  4. Probleme mit Bluetooth Adapter
ble adapterbleerrorproblemerror
5 Beiträge 3 Kommentatoren 759 Aufrufe 3 Beobachtet
    raspberry
    |Hardwaresystem:| NUC
    |Arbeitsspeicher:| 4GB |
    |Festplattenart:| SSD/HDD |
    |Betriebssystem:| Ubuntu
    |Node-Version:| 12.18.2
    |Nodejs-Version:| 8.10.0
    |NPM-Version:| 6.14.5
    |Installationsart:| Skript
    |Image genutzt:| Nein |
    ich habe folgendes Problem mit dem BLE Adapter. Wenn ich versuche ihn zu starten erscheint folgendes im Log.
    ble.0	2020-07-06 00:41:57.442	info	(14856) Terminated (NO_ERROR): Without reason
    ble.0	2020-07-06 00:41:57.441	info	(14856) terminating
    ble.0	2020-07-06 00:41:57.431	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    ble.0	2020-07-06 00:41:57.431	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8147:76
    ble.0	2020-07-06 00:41:57.431	error	at Object.ready (/opt/iobroker/node_modules/iobroker.ble/build/main.js:39:18)
    ble.0	2020-07-06 00:41:57.431	error	at __awaiter (/opt/iobroker/node_modules/iobroker.ble/build/main.js:4:12)
    ble.0	2020-07-06 00:41:57.431	error	at new Promise (<anonymous>)
    ble.0	2020-07-06 00:41:57.431	error	at /opt/iobroker/node_modules/iobroker.ble/build/main.js:8:71
    ble.0	2020-07-06 00:41:57.431	error	at Generator.next (<anonymous>)
    ble.0	2020-07-06 00:41:57.431	error	at /opt/iobroker/node_modules/iobroker.ble/build/main.js:43:39
    ble.0	2020-07-06 00:41:57.431	error	at new ObjectCache (/opt/iobroker/node_modules/iobroker.ble/build/lib/object-cache.js:25:33)
    ble.0	2020-07-06 00:41:57.431	error	(14856) TypeError: sorted_list_1.SortedList is not a constructor
    ble.0	2020-07-06 00:41:57.429	error	(14856) unhandled promise rejection: sorted_list_1.SortedList is not a constructor
    Unhandled	2020-07-06 00:41:57.429	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ble.0	2020-07-06 00:41:57.416	info	(14856) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.6
    Ich vermute es liegt am Update auf node 12.18.2, aber eigentlich sollte es damit keine Probleme geben.
    Der Bluetooth Dongle funktioniert, wenn ich damit nach Geräten über die Konsole scanne.
    Der "fixer" oder Neuinstallation des Adapters brachte keine Abhilfe.
    • R raspberry
      @raspberry
      Wenn das stimmt, dann ist node falsch installiert. Die Versionen müssen gleich sein.
      Schau nach:
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      Konsolenausgaben bitte als Text in CodeTags </> hier rein
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        schrieb am zuletzt editiert von AlCalzone
        Die Ursache ist zwar kein Node-Problem, sondern ein Problem mit dem Adapter bzw. einem installierten Modul - geradebiegen sollte man es aber.
        Zum eigentlichen Problem:
        Installiere mal den Adapter neu drüber, am besten nachdem ihr die Node-Versionen geradegezogen habt:
        cd /opt/iobroker
        npm i iobroker.ble
          raspberry
          Danke für die schnelle Hilfe.
          Es lag an der falschen Nodejs Version. Ich dachte diese würde auch mittel "n <version>" aktualisiert.
          Ich habe aber eine Anleitung gefunden Nodejs auch auf die 12.18.2 zu bringen und dann ble neu installiert, wie beschrieben. Jetzt geht alles wieder.
          Danke für die Tipps.
          • R raspberry
            @raspberry Mein Reden...
            Auf Ubuntu und sonstigen Debian-Derivativen am besten immer über den Paketmanager installieren. Was kommt denn jetzt bei
            herum?
