  4. VIS Binding übernimmt Status nicht
    2.8k
    4.8k
    4.1k
vis
9 Beiträge 4 Kommentatoren 397 Aufrufe 4 Beobachtet
  • K Offline
    Kuddel
    schrieb am zuletzt editiert von Kuddel
    ich habe mir ein kleines JavaScript geschrieben, um alle meine Sonoff / Tasmota Aktoren in meiner VIS darzustellen.
    Leider funktioniert die Darstellung des Powerstates nicht.
    Als Beispiel nehme ich das Gerät "Sonoff-Monitore"
    Eigener DP
    javascript.0.Sonoff-Devices.Device_4.Powerschalter
    mit dem Wert
    sonoff.0.Sonoff-Monitore.POWER
    Zum Vergleich des Power-State vom Sonoff-Gerät
    Die Werte sind identisch.
    Im Widget habe ich den State so verknüpft
    {javascript.0.Sonoff-Devices.Device_4.Powerschalter}
    Widget-Export
    [{"tpl":"tplFancyDarkAnAus","data":{"oid":"{javascript.0.Sonoff-Devices.Device_4.Powerschalter}","g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":">","visibility-val":"3","visibility-groups-action":"hide","valFalse":"false","valTrue":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"name":"Schalter_4","visibility-oid":"javascript.0.Sonoff-Devices.Anzahl"},"style":{"left":"920px","top":"160px","width":"110px","height":"40px"},"widgetSet":"fancyswitch"}]
    Obwohl die Werte meiner Meinung nach alle korrekt sind, bleibt der Power-Status in der VIS ausgeschaltet.
    Kann jemand helfen ?
    sigi234S C 3 Antworten Letzte Antwort
    • K Kuddel
      Eigener DP
      mit dem Wert
      Widget-Export
      sigi234S Online
      sigi234S Online
      sigi234
      @Kuddel
      Warum mit Klammer? Lass die mal weg. Willst du nur den State oder auch schalten?
      Immer Daten sichern!
      K 1 Antwort Letzte Antwort
      • K Kuddel
        Eigener DP
        mit dem Wert
        Widget-Export
        Chrunchy
        @Kuddel Wird die Tabelle im Script zusammengesetzt und anschl. in der Vis abgebildet?
        Gruß Chrunchy
        • sigi234S sigi234
          @Kuddel
          Kuddel
          @sigi234 ohne klammern geht das schalten und die anzeige nicht.
          wenn ich per VIS den Aktor anschalte, ist die Darstellung auch korrekt.
          Nur wenn Blockly den Aktor schaltet, bekommt das die VIS nicht mit
          • C Chrunchy
            Kuddel
            @Chrunchy das ist keine Tabelle im eigentlichen Sinne.
            Das sind alles einzelne DPs:
            C 1 Antwort Letzte Antwort
            • K Kuddel
              Chrunchy
              @Kuddel Hatte ein Ähnliches Problem hier...
              So wie ich OliverIO verstanden habe, erfolgt die Interpretation/Auswertung des Bindings nur bei Load der Vis. Keine Änderung der States ohne Reload.
              Gruß Chrunchy
              • C Chrunchy
                Kuddel
                @Chrunchy auch beum Neuladen der VIS ändert sich der Status nicht, obwohl das Gerät eingeschaltet ist
                • K Kuddel
                  Eigener DP
                  mit dem Wert
                  Widget-Export
                  sigi234S Online
                  sigi234S Online
                  sigi234
                  @Kuddel sagte in VIS Binding übernimmt Status nicht:
                  Da kann dir sicher @liv-in-sky was dazu sagen.
                  • sigi234S sigi234
                    liv-in-skyL Offline
                    liv-in-skyL Offline
                    liv-in-sky
                    @sigi234
                    ich kenne dieses script nicht - ich habe ja ein eigenes sonoff script, welches ein html file erzeugt - damit dies up-to-date bleibt, wird das script automatisch aufgerufen, wenn sich einer der power datenpunkte ändert - dadurch wird die tabelle neu geschrieben und zeigt die richtigen werte an
                    ohne binding funktioniert das widget - für ein und ausschalten eines powerstates
