  4. Error Resource temporarily unavailable Cannot lock port
    6.6k
zigbee adapter
7 Beiträge 5 Kommentatoren 8.5k Aufrufe 5 Beobachtet
    Th3RockYeah
    ich habe seit heute das Problem, dass ich folgende Fehlermeldung beim Starten meines Zigbee Adapters bekomme:
    zigbee.0	2020-06-17 23:53:27.729	error	at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0	2020-06-17 23:53:27.729	error	at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14)
    zigbee.0	2020-06-17 23:53:27.729	error	at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:111:49)
    zigbee.0	2020-06-17 23:53:27.729	error	at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:4:12)
    zigbee.0	2020-06-17 23:53:27.729	error	at new Promise (<anonymous>)
    zigbee.0	2020-06-17 23:53:27.729	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:8:71
    zigbee.0	2020-06-17 23:53:27.729	error	at Generator.next (<anonymous>)
    zigbee.0	2020-06-17 23:53:27.729	error	at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:113:32)
    zigbee.0	2020-06-17 23:53:27.729	error	(2238) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
    zigbee.0	2020-06-17 23:53:27.728	error	(2238) Failed to start Zigbee
    zigbee.0	2020-06-17 23:53:27.495	info	(2238) Starting Zigbee...
    zigbee.0	2020-06-17 23:53:27.494	info	(2238) Try to reconnect. 1 attempts left
    zigbee.0	2020-06-17 23:53:17.492	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:6:65)
    zigbee.0	2020-06-17 23:53:17.492	error	at Generator.throw (<anonymous>)
    zigbee.0	2020-06-17 23:53:17.492	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:158:23
    zigbee.0	2020-06-17 23:53:17.492	error	(2238) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
    zigbee.0	2020-06-17 23:53:17.490	error	(2238) Failed to start Zigbee
    zigbee.0	2020-06-17 23:52:12.022	info	(2238) Starting Zigbee...
    Genau erklären, wann das und wie das passiert ist weiß ich nicht. Ich hatte heute einige Updates über die "Katze" gemacht und auch ein sudo apt-get update/upgrade.
    Bei meiner Fehlersuche bin ich auf folgendes gestoßen und frage mich, ob das evtl. mein Problem ist:
    An meinen Pi ist EIN Zigbee USB Stick angeschlossen, wenn ich aber den serial port aufliste werden mir zwei angezeigt:
    pi@raspberrypi:~ $ ls -l /dev/serial/by-id
    insgesamt 0
    lrwxrwxrwx 1 root root 13 Jun 17 23:49 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L43002R4-if00 -> ../../ttyACM0
    lrwxrwxrwx 1 root root 13 Jun 17 23:49 usb-Texas_Instruments_XDS110__03.00.00.12__Embed_with_CMSIS-DAP_L43002R4-if03 -> ../../ttyACM1
    Ist das normal? Wenn nicht, was ich vermute, würde es erklären, warum sich die Ports gegenseitig blocken.
    Leider weiß ich jetzt nicht weiter. Habt ihr einen Tipp?
    • T Th3RockYeah
      insgesamt 0
      @Th3RockYeah
      Über die 'Katze' macht man ja auch keine 'Updates'
      T 2 Antworten Letzte Antwort
        @Th3RockYeah
        Th3RockYeah
        @Thomas-Braun Fairer Punkt. :)
        Kannst du mir dennoch jemand sagen, ob der Pi bei einem angeschlossen USB Stick nur einen Serial Port auflistet oder nicht? Je nachdem würde ich das Pi OS (incl. IoBroker) noch mal neu aufzusetzen. Da ich absolut keine Idee habe, wieso die Konstellation bei mir gerade so ist und woher das kommt.
          @Th3RockYeah
          Th3RockYeah
          Update: Ich habe den Fehler gefunden. Die PanID muss gewechselt werden, danach funktioniert es auch wieder im IoBroker.
          Es scheint etwas hiermit zu tun zu haben; https://forum.iobroker.net/topic/34500/achtung-zigbee-adapter-problem-ab-17-06-2020
          • T Th3RockYeah
            maxpd
            @Th3RockYeah
            Vor langem hatte ich schonmal einen Fehler wo ich auf 16x D umstellen musste.
            Jetzt habe ich den gleichen Fehler wie du, aber 16xD ist noch eingestellt.
            Hat jemand eine Idee woran es noch liegen kann. Ich habe nur sudo reboot gemacht.
            maxpd
            Raspi 4 8gb | iobroker + pivccu3 | 46 Adapter | 68 Scripte, 120 Devices
            X 1 Antwort Letzte Antwort
            • M maxpd
              @Th3RockYeah
              X Offline
              X Offline
              xADDRx
              @maxpd Bei mir leider gleiches Problem
              Sonos, Intel Nuc, Iobroker Pro, Proxmox, IPad Air (Wand), Vis, Xiaomi, Devolo, Bose, Philips Hue, Instar, Synology
              • X xADDRx
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @xADDRx sagte in Error Resource temporarily unavailable Cannot lock port:
                • welches Problem genau ?
                • Mit welcher Hardware
                • Mit welcher Software version ?
                So eine Aussage "Das Problem hab ich auch" bringt selten etwas.
                A.
