  4. host.iobroker Fehlermeldung
host.iobroker
19 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • K Offline
    karstent
    Von jetzt auf gleich bekomme ich folgende fehlermeldung im Log. Davor habe ich eigentlich nur versucht den Synology Adapter in betrieb zu nehmen.
    host.iobroker	2020-05-18 11:44:34.748	error	instance system.adapter.history.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at bootstrap_node.js:625:3
    host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
    host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
    host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
    host.iobroker	2020-05-18 11:44:34.746	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
    host.iobroker	2020-05-18 11:44:34.746	error	Caught by controller[0]: at Module.load (module.js:566:32)
    host.iobroker	2020-05-18 11:44:34.746	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
    host.iobroker	2020-05-18 11:44:34.745	error	Caught by controller[0]: at Module._compile (module.js:617:28)
    host.iobroker	2020-05-18 11:44:34.745	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
    host.iobroker	2020-05-18 11:44:34.745	error	Caught by controller[0]: at createScript (vm.js:80:10)
    host.iobroker	2020-05-18 11:44:34.744	error	Caught by controller[0]: SyntaxError: Unexpected token {
    host.iobroker	2020-05-18 11:44:34.744	error	Caught by controller[0]: ^
    host.iobroker	2020-05-18 11:44:34.743	error	Caught by controller[0]: } catch {
    host.iobroker	2020-05-18 11:44:34.742	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.history/main.js:1020
    Was ist den da schief gelaufen?
    Typ: js-controller
    Titel: JS controller
    OS: linux
    Verfügbar: 3.1.4
    Installiert: 2.2.8
    Ereignisse: ↦31 / ↦13
    • K Offline
      karstent
      schrieb am zuletzt editiert von karstent
      zu früh gefreut.
      • K karstent
        Typ: js-controller
        OS: linux
        Verfügbar: 3.1.4
        Installiert: 2.2.8
        @karstent
        nodejs -v && node -v && npm -v
        which nodejs && which node && which npm
        • K Offline
          karstent
          ich schau nach.
          • K Offline
            karstent
            node -v v8.16.0
            npm -v 6.4.1
            nodejs -v v8.16.0
            Nach dem ich versucht habe ein Update der ioBroker Installation zu machen kommt folgende Fehlermeldung:
            iobroker upgrade self
            Update js-controller from @2.2.8 to @3.1.4
            NPM version: 6.4.1
            npm install iobroker.js-controller@3.1.4 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
            /opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliPlugin.js:253
                                } catch {
                at Module.require (module.js:597:17)
                at require (internal/module.js:11:18)
                at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/index.js:19:17)
            npm ERR! code ELIFECYCLE
            npm ERR! errno 1
            npm ERR! iobroker.js-controller@3.1.4 install: `node iobroker.js setup first`
            npm ERR! Exit status 1
            npm ERR!
            npm ERR! Failed at the iobroker.js-controller@3.1.4 install script.
            npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            • K karstent
              node -v v8.16.0
              npm -v 6.4.1
              nodejs -v v8.16.0
              NPM version: 6.4.1
                                  } catch {
              npm ERR! errno 1
              npm ERR!
              @karstent node zu alt. node12 installieren.
              • K Offline
                karstent
                node -v v10.20.1
                nodejs -v v10.20.1
                npm -v6.14.4
                schlägt fehl mein Update:
                internal/modules/cjs/loader.js:638
                    throw err;
                Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                    at startup (internal/bootstrap/node.js:283:19)
                    at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                weiß nich weiter :-(
                • K karstent
                  node -v v10.20.1
                  nodejs -v v10.20.1
                  npm -v6.14.4
                      throw err;
                  @karstent node 12 installieren...
                  Wo hängst du denn da nun mit node genau?
                  apt policy nodejs
                  K 1 Antwort Letzte Antwort
                    apt policy nodejs
                    karstent
                    @Thomas-Braun ```
                    nodejs:
                    Installiert: 10.20.1-1nodesource1
                    Installationskandidat: 10.20.1-1nodesource1
                    Versionstabelle:
                    *** 10.20.1-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
                    100 /var/lib/dpkg/status
                    4.8.2~dfsg-1 500
                    500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                    • K karstent
                      @Thomas-Braun ```
                      nodejs:
                      Versionstabelle:
                      4.8.2~dfsg-1 500
                      @karstent
                      Die anderen Ausgaben waren geheim?
                      • K Offline
                        karstent
                        mehr kommt da nicht
                        iobroker:~$ which nodejs && which node && which npm
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        ktrepte@iobroker:~$ apt policy nodejs
                        nodejs:
                          Versionstabelle:
                             4.8.2~dfsg-1 500
                        • K karstent
                          mehr kommt da nicht
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          nodejs:
                            Versionstabelle:
                               4.8.2~dfsg-1 500
                          @karstent
                          iobroker update
                          iobroker upgrade
                          • K Offline
                            karstent
                            das ist alles:
                            ktrepte@iobroker:~$ iobroker update
                                throw err;
                            ktrepte@iobroker:~$ iobroker upgrade
                                throw err;
                            • K karstent
                              das ist alles:
                                  throw err;
                                  throw err;
                              @karstent
                              cd /opt/iobroker
                              sudo -H -u iobroker npm install iobroker.js-controller
                              • K Offline
                                karstent
                                wieder so eine Ellenlange Ausgabe:
                                ktrepte@iobroker:~$ cd /opt/iobroker
                                ktrepte@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                > node lib/preinstallCheck.js
                                NPM version: 6.14.4
                                > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                                110 file(s) successfully synchronized with ioBroker storage.
                                Please DO NOT copy files manually into ioBroker storage directories!
                                The following notifications happened during sync:
                                - Added 94 Files in Directory "iqontrol.meta"
                                - Added 16 Files in Directory "javascript.admin"
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                + iobroker.js-controller@2.2.10
                                added 59 packages from 83 contributors and audited 1498 packages in 48.098s
                                7 packages are looking for funding
                                  run `npm fund` for details
                                found 76 vulnerabilities (56 low, 20 high)
                                  run `npm audit fix` to fix them, or `npm audit` for details
                                ktrepte@iobroker:/opt/iobroker$ npm audit fix
                                npm ERR! code ELOCKVERIFY
                                npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
                                npm ERR!     Invalid: lock file's iobroker.admin@3.6.0 does not satisfy iobroker.admin@^4.1.1
                                npm ERR!     Missing: iobroker.alexa2@^3.1.2
                                npm ERR!     Missing: iobroker.backitup@^1.5.7
                                npm ERR!     Missing: iobroker.cloud@^2.6.2
                                npm ERR!     Missing: iobroker.devices@^0.3.6
                                npm ERR!     Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@^2.3.3
                                npm ERR!     Missing: iobroker.flot@^1.9.2
                                npm ERR!     Missing: iobroker.fritzdect@^0.3.2
                                npm ERR!     Missing: iobroker.history@^1.9.6
                                npm ERR!     Missing: iobroker.hm-rega@^2.6.7
                                npm ERR!     Missing: iobroker.hm-rpc@^1.14.2
                                npm ERR!     Missing: iobroker.ical@^1.7.0
                                npm ERR!     Missing: iobroker.influxdb@^1.8.6
                                npm ERR!     Invalid: lock file's iobroker.info@1.3.7 does not satisfy iobroker.info@^1.7.2
                                npm ERR!     Missing: iobroker.iot@^1.2.0
                                npm ERR!     Missing: iobroker.iqontrol@https://github.com/sbormann/ioBroker.iqontrol/tarball/master
                                npm ERR!     Missing: iobroker.javascript@^4.6.4
                                npm ERR!     Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@^2.2.10
                                npm ERR!     Missing: iobroker.meross@^1.3.13
                                npm ERR!     Missing: iobroker.mihome@^1.3.0
                                npm ERR!     Missing: iobroker.mobile@^0.5.0
                                npm ERR!     Missing: iobroker.mqtt@^2.1.3
                                npm ERR!     Missing: iobroker.mqtt-client@^1.3.1
                                npm ERR!     Missing: iobroker.node-red@^1.16.5
                                npm ERR!     Missing: iobroker.nut@^1.1.3
                                npm ERR!     Missing: iobroker.parser@^1.0.7
                                npm ERR!     Missing: iobroker.proxmox@^1.0.2
                                npm ERR!     Missing: iobroker.rickshaw@^1.0.0
                                npm ERR!     Missing: iobroker.scenes@^1.1.0
                                npm ERR!     Missing: iobroker.simple-api@^2.4.1
                                npm ERR!     Missing: iobroker.snmp@^0.5.0
                                npm ERR!     Missing: iobroker.socketio@^3.0.7
                                npm ERR!     Missing: iobroker.sonoff@^2.3.3
                                npm ERR!     Missing: iobroker.sql@^1.9.5
                                npm ERR!     Missing: iobroker.squeezebox@^1.0.0
                                npm ERR!     Missing: iobroker.statistics@^0.2.2
                                npm ERR!     Missing: iobroker.synology@^0.1.10
                                npm ERR!     Missing: iobroker.systeminfo@^0.3.1
                                npm ERR!     Missing: iobroker.terminal@^0.1.2
                                npm ERR!     Missing: iobroker.tr-064@^0.4.18
                                npm ERR!     Missing: iobroker.tr-064-community@https://github.com/iobroker-community-adapters/ioBroker.tr-064-community/tarball/master
                                npm ERR!     Missing: iobroker.upnp@^1.0.14
                                npm ERR!     Missing: iobroker.viessmannapi@^1.3.2
                                npm ERR!     Missing: iobroker.virtualpowermeter@^1.0.1
                                npm ERR!     Missing: iobroker.vis@^1.2.3
                                npm ERR!     Missing: iobroker.vis-hqwidgets@^1.1.2
                                npm ERR!     Missing: iobroker.vis-jqui-mfd@^1.0.12
                                npm ERR!     Missing: iobroker.web@^3.0.5
                                npm ERR!     /home/ktrepte/.npm/_logs/2020-05-18T20_42_42_679Z-debug.log
                                • K Offline
                                  karstent
                                  Nach dem ich die ioBroker Instanz wieder starten konnte ergibt sich folgendes im log:
                                  host.iobroker	2020-05-18 22:49:03.812	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                  host.iobroker	2020-05-18 22:49:03.812	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                  host.iobroker	2020-05-18 22:49:03.811	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                  host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                  host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                                  host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                  host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                  host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                  host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                  host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                  host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                                  host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                  host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                                  host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                                  host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: was compiled against a different Node.js version using
                                  host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                                  host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: ^
                                  host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                                  host.iobroker	2020-05-18 22:49:03.801	error	Caught by controller[0]: internal/modules/cjs/loader.js:807
                                  • K karstent
                                    @karstent
                                    iobroker rebuild
                                      @karstent
                                      iobroker rebuild
                                      karstent
                                      Vielen Dank für deine Hilfe. Nach dem ich aus Verzweiflung noch einmal die befehle
                                      cd /opt/iobroker
                                      npm cache clean
                                      sudo iobroker stop
                                      sudo iobroker update
                                      sudo iobroker upgrade self
                                      sudo iobroker start
                                      in die Console getippt habe hat sich, oh Wunder, die Instanz wieder selber zum leben erweckt. Im Moment habe ich keinerlei Fehlermeldungen mehr und der Controller ist jetzt dort wo er sein soll:
                                      Typ: js-controller
                                      Verfügbar: 3.1.4
                                      Installiert: 3.1.4
                                      Also, vielen Dank noch mal :-)
                                        Stejin
                                        sry fürs raus kramen, aber ich hatte das gleiche Problem, mir hat das update auf node12 geholfen!
                                        sudo apt-get install curl software-properties-common
                                        curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                                        apt-get install nodejs
