  4. host.iobroker Fehlermeldung
host.iobroker
19 Beiträge 3 Kommentatoren 3.2k Aufrufe 3 Beobachtet
    karstent
    ich schau nach.
      karstent
      node -v v8.16.0
      npm -v 6.4.1
      nodejs -v v8.16.0
      Nach dem ich versucht habe ein Update der ioBroker Installation zu machen kommt folgende Fehlermeldung:
      iobroker upgrade self
      Update js-controller from @2.2.8 to @3.1.4
      NPM version: 6.4.1
      npm install iobroker.js-controller@3.1.4 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
      /opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliPlugin.js:253
                          } catch {
      SyntaxError: Unexpected token {
          at createScript (vm.js:80:10)
          at Object.runInThisContext (vm.js:139:10)
          at Module._compile (module.js:617:28)
          at Object.Module._extensions..js (module.js:664:10)
          at Module.load (module.js:566:32)
          at tryModuleLoad (module.js:506:12)
          at Function.Module._load (module.js:498:3)
          at Module.require (module.js:597:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/index.js:19:17)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@3.1.4 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@3.1.4 install script.
      • K karstent
        node -v v8.16.0
        npm -v 6.4.1
        nodejs -v v8.16.0
        NPM version: 6.4.1
                            } catch {
        npm ERR! errno 1
        npm ERR!
        @karstent node zu alt. node12 installieren.
          karstent
          node -v v10.20.1
          nodejs -v v10.20.1
          npm -v6.14.4
          schlägt fehl mein Update:
          internal/modules/cjs/loader.js:638
              throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
              at Function.Module._load (internal/modules/cjs/loader.js:562:25)
              at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
              at startup (internal/bootstrap/node.js:283:19)
              at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          weiß nich weiter :-(
          • K karstent
            node -v v10.20.1
            nodejs -v v10.20.1
            npm -v6.14.4
                throw err;
            @karstent node 12 installieren...
            Wo hängst du denn da nun mit node genau?
            nodejs -v && node -v && npm -v
            which nodejs && which node && which npm
            apt policy nodejs
              apt policy nodejs
              karstent
              @Thomas-Braun ```
              nodejs:
              Installiert: 10.20.1-1nodesource1
              Installationskandidat: 10.20.1-1nodesource1
              Versionstabelle:
              *** 10.20.1-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
              4.8.2~dfsg-1 500
              500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
              • K karstent
                @Thomas-Braun ```
                nodejs:
                Versionstabelle:
                4.8.2~dfsg-1 500
                @karstent
                Die anderen Ausgaben waren geheim?
                  karstent
                  mehr kommt da nicht
                  iobroker:~$ which nodejs && which node && which npm
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  ktrepte@iobroker:~$ apt policy nodejs
                  nodejs:
                    Versionstabelle:
                       4.8.2~dfsg-1 500
                  • K karstent
                    mehr kommt da nicht
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    nodejs:
                      Versionstabelle:
                         4.8.2~dfsg-1 500
                    @karstent
                    iobroker update
                    iobroker upgrade
                      karstent
                      das ist alles:
                      ktrepte@iobroker:~$ iobroker update
                          throw err;
                      ktrepte@iobroker:~$ iobroker upgrade
                          throw err;
                      • K karstent
                        das ist alles:
                            throw err;
                            throw err;
                        @karstent
                        cd /opt/iobroker
                        sudo -H -u iobroker npm install iobroker.js-controller
                          karstent
                          wieder so eine Ellenlange Ausgabe:
                          ktrepte@iobroker:~$ cd /opt/iobroker
                          ktrepte@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                          > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                          > node lib/preinstallCheck.js
                          NPM version: 6.14.4
                          > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                          110 file(s) successfully synchronized with ioBroker storage.
                          Please DO NOT copy files manually into ioBroker storage directories!
                          The following notifications happened during sync:
                          - Added 94 Files in Directory "iqontrol.meta"
                          - Added 16 Files in Directory "javascript.admin"
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                          + iobroker.js-controller@2.2.10
                          added 59 packages from 83 contributors and audited 1498 packages in 48.098s
                          7 packages are looking for funding
                            run `npm fund` for details
                          found 76 vulnerabilities (56 low, 20 high)
                            run `npm audit fix` to fix them, or `npm audit` for details
                          ktrepte@iobroker:/opt/iobroker$ npm audit fix
                          npm ERR! code ELOCKVERIFY
                          npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
                          npm ERR!     Invalid: lock file's iobroker.admin@3.6.0 does not satisfy iobroker.admin@^4.1.1
                          npm ERR!     Missing: iobroker.alexa2@^3.1.2
                          npm ERR!     Missing: iobroker.backitup@^1.5.7
                          npm ERR!     Missing: iobroker.cloud@^2.6.2
                          npm ERR!     Missing: iobroker.devices@^0.3.6
                          npm ERR!     Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@^2.3.3
                          npm ERR!     Missing: iobroker.flot@^1.9.2
                          npm ERR!     Missing: iobroker.fritzdect@^0.3.2
                          npm ERR!     Missing: iobroker.history@^1.9.6
                          npm ERR!     Missing: iobroker.hm-rega@^2.6.7
                          npm ERR!     Missing: iobroker.hm-rpc@^1.14.2
                          npm ERR!     Missing: iobroker.ical@^1.7.0
                          npm ERR!     Missing: iobroker.influxdb@^1.8.6
                          npm ERR!     Invalid: lock file's iobroker.info@1.3.7 does not satisfy iobroker.info@^1.7.2
                          npm ERR!     Missing: iobroker.iot@^1.2.0
                          npm ERR!     Missing: iobroker.iqontrol@https://github.com/sbormann/ioBroker.iqontrol/tarball/master
                          npm ERR!     Missing: iobroker.javascript@^4.6.4
                          npm ERR!     Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@^2.2.10
                          npm ERR!     Missing: iobroker.meross@^1.3.13
                          npm ERR!     Missing: iobroker.mihome@^1.3.0
                          npm ERR!     Missing: iobroker.mobile@^0.5.0
                          npm ERR!     Missing: iobroker.mqtt@^2.1.3
                          npm ERR!     Missing: iobroker.mqtt-client@^1.3.1
                          npm ERR!     Missing: iobroker.node-red@^1.16.5
                          npm ERR!     Missing: iobroker.nut@^1.1.3
                          npm ERR!     Missing: iobroker.parser@^1.0.7
                          npm ERR!     Missing: iobroker.proxmox@^1.0.2
                          npm ERR!     Missing: iobroker.rickshaw@^1.0.0
                          npm ERR!     Missing: iobroker.scenes@^1.1.0
                          npm ERR!     Missing: iobroker.simple-api@^2.4.1
                          npm ERR!     Missing: iobroker.snmp@^0.5.0
                          npm ERR!     Missing: iobroker.socketio@^3.0.7
                          npm ERR!     Missing: iobroker.sonoff@^2.3.3
                          npm ERR!     Missing: iobroker.sql@^1.9.5
                          npm ERR!     Missing: iobroker.squeezebox@^1.0.0
                          npm ERR!     Missing: iobroker.statistics@^0.2.2
                          npm ERR!     Missing: iobroker.synology@^0.1.10
                          npm ERR!     Missing: iobroker.systeminfo@^0.3.1
                          npm ERR!     Missing: iobroker.terminal@^0.1.2
                          npm ERR!     Missing: iobroker.tr-064@^0.4.18
                          npm ERR!     Missing: iobroker.tr-064-community@https://github.com/iobroker-community-adapters/ioBroker.tr-064-community/tarball/master
                          npm ERR!     Missing: iobroker.upnp@^1.0.14
                          npm ERR!     Missing: iobroker.viessmannapi@^1.3.2
                          npm ERR!     Missing: iobroker.virtualpowermeter@^1.0.1
                          npm ERR!     Missing: iobroker.vis@^1.2.3
                          npm ERR!     Missing: iobroker.vis-hqwidgets@^1.1.2
                          npm ERR!     Missing: iobroker.vis-jqui-mfd@^1.0.12
                          npm ERR!     Missing: iobroker.web@^3.0.5
                          npm ERR!     /home/ktrepte/.npm/_logs/2020-05-18T20_42_42_679Z-debug.log
                            karstent
                            Nach dem ich die ioBroker Instanz wieder starten konnte ergibt sich folgendes im log:
                            host.iobroker	2020-05-18 22:49:03.812	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.iobroker	2020-05-18 22:49:03.812	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                            host.iobroker	2020-05-18 22:49:03.811	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                            host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                            host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                            host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                            host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                            host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                            host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                            host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                            host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                            host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                            host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                            host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                            host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: was compiled against a different Node.js version using
                            host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                            host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: ^
                            host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                            host.iobroker	2020-05-18 22:49:03.801	error	Caught by controller[0]: internal/modules/cjs/loader.js:807
                            • K karstent
                              @karstent
                              iobroker rebuild
                                @karstent
                                iobroker rebuild
                                karstent
                                Vielen Dank für deine Hilfe. Nach dem ich aus Verzweiflung noch einmal die befehle
                                cd /opt/iobroker
                                npm cache clean
                                sudo iobroker stop
                                sudo iobroker update
                                sudo iobroker upgrade self
                                sudo iobroker start
                                in die Console getippt habe hat sich, oh Wunder, die Instanz wieder selber zum leben erweckt. Im Moment habe ich keinerlei Fehlermeldungen mehr und der Controller ist jetzt dort wo er sein soll:
                                Typ: js-controller
                                Titel: JS controller
                                Verfügbar: 3.1.4
                                Installiert: 3.1.4
                                Also, vielen Dank noch mal :-)
                                  Stejin
                                  sry fürs raus kramen, aber ich hatte das gleiche Problem, mir hat das update auf node12 geholfen!
                                  sudo apt-get install curl software-properties-common
                                  curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                                  apt-get install nodejs
