  4. Fehler Zigbee Stick
    5.7k
Fehler Zigbee Stick
zigbee
14 Beiträge 7 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • L Offline
    lustig29
    kann mir jemand sagen was es mit diesem Fehler auf sich hat und wie ich ihn abstellen kann? Hänge mal einen Auszug aus dem Log an, vielleicht hilft es ja.
    (2956) Zigbee started
    zigbee.0 2020-06-15 16:41:34.689 info (2956) 0x00158d00045dc6fa (addr 44675): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
    zigbee.0 2020-06-15 16:41:34.686 info (2956) 0x00158d0003cd921c (addr 5952): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    zigbee.0 2020-06-15 16:41:34.683 info (2956) 0x00158d0003d01885 (addr 30432): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
    zigbee.0 2020-06-15 16:41:34.679 info (2956) 0x00158d0003d01800 (addr 45139): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
    zigbee.0 2020-06-15 16:41:34.676 info (2956) 0x00158d0002b7ceec (addr 14799): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
    zigbee.0 2020-06-15 16:41:34.668 info (2956) Currently 5 devices are joined:
    zigbee.0 2020-06-15 16:41:34.633 info (2956) --> transmitPower : normal
    zigbee.0 2020-06-15 16:41:34.601 info (2956) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190619}}
    zigbee.0 2020-06-15 16:41:32.705 info (2956) Starting Zigbee...
    zigbee.0 2020-06-15 16:41:32.700 error (2956) Serial port not selected! Go to settings page.
    zigbee.0 2020-06-15 16:41:32.639 info (2956) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.0, js-controller: 3.1.4
    host.raspberrypi 2020-06-15 16:41:29.442 info instance system.adapter.zigbee.0 started with pid 2956
    host.raspberrypi 2020-06-15 16:40:59.359 info Restart adapter system.adapter.zigbee.0 because enabled
    host.raspberrypi 2020-06-15 16:40:59.344 info instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
    zigbee.0 2020-06-15 16:40:58.733 info (2939) Terminated (NO_ERROR): Without reason
    zigbee.0 2020-06-15 16:40:58.731 info (2939) terminating
    zigbee.0 2020-06-15 16:40:58.671 info (2939) Zigbee: disabling joining new devices.
    zigbee.0 2020-06-15 16:40:58.667 info (2939) cleaned everything up...
    zigbee.0 2020-06-15 16:40:58.665 error at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0 2020-06-15 16:40:58.665 error at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:199:19)
    zigbee.0 2020-06-15 16:40:58.665 error at Array.forEach (<anonymous>)
    zigbee.0 2020-06-15 16:40:58.665 error at /opt/iobroker/node_modules/iobroker.zigbee/main.js:213:95
    zigbee.0 2020-06-15 16:40:58.665 error (2939) ReferenceError: stateKey is not defined
    zigbee.0 2020-06-15 16:40:58.664 error (2939) unhandled promise rejection: stateKey is not defined
    Unhandled 2020-06-15 16:40:58.662 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().zigbee.0 2020-06-15 16:30:38.175 error at processTicksAndRejections (internal/process/task_queues.js:97:5)
    zigbee.0 2020-06-15 16:30:38.175 error at runMicrotasks (<anonymous>)
    zigbee.0 2020-06-15 16:30:38.175 error at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:199:19)
    zigbee.0 2020-06-15 16:30:38.175 error at Array.forEach (<anonymous>)
    zigbee.0 2020-06-15 16:30:38.175 error at /opt/iobroker/node_modules/iobroker.zigbee/main.js:213:95
    zigbee.0 2020-06-15 16:30:38.175 error (1805) ReferenceError: stateKey is not defined
    zigbee.0 2020-06-15 16:30:38.174 error (1805) unhandled promise rejection: stateKey is not defined
    Unhandled 2020-06-15 16:30:38.172 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    B 1 Antwort Letzte Antwort
    • L lustig29
      bob der 1.
      schrieb am zuletzt editiert von bob der 1.
      @lustig29
      Was ich lese.
      Dein Port stimmt nicht.
      L 1 Antwort Letzte Antwort
      • B bob der 1.
        @lustig29
        Was ich lese.
        lustig29
        @bob-der-1 Stick funktioniert ja, wenn auch nur teilweise. Startet öfters neu und heute Nacht hat sich mein Led Stripe selbstständig eingeschaltet. Wie kann ich denn das Problem beheben?
        • L lustig29
          bob der 1.
          @lustig29
          Bin da kein Profi,da ich den unproblematischen Conbee 2 Stick nutze.
          Ich würde nun einfach den Adapter Löschen und dann erst mal da sehen.....wenn es nicht besser wird.....Stick rauswerfen bzw. Mal nach der Firmware sehen ob die Up to date ist.
          Wenn das nicht hilft selektieren wie weit die Geräte auseinander sind wg. Empfangsproblemen etc.
          Das mit dem Port würde ich eben als Indiz sehen das es am Adapter liegt.
          • arteckA Offline
            arteckA Offline
            arteck
            @lustig29 sagte in Fehler Zigbee Stick:
            Version 1.0.4 i
            installiere bitte die Version 1.1.1 von GIT..
            L LichtAnL 2 Antworten Letzte Antwort
            • arteckA arteck
              Version 1.0.4 i
              lustig29
              @arteck hast du Mal den Link für mich da?
              • L lustig29
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @lustig29
                https://github.com/ioBroker/ioBroker.zigbee
                Hinweis:
                Link Text
                • GlasfaserG Glasfaser
                  @lustig29
                  Hinweis:
                  Link Text
                  lustig29
                  @Glasfaser super, danke. Irgendwie hab ich das Gefühl, er wird nicht richtig installiert. Unter dem Adaptern wird mir angezeigt, dass die Version 1.1 installiert. Bei den Instanzen taucht allerdings nichts auf
                  GlasfaserG Meister MopperM 2 Antworten Letzte Antwort
                  • L lustig29
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Glasfaser
                    @lustig29
                    Du hast Ihn doch zuvor als Version 1.04 gehabt (dein Log ) , hast du Ihn zuvor gelöscht !?
                    Du solltest doch nur ein Update machen .
                    • L lustig29
                      Meister MopperM Online
                      Meister Mopper
                      schrieb am zuletzt editiert von Meister Mopper
                      @lustig29 Du hast über github den Adapter installiert. Jetzt musst Du noch eine Instanz des Adapters installieren.
                      Proxmox und HA ...
                      • L Offline
                        lustig29
                        Adapter läuft jetzt wieder. Nun kommt folgender Fehler im Log:
                        1. No converter available for 'lumi.sensor_motion' with key 'occupancy'
                          Andre R.
                          Hat schon jemand ne Lösung hab das geiche Problem mit 2 BWM.
                          • arteckA arteck
                            Version 1.0.4 i
                            LichtAnL Offline
                            LichtAnL Offline
                            LichtAn
                            @arteck
                            Hab seit gestern auch 2 neue Bewegungsmelder und bekomme auch diese Meldung.
                            (14535) No converter available for 'RTCGQ11LM' with key 'occupancy'
                            Hab den CC2538 + CC259 Stick von dimaiv
                            Adapter ist der aktuelle 1.2.1
                            Hab die Teile jetzt schon mal gelöscht und neu gepairt. Hat aber nix gebracht. Was mir aufgefallen ist das der BW ewig um pairen braucht. Bin ich seit der der Version mit dem herdsman Converter gar nicht mehr gewohnt. Sonst geht Pairen immer innerhalb von Sekunden.
                            • LichtAnL LichtAn
                              @arteck
                              arteckA Offline
                              arteckA Offline
                              arteck
                              @LichtAn sagte in Fehler Zigbee Stick:
                              na einfach so kommt die meldung nicht
