  4. Wärmepumpe Daikin Altherma 3 H HT und ioBroker
    6.8k
wärmepumpedaikinaltherma 3 h ht
88 Beiträge 17 Kommentatoren 26.8k Aufrufe 17 Beobachtet
  • D Diet_Po
    Hallo zusammen
    Ich scheiter gerade an der Modbusanbindung meiner WÄRMEPUMPE
    Keine Verbindung
    Modbus tcp port802
    Holding-Register: 40009; 16 bit signed; level
    Hat einer ne Idee/Lösung
    Danke schon mal
    Zeit
    debug
    Nachricht
    modbus.0
    2025-05-13 23:29:03.977	info	Disconnected from slave 192.168.178.213
    modbus.0
    2025-05-13 23:29:03.976	debug	Closing client on purpose.
    modbus.0
    2025-05-13 23:29:02.977	debug	Cleaning up request fifo.
    modbus.0
    2025-05-13 23:29:02.976	debug	Clearing timeout of the current request.
    modbus.0
    2025-05-13 23:29:02.976	debug	Socket closed with error
    modbus.0
    2025-05-13 23:29:02.974	error	Wrong CRC for frame: 21,3,3,0,2,2,22,21
    modbus.0
    2025-05-13 23:29:02.971	debug	Sending pdu to the socket.
    modbus.0
    2025-05-13 23:29:02.970	debug	[DevID_1/holdingRegs] Poll address 40009 - 1 registers
    modbus.0
    2025-05-13 23:29:02.970	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2025-05-13 23:29:02.969	info	Connected to slave
    modbus.0
    2025-05-13 23:28:02.966	info	Disconnected from slave 192.168.178.213
    modbus.0
    2025-05-13 23:28:02.966	debug	Closing client on purpose.
    modbus.0
    2025-05-13 23:28:01.965	debug	Cleaning up request fifo.
    modbus.0
    2025-05-13 23:28:01.965	debug	Clearing timeout of the current request.
    modbus.0
    2025-05-13 23:28:01.965	debug	Socket closed with error
    modbus.0
    2025-05-13 23:28:01.953	debug	Sending pdu to the socket.
    modbus.0
    2025-05-13 23:28:01.953	debug	[DevID_1/holdingRegs] Poll address 40009 - 1 registers
    modbus.0
    2025-05-13 23:28:01.952	debug	Initialization of scale factors done!
    modbus.0
    2025-05-13 23:28:01.951	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2025-05-13 23:28:01.951	info	Connected to slave
    modbus.0
    2025-05-13 23:28:01.842	debug	Add holdingRegisters.40009_test1: {"_id":"holdingRegisters.40009_test1","type":"state","common":{"name":"bl","role":"level","type":"number","read":true,"write":true,"def":0,"unit":""},"native":{"regType":"holdingRegs","address":40009,"deviceId":1,"type":"int16le","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.0
    2025-05-13 23:28:01.842	debug	Initialize Objects for holdingRegs: [{"_address":"40009","name":"test1","description":"bl","unit":"","type":"int16le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40009,"deviceId":1,"id":"holdingRegisters.40009_test1"}]
    modbus.0
    2025-05-13 23:28:01.841	debug	Initialize Objects for inputRegs: []
    modbus.0
    2025-05-13 23:28:01.841	debug	Initialize Objects for coils: []
    modbus.0
    2025-05-13 23:28:01.841	debug	Initialize Objects for disInputs: []
    modbus.0
    2025-05-13 23:28:01.789	info	starting. Version 6.3.2 in /opt/iobroker/node_modules/iobroker.modbus, node: v20.18.0, js-controller: 7.0.6
    modbus.0
    2025-05-13 23:28:01.645	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.0
    2025-05-13 23:28:01.631	debug	States connected to redis: 127.0.0.1:9000
    modbus.0
    2025-05-13 23:28:01.582	debug	States create User PubSub Client
    modbus.0
    2025-05-13 23:28:01.581	debug	States create System PubSub Client
    modbus.0
    2025-05-13 23:28:01.577	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    modbus.0
    2025-05-13 23:28:01.559	debug	Objects connected to redis: 127.0.0.1:9001
    modbus.0
    2025-05-13 23:28:01.551	debug	Objects client initialize lua scripts
    modbus.0
    2025-05-13 23:28:01.536	debug	Objects create User PubSub Client
    modbus.0
    2025-05-13 23:28:01.536	debug	Objects create System PubSub Client
    modbus.0
    2025-05-13 23:28:01.535	debug	Objects client ready ... initialize now
    wendy2702W Online
    wendy2702W Online
    wendy2702
    #81
    @diet_po sagte in Wärmepumpe Daikin Altherma 3 H HT und ioBroker:
    Modbus tcp port802
    Sehr Ungewöhnlich wenn das kein Tippfehler ist.
    EDIT:
    Ich habe die Einstellungen von Robbman übernommen, sollte ja genauso sein.
    Von wo? Ich konnte in dem Thread nur paar Screenshots von Registern sehen.
    Zeige nochmal deine Einstellungen und hast du denn die Hardware die @robmann hat was die WP betrifft?
      Diet_Po
      #82
      Mein Modbus TCP will einfach nicht an meiner Daikin Altherma -Wärmepumpe laufen
      hat einer von euch evtl. die Einstellungen von der Wärmepumpe und vom ioBroker - bin langsam am Verzweifeln :-)
      wendy2702W HomoranH 2 Antworten Letzte Antwort
      • D Diet_Po
        wendy2702W Online
        wendy2702W Online
        wendy2702
        #83
        @diet_po Wir hatten dich bereits mehrfach gebeten logs als Text in Code Tags zu posten und nicht als Screenshot. Kannst du das bitte ändern.
        Weiterhin glaube ich nicht das Port 802 richtig ist. Woher hast du diesen Wert?
        Der "Standart Port" für Modbus TCP ist bei 99,5% aller Geräte 502, oder hast du den an der WP so eingestellt?
        EDIT: Mal im Screenshot der Register Einstellungen von Robmann geschaut, der verwendet "Signed 16 bit (Big Endian), warum hast du dann "Little Endian" ausgewählt?
        • D Diet_Po
          #84
          hier mal Screenshot's von meinen Test
          sorry, da kann msn witklich nicht helfen
          Erstens Screeshot von Text und dann noch 2.5k!
          So viel Auflösung hat kein Handy!
          • wendy2702W wendy2702
            Diet_Po
            #85
            @wendy2702
            Port 802 ist tls 502 ungesichert, egal welche Einstellung gich verwende funzt beides nicht ebso ob 16 bit little oder big endian oder anderes Register.
            Habe mittlerweile von Daikin Antwort bekommen, soll Homebox mal reseten - werde ich die Tage mal testen und mich dann berichten.
            Sorry nochmal für Screenshots
              RBZ32
              #86
              Guten Abend,
              Ich habe seit ein paar Tagen die Daikin Altherma 3 M im Betrieb und bin soweit zufrieden, doch leider bekomme ich die Wärmepumpe mit HEM verbunden.
              Ich benutze seit paar Jahren Iobroker und visualisiere und steuere damit so ziemlich alles im Haus, die PV-Anlage ist von Huawei und lässt sich damit per Modbus TCP und RTU steuern.
              Nun möchte ich die Wärmepumpe mit aufnehmen und steuern, laut Daikin Betriebsanleitung und Broschüren sollte das ja gehen, doch leider gibt in meiner MMI2 Bedieneinheit keine Funktion, wo ich die Möglichkeit habe den HomeHub von Daikin zu aktivieren. Die MMI2 hat die aktuelle Firmware 07.07.00 installiert bekommen und laut Anleitung sollte die Funktion mit HomeHub ab 07.05.00 geben aber leider nicht.
              Angeschlossen wurde an P1/P2 Klemmen und im Iobroker sehe ich über Modbus Adapter die Werte, die alle auf max stehen.
              Ich komme leider nicht weiter, vielleicht übersehe ich auch was bitte um Hilfe
              Elektroniker86E 1 Antwort Letzte Antwort
              • R RBZ32
                Guten Abend,
                Elektroniker86E Offline
                Elektroniker86
                schrieb am zuletzt editiert von Elektroniker86
                #87
                @rbz32
                Hi, ich habe zwar nicht alles hier gelesen aber ich lese die Altherma 3HHT erfolgreich über den CAN Bus Adapter aus eventuell klappt das auch mit deiner Kiste?
                Kann man hier nachlesen:
                https://forum.iobroker.net/topic/52171/rotex-hpsu-daikin-altherma-wärmepumpe-über-iobroker-canbus/495?_=1748025855535
                Beste Grüße
                • R robmann
                  Register-Einstellung sieht wie folgt aus:
                  zum Vergleich: Register 40009 und 40056 identisch konfiguriert. Das setzten von "Leise-Modus" klappt.
                  Diet_Po
                  #88
                  @robmann
                  Kannst du mir bitte mal die Einstellungen deiner Wärmepumpe posten (auch die Einstellungen vom Modbus vom IOB)
                  Ich bekomme es leider nicht hin - mal sehen wo ich Mist gebaut habe :-)
