  4. [Gelöst] Zigbee Instanz startet nicht mehr...
iobroker updateiobroker app
7 Beiträge 3 Kommentatoren 739 Aufrufe 3 Beobachtet
  • C Offline
    CrazyCarlton
    schrieb am zuletzt editiert von CrazyCarlton
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi3
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu
    Node-Version: 10.x.x
    Nodejs-Version: v10.22.0
    NPM-Version: 6.14.6
    Hi zusammen, nach einem Update vom ioBroker startet die Zigbee Instanz nichtmehr. Folgendes steht im Log:
    host.raspberrypi	2020-08-28 15:42:43.994	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi	2020-08-28 15:42:43.994	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
    host.raspberrypi	2020-08-28 15:42:43.993	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
    host.raspberrypi	2020-08-28 15:42:43.993	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
    host.raspberrypi	2020-08-28 15:42:43.993	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    host.raspberrypi	2020-08-28 15:42:43.992	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    host.raspberrypi	2020-08-28 15:42:43.992	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
    host.raspberrypi	2020-08-28 15:42:43.992	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
    host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
    host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v64-linux-arm/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.990	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.990	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.990	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.989	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/10.22.0/linux/arm/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.989	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.989	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.988	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.988	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.988	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.987	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.987	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.987	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
    host.raspberrypi	2020-08-28 15:42:43.986	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
    host.raspberrypi	2020-08-28 15:42:43.986	error	Caught by controller[0]: ^
    host.raspberrypi	2020-08-28 15:42:43.985	error	Caught by controller[0]: throw err;
    host.raspberrypi	2020-08-28 15:42:43.984	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
    hat wer eine Ahnung wo ich hier ansetzen kann?
    Vielen Dank :)
    • C CrazyCarlton
      @Thomas-Braun Super, danke!
      habe es jetzt gerade gezogen. Leider noch immer der gleiche Fehler.
      /usr/bin/nodejs
      v12.18.3
      /usr/bin/node
      v12.18.3
      /usr/bin/npm
      6.14.6
      nodejs:
        Installed: 12.18.3-1nodesource1
        Candidate: 12.18.3-1nodesource1
        Version table:
       *** 12.18.3-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.22.0-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
           10.21.0~dfsg-1~deb10u1+rpi1 500
      host.raspberrypi	2020-08-28 16:32:14.790	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2020-08-28 16:32:14.789	error	Caught by controller[0]: }
      host.raspberrypi	2020-08-28 16:32:14.788	error	Caught by controller[0]: ]
      host.raspberrypi	2020-08-28 16:32:14.788	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
      host.raspberrypi	2020-08-28 16:32:14.787	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.787	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.786	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.786	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.18.3/linux/arm/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.785	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.785	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.785	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.784	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.784	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.782	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node',
      host.raspberrypi	2020-08-28 16:32:14.782	error	Caught by controller[0]: tries: [
      host.raspberrypi	2020-08-28 16:32:14.781	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30) {
      host.raspberrypi	2020-08-28 16:32:14.781	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
      host.raspberrypi	2020-08-28 16:32:14.781	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
      host.raspberrypi	2020-08-28 16:32:14.780	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
      host.raspberrypi	2020-08-28 16:32:14.777	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
      host.raspberrypi	2020-08-28 16:32:14.777	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
      host.raspberrypi	2020-08-28 16:32:14.776	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
      host.raspberrypi	2020-08-28 16:32:14.776	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
      host.raspberrypi	2020-08-28 16:32:14.775	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
      host.raspberrypi	2020-08-28 16:32:14.775	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
      host.raspberrypi	2020-08-28 16:32:14.774	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.774	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.773	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.773	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.772	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.18.3/linux/arm/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.772	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.771	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.771	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.770	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.770	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.769	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.769	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.768	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
      host.raspberrypi	2020-08-28 16:32:14.767	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.raspberrypi	2020-08-28 16:32:14.767	error	Caught by controller[0]: ^
      host.raspberrypi	2020-08-28 16:32:14.766	error	Caught by controller[0]: throw err;
      host.raspberrypi	2020-08-28 16:32:14.758	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @CrazyCarlton
      hast du nach dem Update von Node im Verzeichnis /opt/iobroker nen "npm rebuild" durchlaufen lassen ?
      A.
      C 1 Antwort Letzte Antwort
      • C CrazyCarlton
        Hardwaresystem: Pi3
        NPM-Version: 6.14.6
        Vielen Dank :)
        @CrazyCarlton
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
          @CrazyCarlton
          CrazyCarlton
          @Thomas-Braun said in Zigbee Instanz startet nicht mehr nach iobroker update:
          /usr/bin/nodejs
          v10.22.0
          /home/pi/.nvm/versions/node/v12.16.3/bin/node
          v12.16.3
          /home/pi/.nvm/versions/node/v12.16.3/bin/npm
          6.14.4
          nodejs:
            Installed: 10.22.0-1nodesource1
            Candidate: 10.22.0-1nodesource1
            Version table:
           *** 10.22.0-1nodesource1 500
          • C CrazyCarlton
            /usr/bin/nodejs
            v10.22.0
            v12.16.3
            6.14.4
            nodejs:
              Version table:
            @CrazyCarlton nodejs ist falsch bzw. doppelt installiert.
            Schau hier rein:
              Schau hier rein:
              CrazyCarlton
              /usr/bin/nodejs
              v12.18.3
              /usr/bin/node
              v12.18.3
              /usr/bin/npm
              6.14.6
              nodejs:
                Version table:
              • C CrazyCarlton
                /usr/bin/nodejs
                v12.18.3
                /usr/bin/node
                v12.18.3
                /usr/bin/npm
                6.14.6
                nodejs:
                  Version table:
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @CrazyCarlton
                A.
                • AsgothianA Asgothian
                  @CrazyCarlton
                  A.
                  CrazyCarlton
                  @Asgothian
                  Das wars! Vielen Dank! :)
