  4. Chromecast Adapter stürzt ab :(
    6.3k
crashandroid tvchromecastadapter
11 Beiträge 5 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • JackDanielJ Offline
    JackDanielJ Offline
    JackDaniel
    schrieb am zuletzt editiert von JackDaniel
    hi,
    der adapter läuft mit allen meinen 4 google home minis, 1 x google home, 1 x chromecast und einmal android tv 7 ohne probleme, aber sobad ich meinen androd tv 9 aus dem standby hole crasht der adapter :(
    chromecast.0	2020-08-10 19:02:39.681	error	at Client.emit (events.js:327:22)
    chromecast.0	2020-08-10 19:02:39.681	error	at Client.onmessage (/opt/iobroker/node_modules/castv2/lib/channel.js:23:10)
    chromecast.0	2020-08-10 19:02:39.681	error	at Channel.emit (events.js:315:20)
    chromecast.0	2020-08-10 19:02:39.681	error	at Channel.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/controller.js:16:10)
    chromecast.0	2020-08-10 19:02:39.681	error	at fn.emit (events.js:327:22)
    chromecast.0	2020-08-10 19:02:39.681	error	at fn.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/media.js:21:12)
    chromecast.0	2020-08-10 19:02:39.681	error	at fn.emit (events.js:315:20)
    chromecast.0	2020-08-10 19:02:39.681	error	at fn.onstatus (/opt/iobroker/node_modules/castv2-client/lib/senders/default-media-receiver.js:16:10)
    chromecast.0	2020-08-10 19:02:39.681	error	at DefaultMediaReceiver.emit (events.js:315:20)
    chromecast.0	2020-08-10 19:02:39.681	error	at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58)
    chromecast.0	2020-08-10 19:02:39.681	error	(18101) TypeError: Cannot read property 'contentId' of undefined
    chromecast.0	2020-08-10 19:02:39.679	error	(18101) uncaught exception: Cannot read property 'contentId' of undefined
    chromecast.0	2020-08-10 19:02:39.634	info	(18101) TV Schlafzimmer - Player joint
    chromecast.0	2020-08-10 19:02:39.623	info	(18101) TV Schlafzimmer - Connected player
    chromecast.0	2020-08-10 19:02:39.617	info	(18101) TV Schlafzimmer - Try to join player
    jemand eine idee warum/wieso?
    danke im voraus
    Carpe diem
    Mojito JoeM 1 Antwort Letzte Antwort
    • JackDanielJ JackDaniel
      hi,
      danke im voraus
      Mojito JoeM Offline
      Mojito JoeM Offline
      Mojito Joe
      @JackDaniel Habe das gleiche Problem...
      host.DHH6SmartHome	2020-09-26 16:34:17.720	info	instance system.adapter.chromecast.0 started with pid 23928
      host.DHH6SmartHome	2020-09-26 16:33:47.702	info	Restart adapter system.adapter.chromecast.0 because enabled
      host.DHH6SmartHome	2020-09-26 16:33:47.702	info	instance system.adapter.chromecast.0 terminated with code 0 (NO_ERROR)
      chromecast.0	2020-09-26 16:33:47.181	info	(23844) Terminated (NO_ERROR): Without reason
      chromecast.0	2020-09-26 16:33:47.180	info	(23844) terminating
      chromecast.0	2020-09-26 16:33:47.080	info	(23844) Unload completed sucesfully
      chromecast.0	2020-09-26 16:33:47.079	info	(23844) Arbeitszimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.079	info	(23844) Wohnzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.078	info	(23844) Badezimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.078	info	(23844) Schlafzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.062	info	(23844) TV Wohnzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.059	info	(23844) TV Wohnzimmer - Detached player
      chromecast.0	2020-09-26 16:33:47.058	info	(23844) TV Wohnzimmer - Detached player
      chromecast.0	2020-09-26 16:33:47.057	info	(23844) Google-Home-Schlafzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.057	info	(23844) Google-Home-Bad - client disconnected
      chromecast.0	2020-09-26 16:33:47.056	info	(23844) Google-Home-Arbeitszimmer - client disconnected
      chromecast.0	2020-09-26 16:33:47.055	info	(23844) Google-Home-Max - client disconnected
      chromecast.0	2020-09-26 16:33:47.050	info	(23844) Destroying chromecast scanner
      chromecast.0	2020-09-26 16:33:47.050	info	(23844) Unload triggered
      chromecast.0	2020-09-26 16:33:47.049	error	(23844) TypeError: Cannot read property 'contentId' of undefined at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58) at DefaultMediaRece
      chromecast.0	2020-09-26 16:33:47.048	error	(23844) uncaught exception: Cannot read property 'contentId' of undefined
      chromecast.0	2020-09-26 16:33:46.990	info	(23844) TV Wohnzimmer - Player joint
      chromecast.0	2020-09-26 16:33:46.989	info	(23844) TV Wohnzimmer - Connected player
      chromecast.0	2020-09-26 16:33:46.987	info	(23844) TV Wohnzimmer - Try to join player
      chromecast.0	2020-09-26 16:33:46.980	info	(23844) Arbeitszimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.977	info	(23844) Wohnzimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.976	info	(23844) Google-Home-Max - Connected client
      chromecast.0	2020-09-26 16:33:46.973	info	(23844) Schlafzimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.972	info	(23844) Badezimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.967	info	(23844) Google-Home-Arbeitszimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.965	info	(23844) Google-Home-Bad - Connected client
      chromecast.0	2020-09-26 16:33:46.961	info	(23844) Google-Home-Schlafzimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.931	info	(23844) TV Wohnzimmer - Connected client
      chromecast.0	2020-09-26 16:33:46.390	info	(23844) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v10.22.1, js-controller: 3.1.6
      host.DHH6SmartHome	2020-09-26 16:33:45.552	info	instance system.adapter.chromecast.0 started with pid 23844
      host.DHH6SmartHome	2020-09-26 16:33:15.532	info	Restart adapter system.adapter.chromecast.0 because enabled
      host.DHH6SmartHome	2020-09-26 16:33:15.532	info	instance system.adapter.chromecast.0 terminated with code 0 (NO_ERROR)
      chromecast.0	2020-09-26 16:33:15.014	info	(23787) Terminated (NO_ERROR): Without reason
      chromecast.0	2020-09-26 16:33:15.014	info	(23787) terminating
      chromecast.0	2020-09-26 16:33:14.827	info	(23787) Unload completed sucesfully
      chromecast.0	2020-09-26 16:33:14.815	info	(23787) HiFi Musikanlage - client disconnected
      chromecast.0	2020-09-26 16:33:14.814	info	(23787) Arbeitszimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.814	info	(23787) Wohnzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.813	info	(23787) Badezimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.812	info	(23787) Schlafzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.811	info	(23787) TV Wohnzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.810	info	(23787) TV Wohnzimmer - Detached player
      chromecast.0	2020-09-26 16:33:14.804	info	(23787) TV Wohnzimmer - Detached player
      chromecast.0	2020-09-26 16:33:14.791	info	(23787) Google-Home-Schlafzimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.790	info	(23787) Google-Home-Bad - client disconnected
      chromecast.0	2020-09-26 16:33:14.786	info	(23787) Google-Home-Arbeitszimmer - client disconnected
      chromecast.0	2020-09-26 16:33:14.785	info	(23787) Google-Home-Max - client disconnected
      chromecast.0	2020-09-26 16:33:14.781	info	(23787) Destroying chromecast scanner
      chromecast.0	2020-09-26 16:33:14.774	info	(23787) Unload triggered
      chromecast.0	2020-09-26 16:33:14.773	error	(23787) TypeError: Cannot read property 'contentId' of undefined at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58) at DefaultMediaRece
      chromecast.0	2020-09-26 16:33:14.772	error	(23787) uncaught exception: Cannot read property 'contentId' of undefined
      chromecast.0	2020-09-26 16:33:14.731	info	(23787) Wohnzimmer - Connected client
      chromecast.0	2020-09-26 16:33:14.725	info	(23787) TV Wohnzimmer - Player joint
      chromecast.0	2020-09-26 16:33:14.724	info	(23787) TV Wohnzimmer - Connected player
      chromecast.0	2020-09-26 16:33:14.721	info	(23787) TV Wohnzimmer - Try to join player
      chromecast.0	2020-09-26 16:33:14.713	info	(23787) Arbeitszimmer - Connected client
      chromecast.0	2020-09-26 16:33:14.647	info	(23787) Badezimmer - Connected client
      chromecast.0	2020-09-26 16:33:14.645	info	(23787) HiFi Musikanlage - Connected client
      chromecast.0	2020-09-26 16:33:14.644	info	(23787) Schlafzimmer - Connected client
      chromecast.0	2020-09-26 16:33:14.641	info	(23787) TV Wohnzimmer - Connected client
      chromecast.0	2020-09-26 16:33:14.374	info	(23787) Google-Home-Max - Connected client
      chromecast.0	2020-09-26 16:33:14.336	info	(23787) Google-Home-Arbeitszimmer - Connected client
      chromecast.0	2020-09-26 16:33:14.331	info	(23787) Google-Home-Bad - Connected client
      chromecast.0	2020-09-26 16:33:14.301	info	(23787) Google-Home-Schlafzimmer - Connected client
      chromecast.0	2020-09-26 16:33:13.935	info	(23787) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v10.22.1, js-controller: 3.1.6
      und leider auch keine Lösung. Es macht wohl Sinn, sich hier ranzuhängen und das Problem sichtbarer werden zu lassen.
      • Mojito JoeM Mojito Joe
        @Mojito-Joe Unabhängig vom konkreten Problem würde ich node12 empfehlen.
          Mojito JoeM Offline
          Mojito JoeM Offline
          Mojito Joe
          @Thomas-Braun Löst zwar dieses Problem nicht, aber ein paar andere errors mit anderen Adaptern. War mir nicht bewusst, dass diese an der nodeJS Version liegen. Danke!
            JackDanielJ Offline
            JackDaniel
            ich hab nun einfach den tv deaktiviert da ich eh nur die google home im adapter benötige.
            Carpe diem
            Mojito JoeM David G.D 2 Antworten Letzte Antwort
              Mojito JoeM Offline
              Mojito JoeM Offline
              Mojito Joe
              @JackDaniel Schau mal hier, wurde bereits beim Adapter als Issue gemeldet. Nun muss es nur noch jemand fixen, dafür reichen meine Fähigkeiten nicht.
              Schaue ich mir den Zeitpunkt des letzten Updates dieses Repositories an, habe ich da meine Zweifel, dass dies demnächst geschieht ;-)
                David G.D Online
                David G.D Online
                David G.
                @jackdaniel sagte in Chromecast Adapter stürzt ab :(:
                Das Thema ist zwar schon was älter, hänge mich aber mal dran.
                Das Problem scheint ja noch nicht gefixt zu sein.
                Wue hast du deinen Fernseher deaktiviert? Finde da keine Settings IM Adapter.
                JackDanielJ 1 Antwort Letzte Antwort
                • David G.D David G.
                  JackDanielJ Offline
                  JackDanielJ Offline
                  JackDaniel
                  @david-g
                  wenn ich mich recht erinnere ist das unter den objekten vom gerät zu finden
                  Carpe diem
                  David G.D C 2 Antworten Letzte Antwort
                    @david-g
                    David G.D Online
                    David G.D Online
                    David G.
                    @jackdaniel
                    Gefunden, danke.
                      @david-g
                      chefffe
                      @jackdaniel
                      hab das gleiche Problem.....
                      Das Deaktivieren des TVs geht über den Datenpunkt "Enabled" auf false setzen?
                      Oder hast du den ganzen Datenpunkt gelöscht?
                        JackDanielJ Offline
                        JackDaniel
                        Ja genau, sollte aber mit der neuen Version eh nicht mehr vorkommen
                        Carpe diem
