  4. Test Adapter deConz v2.0.x
    6.4k
deconzconbeephoscon
196 Beiträge 38 Kommentatoren 45.0k Aufrufe 38 Beobachtet
  • S0NICS S0NIC
    Moin, bei mir wird die 2.0 nicht grün...
    2020-06-14 23:01:36.053 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 17312
    2020-06-14 23:01:37.574 - info: deconz.0 (17312) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 23:01:37.645 - info: deconz.0 (17312) deConz Version: 2.5.75; API version: 1.16.0
    2020-06-14 23:01:37.806 - info: deconz.0 (17312) Code 404: Ressource not found get devices: []
    2020-06-14 23:01:41.994 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-06-14 23:01:41.999 - error: deconz.0 (17312) unhandled promise rejection: Cannot read property 'toString' of null
    2020-06-14 23:01:42.010 - error: deconz.0 (17312) TypeError: Cannot read property 'toString' of null
    at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    at runMicrotasks ()
    at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:01:42.014 - info: deconz.0 (17312) cleaned everything up...
    2020-06-14 23:01:42.099 - info: deconz.0 (17312) terminating
    2020-06-14 23:01:42.101 - info: deconz.0 (17312) Terminated (NO_ERROR): Without reason
    2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'toString' of null
    2020-06-14 23:01:42.636 - error: host.ioBroker Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    2020-06-14 23:01:42.637 - error: host.ioBroker Caught by controller[1]: at runMicrotasks ()
    2020-06-14 23:01:42.637 - error: host.ioBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:01:42.637 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-06-14 23:01:42.637 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
    2020-06-14 23:02:12.660 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 17662
    2020-06-14 23:02:14.393 - info: deconz.0 (17662) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 23:02:14.468 - info: deconz.0 (17662) deConz Version: 2.5.75; API version: 1.16.0
    2020-06-14 23:02:14.589 - info: deconz.0 (17662) Code 404: Ressource not found get devices: []
    2020-06-14 23:02:15.183 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-06-14 23:02:15.183 - error: deconz.0 (17662) unhandled promise rejection: Cannot read property 'toString' of null
    2020-06-14 23:02:15.189 - error: deconz.0 (17662) TypeError: Cannot read property 'toString' of null
    at runMicrotasks ()
    2020-06-14 23:02:15.190 - info: deconz.0 (17662) cleaned everything up...
    2020-06-14 23:02:15.222 - info: deconz.0 (17662) terminating
    2020-06-14 23:02:15.223 - info: deconz.0 (17662) Terminated (NO_ERROR): Without reason
    2020-06-14 23:02:15.738 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: TypeError: Cannot read property 'toString' of null
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at runMicrotasks ()
    2020-06-14 23:02:15.739 - error: host.ioBroker Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:02:15.739 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-06-14 23:02:15.739 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
    2020-06-14 23:02:45.761 - info: host.ioBroker instance system.adapter.deconz.0 started with pid 18024
    2020-06-14 23:02:47.211 - info: deconz.0 (18024) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.deconz, node: v12.18.0, js-controller: 3.1.5
    2020-06-14 23:02:47.279 - info: deconz.0 (18024) deConz Version: 2.5.75; API version: 1.16.0
    2020-06-14 23:02:47.406 - info: deconz.0 (18024) Code 404: Ressource not found get devices: []
    2020-06-14 23:02:47.976 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2020-06-14 23:02:47.976 - error: deconz.0 (18024) unhandled promise rejection: Cannot read property 'toString' of null
    2020-06-14 23:02:47.979 - error: deconz.0 (18024) TypeError: Cannot read property 'toString' of null
    at runMicrotasks ()
    2020-06-14 23:02:47.980 - info: deconz.0 (18024) cleaned everything up...
    2020-06-14 23:02:48.030 - info: deconz.0 (18024) terminating
    2020-06-14 23:02:48.031 - info: deconz.0 (18024) Terminated (NO_ERROR): Without reason
    2020-06-14 23:02:48.546 - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: TypeError: Cannot read property 'toString' of null
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:1401:68)
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at runMicrotasks ()
    2020-06-14 23:02:48.547 - error: host.ioBroker Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
    2020-06-14 23:02:48.547 - info: host.ioBroker instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
    2020-06-14 23:02:48.547 - info: host.ioBroker Restart adapter system.adapter.deconz.0 because enabled
    Jey CeeJ Online
    Jey CeeJ Online
    Jey Cee
    @S0NIC kannst du mal mit der 1.3.9 ein log erstellen. Bitte das Log Level der Instanz auf debug stellen und dann Log Herunterladen und hier posten.
    Scheint als Gebe es hier Ausreißer bei den MAC Addressen zu geben. Aber um das weiter zu Untersuchen brauche ich eben das Log.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      Nicht Installieren das ist noch irgendwo ein großer Bug, den ich auf dem Entwicklersystem nicht hatte.
      So die V2 ist jetzt im Hauptzweig und läuft bei mir auf dem Produktiv System.
      Installiert werden kann sie momentan nur über Github, Link im ersten Beitrag angepasst.
      S0NICS 1 Antwort Letzte Antwort
      • K Offline
        Kugelkopf
        Hallo @Jey-Cee!
        Aktuell bekomme ich in ioBroker ein Update von v 1.3.9 auf 1.3.10 angeboten. Jedoch scheint es mir so, als wenn dann ein Update auf Version 2.0.1 vollzogen wird. Ist das korrekt? Weil unter diesen Umständen denken sicherlich viele, dass sie weiterhin mit dem alten ID System arbeiten können und noch nicht auf das neue MAC System updaten. Wenn sie dann Updaten, stehen sie auf einmal vor einem nicht mehr funktionierenden System..
        Evtl. Wäre es sehr wichtig, wenn du im Changelog auch nochmal für alle die nicht deinen Beiträgen im Forum folgen, erwähnst, dass es sich um Breaking Changes handelt.
        Viele Grüße, und vielen Dank für diesen tollen Adapter! =)
        • K Kugelkopf
          Hallo @Jey-Cee!
          Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          @Kugelkopf leider verstehe ich deinen Gedanken gang nicht. Hast du die 1.3.10 installiert und Probleme?
          Die 1.3.10 ist auf npm und kommt über latest, die 2.0.2 gibt es nur von Github.
          1.3.10 gibt es nur weil in deConz .78 eine Änderung drin ist die größere Probleme verursacht.
          K 1 Antwort Letzte Antwort
          • Jey CeeJ Jey Cee
            Kugelkopf
            @Jey-Cee ok! Wie gesagt, es hat den Eindruck, weil wenn man auf die changelog Infos geht, bekommt man direkt die 2.0 angezeigt und keine Infos zu 1.3.10 angezeigt. Deshalb verwirrt es!
            D9D2166E-37D6-4946-BF7B-BCDCDA458BBB.png 88CC3E67-3A33-427C-9A3B-A6302308566F.png
            Das sollte kein Angriff sein.
            • K Kugelkopf
              Jey CeeJ Online
              Jey CeeJ Online
              Jey Cee
              @Kugelkopf ah das hatte ich nicht bedacht, das Changelog wird von Github geladen und dort ist schon das von der Version 2 hinterlegt.
              • Jey CeeJ Jey Cee
                S0NICS Offline
                S0NICS Offline
                S0NIC
                schrieb am zuletzt editiert von S0NIC
                @Jey-Cee said in Test Adapter deConz v2.0.x:
                @Jey-Cee Habe es trotzdem installiert und läuft super. Behalte die Version bei, da die MAC Adressen vieles für mich vereinfachen, gerade bei Änderungen. DANKE für die bereits geleistete und auch für die noch kommende Arbeit! :-)
                • Jey CeeJ Online
                  Jey CeeJ Online
                  Jey Cee
                  @all gibt es Wünsche für die v2, außer einer Grafischen Darstellung für das Netzwerk?
                  M 2 Antworten Letzte Antwort
                  • Jey CeeJ Jey Cee
                    Markus84
                    @Jey-Cee Also wenn ich mir etwas wünschen dürfte, wäre es eine Backupmöglichkeit (am besten natürlich noch automatisiert) des Sticks, damit man sich nicht immer umständlich in Phoscon einloggen muss, um ein Backup zu machen. Falls dann wirklich mal der Stick defekt gehen sollte, könnte man einfach einen neuen Stick kaufen, backup einspielen und alles wäre wie vorher...
                    • Jey CeeJ Jey Cee
                      Markus84
                      @Jey-Cee Jetzt fällt mir noch etwas ein, was ich mir aber nur extrem schwer umsetzbar vorstelle: Firmwareupdates der devices. Ich habe meine Tradfri Lampen mal über die GUI geupdatet (musste dafür den Conbee an einen PC umstecken). Aber ich weiß nicht, ob sich der Aufwand hierfür lohnen würde. Aber du hast ja nach Wünschen gefragt ;-)
                        Pittini
                        So, ich hab auch wieder mal etwas rumgetestet. War gestern bei Ikea und hab mir paar Lampen und nen Fyrtur Rollo geholt. Alles eingebunden direkt über Phoscon. Hat problemlos geklappt, hab dort auch direkt alles umbenannt.
                        Geräte wurden vom Adapter (V2.0.3) alle angelegt, allerdings nicht alle umbennugen "mitgenommen". Beim Rollo werden 2 Geräte angelegt, einmal der Rollo als Licht und dann nochmal als Sensor. Der Rollo hat sich umbenannt, den Sensor mußte ich mit Hand ändern. Der beiliegende Schalter wurde auch nicht umbenannt.
                        Insgesamt gibt es wieder gefühlte tausend Datenpunkte, wobei nur einige wenige Relevanz/Funktion haben. Ich finde das etwas verstörend, ebenso wie die seltsamen Bennungen. Beispiel der Rollo:
                        "Window Covering Device" war der ursprünglich autom. vergebene Name. Jetzt dacht ich mir so, ok, alles was so benannt wurde hat ne Funktion, alles was undefined heißt hat keine. Leider war das ein Trugschluß, das ganze ist gemischt "on","lift" und "level" haben durchaus Funktion, z.B. "action" oder "trasitiontime" aber nicht. Und ganz allgemein fehlt mir ein "stop" button um den fahrenden Rollo iwo mit 2tem Schalterclick stoppen zu können (Hab das jetzt über Positionsermittlung und anfahren bestimmter Pos gemacht, aber elegant is anders).
                          Pittini
                          Nachtrag:
                          Nachdem die neuen Ikea Devices drin sind krieg ich nun zum 3ten mal folgenden Fehlerblock. Offenbar wird der Adapter dabei neugestartet und es werden Datenpunkte getriggert. Führt z.B. dazu dass bei Adapterneustart mein Rollo hochfährt.
                          deconz.0	2020-07-17 18:25:37.921	info	(19702) deConz Version: 2.5.77; API version: 1.16.0
                          deconz.0	2020-07-17 18:25:37.835	info	(19702) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0, js-controller: 3.1.4
                          host.Iobroker	2020-07-17 18:25:35.689	info	instance system.adapter.deconz.0 started with pid 19702
                          host.Iobroker	2020-07-17 18:25:05.672	info	Restart adapter system.adapter.deconz.0 because enabled
                          host.Iobroker	2020-07-17 18:25:05.672	info	instance system.adapter.deconz.0 terminated with code 0 (NO_ERROR)
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[3]: at process._tickCallback (internal/process/next_tick.js:68:7)
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[3]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46)
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[3]: TypeError: Cannot read property 'name' of undefined
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[3]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[2]: at process._tickCallback (internal/process/next_tick.js:68:7)
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[2]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46)
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[2]: TypeError: Cannot read property 'name' of undefined
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
                          host.Iobroker	2020-07-17 18:25:05.672	error	Caught by controller[1]: at process._tickCallback (internal/process/next_tick.js:68:7)
                          host.Iobroker	2020-07-17 18:25:05.671	error	Caught by controller[1]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46)
                          host.Iobroker	2020-07-17 18:25:05.671	error	Caught by controller[1]: TypeError: Cannot read property 'name' of undefined
                          host.Iobroker	2020-07-17 18:25:05.671	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
                          deconz.0	2020-07-17 18:25:05.146	info	(1982) Terminated (NO_ERROR): Without reason
                          deconz.0	2020-07-17 18:25:05.145	info	(1982) terminating
                          deconz.0	2020-07-17 18:25:05.138	error	(1982) TypeError: Cannot read property 'name' of undefined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46) at process._tickCallback (internal/process/next
                          deconz.0	2020-07-17 18:25:05.138	error	(1982) unhandled promise rejection: Cannot read property 'name' of undefined
                          deconz.0	2020-07-17 18:25:05.137	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          deconz.0	2020-07-17 18:25:05.132	error	(1982) TypeError: Cannot read property 'name' of undefined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46) at process._tickCallback (internal/process/next
                          deconz.0	2020-07-17 18:25:05.132	error	(1982) unhandled promise rejection: Cannot read property 'name' of undefined
                          deconz.0	2020-07-17 18:25:05.131	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          deconz.0	2020-07-17 18:25:05.120	info	(1982) cleaned everything up...
                          deconz.0	2020-07-17 18:25:05.118	error	(1982) TypeError: Cannot read property 'name' of undefined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46) at process._tickCallback (internal/process/next
                          deconz.0	2020-07-17 18:25:05.113	error	(1982) unhandled promise rejection: Cannot read property 'name' of undefined
                          deconz.0	2020-07-17 18:25:05.113	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          • P Pittini
                            Nachtrag:
                            Jey CeeJ Online
                            Jey CeeJ Online
                            Jey Cee
                            @Pittini kannst du bitte mal das Log Level für die Adapter Instanz auf Debug stellen und dann nochmal das Log zeigen wenn so ein Absturz passiert.
                            Erklärt vermutlich auch warum der Name nicht übernommen wurde.
                            @Pittini sagte in Test Adapter deConz v2.0.x:
                            Die werden nur angelegt wenn die API das so ausgibt, dann haben sie auch eine Funktion.
                            Der Adapter setzt nur um was er bekommt, es ist nicht vorgesehen eine eigene Definition der Geräte zu Pflegen, das macht deConz ja schon. In manchen Fällen leider nicht so gut.
                            @Markus84 sagte in Test Adapter deConz v2.0.x:
                            Backupmöglichkeit
                            Denke das sollte kein Problem sein, muss nur schauen wie ich an die zip Datei komme und wo die hin soll. Nach Möglichkeit kommt das mit in den Backitup Adapter.
                            Leider das gleiche Thema wie Netzwerkanzeige.
                            Was geht ist Update von deConz selbst (nur Raspberry Pi) und Firmware des Conbee Sticks.
                            M simatecS 2 Antworten Letzte Antwort
                            • Jey CeeJ Jey Cee
                              Backupmöglichkeit
                              Markus84
                              Backitup Adapter wäre natürlich super!
                                Pittini
                                @Jey-Cee sagte in Test Adapter deConz v2.0.x:
                                So, hier ist der Fehler mit debug Log. Er tritt reproduzierbar auf, wenn ich etwas in der Phoscon App umbenenne. Hab grad eben den Temp/Hum Sensor "Th1frei" umbenannt zu "TH1 frei" und zack:
                                deconz.0	2020-07-18 12:46:01.118	debug	(7963) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-18T10:46:01.116","presence":true},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                deconz.0	2020-07-18 12:46:01.114	debug	(7963) Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-07-18T10:46:01.112","lightlevel":18130,"lux":65},"t":"event","uniqueid":"00:
                                deconz.0	2020-07-18 12:45:23.619	debug	(7963) Subscribed to updates...
                                deconz.0	2020-07-18 12:45:23.615	debug	(7963) Websocket connection closed
                                deconz.0	2020-07-18 12:45:16.800	debug	(7963) Code 200: Request succeded get group attributes 65520: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"
                                deconz.0	2020-07-18 12:45:16.795	debug	(7963) reachable: true
                                deconz.0	2020-07-18 12:45:16.794	debug	(7963) on: false
                                deconz.0	2020-07-18 12:45:16.793	debug	(7963) ct: 370
                                deconz.0	2020-07-18 12:45:16.792	debug	(7963) colormode: ct
                                deconz.0	2020-07-18 12:45:16.791	debug	(7963) bri: 254
                                deconz.0	2020-07-18 12:45:16.787	debug	(7963) reachable: true
                                deconz.0	2020-07-18 12:45:16.786	debug	(7963) on: false
                                deconz.0	2020-07-18 12:45:16.786	debug	(7963) ct: 370
                                deconz.0	2020-07-18 12:45:16.786	debug	(7963) colormode: ct
                                deconz.0	2020-07-18 12:45:16.785	debug	(7963) bri: 254
                                deconz.0	2020-07-18 12:45:16.766	debug	(7963) Websocket message: {"e":"changed","id":"65520","r":"groups","state":{"all_on":false,"any_on":false},"t":"event"}
                                deconz.0	2020-07-18 12:45:16.763	debug	(7963) Event has state-tag
                                deconz.0	2020-07-18 12:45:16.763	debug	(7963) Websocket message: {"e":"changed","id":"7","r":"lights","state":{"bri":254,"colormode":"ct","ct":370,"on":false,"reachable":true},"t":"event","uniqueid":"68:0a:e2:ff:fe:0c:a6:71-01"}
                                deconz.0	2020-07-18 12:45:16.762	debug	(7963) Code 200: Request succeded set light state 7: [{"success":{"/lights/7/state/on":false}}]
                                deconz.0	2020-07-18 12:45:16.750	debug	(7963) Event has state-tag
                                deconz.0	2020-07-18 12:45:16.745	debug	(7963) Websocket message: {"e":"changed","id":"6","r":"lights","state":{"bri":254,"colormode":"ct","ct":370,"on":false,"reachable":true},"t":"event","uniqueid":"ec:1b:bd:ff:fe:32:de:48-01"}
                                deconz.0	2020-07-18 12:45:16.740	debug	(7963) Code 200: Request succeded set light state 6: [{"success":{"/lights/6/state/on":false}}]
                                deconz.0	2020-07-18 12:45:16.689	debug	(7963) dp: on; id:Lights.680ae2fffe0ca671 tmp: deconz,0,Lights,680ae2fffe0ca671
                                deconz.0	2020-07-18 12:45:16.687	debug	(7963) dp: on; id:Lights.ec1bbdfffe32de48 tmp: deconz,0,Lights,ec1bbdfffe32de48
                                deconz.0	2020-07-18 12:45:16.488	debug	(7963) Code 200: Request succeded set light state 5: [{"success":{"/lights/5/state/lift":0}}]
                                deconz.0	2020-07-18 12:45:16.473	debug	(7963) dp: level; id:Lights.680ae2fffe8b8564 tmp: deconz,0,Lights,680ae2fffe8b8564
                                deconz.0	2020-07-18 12:45:15.764	debug	(7963) Code 200: Request succeded get group attributes 2: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["12"],"
                                deconz.0	2020-07-18 12:45:15.758	debug	(7963) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag
                                deconz.0	2020-07-18 12:45:15.613	debug	(7963) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":"
                                deconz.0	2020-07-18 12:45:15.611	debug	(7963) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"70226f7a49206a7145b9dbfe5657cd8a","manufacturername":"Phil
                                deconz.0	2020-07-18 12:45:15.570	debug	(7963) Code 200: Request succeded get all lights: {"1":{"ctmax":65535,"ctmin":0,"etag":"602b49254dcb8571ac5772a4dd0af07f","hascolor":true,"lastseen":"2020-07-15T16:19:40.675","manufacturername":"IKEA
                                deconz.0	2020-07-18 12:45:15.553	debug	(7963) Subscribed to updates...
                                deconz.0	2020-07-18 12:45:15.533	info	(7963) deConz Version: 2.5.77; API version: 1.16.0
                                deconz.0	2020-07-18 12:45:15.532	debug	(7963) Code 200: Request succeded get config: {"UTC":"2020-07-18T10:45:15","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05B369","datastoreversion":"60","device
                                deconz.0	2020-07-18 12:45:15.463	info	(7963) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0, js-controller: 3.1.4
                                deconz.0	2020-07-18 12:45:15.368	debug	(7963) Plugin sentry Initialize Plugin (enabled=true)
                                deconz.0	2020-07-18 12:44:42.970	info	(31624) Terminated (NO_ERROR): Without reason
                                deconz.0	2020-07-18 12:44:42.969	debug	(31624) Plugin sentry destroyed
                                deconz.0	2020-07-18 12:44:42.968	info	(31624) terminating
                                deconz.0	2020-07-18 12:44:42.907	error	(31624) TypeError: Cannot read property 'name' of undefined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46) at process._tickCallback (internal/process/nex
                                deconz.0	2020-07-18 12:44:42.907	error	(31624) unhandled promise rejection: Cannot read property 'name' of undefined
                                deconz.0	2020-07-18 12:44:42.906	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                deconz.0	2020-07-18 12:44:42.902	error	(31624) TypeError: Cannot read property 'name' of undefined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46) at process._tickCallback (internal/process/nex
                                deconz.0	2020-07-18 12:44:42.902	error	(31624) unhandled promise rejection: Cannot read property 'name' of undefined
                                deconz.0	2020-07-18 12:44:42.901	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                deconz.0	2020-07-18 12:44:42.897	debug	(31624) Websocket connection closed
                                deconz.0	2020-07-18 12:44:42.889	info	(31624) cleaned everything up...
                                deconz.0	2020-07-18 12:44:42.888	error	(31624) TypeError: Cannot read property 'name' of undefined at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.deconz/main.js:772:46) at process._tickCallback (internal/process/nex
                                deconz.0	2020-07-18 12:44:42.882	error	(31624) unhandled promise rejection: Cannot read property 'name' of undefined
                                deconz.0	2020-07-18 12:44:42.882	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                deconz.0	2020-07-18 12:44:42.850	debug	(31624) Websocket message: {"e":"changed","id":"9","name":"TH1 frei","r":"sensors","t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0403"}
                                deconz.0	2020-07-18 12:44:42.849	debug	(31624) Websocket message: {"e":"changed","id":"8","name":"TH1 frei","r":"sensors","t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0405"}
                                deconz.0	2020-07-18 12:44:42.846	debug	(31624) Websocket message: {"e":"changed","id":"7","name":"TH1 frei","r":"sensors","t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0402"}
                                deconz.0	2020-07-18 12:44:41.033	debug	(31624) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-18T10:44:41.031","presence":true},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                deconz.0	2020-07-18 12:44:41.023	debug	(31624) Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-07-18T10:44:41.021","lightlevel":18389,"lux":69},"t":"event","uniqueid":"00
                                deconz.0	2020-07-18 12:44:36.945	debug	(31624) Subscribed to updates...
                                deconz.0	2020-07-18 12:44:36.930	debug	(31624) Websocket connection closed
                                deconz.0	2020-07-18 12:43:36.929	debug	(31624) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2020-07-18T10:43:36.927","pressure":978},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0403"}
                                deconz.0	2020-07-18 12:43:36.923	debug	(31624) Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"humidity":4709,"lastupdated":"2020-07-18T10:43:36.922"},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0405"}
                                deconz.0	2020-07-18 12:43:36.918	debug	(31624) Websocket message: {"e":"changed","id":"7","r":"sensors","state":{"lastupdated":"2020-07-18T10:43:36.916","temperature":2786},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0402"}
                                deconz.0	2020-07-18 12:43:03.437	debug	(31624) Websocket message: {"config":{"alert":"none","battery":87,"group":"2","on":true,"reachable":true},"e":"changed","id":"12","r":"sensors","t":"event","uniqueid":"68:0a:e2:ff:fe:3f:9d:85-01-1000"
                                deconz.0	2020-07-18 12:42:06.311	debug	(31624) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-18T10:42:06.310","presence":false},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                deconz.0	2020-07-18 12:42:05.975	debug	(31624) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2020-07-18T10:42:05.972","pressure":978},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0403"}
                                deconz.0	2020-07-18 12:42:05.972	debug	(31624) Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"humidity":4735,"lastupdated":"2020-07-18T10:42:05.970"},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0405"}
                                deconz.0	2020-07-18 12:42:05.964	debug	(31624) Websocket message: {"e":"changed","id":"7","r":"sensors","state":{"lastupdated":"2020-07-18T10:42:05.962","temperature":2735},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0402"}
                                deconz.0	2020-07-18 12:41:55.184	debug	(31624) Subscribed to updates...
                                deconz.0	2020-07-18 12:41:55.179	debug	(31624) Websocket connection closed
                                deconz.0	2020-07-18 12:40:55.179	debug	(31624) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2020-07-18T10:40:55.177","pressure":978},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0403"}
                                deconz.0	2020-07-18 12:40:55.175	debug	(31624) Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"humidity":4726,"lastupdated":"2020-07-18T10:40:55.173"},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0405"}
                                deconz.0	2020-07-18 12:40:55.166	debug	(31624) Websocket message: {"e":"changed","id":"7","r":"sensors","state":{"lastupdated":"2020-07-18T10:40:55.164","temperature":2684},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0402"}
                                deconz.0	2020-07-18 12:40:36.207	debug	(31624) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-18T10:40:36.203","presence":true},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                deconz.0	2020-07-18 12:40:36.194	debug	(31624) Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-07-18T10:40:36.192","lightlevel":18921,"lux":78},"t":"event","uniqueid":"00
                                deconz.0	2020-07-18 12:40:17.512	debug	(31624) Websocket message: {"e":"changed","id":"6","r":"sensors","state":{"lastupdated":"2020-07-18T10:40:17.510","presence":false},"t":"event","uniqueid":"00:15:8d:00:03:1b:29:eb-01-0406"}
                                deconz.0	2020-07-18 12:40:01.412	debug	(31624) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-18T10:40:01.410","presence":false},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                deconz.0	2020-07-18 12:39:04.068	debug	(31624) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2020-07-18T10:39:04.066","pressure":978},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0403"}
                                deconz.0	2020-07-18 12:39:04.063	debug	(31624) Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"humidity":4628,"lastupdated":"2020-07-18T10:39:04.061"},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0405"}
                                deconz.0	2020-07-18 12:39:04.047	debug	(31624) Websocket message: {"e":"changed","id":"7","r":"sensors","state":{"lastupdated":"2020-07-18T10:39:04.045","temperature":2623},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0402"}
                                deconz.0	2020-07-18 12:38:47.493	debug	(31624) Websocket message: {"e":"changed","id":"6","r":"sensors","state":{"lastupdated":"2020-07-18T10:38:47.491","presence":true},"t":"event","uniqueid":"00:15:8d:00:03:1b:29:eb-01-0406"}
                                deconz.0	2020-07-18 12:38:47.488	debug	(31624) Websocket message: {"e":"changed","id":"5","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-07-18T10:38:47.486","lightlevel":14624,"lux":29},"t":"event","uniqueid":"00:
                                deconz.0	2020-07-18 12:38:31.407	debug	(31624) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-18T10:38:31.405","presence":true},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                deconz.0	2020-07-18 12:38:31.402	debug	(31624) Websocket message: {"e":"changed","id":"10","r":"sensors","state":{"dark":false,"daylight":false,"lastupdated":"2020-07-18T10:38:31.400","lightlevel":18693,"lux":74},"t":"event","uniqueid":"00
                                deconz.0	2020-07-18 12:37:43.621	debug	(31624) Subscribed to updates...
                                deconz.0	2020-07-18 12:37:43.615	debug	(31624) Websocket connection closed
                                deconz.0	2020-07-18 12:37:26.941	debug	(31624) reachable: true
                                deconz.0	2020-07-18 12:37:26.941	debug	(31624) on: true
                                deconz.0	2020-07-18 12:37:26.940	debug	(31624) ct: 370
                                deconz.0	2020-07-18 12:37:26.939	debug	(31624) colormode: ct
                                deconz.0	2020-07-18 12:37:26.938	debug	(31624) bri: 254
                                deconz.0	2020-07-18 12:37:26.924	debug	(31624) reachable: true
                                deconz.0	2020-07-18 12:37:26.923	debug	(31624) on: true
                                deconz.0	2020-07-18 12:37:26.923	debug	(31624) ct: 370
                                deconz.0	2020-07-18 12:37:26.922	debug	(31624) colormode: ct
                                deconz.0	2020-07-18 12:37:26.921	debug	(31624) bri: 254
                                deconz.0	2020-07-18 12:37:26.912	debug	(31624) Code 200: Request succeded get group attributes 65520: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],
                                deconz.0	2020-07-18 12:37:26.892	debug	(31624) Event has state-tag
                                deconz.0	2020-07-18 12:37:26.891	debug	(31624) Websocket message: {"e":"changed","id":"7","r":"lights","state":{"bri":254,"colormode":"ct","ct":370,"on":true,"reachable":true},"t":"event","uniqueid":"68:0a:e2:ff:fe:0c:a6:71-01"}
                                deconz.0	2020-07-18 12:37:26.890	debug	(31624) Code 200: Request succeded set light state 7: [{"success":{"/lights/7/state/on":true}}]
                                deconz.0	2020-07-18 12:37:26.887	debug	(31624) Websocket message: {"e":"changed","id":"65520","r":"groups","state":{"all_on":false,"any_on":true},"t":"event"}
                                deconz.0	2020-07-18 12:37:26.884	debug	(31624) Event has state-tag
                                deconz.0	2020-07-18 12:37:26.884	debug	(31624) Websocket message: {"e":"changed","id":"6","r":"lights","state":{"bri":254,"colormode":"ct","ct":370,"on":true,"reachable":true},"t":"event","uniqueid":"ec:1b:bd:ff:fe:32:de:48-01"}
                                deconz.0	2020-07-18 12:37:26.876	debug	(31624) Code 200: Request succeded set light state 6: [{"success":{"/lights/6/state/on":true}}]
                                deconz.0	2020-07-18 12:37:26.823	debug	(31624) dp: on; id:Lights.680ae2fffe0ca671 tmp: deconz,0,Lights,680ae2fffe0ca671
                                deconz.0	2020-07-18 12:37:26.819	debug	(31624) dp: on; id:Lights.ec1bbdfffe32de48 tmp: deconz,0,Lights,ec1bbdfffe32de48
                                deconz.0	2020-07-18 12:37:26.589	debug	(31624) Code 200: Request succeded set light state 5: [{"success":{"/lights/5/state/lift":0}}]
                                deconz.0	2020-07-18 12:37:26.525	debug	(31624) dp: level; id:Lights.680ae2fffe8b8564 tmp: deconz,0,Lights,680ae2fffe8b8564
                                deconz.0	2020-07-18 12:37:25.728	debug	(31624) Code 200: Request succeded get group attributes 2: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["12"],
                                deconz.0	2020-07-18 12:37:25.718	debug	(31624) Code 200: Request succeded get group attributes 1: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
                                deconz.0	2020-07-18 12:37:25.687	debug	(31624) Code 200: Request succeded get all groups: {"1":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":[],"etag":
                                deconz.0	2020-07-18 12:37:25.685	debug	(31624) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"70226f7a49206a7145b9dbfe5657cd8a","manufacturername":"Phi
                                deconz.0	2020-07-18 12:37:25.646	debug	(31624) Code 200: Request succeded get all lights: {"1":{"ctmax":65535,"ctmin":0,"etag":"602b49254dcb8571ac5772a4dd0af07f","hascolor":true,"lastseen":"2020-07-15T16:19:40.675","manufacturername":"IKEA
                                deconz.0	2020-07-18 12:37:25.623	debug	(31624) Subscribed to updates...
                                deconz.0	2020-07-18 12:37:25.601	info	(31624) deConz Version: 2.5.77; API version: 1.16.0
                                deconz.0	2020-07-18 12:37:25.600	debug	(31624) Code 200: Request succeded get config: {"UTC":"2020-07-18T10:37:25","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05B369","datastoreversion":"60","devic
                                deconz.0	2020-07-18 12:37:25.131	info	(31624) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0, js-controller: 3.1.4
                                deconz.0	2020-07-18 12:37:25.024	debug	(31624) Plugin sentry Initialize Plugin (enabled=true)
                                deconz.0	2020-07-18 12:37:20.175	info	(19702) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                deconz.0	2020-07-18 12:37:20.174	info	(19702) terminating
                                deconz.0	2020-07-18 12:37:20.174	info	(19702) cleaned everything up...
                                deconz.0	2020-07-18 12:37:20.168	info	(19702) Got terminate signal TERMINATE_YOURSELF
                                  Pittini
                                  Nach einigen weiteren Test, wollte ich mal der Sche mit dem automatischen einschalten gewisser Lampen bzw. dem Rollo beim Adapterstart auf den Grund gehen. Soviel vorweg, es liegt nicht an den Lampen/Rollo, sondern offenbar an den Schaltern. Ich nutze ein Skript welches auf die relevanten Datenpunkte der Schalter triggert und dann entsprechend zugeordnete Lampen/Lampengruppen schaltet. Deaktivier ich das Skript is Ruhe.
                                  Wenn ich das Log richtig gelesen hab, passiert offenbar folgendes bei Adapterstart, es werden alle Dps auf true gesetzt und dann, nach wieder auf false. Is soweit dann klar warum mein Skript auslöst.
                                  Ich hab mein Skript mal auf einen Schalter limitiert und lass den seine Trigger loggen. Hier ist der Problembereich denk ich:
                                  deconz.0	2020-07-21 15:43:24.272	debug	(7804) Websocket connection closed
                                  javascript.0	2020-07-21 15:43:15.157	info	(1500) script.js.common.ButtonsAuswerten: dp.state.val von Button deconz.0.Sensors.680ae2fffe3f9d85.buttonevent.1.release_press ist=false, dp.oldState.val=true
                                  deconz.0	2020-07-21 15:43:15.148	debug	(7804) Code 200: Request succeded set light state 5: [{"success":{"/lights/5/state/lift":0}}]
                                  javascript.0	2020-07-21 15:43:15.037	info	(1500) script.js.common.ButtonsAuswerten: Reaching Meldung, msg= Rollo öffnet
                                  javascript.0	2020-07-21 15:43:15.037	info	(1500) script.js.common.ButtonsAuswerten: dp.state.val von Button deconz.0.Sensors.680ae2fffe3f9d85.buttonevent.1.release_press ist=true, dp.oldState.val=false
                                  deconz.0	2020-07-21 15:43:15.042	debug	(7804) dp: level; id:Lights.680ae2fffe8b8564 tmp: deconz,0,Lights,680ae2fffe8b8564
                                  deconz.0	2020-07-21 15:43:14.186	debug	(7804) Code 200: Request succeded get group attributes 7: {"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
                                  deconz.0	2020-07-21 15:43:14.175	debug	(7804) Code 200: Request succeded get group attributes 6: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["17"],
                                  deconz.0	2020-07-21 15:43:14.167	debug	(7804) Code 200: Request succeded get group attributes 5: {"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"scene":"1","xy":[0,0]},"devicemembership":[],"etag
                                  deconz.0	2020-07-21 15:43:14.162	debug	(7804) Code 200: Request succeded get group attributes 4: {"action":{"bri":128,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":128,"scene":null,"xy":[0,0]},"devicemembership":[],"eta
                                  deconz.0	2020-07-21 15:43:14.155	debug	(7804) Code 200: Request succeded get group attributes 2: {"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["12"],
                                  deconz.0	2020-07-21 15:43:13.955	debug	(7804) Code 200: Request succeded get all groups: {"2":{"action":{"bri":127,"colormode":"hs","ct":0,"effect":"none","hue":0,"on":false,"sat":127,"scene":null,"xy":[0,0]},"devicemembership":["12"],"et
                                  deconz.0	2020-07-21 15:43:13.953	debug	(7804) Code 200: Request succeded get all sensors: {"1":{"config":{"configured":true,"on":true,"sunriseoffset":30,"sunsetoffset":-30},"etag":"f909d6861204dac4184f3f1797949f12","manufacturername":"Phi
                                  deconz.0	2020-07-21 15:43:13.842	debug	(7804) Code 200: Request succeded get all lights: {"1":{"ctmax":65535,"ctmin":0,"etag":"7ba919a62a37921fcdf89cc205803887","hascolor":true,"lastseen":"2020-07-21T13:42:10.095","manufacturername":"IKEA
                                  deconz.0	2020-07-21 15:43:13.816	debug	(7804) Subscribed to updates...
                                  Und falls interessant, hier der komplette Start des Adapters im debug Mode:
                                  deconz.0	2020-07-21 15:43:59.005	debug	(7804) Websocket message: {"e":"changed","id":"9","r":"sensors","state":{"lastupdated":"2020-07-21T13:43:59.003","pressure":979},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0403"}
                                  deconz.0	2020-07-21 15:43:58.995	debug	(7804) Websocket message: {"e":"changed","id":"8","r":"sensors","state":{"humidity":3156,"lastupdated":"2020-07-21T13:43:58.993"},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0405"}
                                  deconz.0	2020-07-21 15:43:58.987	debug	(7804) Websocket message: {"e":"changed","id":"7","r":"sensors","state":{"lastupdated":"2020-07-21T13:43:58.984","temperature":3109},"t":"event","uniqueid":"00:15:8d:00:03:03:fe:b5-01-0402"}
                                  javascript.0	2020-07-21 15:43:53.714	info	(1500) script.js.common.BatterieUeberwachung: Reaching MakeTable
                                  javascript.0	2020-07-21 15:43:53.714	info	(1500) script.js.common.BatterieUeberwachung: Reaching CheckDeadBatt()
                                  deconz.0	2020-07-21 15:43:36.813	debug	(7804) Websocket message: {"e":"changed","id":"11","r":"sensors","state":{"lastupdated":"2020-07-21T13:43:36.810","presence":false},"t":"event","uniqueid":"00:15:8d:00:03:6b:63:75-01-0406"}
                                  deconz.0	2020-07-21 15:43:24.439	debug	(7804) Subscribed to updates...
                                  deconz.0	2020-07-21 15:43:13.794	info	(7804) deConz Version: 2.5.77; API version: 1.16.0
                                  deconz.0	2020-07-21 15:43:13.793	debug	(7804) Code 200: Request succeded get config: {"UTC":"2020-07-21T13:43:13","apiversion":"1.16.0","backup":{"errorcode":0,"status":"idle"},"bridgeid":"00212EFFFF05B369","datastoreversion":"60","devic
                                  deconz.0	2020-07-21 15:43:13.721	info	(7804) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v10.19.0, js-controller: 3.1.4
                                  deconz.0	2020-07-21 15:43:13.624	debug	(7804) Plugin sentry Initialize Plugin (enabled=true)
                                  deconz.0	2020-07-21 15:43:12.065	debug	(7804) statesDB connected
                                  deconz.0	2020-07-21 15:43:12.064	debug	(7804) States connected to redis: 127.0.0.1:9000
                                  deconz.0	2020-07-21 15:43:12.048	debug	(7804) States create System PubSub Client
                                  deconz.0	2020-07-21 15:43:12.047	debug	(7804) States create User PubSub Client
                                  deconz.0	2020-07-21 15:43:12.039	debug	(7804) Redis States: Use Redis connection: 127.0.0.1:9000
                                  deconz.0	2020-07-21 15:43:12.038	debug	(7804) objectDB connected
                                  deconz.0	2020-07-21 15:43:12.034	debug	(7804) Objects connected to redis: 127.0.0.1:9001
                                  deconz.0	2020-07-21 15:43:12.020	debug	(7804) Objects client initialize lua scripts
                                  deconz.0	2020-07-21 15:43:12.020	debug	(7804) Objects create User PubSub Client
                                  deconz.0	2020-07-21 15:43:12.019	debug	(7804) Objects create System PubSub Client
                                  deconz.0	2020-07-21 15:43:12.016	debug	(7804) Objects client ready ... initialize now
                                  deconz.0	2020-07-21 15:43:11.994	debug	(7804) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  host.Iobroker	2020-07-21 15:43:11.285	info	instance system.adapter.deconz.0 started with pid 7804
                                  c_hoch_bC 1 Antwort Letzte Antwort
                                    Pittini
                                    Thema Gruppen. Ich hab da welche die ich nicht (mehr) habe (Test), eine welche einfach so angelegt wurde und eine doppelt:
                                    "Eigentlich" gibts aber nur die drei:
                                    Das Problem: Ich kann die im Adapteradmin nicht löschen, klicke ich aufn Mülleimer z.B. bei "Test", wird der Screen refresht und alles ist...wie vorher.
                                    D Jey CeeJ 3 Antworten Letzte Antwort
                                    • P Pittini
                                      duffbeer2000
                                      @Pittini geh mal im Phoscon auf Hilfe, dort dann auf den Link "Alte WebApp Version Wireless Light Control öffnen (2016)" Es öffnet sich dann ein neuer Tab mit der alten Oberfläche, wenn du da oben auf Groups klickst werden dir alle Gruppen (auch die in Phoscon ausgeblendeten) angezeigt und du kannst dort auch die Gruppenzugehörigkeit anpassen oder die Gruppe löschen.
                                      "TRADFRI open/close remote" und "TRADFRI remote control" sind Schalter/Fernbedienungen welche automatisch eine Gruppe anlegen in welchen die dem Schalter zugehörigen Devices gespeichert werden. Diese kannst du auch nicht löschen.
                                      • P Pittini
                                        Jey CeeJ Online
                                        Jey CeeJ Online
                                        Jey Cee
                                        @Pittini Objekte in ioBroker musst du von Hand löschen.
                                        P 1 Antwort Letzte Antwort
                                        • Jey CeeJ Jey Cee
                                          Pittini
                                          schrieb am zuletzt editiert von Pittini
                                          Ok danke, löschen direkt in der Objektliste hat geklappt. Es stellt sich mir dann aber die Frage wozu hab ich diesen Screen und warum gibts dort Mülleimer zum löschen?
                                          Und... kannst Du mit den anderen Fehlern/Logs was anfangen?
