  4. Curl Antwort als Json auslesen
curljsoniobrokerskript
4 Beiträge 3 Kommentatoren 817 Aufrufe 2 Beobachtet
  • C Offline
    ChrisBGL
    ich habe mir ein Skript von paul53 aus diesem Thema geholt:
    Re: Json verarbeiten
    welches bei mir so aussieht:
    var abfrage = "curl -G https://mongol.brono.com/mongol/api.php?commandname=get_last_transmit -d format=json -d pass=xxx -d user=xxx -d unitnumber=xxx";
    createState("SoC", 0);
    createState("address", 0);
    function abfrageStarten() {
        exec(abfrage, function(err, stdout, stderr) {
            if (err) {
                log("Error: " + err,"warn");
                return;
           var pv = JSON.parse(stdout);
           setState("SoC", pv["soc"]);
           setState("address", pv["address"]);
    setTimeout(abfrageStarten, 100);  // Script start
    schedule("*/1 * * * *", abfrageStarten);  // jede Minute
    Leider bekomme ich eine Fehlermeldung:
    javascript.0	2020-06-30 15:03:06.804	error	(2322) script.js.common.Zero_abfragen: setForeignState: undefined is not a valid state value
    Ich denke, dass das daran liegt, dass die Ausgabe bei mir anders ist, nämlich (Augabe aus Curl unter Windows nach Aufruf des Befehls):
    [{"unitnumber":"xxx","name":"xxx","unittype":"5","unitmodel":"6","analog1":"0.09","mileage":"2091.01","software_version":"190905","logic_state":"2","reason":"2","response":"0","driver":"0","longitude":"9.1440","latitude":"9.9687","altitude":"119","gps_valid":"0","gps_connected":"0","satellites":"0","velocity":"0","heading":"309","emergency":"0","shock":"","ignition":"0","door":"0","hood":"0","volume":"0","water_temp":"","oil_pressure":"0","main_voltage":13.13,"siren":"0","lock":"0","int_lights":"0","datetime_utc":"20200629161954","datetime_actual":"20200630101642","address":"xxx, xx xxxxxxx","perimeter":"","color":2,"soc":82,"tipover":0,"charging":0,"chargecomplete":0,"pluggedin":0,"chargingtimeleft":0}]
    Kann mir bitte jemand helfen das Script anzupassen?
    Gruß,
    Chris
    J.A.R.V.I.S.J paul53P 2 Antworten Letzte Antwort
    • C ChrisBGL
              if (err) {
                  return;
      Gruß,
      Chris
      J.A.R.V.I.S.J Offline
      J.A.R.V.I.S.
      @ChrisBGL du erhälst ein Array. Daraus kannst du nicht direkt den Wert von "soc" rausziehen.
      Bersuch mal folgendes:
             const pv = JSON.parse(stdout);
             setState("SoC", pv[0].soc);
             setState("address", pv[0].address);
      • C ChrisBGL
                if (err) {
                    return;
        Gruß,
        Chris
        @ChrisBGL sagte in Curl Antwort als Json auslesen:
        Script anzupassen?
               var pv = JSON.parse(stdout)[0];
        C 1 Antwort Letzte Antwort
          Script anzupassen?
          ChrisBGL
          Funktioniert, danke!
