  4. Fehlermeldung Module js.550
    6.8k
modulejs controller
10 Beiträge 4 Kommentatoren 911 Aufrufe 4 Beobachtet
  • F Offline
    Franta
    Ich habe folgende wiederkehrende Fehlermeldung:
    throw err;
    2020-08-24 17:28:14 stdout module.js:550
    2020-08-24 17:27:58 stdout
    2020-08-24 17:27:58 stdout at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    2020-08-24 17:27:58 stdout at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    2020-08-24 17:27:58 stdout at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    2020-08-24 17:27:58 stdout at Socket.adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
    2020-08-24 17:27:58 stdout at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
    2020-08-24 17:27:58 stdout at Array.forEach (<anonymous>)
    2020-08-24 17:27:58 stdout at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
    2020-08-24 17:27:58 stdout at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
    2020-08-24 17:27:58 stdout at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
    2020-08-24 17:27:58 stdout TypeError: Cannot read property 'split' of undefined
    2020-08-24 17:27:43 stdout
    2020-08-24 17:27:43 stdout at Function.Module._load (module.js:498:3)
    2020-08-24 17:27:43 stdout at tryModuleLoad (module.js:506:12)
    2020-08-24 17:27:43 stdout at Module.load (module.js:566:32)
    2020-08-24 17:27:43 stdout at Object.Module._extensions..js (module.js:664:10)
    2020-08-24 17:27:43 stdout at Module._compile (module.js:653:30)
    2020-08-24 17:27:43 stdout at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ping/node_modules/@iobroker/adapter-core/build/index.js:29:54)
    2020-08-24 17:27:43 stdout at require (internal/module.js:11:18)
    2020-08-24 17:27:43 stdout at Module.require (module.js:597:17)
    2020-08-24 17:27:43 stdout at Function.Module._load (module.js:475:25)
    2020-08-24 17:27:43 stdout at Function.Module._resolveFilename (module.js:548:15)
    2020-08-24 17:27:43 stdout Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/lib/exitCodes'
    Ich bin Neuling. Vielleicht kann mir jemand helfen?
    |Hardwaresystem:| DS 411+II|
    |Arbeitsspeicher:| 8GB |
    |Festplattenart:| WD Red |
    |Betriebssystem:| Mac |
    |Node-Version:| 8.1 |
    |NPM-Version:| 6.x.x |
    Thomas BraunT AlCalzoneA 2 Antworten Letzte Antwort
    • F Franta
      throw err;
      @Franta
      nodejs -v && node -v && npm -v
      • F Franta
        throw err;
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @Franta Dein JS-Controller ist zu alt für den ping-Adapter, bitte upgraden.
        • AlCalzoneA AlCalzone
          @AlCalzone Der Rest scheint aber auch nicht frischer zu sein.
          F 1 Antwort Letzte Antwort
            Franta
            @Thomas-Braun ich kann leider im Terminal gar nichts mehr eingeben.... kommt immer nur diese Meldung
            • F Franta
              @Franta Strg-C drücken.
              Ich sehe gerade, das ist so'n Synology-Kram...
              Da bin ich raus, das ist mir zu 'krumm'.
              • F Franta
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @Franta Fang mal damit an, den Ping-Adapter zu stoppen.
                -1
                  Franta99
                  @AlCalzone wie komme ich denn dahin, wenn der Terminal nicht mehr auf die Eingaben reagiert?
                  Das ist ja mein größtes Problem...
                  • F Franta99
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    schrieb am zuletzt editiert von AlCalzone
                    @Franta99 Kannst du auf der Diskstation nicht einfach ein zusätzliches Terminal aufmachen? Ansonsten in der Admin UI stoppen.
                      Franta99
                      @AlCalzone Vielen Dank! Werde es probieren!
