  5. Javascript 4.6.14 kann nicht installiert werden
    2.8k
    4.8k
    4.1k
13 Beiträge 3 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • GarganoG Offline
    GarganoG Offline
    Gargano
    ich habe versucht Javascript zu updaten, bricht mit Fehler 243 ab. Hat jemand eine Idee ?
    Hier die Ausgabe :
    $ ./iobroker upgrade javascript
    Update javascript from @4.5.1 to @4.6.14
    NPM version: 6.9.0
    npm install iobroker.javascript@4.6.14 --loglevel error --prefix "/opt/iobroker" (System call)
    npm
    ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-typesnpm ERR! code EACCESnpm ERR! errno -13npm ERR! syscall access
    npm ERR! Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types'npm ERR! { [Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types']npm ERR! stack:npm ERR! 'Error: EACCES: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types'',npm
    ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'access',npm ERR! path:npm ERR! '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types' }npm ERR! npm ERR! The operation was rejected by your operating system.npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2020-05-22T14_01_27_852Z-debug.log
    ERROR: host.raspberrypi Cannot install iobroker.javascript@4.6.14: 243
    • GarganoG Gargano
      Hier die Ausgabe :
      NPM version: 6.9.0
      npm
      @Gargano
      lsb_release -a
      nodejs -v && node -v && npm -v
      which nodejs && which node && which npm
        @Gargano
        lsb_release -a
        GarganoG Offline
        GarganoG Offline
        Gargano
        @Thomas-Braun sagte in Javascript 4.6.14 kann nicht installiert werden:
        Nodejs 10.16.0
        node 10.16.0
        npm 6.9.0
        • GarganoG Gargano
          Nodejs 10.16.0
          node 10.16.0
          npm 6.9.0
          @Gargano Die Ausgaben der Befehle im Volltext, inkl. Eingabezeile.
          Und bitte in </> code tags .
          • GarganoG Offline
            GarganoG Offline
            Gargano
            pi@raspberrypi:~ $ nodejs -v
            v10.16.0
            pi@raspberrypi:~ $ node -v
            v10.16.0
            pi@raspberrypi:~ $ npm -v
            6.9.0
            • GarganoG Gargano
              v10.16.0
              v10.16.0
              6.9.0
              @Gargano
              apt policy nodejs
                Steffl
                Es ist sicher sinnvoll die Versionen zu checken aber in Log steht doch eindeutig: permission denied, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types
                Was bringt denn ein?
                code_text
                ```ls -l /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types
                • S Steffl
                  code_text
                  @Steffl Habe ich gesehen. Aber ich arbeite gerne mit einer soliden Basis bevor ich an die anderen Symptome gehe.
                    Steffl
                    @Thomas-Braun das war ja auch nicht als Kritik gemeint. Kann man so machen, aber vieles steht ja auch schon gleich im Log - z.B. NPM version: 6.9.0. Oder - und die Frage kommt bestimmt noch host.raspberrypi. Er scheint also auf nem Raspi unterwegs zu sein. Und wenn wir lange genug warten, kommt bestimmt jemand mit der defekten SD-Karte ums Eck. ;-)
                    • S Steffl
                      @Steffl Alles gesehen...
                      • GarganoG Offline
                        GarganoG Offline
                        Gargano
                        apt policy nodejs
                        Also hier die fehlenden Infos :
                        lsb_release -a
                        No LSB modules are available.
                        Distributor ID: Raspbian
                        Description:    Raspbian GNU/Linux 10 (buster)
                        Release:        10
                        Codename:       buster
                         apt policy nodejs
                        nodejs:
                          Installed: 10.16.0-1nodesource1
                          Candidate: 10.16.0-1nodesource1
                          Version table:
                         *** 10.16.0-1nodesource1 500
                                500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                                100 /var/lib/dpkg/status
                             10.15.2~dfsg-2+rpi1 500
                        pi@raspberrypi:~ $ ls -l /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/babel-types
                        total 116
                        -rw-r--r--+ 1 pi pi 104220 Apr 24  2019 index.d.ts
                        -rw-r--r--+ 1 pi pi   1183 Apr 24  2019 LICENSE
                        -rw-r--r--+ 1 pi pi   1986 May  1 14:13 package.json
                        -rw-r--r--+ 1 pi pi    668 Apr 24  2019 README.md
                        SD Karte ist neu .
                        • GarganoG Gargano
                          apt policy nodejs
                          lsb_release -a
                          Release:        10
                          Codename:       buster
                           apt policy nodejs
                          nodejs:
                            Version table:
                          total 116
                          SD Karte ist neu .
                          @Gargano
                          iobroker fix
                          • GarganoG Offline
                            GarganoG Offline
                            Gargano
                            iobroker fix habe ich laufen lassen:
                            evtl. wars dies :
                                Checking ioBroker user and directory permissions (2/3)
                            Created /etc/sudoers.d/iobroker
                            Javascript lies sich dann ohne Fehler upgraden.
                            Danke.
