so not removed
      Package 'node-require-all' is not installed, so not removed
      Package 'node-require-dir' is not installed, so not removed
      Package 'node-require-directory' is not installed, so not removed
      Package 'node-require-from-string' is not installed, so not removed
      Package 'node-require-inject' is not installed, so not removed
      Package 'node-require-main-filename' is not installed, so not removed
      Package 'node-require-relative' is not installed, so not removed
      Package 'node-requirejs' is not installed, so not removed
      Package 'node-requirejs-text' is not installed, so not removed
      Package 'node-requires-port' is not installed, so not removed
      Package 'node-reserved' is not installed, so not removed
      Package 'node-resolve' is not installed, so not removed
      Package 'node-resolve-cwd' is not installed, so not removed
      Package 'node-resolve-dir' is not installed, so not removed
      Package 'node-resolve-from' is not installed, so not removed
      Package 'node-resolve-pkg' is not installed, so not removed
      Package 'node-response-time' is not installed, so not removed
      Package 'node-restore-cursor' is not installed, so not removed
      Package 'node-resumer' is not installed, so not removed
      Package 'node-retape' is not installed, so not removed
      Package 'node-retry' is not installed, so not removed
      Package 'node-rimraf' is not installed, so not removed
      Package 'node-ripemd160' is not installed, so not removed
      Package 'node-rollup-plugin-alias' is not installed, so not removed
      Package 'node-rollup-plugin-babel' is not installed, so not removed
      Package 'node-rollup-plugin-buble' is not installed, so not removed
      Package 'node-rollup-plugin-commonjs' is not installed, so not removed
      Package 'node-rollup-plugin-json' is not installed, so not removed
      Package 'node-rollup-plugin-node-resolve' is not installed, so not removed
      Package 'node-rollup-plugin-replace' is not installed, so not removed
      Package 'node-rollup-plugin-string' is not installed, so not removed
      Package 'node-rollup-plugin-typescript' is not installed, so not removed
      Package 'node-rollup-pluginutils' is not installed, so not removed
      Package 'node-run-async' is not installed, so not removed
      Package 'node-run-queue' is not installed, so not removed
      Package 'node-rw' is not installed, so not removed
      Package 'node-rx' is not installed, so not removed
      Package 'node-safe-buffer' is not installed, so not removed
      Package 'node-samsam' is not installed, so not removed
      Package 'node-sax' is not installed, so not removed
      Package 'node-schema-utils' is not installed, so not removed
      Package 'node-schlock' is not installed, so not removed
      Package 'node-sdp-jingle-json' is not installed, so not removed
      Package 'node-security' is not installed, so not removed
      Package 'node-seedrandom' is not installed, so not removed
      Package 'node-select2' is not installed, so not removed
      Package 'node-sellside-emitter' is not installed, so not removed
      Package 'node-semver' is not installed, so not removed
      Package 'node-semver-diff' is not installed, so not removed
      Package 'node-send' is not installed, so not removed
      Package 'node-seq' is not installed, so not removed
      Package 'node-sequencify' is not installed, so not removed
      Package 'node-serve-favicon' is not installed, so not removed
      Package 'node-serve-index' is not installed, so not removed
      Package 'node-serve-static' is not installed, so not removed
      Package 'node-set-blocking' is not installed, so not removed
      Package 'node-set-getter' is not installed, so not removed
      Package 'node-set-immediate-shim' is not installed, so not removed
      Package 'node-set-value' is not installed, so not removed
      Package 'node-setimmediate' is not installed, so not removed
      Package 'node-setprototypeof' is not installed, so not removed
      Package 'node-sha' is not installed, so not removed
      Package 'node-sha.js' is not installed, so not removed
      Package 'node-shasum' is not installed, so not removed
      Package 'node-shebang-command' is not installed, so not removed
      Package 'node-shebang-regex' is not installed, so not removed
      Package 'node-shelljs' is not installed, so not removed
      Package 'node-shiny-server-client' is not installed, so not removed
      Package 'node-should' is not installed, so not removed
      Package 'node-sigmund' is not installed, so not removed
      Package 'node-signal-exit' is not installed, so not removed
      Package 'node-simple-is' is not installed, so not removed
      Package 'node-simple-swizzle' is not installed, so not removed
      Package 'node-sink-test' is not installed, so not removed
      Package 'node-sinon' is not installed, so not removed
      Package 'node-sinon-chai' is not installed, so not removed
      Package 'node-slash' is not installed, so not removed
      Package 'node-slice-ansi' is not installed, so not removed
      Package 'node-slide' is not installed, so not removed
      Package 'node-smash' is not installed, so not removed
      Package 'node-snapdragon' is not installed, so not removed
      Package 'node-snapdragon-node' is not installed, so not removed
      Package 'node-snapdragon-token' is not installed, so not removed
      Package 'node-snapdragon-util' is not installed, so not removed
      Package 'node-sntp' is not installed, so not removed
      Package 'node-socket.io-parser' is not installed, so not removed
      Package 'node-solid-keychain' is not installed, so not removed
      Package 'node-solid-rest' is not installed, so not removed
      Package 'node-sort-keys' is not installed, so not removed
      Package 'node-sorted-object' is not installed, so not removed
      Package 'node-source-list-map' is not installed, so not removed
      Package 'node-source-map' is not installed, so not removed
      Package 'node-source-map-support' is not installed, so not removed
      Package 'node-sourcemap-codec' is not installed, so not removed
      Package 'node-sparkles' is not installed, so not removed
      Package 'node-spdx-correct' is not installed, so not removed
      Package 'node-spdx-exceptions' is not installed, so not removed
      Package 'node-spdx-expression-parse' is not installed, so not removed
      Package 'node-spdx-license-ids' is not installed, so not removed
      Package 'node-sphericalmercator' is not installed, so not removed
      Package 'node-split' is not installed, so not removed
      Package 'node-split-string' is not installed, so not removed
      Package 'node-split2' is not installed, so not removed
      Package 'node-sprintf-js' is not installed, so not removed
      Package 'node-sqlite3' is not installed, so not removed
      Package 'node-srs' is not installed, so not removed
      Package 'node-sshpk' is not installed, so not removed
      Package 'node-ssri' is not installed, so not removed
      Package 'node-stable' is not installed, so not removed
      Package 'node-stack-utils' is not installed, so not removed
      Package 'node-standard-error' is not installed, so not removed
      Package 'node-standard-http-error' is not installed, so not removed
      Package 'node-starttls' is not installed, so not removed
      Package 'node-static' is not installed, so not removed
      Package 'node-static-eval' is not installed, so not removed
      Package 'node-static-extend' is not installed, so not removed
      Package 'node-static-module' is not installed, so not removed
      Package 'node-stats-webpack-plugin' is not installed, so not removed
      Package 'node-statuses' is not installed, so not removed
      Package 'node-stealthy-require' is not installed, so not removed
      Package 'node-step' is not installed, so not removed
      Package 'node-stream-array' is not installed, so not removed
      Package 'node-stream-assert' is not installed, so not removed
      Package 'node-stream-browserify' is not installed, so not removed
      Package 'node-stream-combiner2' is not installed, so not removed
      Package 'node-stream-consume' is not installed, so not removed
      Package 'node-stream-each' is not installed, so not removed
      Package 'node-stream-http' is not installed, so not removed
      Package 'node-stream-iterate' is not installed, so not removed
      Package 'node-stream-shift' is not installed, so not removed
      Package 'node-stream-splicer' is not installed, so not removed
      Package 'node-stream-to-observable' is not installed, so not removed
      Package 'node-streamtest' is not installed, so not removed
      Package 'node-strict-uri-encode' is not installed, so not removed
      Package 'node-string-decoder' is not installed, so not removed
      Package 'node-string-width' is not installed, so not removed
      Package 'node-string.prototype.codepointat' is not installed, so not removed
      Package 'node-stringmap' is not installed, so not removed
      Package 'node-stringstream' is not installed, so not removed
      Package 'node-strip-ansi' is not installed, so not removed
      Package 'node-strip-bom' is not installed, so not removed
      Package 'node-strip-bom-stream' is not installed, so not removed
      Package 'node-strip-eof' is not installed, so not removed
      Package 'node-strip-indent' is not installed, so not removed
      Package 'node-strip-json-comments' is not installed, so not removed
      Package 'node-style-loader' is not installed, so not removed
      Package 'node-stylus' is not installed, so not removed
      Package 'node-subarg' is not installed, so not removed
      Package 'node-superagent' is not installed, so not removed
      Package 'node-supertest' is not installed, so not removed
      Package 'node-supports-color' is not installed, so not removed
      Package 'node-symbol-observable' is not installed, so not removed
      Package 'node-syntax-error' is not installed, so not removed
      Package 'node-tacks' is not installed, so not removed
      Package 'node-tap' is not installed, so not removed
      Package 'node-tap-mocha-reporter' is not installed, so not removed
      Package 'node-tap-parser' is not installed, so not removed
      Package 'node-tapable' is not installed, so not removed
      Package 'node-tape' is not installed, so not removed
      Package 'node-tar' is not installed, so not removed
      Package 'node-tar-stream' is not installed, so not removed
      Package 'node-telegram-bot-api' is not installed, so not removed
      Package 'node-temp' is not installed, so not removed
      Package 'node-temporary' is not installed, so not removed
      Package 'node-term-size' is not installed, so not removed
      Package 'node-terser' is not installed, so not removed
      Package 'node-test' is not installed, so not removed
      Package 'node-text-encoding' is not installed, so not removed
      Package 'node-text-table' is not installed, so not removed
      Package 'node-thenify' is not installed, so not removed
      Package 'node-thenify-all' is not installed, so not removed
      Package 'node-three-orbit-controls' is not installed, so not removed
      Package 'node-three-stl-loader' is not installed, so not removed
      Package 'node-through' is not installed, so not removed
      Package 'node-through2' is not installed, so not removed
      Package 'node-through2-filter' is not installed, so not removed
      Package 'node-tildify' is not installed, so not removed
      Package 'node-tilejson' is not installed, so not removed
      Package 'node-tilelive' is not installed, so not removed
      Package 'node-time-stamp' is not installed, so not removed
      Package 'node-time-zone' is not installed, so not removed
      Package 'node-timeago.js' is not installed, so not removed
      Package 'node-timed-out' is not installed, so not removed
      Package 'node-timers-browserify' is not installed, so not removed
      Package 'node-tinycolor' is not installed, so not removed
      Package 'node-tippex' is not installed, so not removed
      Package 'node-tldjs' is not installed, so not removed
      Package 'node-tmatch' is not installed, so not removed
      Package 'node-tmp' is not installed, so not removed
      Package 'node-to-absolute-glob' is not installed, so not removed
      Package 'node-to-arraybuffer' is not installed, so not removed
      Package 'node-to-fast-properties' is not installed, so not removed
      Package 'node-to-object-path' is not installed, so not removed
      Package 'node-to-regex' is not installed, so not removed
      Package 'node-to-regex-range' is not installed, so not removed
      Package 'node-toidentifier' is not installed, so not removed
      Package 'node-tough-cookie' is not installed, so not removed
      Package 'node-transformers' is not installed, so not removed
      Package 'node-traverse' is not installed, so not removed
      Package 'node-trim-newlines' is not installed, so not removed
      Package 'node-trust-json-document' is not installed, so not removed
      Package 'node-trust-keyto' is not installed, so not removed
      Package 'node-trust-webcrypto' is not installed, so not removed
      Package 'node-tslib' is not installed, so not removed
      Package 'node-tty-browserify' is not installed, so not removed
      Package 'node-tunein' is not installed, so not removed
      Package 'node-tunnel-agent' is not installed, so not removed
      Package 'node-turbolinks' is not installed, so not removed
      Package 'node-tweetnacl' is not installed, so not removed
      Package 'node-type-check' is not installed, so not removed
      Package 'node-type-detect' is not installed, so not removed
      Package 'node-type-is' is not installed, so not removed
      Package 'node-typedarray' is not installed, so not removed
      Package 'node-typedarray-to-buffer' is not installed, so not removed
      Package 'node-typescript' is not installed, so not removed
      Package 'node-typescript-types' is not installed, so not removed
      Package 'node-ua-parser-js' is not installed, so not removed
      Package 'node-uglify' is not installed, so not removed
      Package 'node-uglify-js' is not installed, so not removed
      Package 'node-uglify-save-license' is not installed, so not removed
      Package 'node-uglifyjs-webpack-plugin' is not installed, so not removed
      Package 'node-uid-number' is not installed, so not removed
      Package 'node-uid-safe' is not installed, so not removed
      Package 'node-ultron' is not installed, so not removed
      Package 'node-umd' is not installed, so not removed
      Package 'node-unbzip2-stream' is not installed, so not removed
      Package 'node-unc-path-regex' is not installed, so not removed
      Package 'node-underscore' is not installed, so not removed
      Package 'node-underscore.string' is not installed, so not removed
      Package 'node-unicode-13.0.0' is not installed, so not removed
      Package 'node-unicode-canonical-property-names-ecmascript' is not installed, so not removed
      Package 'node-unicode-loose-match' is not installed, so not removed
      Package 'node-unicode-match-property-ecmascript' is not installed, so not removed
      Package 'node-unicode-match-property-value-ecmascript' is not installed, so not removed
      Package 'node-unicode-property-aliases' is not installed, so not removed
      Package 'node-unicode-property-aliases-ecmascript' is not installed, so not removed
      Package 'node-unicode-property-value-aliases' is not installed, so not removed
      Package 'node-unicode-property-value-aliases-ecmascript' is not installed, so not removed
      Package 'node-union-value' is not installed, so not removed
      Package 'node-uniq' is not installed, so not removed
      Package 'node-uniqid' is not installed, so not removed
      Package 'node-uniqs' is not installed, so not removed
      Package 'node-unique-filename' is not installed, so not removed
      Package 'node-unique-stream' is not installed, so not removed
      Package 'node-unique-string' is not installed, so not removed
      Package 'node-universalify' is not installed, so not removed
      Package 'node-unorm' is not installed, so not removed
      Package 'node-unpipe' is not installed, so not removed
      Package 'node-unset-value' is not installed, so not removed
      Package 'node-uri-js' is not installed, so not removed
      Package 'node-uri-path' is not installed, so not removed
      Package 'node-url' is not installed, so not removed
      Package 'node-url-join' is not installed, so not removed
      Package 'node-url-loader' is not installed, so not removed
      Package 'node-url-parse' is not installed, so not removed
      Package 'node-url-parse-lax' is not installed, so not removed
      Package 'node-url-to-options' is not installed, so not removed
      Package 'node-urlgrey' is not installed, so not removed
      Package 'node-use' is not installed, so not removed
      Package 'node-util' is not installed, so not removed
      Package 'node-util-deprecate' is not installed, so not removed
      Package 'node-utilities' is not installed, so not removed
      Package 'node-utils-merge' is not installed, so not removed
      Package 'node-utml' is not installed, so not removed
      Package 'node-uuid' is not installed, so not removed
      Package 'node-v8flags' is not installed, so not removed
      Package 'node-vali-date' is not installed, so not removed
      Package 'node-validate-npm-package-license' is not installed, so not removed
      Package 'node-validate-npm-package-name' is not installed, so not removed
      Package 'node-vary' is not installed, so not removed
      Package 'node-vasync' is not installed, so not removed
      Package 'node-verror' is not installed, so not removed
      Package 'node-vhost' is not installed, so not removed
      Package 'node-vinyl' is not installed, so not removed
      Package 'node-vinyl-fs' is not installed, so not removed
      Package 'node-vinyl-sourcemaps-apply' is not installed, so not removed
      Package 'node-vlq' is not installed, so not removed
      Package 'node-vm-browserify' is not installed, so not removed
      Package 'node-vows' is not installed, so not removed
      Package 'node-vue' is not installed, so not removed
      Package 'node-vue-hot-reload-api' is not installed, so not removed
      Package 'node-vue-resource' is not installed, so not removed
      Package 'node-vue-style-loader' is not installed, so not removed
      Package 'node-watchpack' is not installed, so not removed
      Package 'node-wcwidth.js' is not installed, so not removed
      Package 'node-webassemblyjs' is not installed, so not removed
      Package 'node-webfinger' is not installed, so not removed
      Package 'node-webidl-conversions' is not installed, so not removed
      Package 'node-webpack-merge' is not installed, so not removed
      Package 'node-webpack-sources' is not installed, so not removed
      Package 'node-webpack-stats-plugin' is not installed, so not removed
      Package 'node-webrtc-adapter' is not installed, so not removed
      Package 'node-websocket' is not installed, so not removed
      Package 'node-websocket-driver' is not installed, so not removed
      Package 'node-websocket-stream' is not installed, so not removed
      Package 'node-when' is not installed, so not removed
      Package 'node-which' is not installed, so not removed
      Package 'node-which-module' is not installed, so not removed
      Package 'node-wide-align' is not installed, so not removed
      Package 'node-widest-line' is not installed, so not removed
      Package 'node-wildemitter' is not installed, so not removed
      Package 'node-with' is not installed, so not removed
      Package 'node-wordwrap' is not installed, so not removed
      Package 'node-worker-loader' is not installed, so not removed
      Package 'node-wrap-ansi' is not installed, so not removed
      Package 'node-wrappy' is not installed, so not removed
      Package 'node-write' is not installed, so not removed
      Package 'node-write-file-atomic' is not installed, so not removed
      Package 'node-write-file-promise' is not installed, so not removed
      Package 'node-ws' is not installed, so not removed
      Package 'node-xdg-basedir' is not installed, so not removed
      Package 'node-xml2js' is not installed, so not removed
      Package 'node-xmldom' is not installed, so not removed
      Package 'node-xmlhttprequest' is not installed, so not removed
      Package 'node-xmlhttprequest-ssl' is not installed, so not removed
      Package 'node-xoauth2' is not installed, so not removed
      Package 'node-xtend' is not installed, so not removed
      Package 'node-xterm' is not installed, so not removed
      Package 'node-xxhashjs' is not installed, so not removed
      Package 'node-y18n' is not installed, so not removed
      Package 'node-yajsml' is not installed, so not removed
      Package 'node-yallist' is not installed, so not removed
      Package 'node-yamlish' is not installed, so not removed
      Package 'node-yargs' is not installed, so not removed
      Package 'node-yargs-parser' is not installed, so not removed
      Package 'node-yauzl' is not installed, so not removed
      Package 'node-yazl' is not installed, so not removed
      Package 'node-yn' is not installed, so not removed
      Package 'node-ytdl-core' is not installed, so not removed
      Package 'node-zen-observable' is not installed, so not removed
      Package 'node-zeparser' is not installed, so not removed
      Package 'node-zipfile' is not installed, so not removed
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      @mrMuppet Okay, dann ist die Grundinstallation jetzt sauber.
      Als Gegencheck nochmal die Ausgabe von
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      Mit dem eigentlichen Phänomen muss dir dann jemand anderes helfen, von javaskript hab ich keine Ahnung. Weder vom Adapter noch von der Sprache.
      M 2 Antworten Letzte Antwort
        mrMuppet
        @Thomas-Braun sagte in HILFE! Scripte Bereich im WebUI nach 0,5 sec. ausgeblendet:
        /usr/bin/nodejs
        v12.20.0
        /usr/bin/node
        v12.20.0
        /usr/bin/npm
        6.14.8
        nodejs:
          Installed: 12.20.0-deb-1nodesource1
          Candidate: 12.20.0-deb-1nodesource1
          Version table:
         *** 12.20.0-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x groovy/main amd64 Packages
                100 /var/lib/dpkg/status
             12.18.2~dfsg-1ubuntu2 500
                500 http://de.archive.ubuntu.com/ubuntu groovy/universe amd64 Packages
        ioBroker auf NUC (Celeron mit Ubuntu-Server)
        Homematic, HMIP, Hue, Unifi, Plex, Nest, Roborock, Google Assistant
          mrMuppet
          Trotzdem Danke für deinen Einsatz!
          • M mrMuppet
            @mrMuppet
            Du bist aber nicht zufällig als root unterwegs?
            Mit dem
            iobroker stop
            iobroker fix
            iobroker start
            Dreisatz kannst du es auch nochmal probieren.
              @mrMuppet
              Mit dem
              iobroker stop
              iobroker fix
              iobroker start
              mrMuppet
              @Thomas-Braun hab ich noch mal drüber laufen lassen. War aber auch nicht als root drin.
              Ich hatte das selbe Problem ja auch schon auf meinem FreeNAS /TrueNAS -Rechner unter FreeBSD. ich würde gerne mal einzelne js Skripte ausschalten oder so.. Leider kommt ich da ja nicht dran. Gibt es eine aktuelle Variante von ioBroker.js2fs oder ähnlichem um an die Skripte dran zu kommen?
              • M mrMuppet
                mrMuppet
                Im Entwicklermodus von Chrome gibt es einige Fehler: f53e9da9-d54d-4526-a5ed-69f80241a775-image.png
                Vielleicht kann ja da jemand einen Tipp herauslesen, wie ich mein Problem beseitigen kann!
                • M mrMuppet
                  @mrMuppet
                  iobroker list adapters | grep socket
                  Sollte
                  system.adapter.socketio                : socketio       - v3.0.13
                  bei herum kommen.
                    @mrMuppet
                    Sollte
                    bei herum kommen.
                    mrMuppet
                    @Thomas-Braun Tut es.
                    • M mrMuppet
                      mrMuppet
                      Ich habe tatsächlich einen Snapshot von meiner IOBroker installation vor 6 Monaten gefunden. Jetzt überlege ich ja ernsthaft dieses Backup wieder einzuspielen und wieder alles upzudaten. Oder gibt es eine bessere Lösung?
                      • M mrMuppet
                        mrMuppet
                        Ich habe jetzt wirklich das alte Backup wieder installiert. Dort ist der Fehler noch nicht vorhanden. Was wirklich die Ursache war konnte ich nicht rausfinden.
                        Endlich kann ich wieder Skripte editieren!
